In today's tests, I will use the latest G.Skill TridentZ Royal 16GB/2x8GB memory kit which is specified to run at DDR4-3600 CL18-22-22-42 and 1.35V. These settings are quite relaxed but as we know, many of cheaper memory kits at loose timings overclock well. I wanted to check if this memory kit has more to offer than only great looking lighting so here we go.
The F4-3600C18D-16GTRS is listed on various motherboard manufacturers QVL as memory based on Micron E-die IC. I was also counting on this IC while my memory kit has Samsung B-die.
Below you can see a screenshot from Thaiphoon Burner:
Some users may notice that the IC is exactly the same as we can find in DDR4-3200 CL14-14-14, 3600 16-16-16 or 4000 17-17-17. However, it only looks like that as in reality, it's not overclocking nearly as well.
I'm usually performing more tests but on this memory kit, I simply couldn't pass DDR4-4000 at any reasonable settings or run it at tight timings at lower frequencies. Now I know why G.Skill used it in a DDR4-3600 CL18-22-22 memory kit.
The memory works well at XMP settings. On both ASRock X570 Extreme4 and Gigabyte X570 I Pro WiFi was no problems with stability at XMP settings. Performance is actually quite good for given settings but I wouldn't expect anything better and in the next post you can see why.
