Ryzen performance is affected much more by memory clock than timings so 3600 even CL18 will be usually faster than 3200 CL14 or anything else. 3600 CL18 can be faster than CL16 if you compare different memory kits.
IF ratio and memory controller ratio can be manually set on most motherboards. If it's not in the main tab then it will be in AMD OC options. At lower memory clocks, up to ~3800, most motherboards will set it automatically at 1:1. When you pass some clock then it will run at 1:2 so have to set it manually.
I wouldn't count on much better results on new AGESA, if we ever get the one that supposed to improve memory OC at 1:1 ratio. Most CPUs seem to be limited anyway. On current AGESA should be still possible to pass 3800 while not all users can even reach that. I just doubt it's a matter of AGESA when IMC is the same as in Ryzen 3000 series and I could make exactly the same max memory clock 1:1 on Ryzen 3900X and 5900X ... with the little difference that on 3900X I could run higher 2x32GB or 4 memory stick kits.
If you have 4x8GB/2x16GB/2x32GB kits then stick with 1:1 ratio but if you have 2x8GB or single rank 2x16GB (only Micron so far) then you may play with a higher memory clock and 1:2 IF ratio but 1800MHz+ memory controller clock. Because of lower latency in Ryzen 5000, these settings give the same or sometimes better results, especially when you can push your RAM to 4800+ CL16/18. It's a matter of various settings and a lot to describe so won't cover it here.
Btw, to run memory at CL13/15/17, you have to disable gear down mode in BIOS.
