What mouse and KB do you use, also are you using a USB hub or anything similar
What are you using for sound? On board, add in or through graphics?
Alright guys, I've re-installed Windows, things seem to be working OK, and the stuttering is liveable, I guess it's just the nature of some games and I can't do anything about it. I will just leave it at that. I am so grateful to everyone that tried to help me. Cheers!
If anyone comes across a potential solution to this tiny stuttering, you can always private message me. Thanks again guys, I really appreciated every bit of help!
That sounds just like old/slow HDD loading textures or buffering sound at the start of a game, an SSD should not have that issue ?
Out of curiosity what's your sound settings in CP ? I know that Windows defaults to something like 48000hz 24bit, try lowering to 44000hz 16bit. Doubt it will solve it but some cards/drivers have issues with 24bit sound output. Also on the same tabs check if you don't have weird sound effects like surround/treble turned on on top of the sound settings you have in it's default program.
That reminds me of a setting in your nVidia CP - Shader Cache - try turning it off/on and see if there's any difference. Also if you play your games in true fullscreen (not windowed fullscreen/borderless) try changing "Maximum Pre-Rendered Frames" to max (4) and play something, then to min (1) and try again, default is 3, and stick to whatever you like the most. Max forces the GPU to create more frame buffers before displaying which makes the gameplay smoother but creates some input lag, 1 removes input lag but makes gameplay jittery/stuttery. If you play in Windowed-Fullscreen/Borderless stay at default settings.
You tried it on the new hardware or the old ?
