crypticjoker
- Dec 15, 2013
hi, this is my first post so thought i would say hello to everyone and thank you ahead of time for helping me out.
i recently upgraded my setup
windows 8.1 pro x64
asus maximus vi hero
intel i7 4770k (currently running stock because i gave up with this issue)
hyper 212 evo
g.skill trident x 16gb(2x8gb) 2133mhz [part# F3-2133C9D-16GTX]
evga geforce 670 ftw
corsair ax850w
originally had my system OC'ed @ 4.3 using 1.190v (i did try bringing voltage up to 1.20 to see if it changed anything and nothing changed with my freezes)
my issue happens everytime i put the ram up to 2133mhz, i've tried oc'ing the cpu and doing this but it seems everytime i use some of my systems resources (i.e video render, ultra gameplay battlefield 4, max settings assassins creed iv) you get the idea... anytime my cpu goes under load it hard freezes where i can't do anything and forced to restart (or if i leave it frozen the system will shut it's self down)
things i've tried
before the new ram i used 8gb(2x4gb) corsair vengeance 1600mhz running the 100% exact settings and my pc had no issues its ever since i've installed the new ram. (i installed this ram again to test if anything has changed with my system and it ran 100% perfect) also since this problem has began i havn't changed ANYTHING on my system setup except the ram.
i've tried using just 1 of the sticks of ram using the same settings and it would still lockup and freeze.
i've ran memtest with no issues, strangely enough i can run prime95 for awhile (however the program crashes after 25 runs)
all of this was using asus XMP profiles (1 and 2) i get the same results. my last resort was a post i found regarding "never use xmp" and i tried my best at basically duplicating all the settings from xmp to set my ram up to 2133mhz which i've never really OC'ed ram before is why i didn't go too crazy with suggestions people were giving because i was blind on what to run. however after setting the manual profile it ran smoother however every game i played or every program i ran would run for about 5mins - 1 hour then the program would crash. this would cause the program to crash twice then on the 3rd run the system would hard freeze.
so i've come to the final conclusion either,
A. my board may be bad
B. i'm doing something wrong (most likely)
C. cpu possibly bad? (have had this cpu for 35 days)
can anyone suggest some ideas on what i can do here? maybe a walk through trying to setup a better OC profile for the ram/cpu to possibly get this running because i have nothing but headaches the past week reading forums, contacting people and i've just about given up on this.
windows 8.1 pro x64
hyper 212 evo
corsair ax850w
things i've tried
