200/333
200/400(i saw a pro that was 200/366 once, didnt rememebr what one it was tho)
250/500
those are the stock speeds, i'll let you guess which is which
oc'd speeds can range really big. also sometimes adding ramsinks helps, sometimes it dont. from what i have been seeing over the past year, you can pretty much garuntee a 30mhz overclock on the mem for the most part(most card?
after that it's really just luck of the draw, because there's alot of variables that can affect it
