Today I have a memory kit which is in use for about 4 months and I had no time to test it before - G.Skill TridentZ Royal 16GB DDR4-3200 C14.
The main difference between this memory kit and previous TridentZ series is the heatsink design and lighting. Used IC and overclocking potential is similar to what we could already see in previous Trident Z 3200 CL14 kits. On the other hand, I'm glad that G.Skill still uses the same, top series Samsung IC.
Some photos:
Here is a screenshot from Thaiphoon Burner which is showing more details about the memory modules and used IC.
As expected there are no issues at rated speed. XMP profile runs at 3200 14-14-14-34 1.35V.
XMP@ 3200 14-14-14-34 1.35V
In next post will be some benchmark results. I will add some more in next days/weeks as I finally solved issues with my motherboard and it runs at a bit tighter timings now. Anyway, most users can count on settings which are presented in post #2 and I think they are more than enough unless you think about competitive benchmarking where additional tweaking will be required. Not all motherboards can handle the same sub timings or clock at given voltages. Tests were performed on ASUS Maximus XI Gene which is let's say below average so out of the box won't run at 4000+ and Command Rate 1N.
Some photos:
