First I'll give you my setup: AMD T-Bird 1.2 ghz, 512 DDR pc2100 ram, ECS KS75A mobo, 2X WD 120 gig 7200 rpm, liteon 24x burner, 52x cd rom, Hercules Gamesurround Fortissimo 2, No Name 32 meg Geforce 2 MX 100/200, running Windows XP Professional with SP1.
No heres the problem, I've been running windows XP professional for a while without any problems, even after I upgraded to Sp1, everything worked fine. I re-formatted and when I installed the new drivers for the geforce, off www.geforce.com (by the way the driver I got was 40.72 winxp WHQL) and re-started my computer, in the spash screen before the mem count where it says geforce and your driver version and stuff, it said 8mg, instead of the usual 32 mg, nothing on my system is overclocked, no video card tweaking or anything. I unistalled the card from windows, unistalled the drivers, pulled the card, and re-installed the drivers. Same problem, I was jsut wondering what has happened to cause this..or is the memory gone. And something to take notice is that on my card there are only 2 memory chunks on the card..I thought that there would be four 8 meg chips, but thats beside the fact. The card is stamped and saying GEforce 32 mx 100/200.
