- Apr 2, 2002
- Ontario Canada
I am planning on buying a GeForce 4 Ti 4600 i was wondering is it worth the money they charge or do they have a better card
-King Zielke
-King Zielke
The GF4 Ti4600 is FAR, FAR faster than a Ti200, in raw clock speeds even it is about twice as fast on the core and 70% faster on the memory. Factor in that the more efficient core provides about 20% more speed at the same clock speeds when you underclock the Ti4600 and compare to a GF3, and that the anti-aliasing engine of the Ti4600 is far better and gives a large amount more performance (about 50-60% at same clock speeds, about 110-120% over a Ti200 with both at stock), and you can easily see why the card wouldn't be the limiting factor when even on the older GF3 we were starting to see CPU limitations in some games.
GoldenTiger said:3dmark is very CPU-limited. Try something that is more demanding and has a higher resolution or FSAA/anisotropy. UT and Q3 are a few years old... try MOHAA with some FSAA and tell me what you get. May as well do Dungeon Siege, Warcraft III, or Jedi Knight 2 as well, while you're at it. I have all of those games (well, Warcraft III is a copy played on bnetd, but I don't consider it warez since the game isn't even out yet) and the difference is quite noticable in framerate.
