- Feb 25, 2004
Here are TPF in my log for anyone (HayesK) who finds it useful. I am interested in TPF comparison with a Gen 4 , to find out if it is a cost effective upgrade. This is the 3rd PC in sig that I just switched to Ubuntu Linux. I only have the next unit flag added. I have not found any others to be useful....If any one thinks I should try one of the others (Big, advanced, beta etc.) let me know and I'll add it.
Code:
*********************** Log Started 2021-11-11T00:07:37Z ***********************
00:07:37:******************************* libFAH ********************************
00:07:37: Date: Oct 20 2020
00:07:37: Time: 20:36:39
00:07:37: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
00:07:37: Branch: master
00:07:37: Compiler: GNU 8.3.0
00:07:37: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
00:07:37: -fdata-sections -O3 -funroll-loops -fno-pie
00:07:37: Platform: linux2 5.8.0-1-amd64
00:07:37: Bits: 64
00:07:37: Mode: Release
00:07:37:****************************** FAHClient ******************************
00:07:37: Version: 7.6.21
00:07:37: Author: Joseph Coffland <[email protected]>
00:07:37: Copyright: 2020 foldingathome.org
00:07:37: Homepage: https://foldingathome.org/
00:07:37: Time: 20:39:00
00:07:37: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
00:07:37: Bits: 64
00:07:37: Args: --child /etc/fahclient/config.xml --run-as fahclient
00:07:37: --pid-file=/var/run/fahclient.pid --daemon
00:07:37: Config: /etc/fahclient/config.xml
00:07:37:******************************** CBang ********************************
00:07:37: Time: 18:37:59
00:07:37: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
00:07:37: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
00:07:37: Bits: 64
00:07:37:******************************* System ********************************
00:07:37: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
00:07:37: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
00:07:37: CPUs: 8
00:07:37: Memory: 15.58GiB
00:07:37: Free Memory: 14.62GiB
00:07:37: Threads: POSIX_THREADS
00:07:37: OS Version: 5.11
00:07:37: Has Battery: false
00:07:37: On Battery: false
00:07:37: UTC Offset: -5
00:07:37: PID: 1184
00:07:37: CWD: /var/lib/fahclient
00:07:37: OS: Linux 5.11.0-40-generic x86_64
00:07:37: OS Arch: AMD64
00:07:37: GPUs: 1
00:07:37: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080 Lite Hash
00:07:37: Rate]
00:07:37: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.5
00:07:37:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:495.44
00:07:37:***********************************************************************
00:07:37:<config>
00:07:37: <!-- Client Control -->
00:07:37: <fold-anon v='true'/>
00:07:37:
00:07:37: <!-- Network -->
00:07:37: <proxy v=':8080'/>
00:07:37:
00:07:37: <!-- Slot Control -->
00:07:37: <power v='full'/>
00:07:37:
00:07:37: <!-- User Information -->
00:07:37: <passkey v='*****'/>
00:07:37: <team v='32'/>
00:07:37: <user v='dfonda_Team32'/>
00:07:37:
00:07:37: <!-- Work Unit Control -->
00:07:37: <next-unit-percentage v='100'/>
00:07:37:
00:07:37: <!-- Folding Slots -->
00:07:37: <slot id='1' type='GPU'>
00:07:37: <pci-bus v='1'/>
00:07:37: <pci-slot v='0'/>
00:07:37: </slot>
00:07:37:</config>
00:07:37:Trying to access database...
