Been searching the net and forums for many hours now, I still need a little help with GAT to max out my memory with my new AI7.
specs:
Abit AI7
2.4b 533cpu @ 3.1ghz vcore1.525 / 172fsb
2x 512mb xms3500 @ 345DDR 1:1
With the above specs im running 2-2-2-5 a-a-a-d-d
I can't enable F1 but normal, turbo, street racer settings work ok.
Can run any set upto aggressive.
Can set Read Delay up 3
Found out that the two last setttings make my system unstable, so I always disable these now
sisoft: 4323 / 4308
What I need to know is, when I run the extra GAT settings I don't gain any extra. I get slighty lower memory bandwidth and a reduction in 3dmark01. Whats going on here?
I can run as high as [email protected]/185fsb -- 450mhzDDR 4:5 / 2-2-2-5 a-a-a-d-d @ 3.0v, sisoft 4626/4611 but there not much point running high voltage for just 100mb/s increase being its a 533fsb prcoessor. At any speed 4:5 roughly only yeilds a 100mb/s gain over 1:1
Can someone help me out with getting the most out of the GAT, cause im sure theres nothing to gain and everything to gain with just auto settings.
specs:
Abit AI7
sisoft: 4323 / 4308
