- Jan 10, 2019
Thank you. So the test result is good?
Doesnt seem memory to be my issue. Especially after so many hours of testing.
I dont have any bsdo or crashes etc. Not even one. Temps max on Prime 95 small... max 79* with fans / pumb speed 50-75* for noise purposes.
Not sure about whea though.
I used to be able to check them using day per day columns but somehow i cant find it again (inside windows). My memory getting old...
I use a Thermaltake P5 with custom watercooling... maybe that GPU rise cable isnt function as it should...
I think i got some microstutters (not sure though if my eyes getting old or its real) and i am trying to figure out whats the issue.
Battlefield V.... is it the game? Is it my system.... who knows...
Today i am going to install the GPU without that riser cable and see if it helps.
BTW 1st time trying oc's .... any kind...