00:07:37:Successfully acquired database lock
00:07:37:FS01:Initialized folding slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate]
00:07:37:WU01:FS01:Starting
00:07:37:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.18/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:07:37:WU01:FS01:Started FahCore on PID 1194
00:07:37:WU01:FS01:Core PID:1198
00:07:37:WU01:FS01:FahCore 0x22 started
00:07:38:WU01:FS01:0x22:*********************** Log Started 2021-11-11T00:07:37Z ***********************
00:07:38:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
00:07:38:WU01:FS01:0x22: Core: Core22
00:07:38:WU01:FS01:0x22: Type: 0x22
00:07:38:WU01:FS01:0x22: Version: 0.0.18
00:07:38:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
00:07:38:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
00:07:38:WU01:FS01:0x22: Homepage: https://foldingathome.org/
00:07:38:WU01:FS01:0x22: Date: Sep 28 2021
00:07:38:WU01:FS01:0x22: Time: 05:43:02
00:07:38:WU01:FS01:0x22: Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
00:07:38:WU01:FS01:0x22: Branch: HEAD
00:07:38:WU01:FS01:0x22: Compiler: GNU 9.4.0
00:07:38:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
00:07:38:WU01:FS01:0x22: -funroll-loops -fno-pie -DOPENMM_VERSION="\"7.6.0\""
00:07:38:WU01:FS01:0x22: Platform: linux 5.8.0-1041-azure
00:07:38:WU01:FS01:0x22: Bits: 64
00:07:38:WU01:FS01:0x22: Mode: Release
00:07:38:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
00:07:38:WU01:FS01:0x22: <[email protected]>
00:07:38:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 1194 -checkpoint 15
00:07:38:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:07:38:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
00:07:38:WU01:FS01:0x22:************************************ libFAH ************************************
00:07:38:WU01:FS01:0x22: Time: 05:42:27
00:07:38:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:07:38:WU01:FS01:0x22:************************************ CBang *************************************
00:07:38:WU01:FS01:0x22: Time: 05:42:00
00:07:38:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:07:38:WU01:FS01:0x22: -funroll-loops -fno-pie -fPIC
00:07:38:WU01:FS01:0x22:************************************ System ************************************
00:07:38:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
00:07:38:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
00:07:38:WU01:FS01:0x22: CPUs: 8
00:07:38:WU01:FS01:0x22: Memory: 15.58GiB
00:07:38:WU01:FS01:0x22:Free Memory: 14.60GiB
00:07:38:WU01:FS01:0x22: Threads: POSIX_THREADS
00:07:38:WU01:FS01:0x22: OS Version: 5.11
00:07:38:WU01:FS01:0x22:Has Battery: false
00:07:38:WU01:FS01:0x22: On Battery: false
00:07:38:WU01:FS01:0x22: UTC Offset: -5
00:07:38:WU01:FS01:0x22: PID: 1198
00:07:38:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
00:07:38:WU01:FS01:0x22:************************************ OpenMM ************************************
00:07:38:WU01:FS01:0x22: Version: 7.6.0
00:07:38:WU01:FS01:0x22:********************************************************************************
00:07:38:WU01:FS01:0x22:Project: 16484 (Run 1, Clone 302, Gen 7)
00:07:38:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
00:07:38:WU01:FS01:0x22:Digital signatures verified
00:07:38:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
00:07:38:WU01:FS01:0x22:Version 0.0.18
00:07:38:WU01:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
00:07:38:WU01:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:07:38:WU01:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
00:07:38:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
00:07:38:WU01:FS01:0x22:There are 4 platforms available.
