- Jan 6, 2002
- Connecticut
Well, my great joy was quickly dampened tonight after my GF4 came in. I installed it, and it kept having problems like this:
It also was spouting out direct x errors sometimes, and in 3dmark on the high detail dragothic demo would just drop to the desktop with no error or black screen with a moving mouse cursor but no response to alt-tab, etc. It would drop out of games randomly with no message often, too. I originally tried the 28.32 drivers on a near-fresh OS install, porting in from a GF3 Ti200 that worked perfectly. After a few games, the problems began. I tried reinstalling Windows now with no luck using the 27.20 drivers, too. Same problems occur
! I'm wondering if the card is broken... the case is a well-ventilated Antec 1040b with a load temp of 48c CPU and about 31c case, so I know it's not a heat problem. In the Nature scene in 3dmark 2k1 SE, the leaves on the trees vanish and then pop back in, then vanish again many times during the demo. The other demos are exhibiting similar things with stuff popping in and out, and a couple it just crashes instantly on. One of the times I launched 3dmark it gave a DX8 error and the error.log file claims that the error was "no dx8 compatible card installed". I've thought of a few things that could be wrong:
1) I'm cursed.
2) Card's heatsink isn't mounted properly. It looks fine though and appears to be making fine contact, so I don't think this is it.
3) Card is broken.
4) I'm cursed.
Does anyone have any suggestions as to how to fix this? Bear in mind I have tried:
Reinstalling OS with a complete format of the drive
Two driver sets seperately on clean installs
Direct X 8.1 as well as DX8.1 repair
Cleaning AGP slot and card with isopropyl alcohol (contacts)
Swearing at it repeatedly
Many games in direct3d, no OGL ones yet
3dmark crashes at the exact same spot ALWAYS
Tried all games I own, every single one of them exhibits these symptoms
I will update with anything else I try... PLEASE give suggestions, I'm calling Visiontek up tomorrow to try and find out what's wrong if I can't solve it. I'm heavily hedging on the card being bad, though
1) I'm cursed.
3) Card is broken.
4) I'm cursed.
