geforce 4 mx 4400 vs geforce 256
peppy
This may sound like a dumb question but there is no dumb questions, he he. I have a geforce 256 ddr @162 clock and 366 mem, what are the clock speeds of the geforce 4 mx 4400, is it worth 85$, im think in it is cause i really want tv out. Will it preform better than my original (great ol' geforce 1) ? any help is cool. thanks every one.
Geforce4 MX 440 is quite a bit better than a Geforce1....though for that same money a Radeon7500 would be better....
really i thought radeon 7500 sucked big arse, i found out the specs
Specifications
Controller: NVIDIA GeForce4 MX 440
Bus Type AGP
Memory 64MB DDR
Core Clock 270MHz
Memory Clock 400MHz effective
DDR memory
RAMDAC Dual 350MHz RAMDACs
API Support Direct-X®, Open GL ICD®
for Windows
Connectors Dual VGA
1.1 Billion texel fill rate
34 Million vertices/sec setup
6.4GB/second memory bandwidth
Features at a Glance
TV-out
AGP 4x compatible with fast writes
256-bit 3D and 2D graphics accelerator
NVIDIA nView™ display technologies
Lightspeed Memory Architecture™ II
Dual Integrated 350MHz DACs
Accuview Antialiasing™
High Definition Video Processing Engine
MX memory Crossbar
I was thinking sabout a GF4MX440 but I'm glad I didn't get it b/c the Gf3 Ti200 is a very nice card and mine overclocks very well
the MX440 doesnt' take full advantage of directX 8 and is also lacking other things that will make performance similar to your geforce256. Yes you will get better FPS but thats about it
ill think about a ti 200, but it says it has a high definition video prcessing engine, hmmmmm, i have a 55in digital wide screen tv, so does that mean if i get a capture card and use the tv out ill be watchin hdtv on my hdtv tv?
i have a mx400 now that runs at 218/218 comfortably, would i notice a differnce with the 7500 radeon?