00:07:38:WU01:FS01:0x22:Platform 0: Reference
00:07:38:WU01:FS01:0x22:Platform 1: CPU
00:07:38:WU01:FS01:0x22:Platform 2: OpenCL
00:07:38:WU01:FS01:0x22: opencl-device 0 specified
00:07:38:WU01:FS01:0x22:Platform 3: CUDA
00:07:38:WU01:FS01:0x22: cuda-device 0 specified
00:07:46:WU01:FS01:0x22:Attempting to create CUDA context:
00:07:46:WU01:FS01:0x22: Configuring platform CUDA
00:07:54:WU01:FS01:0x22: Using CUDA and gpu 0
00:07:54:WU01:FS01:0x22:Completed 1500000 out of 2500000 steps (60%)
00:09:00:WU01:FS01:0x22:Completed 1525000 out of 2500000 steps (61%)
00:10:06:WU01:FS01:0x22:Completed 1550000 out of 2500000 steps (62%)
00:11:11:WU01:FS01:0x22:Completed 1575000 out of 2500000 steps (63%)
00:12:17:WU01:FS01:0x22:Completed 1600000 out of 2500000 steps (64%)
00:13:24:WU01:FS01:0x22:Completed 1625000 out of 2500000 steps (65%)
00:13:24:WU01:FS01:0x22:Checkpoint completed at step 1625000
00:14:32:WU01:FS01:0x22:Completed 1650000 out of 2500000 steps (66%)
00:15:40:WU01:FS01:0x22:Completed 1675000 out of 2500000 steps (67%)
00:16:45:WU01:FS01:0x22:Completed 1700000 out of 2500000 steps (68%)
00:17:51:WU01:FS01:0x22:Completed 1725000 out of 2500000 steps (69%)
00:18:56:WU01:FS01:0x22:Completed 1750000 out of 2500000 steps (70%)
00:18:57:WU01:FS01:0x22:Checkpoint completed at step 1750000
00:20:03:WU01:FS01:0x22:Completed 1775000 out of 2500000 steps (71%)
00:21:09:WU01:FS01:0x22:Completed 1800000 out of 2500000 steps (72%)
00:22:14:WU01:FS01:0x22:Completed 1825000 out of 2500000 steps (73%)
00:23:20:WU01:FS01:0x22:Completed 1850000 out of 2500000 steps (74%)
00:24:24:WU01:FS01:0x22:Completed 1875000 out of 2500000 steps (75%)
00:24:25:WU01:FS01:0x22:Checkpoint completed at step 1875000
00:25:30:WU01:FS01:0x22:Completed 1900000 out of 2500000 steps (76%)
00:26:34:WU01:FS01:0x22:Completed 1925000 out of 2500000 steps (77%)
00:27:39:WU01:FS01:0x22:Completed 1950000 out of 2500000 steps (78%)
00:28:43:WU01:FS01:0x22:Completed 1975000 out of 2500000 steps (79%)
00:29:48:WU01:FS01:0x22:Completed 2000000 out of 2500000 steps (80%)
00:29:49:WU01:FS01:0x22:Checkpoint completed at step 2000000
00:30:53:WU01:FS01:0x22:Completed 2025000 out of 2500000 steps (81%)
00:31:58:WU01:FS01:0x22:Completed 2050000 out of 2500000 steps (82%)
00:33:02:WU01:FS01:0x22:Completed 2075000 out of 2500000 steps (83%)
00:34:07:WU01:FS01:0x22:Completed 2100000 out of 2500000 steps (84%)
00:35:11:WU01:FS01:0x22:Completed 2125000 out of 2500000 steps (85%)
00:35:12:WU01:FS01:0x22:Checkpoint completed at step 2125000
00:36:16:WU01:FS01:0x22:Completed 2150000 out of 2500000 steps (86%)
00:37:21:WU01:FS01:0x22:Completed 2175000 out of 2500000 steps (87%)
00:38:25:WU01:FS01:0x22:Completed 2200000 out of 2500000 steps (88%)
00:39:29:WU01:FS01:0x22:Completed 2225000 out of 2500000 steps (89%)
00:40:34:WU01:FS01:0x22:Completed 2250000 out of 2500000 steps (90%)
00:40:34:WU01:FS01:0x22:Checkpoint completed at step 2250000
00:41:39:WU01:FS01:0x22:Completed 2275000 out of 2500000 steps (91%)
00:42:43:WU01:FS01:0x22:Completed 2300000 out of 2500000 steps (92%)
00:43:48:WU01:FS01:0x22:Completed 2325000 out of 2500000 steps (93%)
00:44:52:WU01:FS01:0x22:Completed 2350000 out of 2500000 steps (94%)
00:45:57:WU01:FS01:0x22:Completed 2375000 out of 2500000 steps (95%)
00:45:57:WU01:FS01:0x22:Checkpoint completed at step 2375000
00:47:02:WU01:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
00:48:06:WU01:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
00:49:11:WU01:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
00:50:15:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
00:51:19:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
00:51:19:WU01:FS01:0x22:Average performance: 268.323 ns/day
00:51:20:WU01:FS01:0x22:Checkpoint completed at step 2500000
00:51:20:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:51:20:WU00:FS01:Assigned to work server 129.32.209.202
00:51:20:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
00:51:20:WU00:FS01:Connecting to 129.32.209.202:8080
00:51:21:WU00:FS01:Downloading 27.80MiB
00:51:23:WU00:FS01:Download complete
00:51:23:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18431 run:9 clone:67 gen:69 core:0x22 unit:0x0000004300000045000047ff00000009
00:51:27:WU01:FS01:0x22:Saving result file ../logfile_01.txt
00:51:27:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
