Gemini mounting hardware.
Hello guys, I'm very sorry to hear so many of you are having mounting issues. Here's the long version of what is happening, in 100,000 words or less.
Personally, when I installed the water block for the 1st time, I looked at the motherboard and felt that there is no way in hell I would want to force users to remove EVERYTHING from their system to install a CPU cooler. So I turned to the official AMD documentation and read the specification on the mounting holes. .157 with a 'dead zone'. So on my 1st test system, which just so happen to have an epox board, I confirmed this specification and setout to find a mounting solution. Once I found the snap in standoffs (the stuff pictured in hoots review), I was quite satisfied with mounting the block in this fashion.
It took about one week for me to discover that my personal Abit motherboard does NOT use this mounting solution. Abit decided to make the mounting holes .247 in diameter which includes the AMD specified 'dead zone'. So now I was forced into a dilemma. I liked the nylon screws and standoffs. I really liked front mounting the block. I had a very difficult time determining an economical way to front mount the block on these .247 boards. In the short term, I began telling everyone who ordered from GeminiCool that I did NOT have detailed instructions and that there are some mounting issues to be addressed. I also began including longer screws, locking nuts, and washers assuming people could simply through mount the blocks for the time being.
Ok here's where things got out of sink. Inorder to accommodate through board mounting I had to switch to longer screws. I also included locking nuts so that when in transport there would be NO WAY for the bolts to come lose. I made the mistake of not getting the instructions out there fast enough and not making the mounting issues well enough known. I wrongly assumed, since I'd been working so closely with the hardware, that most people would see things the same way I did. If you received the longer screw and wanted to surface mount the cooler, I had hoped scissors would be used to cut the bolt to size.
I had also hoped that people recognized the lock nut, although it is more difficult to turn than I had expected. The bolt is an 8-32 thread as is the nut. No you aren't cross threading the thing although the threads do get 'flattened' a bit. The screw now has a slot on top so you don't rip your fingers apart while turning the nut with a ratchet. During this time I also realized that the o-rings do not work as well when using the through board mounting because you do not get any 'feedback'.
As soon as I recieved my first e-mails with people having problems mounting the block, I spent the day working through all of these issues. I have begun taking pictures and writing a formal mounting section. I am also in the process of updating the site. You will be able to order the blocks for $39 or $34 without hardware, and purchase the hardware kit separately for $3.00. In the new hardware kit, I will include formal instructions.
The kit will contain.
4 nylon screws to use in through mount OR .247 surface mounting
4 surface mounting .247
4 nylon LOCK nuts
4 nylon washers
4 shorter nylon screws for surface mounting .157 holes
4 3/8" .157 locking standoffs
4 .5" springs rated at 4-5lbs compression.
I have found that asking customers to cut the screws themselves is a bad idea and I'm sorry to anyone who I lead astray there. I will be including two sizes of screws so that no cutting will be needed. Expect to see the updates published at
www.geminicool.com by the end of the week.
I hope this helps clear up the mounting issues/problems.
Also here's another little trick, that I *hope* everyone out there knows. When installing the tubing, always wet the end before sliding it over the fitting. If you must twist the tubing, try to twist it in a clockwise direction. And finally ALWAYS use something to clamp the tube once in place.
This is my 1st time working with such a large variety of people so I appreciate your patience while we work through getting the best mounting for everyone.
Thank you,
Peter.
