G.SKILL warranty support.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
http://www.gskill.com/en/rma
After you fill out the form, it gets looked over and they will send you an email with their specific address of where to send it to (quite typical of the RMA process from others).
EarthDog
Buckeyes!
If you are asking do you send your RMA to the USA if you are in the USA, I believe that answer is Yes. I have never RMA'd something from Gskill, but not sure. Logic would tell me yes though. It is typical to send it to USA from USA for most products.
Fill out the form and find out! :)
ATMINSIDE
You fill out the form that EarthDog linked to, then they tell you what you need to do.
The one G.SKILL RMA that I've ever done was the easiest RMA I've ever done.