00:51:27:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
00:51:27:WU01:FS01:0x22:Saving result file positions.xtc
00:51:27:WU01:FS01:0x22:Saving result file science.log
00:51:27:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
00:51:27:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:51:27:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16484 run:1 clone:302 gen:7 core:0x22 unit:0x0000012e000000070000406400000001
00:51:27:WU01:FS01:Uploading 13.46MiB to 140.163.4.200
00:51:27:WU01:FS01:Connecting to 140.163.4.200:8080
00:51:27:WU00:FS01:Starting
00:51:27:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:51:27:WU00:FS01:Started FahCore on PID 3493
00:51:27:WU00:FS01:Core PID:3497
00:51:27:WU00:FS01:FahCore 0x22 started
00:51:28:WU00:FS01:0x22:*********************** Log Started 2021-11-11T00:51:27Z ***********************
00:51:28:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
00:51:28:WU00:FS01:0x22: Core: Core22
00:51:28:WU00:FS01:0x22: Type: 0x22
00:51:28:WU00:FS01:0x22: Version: 0.0.13
00:51:28:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
00:51:28:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
00:51:28:WU00:FS01:0x22: Homepage: https://foldingathome.org/
00:51:28:WU00:FS01:0x22: Date: Sep 19 2020
00:51:28:WU00:FS01:0x22: Time: 01:10:35
00:51:28:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:51:28:WU00:FS01:0x22: Branch: core22-0.0.13
00:51:28:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
00:51:28:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
00:51:28:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
00:51:28:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
00:51:28:WU00:FS01:0x22: Bits: 64
00:51:28:WU00:FS01:0x22: Mode: Release
00:51:28:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
00:51:28:WU00:FS01:0x22: <[email protected]>
00:51:28:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 3493 -checkpoint 15
00:51:28:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:51:28:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
00:51:28:WU00:FS01:0x22:************************************ libFAH ************************************
00:51:28:WU00:FS01:0x22: Date: Sep 15 2020
00:51:28:WU00:FS01:0x22: Time: 05:14:43
00:51:28:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:51:28:WU00:FS01:0x22: Branch: HEAD
00:51:28:WU00:FS01:0x22:************************************ CBang *************************************
00:51:28:WU00:FS01:0x22: Time: 05:11:04
00:51:28:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:51:28:WU00:FS01:0x22: -funroll-loops -fPIC
00:51:28:WU00:FS01:0x22:************************************ System ************************************
00:51:28:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
00:51:28:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
00:51:28:WU00:FS01:0x22: CPUs: 8
00:51:28:WU00:FS01:0x22: Memory: 15.58GiB
00:51:28:WU00:FS01:0x22:Free Memory: 12.95GiB
00:51:28:WU00:FS01:0x22: Threads: POSIX_THREADS
00:51:28:WU00:FS01:0x22: OS Version: 5.11
00:51:28:WU00:FS01:0x22:Has Battery: false
00:51:28:WU00:FS01:0x22: On Battery: false
00:51:28:WU00:FS01:0x22: UTC Offset: -5
00:51:28:WU00:FS01:0x22: PID: 3497
00:51:28:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
00:51:28:WU00:FS01:0x22:************************************ OpenMM ************************************
00:51:28:WU00:FS01:0x22: Revision: 189320d0
00:51:28:WU00:FS01:0x22:********************************************************************************
00:51:28:WU00:FS01:0x22:Project: 18431 (Run 9, Clone 67, Gen 69)
00:51:28:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
00:51:28:WU00:FS01:0x22:Reading tar file core.xml
00:51:28:WU00:FS01:0x22:Reading tar file integrator.xml
00:51:28:WU00:FS01:0x22:Reading tar file state.xml
00:51:28:WU00:FS01:0x22:Reading tar file system.xml
00:51:28:WU00:FS01:0x22:Digital signatures verified
00:51:28:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
00:51:28:WU00:FS01:0x22:Version 0.0.13
00:51:28:WU00:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
00:51:28:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
00:51:28:WU00:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
00:51:28:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
00:51:28:WU00:FS01:0x22:There are 4 platforms available.
