GA-K8NSNXP-939? Good or no?
CreePinG_DeatH
Would anyone know if this is a pretty good board or not? Any horror stories about it?
GIGABYTE "GA-K8NSNXP-939" nForce3 Ultra Chipset Motherboard for AMD Socket 939 CPU -RETAIL
Model# GA-K8NSNXP-939
Item # N82E16813128254
Specifications:
Supported CPU: AMD Athlon64 Processors
Chipset: nVIDIA nForce3 Ultra
RAM: 4x DIMM for Dual-Channel DDR400/333/266 Max 4GB
IDE: 2x ATA 133 up to 4 Devices
Slots: 1x AGP 4X/8X(1.5V), 5x PCI
Ports: 2xPS/2,2xCOM,1xLPT,2xLAN,8xUSB2.0(Rear 4),Audio Ports
Onboard Audio: Realtek ALC850 8-Channel Codec
Onboard LAN: Marvell 8001 GbE + ICS 1883 10/100Mbps
Onboard SATA/RAID: 2 from nForce3 Ultra, RAID 0/1; 2 from SiI3512, RAID 0/1
Onboard 1394: T.I. IEEE1394b controller, 3 Ports
Form Factor: ATX
pantner
give me a week or so and i'll let you know ;-)
wat processor r u thinking of getting??? (im getting a 3800...)
CreePinG_DeatH
CreePinG_DeatH
I am not getting this board anymore. I was going to use an AMD fx-53 with it, but decided against using that plaform for right now
CreePinG_DeatH
CreePinG_DeatH
Thanx for the info. I'lll keep my eye on this board as I near my next major upgrade.
kgeorge78
you can always wait for the next thing to come out - People waited for the new intel stuff and it sucks *** - Just get what's the best right now - I love this board with my fx-53 but I am having problems with ram timings.
CreePinG_DeatH
CreePinG_DeatH
I just ordered a nf7-S rev 2 and a mobile 2500. The rest of the stuf that I ordered, speakers, monitor, case etc... will last me the next upgrade anyway
Scorpvenom
Kgeorge, I also have a fx53 and I was having problems with ram timings but found a solution.
I have a twin pack of corsair XMS x-tra low latency modules (rated at 2-2-2-5), and I was only able to get them stable when I raised the ddr voltage by .2v (my ram is recommened to run at 2.7v but is under warranty until 2.9 v). At 2.8v, it is very stable.
kgeorge78
I've done that already - I have 2 gigs corsair twinx5000 - I dont even care about timings - I just want to board to run the ram at 1:1 with 4 dimms installed - For some reason, It always resets to 2x160 - Using 2 dimms, it works fine!
kgeorge78
After tons of problems, I figured this out and must say this is one of the best boards I've ever owned - Too bad my ram sucks
kgeorge78
the board absolutely will not run 1:1 with 4 dimms installed unless its running a command rate of 2t which decreases the bandwidth huge - I sold the 4x512 and bought 2x1024 - working awesome now at 1:1 @13x210
K_King
So you are you satisfied with it? I was thinking about getting that or the ASUS (need onboard gameport along with my Soundcards Gameport). I didnt even see the ABIT not having it. Can you manually turn off sound and gameport in your BIOS seperate from each other?
kgeorge78
not sure about that but overall I love the board (except nowhere in the back of the motherboard for a rear fan)
No big deal = It's been stable since I figured everything out!
I give it a 9/10
DOUG
QUOTE:
I would wait till nforce 4 comes out till you buy a mobo
The next chipset will be a NF 3-350 andf is a long way off. :attn:
