I have been running the with the GA-7VAXP m/b. I have the AMD xp2000+ cpu with 512mb DD2700 memory. The fsb switch is set to 133 and I'm not doing any overclocking at this time.
However if I set the bios to optimal performance and/or enable top performance, when I boot into windows xp I get random reboots for no apparent reason.
Not for sure what revision the board is or where to even check.
My guess is cheap memory, but not for sure. I have played around with the bios and am wondering if some (or one) of the advanced memory settings (cntl-F1) might be the culprit. Something called "ram burst" settings of either 8 or 4? When set to 4 it seems to be more stable. Also I've incremented the vcore for memory using the .1 increment and that seems like it may have helped.
I'm wondering if any of you have ran into this type of problem.
My temp's seem to be okay (35c m/b - 46c cpu).
Thanks in advance!
Redbird
Thanks in advance!
Redbird
