wuzzapiman said:
um i'm told that you take the 4 standoffs, install them in the motherboard then put the waterblock on and put the 4 smaller screws thru that with the springs between the screws and the waterblock. then tighten the screws in a zig zag pattern till there is 1/4" of spring or till the screw hits the standoff bottom. there is a thru board method but i broke my long screws....gonna test it out tonight when i get my pump. heres a diagram:
But the standoffs are weak little things. If you look, they only have a tinsy little prong to keep themselves in! I don't want to mount my block that flimsily.
The best way I figured out was to take the long screws and put them through the back of the mobo (so the bare threaded ends points up through the mobo and the head of the screw is behind the mobo when mounted), then put the block over the screws, then a nylon washer, then a spring, then a wingnut.
But the flaw with that is the wingnuts are so tight, you can't get them off the main bolts without the high possibility of twisting the main bolt in half! The wingnuts screw in pretty easily, but they do NOT want to come off!
So does anyone else have any more ideas?