00:51:28:WU00:FS01:0x22:Platform 0: Reference
00:51:28:WU00:FS01:0x22:Platform 1: CPU
00:51:28:WU00:FS01:0x22:Platform 2: OpenCL
00:51:28:WU00:FS01:0x22: opencl-device 0 specified
00:51:28:WU00:FS01:0x22:Platform 3: CUDA
00:51:28:WU00:FS01:0x22: cuda-device 0 specified
00:51:30:WU00:FS01:0x22:Attempting to create CUDA context:
00:51:30:WU00:FS01:0x22: Configuring platform CUDA
00:51:30:WU01:FS01:Upload complete
00:51:30:WU01:FS01:Server responded WORK_ACK (400)
00:51:30:WU01:FS01:Final credit estimate, 472867.00 points
00:51:30:WU01:FS01:Cleaning up
00:52:59:WU00:FS01:0x22: Using CUDA and gpu 0
00:52:59:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
00:52:59:WU00:FS01:0x22:Checkpoint completed at step 0
00:53:42:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
00:54:25:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
00:54:25:WU00:FS01:0x22:Checkpoint completed at step 100000
00:55:07:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
00:55:50:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
00:55:50:WU00:FS01:0x22:Checkpoint completed at step 200000
00:56:33:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
00:57:16:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
00:57:16:WU00:FS01:0x22:Checkpoint completed at step 300000
00:57:58:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
00:58:41:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
00:58:41:WU00:FS01:0x22:Checkpoint completed at step 400000
00:59:24:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
01:00:06:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
01:00:06:WU00:FS01:0x22:Checkpoint completed at step 500000
01:00:49:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
01:01:31:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
01:01:31:WU00:FS01:0x22:Checkpoint completed at step 600000
01:02:14:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
01:02:56:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
01:02:56:WU00:FS01:0x22:Checkpoint completed at step 700000
01:03:39:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
01:04:22:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
01:04:22:WU00:FS01:0x22:Checkpoint completed at step 800000
01:05:04:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
01:05:47:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
01:05:47:WU00:FS01:0x22:Checkpoint completed at step 900000
01:06:30:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
01:07:12:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
01:07:12:WU00:FS01:0x22:Checkpoint completed at step 1000000
01:07:55:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
01:08:37:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
01:08:38:WU00:FS01:0x22:Checkpoint completed at step 1100000
01:09:21:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
01:10:03:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
01:10:03:WU00:FS01:0x22:Checkpoint completed at step 1200000
01:10:46:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
01:11:28:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
01:11:29:WU00:FS01:0x22:Checkpoint completed at step 1300000
01:12:11:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
01:12:54:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
01:12:54:WU00:FS01:0x22:Checkpoint completed at step 1400000
01:13:36:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
01:14:19:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
01:14:19:WU00:FS01:0x22:Checkpoint completed at step 1500000
01:15:02:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
01:15:44:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
01:15:44:WU00:FS01:0x22:Checkpoint completed at step 1600000
01:16:27:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
01:17:09:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
01:17:10:WU00:FS01:0x22:Checkpoint completed at step 1700000
01:17:52:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
01:18:35:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
01:18:35:WU00:FS01:0x22:Checkpoint completed at step 1800000
01:19:17:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
01:20:00:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
01:20:00:WU00:FS01:0x22:Checkpoint completed at step 1900000
01:20:42:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
01:21:25:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
01:21:25:WU00:FS01:0x22:Checkpoint completed at step 2000000
01:22:07:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
01:22:50:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
01:22:50:WU00:FS01:0x22:Checkpoint completed at step 2100000
01:23:33:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
01:24:16:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
01:24:16:WU00:FS01:0x22:Checkpoint completed at step 2200000
01:24:58:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
01:25:41:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
01:25:41:WU00:FS01:0x22:Checkpoint completed at step 2300000
