Ge-F 2 &BE-6 II-Sideband disabling
sheren1
Do I even have this option with this set-up,
If so how do I disable it??
To OC further...
Thanks
Sisandra will tell you and i think every overclocker should have this, you can look in the tips section look for videocard performance tips on front page and in there you will find directions for disabling sideband.
goodluck
