GA-686LX bios help
darkstar
How do I upgrade the bios for my cel 366 with out buying a pen 2 slot 1,
just for that 1 job.
the cel 366 & mobo are compatable and I have the bios patch.
If you have a startup disk just boot to command prompt only then run the bios flash that should have come with the bios upgrade. Check the manual and make sure the jumpers and bios settings are where they should be for bios upgrade.
go to add/remove programs and the tab st the end and create a start up disk, then dump the patch in it and reboot