01:26:24:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
01:27:06:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
01:27:06:WU00:FS01:0x22:Checkpoint completed at step 2400000
01:27:49:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
01:28:31:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
01:28:31:WU00:FS01:0x22:Checkpoint completed at step 2500000
01:29:14:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
01:29:56:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
01:29:56:WU00:FS01:0x22:Checkpoint completed at step 2600000
01:30:38:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
01:31:21:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
01:31:21:WU00:FS01:0x22:Checkpoint completed at step 2700000
01:32:03:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
01:32:46:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
01:32:46:WU00:FS01:0x22:Checkpoint completed at step 2800000
01:33:28:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
01:34:10:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
01:34:10:WU00:FS01:0x22:Checkpoint completed at step 2900000
01:34:53:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
01:35:35:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
01:35:35:WU00:FS01:0x22:Checkpoint completed at step 3000000
01:36:17:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
01:36:59:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
01:36:59:WU00:FS01:0x22:Checkpoint completed at step 3100000
01:37:41:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
01:38:24:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
01:38:24:WU00:FS01:0x22:Checkpoint completed at step 3200000
01:39:06:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
01:39:49:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
01:39:49:WU00:FS01:0x22:Checkpoint completed at step 3300000
01:40:31:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
01:41:14:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
01:41:14:WU00:FS01:0x22:Checkpoint completed at step 3400000
01:41:56:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
01:42:38:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
01:42:38:WU00:FS01:0x22:Checkpoint completed at step 3500000
01:43:20:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
01:44:03:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
01:44:03:WU00:FS01:0x22:Checkpoint completed at step 3600000
01:44:45:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
01:45:27:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
01:45:28:WU00:FS01:0x22:Checkpoint completed at step 3700000
01:46:10:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
01:46:52:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
01:46:52:WU00:FS01:0x22:Checkpoint completed at step 3800000
01:47:35:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
01:48:17:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
01:48:17:WU00:FS01:0x22:Checkpoint completed at step 3900000
01:49:00:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
01:49:42:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
01:49:43:WU00:FS01:0x22:Checkpoint completed at step 4000000
01:50:25:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
01:51:08:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
01:51:08:WU00:FS01:0x22:Checkpoint completed at step 4100000
01:51:50:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
01:52:33:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
01:52:33:WU00:FS01:0x22:Checkpoint completed at step 4200000
01:53:15:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
01:53:58:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
01:53:58:WU00:FS01:0x22:Checkpoint completed at step 4300000
01:54:41:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
01:55:23:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
01:55:23:WU00:FS01:0x22:Checkpoint completed at step 4400000
01:56:06:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
01:56:48:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
01:56:48:WU00:FS01:0x22:Checkpoint completed at step 4500000
01:57:31:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
01:58:13:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
01:58:13:WU00:FS01:0x22:Checkpoint completed at step 4600000
01:58:56:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
01:59:38:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
01:59:38:WU00:FS01:0x22:Checkpoint completed at step 4700000
02:00:20:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
02:01:03:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
02:01:03:WU00:FS01:0x22:Checkpoint completed at step 4800000
02:01:45:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
02:02:28:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
02:02:28:WU00:FS01:0x22:Checkpoint completed at step 4900000
02:03:10:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
02:03:53:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
02:03:53:WU00:FS01:0x22:Average performance: 508.235 ns/day
