Geforce 2 GTS OC Question
Mad_Heckler
How do know when I should stop going higher. What programs should I run to mak sure everything is OK.
Thanks
3D Mark is a pretty good program to use for testing. If your system doesn't crash and you don't get artifacts, you could bump it up a bit, and try again. Once you start having problems you drop it down a notch and consider it maxed. (unless of course you wanna get into better cooling or whatever)
You can find 3D Mark on my FTP in my signature.
