G-Skill DDR3 1600 (PC3 12800) 4Gb (2x2GB)
meatloafwsnx
I am building a new pc and am shopping around for ram, it seems newegg has this ram for 93 with free shipping, is this good ram for OC'ing? Any alternatives?
J-O_S-H
England, United Kingdom
is it G.SKILL Ripjaws?
If so... YES... they are very good and popular. A lot of people would reccomend them.
Also, being 1600MHz will help you overclock your CPU easier
J-O_S-H
I can't get those links to work...
If you are going for an LGA1156 build... these are very good... they are $125 though but definately worth the extra
Code:
[url]http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279&cm_re=ripjaws-_-20-231-279-_-Product[/url]
They have much better timings as well as still being 1600MHz.
dgb303
5280, USA
Is it me or do those links not work...
Anyways I've got some non-ripjaw G-Skill DDR3 1600 in my setup now and they've been great.
J-O_S-H
Out of the two.. I'd go for the Ripjaws... they look better and have better cooling.
Apart from that I can't really see the difference.
If you can afford it though... the CL7 RIpjaws are awsome.
M
meatloafwsnx
Yeah they look nice, but unfortunately I am under budget, If i could find some memory used it would be better but I have not had much luck.
M
meatloafwsnx
considering im running a 1.8ghz with 2 gigs of ram on a 9800 pro, it wont take much to wow me. :D:D:D
building a new pc, maybe ill save the memory last and hope i run into a better deal
M
meatloafwsnx
Well I have purchased most of it
This is what I have purchased...
COOLER MASTER RC-690
Radeon HD 4890
Phenom 2 x3
Gigabyte MA790GPT-UD3H
Windows 7 Professional.
This is what I still have to get
Seagate Barracuda 7200 500 GB
Antec EarthWatts EA650
Ram
M
meatloafwsnx
Thanks for the help, any alternative suggestions to the HD and Power SUpply I have listed?
mattspalace
I been Dolk'ed Senior
Stuttgart, Germany
I'd buy a Western Digital Caviar Black versus the Seagate HD.
RAM doesn't matter nearly as much as it once did from a timings perspective. It'll make a slight difference, but not noticeable on anything except a few benchmarks.
