Ok, after reading many threads and articles I decided to fit my blorb. First thing I did, is play games for hours
Then I took the card out (when pc was off, duh) and put it onto a static bag on a table. I put a piece of card under the hsf and got out a blunt knife. I then turned the knife at one corner and the whole thing popped right off. I didnt clean up the surface as it was almost completely clean anyway and I put on the blorb.
Now, I want to do the same thing to someone elses card, but this time I want to clean up the core to apply AS instead of simple fragtape. I have been advised at a local hardware to use Isyprol Alcohol. The guy there told me that simple tape cassette head cleaning solution contains this chemical and would be fine to clean up the core. Is this true? I'm already quite certain that its fine but my friend wants to be extra sure.
PS, thanks moderators for deleting my last post, the other AS guy was a completely different topic. You could have at least just moved it instead of deleting it.