02:03:53:WU00:FS01:0x22:Checkpoint completed at step 5000000
02:03:54:WU00:FS01:0x22:Saving result file ../logfile_01.txt
02:03:54:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
02:03:54:WU00:FS01:0x22:Saving result file checkpointState.xml
02:03:54:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:03:54:WU01:FS01:Assigned to work server 129.32.209.202
02:03:54:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
02:03:54:WU01:FS01:Connecting to 129.32.209.202:8080
02:03:54:WU00:FS01:0x22:Saving result file positions.xtc
02:03:54:WU00:FS01:0x22:Saving result file science.log
02:03:54:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
02:03:54:WU01:FS01:Downloading 27.78MiB
02:03:55:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:03:55:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18431 run:9 clone:67 gen:69 core:0x22 unit:0x0000004300000045000047ff00000009
02:03:55:WU00:FS01:Uploading 14.34MiB to 129.32.209.202
02:03:55:WU00:FS01:Connecting to 129.32.209.202:8080
02:03:57:WU01:FS01:Download complete
02:03:57:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:4 clone:133 gen:94 core:0x22 unit:0x000000850000005e000047ff00000004
02:03:57:WU01:FS01:Starting
02:03:57:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
02:03:57:WU01:FS01:Started FahCore on PID 3687
02:03:57:WU01:FS01:Core PID:3691
02:03:57:WU01:FS01:FahCore 0x22 started
02:03:57:WU01:FS01:0x22:*********************** Log Started 2021-11-11T02:03:57Z ***********************
02:03:57:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
02:03:57:WU01:FS01:0x22: Core: Core22
02:03:57:WU01:FS01:0x22: Type: 0x22
02:03:57:WU01:FS01:0x22: Version: 0.0.13
02:03:57:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
02:03:57:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
02:03:57:WU01:FS01:0x22: Homepage: https://foldingathome.org/
02:03:57:WU01:FS01:0x22: Date: Sep 19 2020
02:03:57:WU01:FS01:0x22: Time: 01:10:35
02:03:57:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
02:03:57:WU01:FS01:0x22: Branch: core22-0.0.13
02:03:57:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
02:03:57:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
02:03:57:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
02:03:57:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
02:03:57:WU01:FS01:0x22: Bits: 64
02:03:57:WU01:FS01:0x22: Mode: Release
02:03:57:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
02:03:57:WU01:FS01:0x22: <[email protected]>
02:03:57:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 3687 -checkpoint 15
02:03:57:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
02:03:57:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
02:03:57:WU01:FS01:0x22:************************************ libFAH ************************************
02:03:57:WU01:FS01:0x22: Date: Sep 15 2020
02:03:57:WU01:FS01:0x22: Time: 05:14:43
02:03:57:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
02:03:57:WU01:FS01:0x22: Branch: HEAD
02:03:57:WU01:FS01:0x22:************************************ CBang *************************************
02:03:57:WU01:FS01:0x22: Time: 05:11:04
02:03:57:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
02:03:57:WU01:FS01:0x22: -funroll-loops -fPIC
02:03:57:WU01:FS01:0x22:************************************ System ************************************
02:03:57:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
02:03:57:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
02:03:57:WU01:FS01:0x22: CPUs: 8
02:03:57:WU01:FS01:0x22: Memory: 15.58GiB
02:03:57:WU01:FS01:0x22:Free Memory: 12.84GiB
02:03:57:WU01:FS01:0x22: Threads: POSIX_THREADS
02:03:57:WU01:FS01:0x22: OS Version: 5.11
02:03:57:WU01:FS01:0x22:Has Battery: false
02:03:57:WU01:FS01:0x22: On Battery: false
02:03:57:WU01:FS01:0x22: UTC Offset: -5
02:03:57:WU01:FS01:0x22: PID: 3691
02:03:57:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
02:03:57:WU01:FS01:0x22:************************************ OpenMM ************************************
02:03:57:WU01:FS01:0x22: Revision: 189320d0
02:03:57:WU01:FS01:0x22:********************************************************************************
02:03:57:WU01:FS01:0x22:Project: 18431 (Run 4, Clone 133, Gen 94)
02:03:57:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
02:03:57:WU01:FS01:0x22:Reading tar file core.xml
02:03:57:WU01:FS01:0x22:Reading tar file integrator.xml
02:03:57:WU01:FS01:0x22:Reading tar file state.xml
02:03:57:WU01:FS01:0x22:Reading tar file system.xml
02:03:57:WU01:FS01:0x22:Digital signatures verified
02:03:57:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
02:03:57:WU01:FS01:0x22:Version 0.0.13
02:03:57:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
02:03:57:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
02:03:57:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
02:03:57:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
02:03:57:WU01:FS01:0x22:There are 4 platforms available.
02:03:57:WU01:FS01:0x22:Platform 0: Reference
02:03:57:WU01:FS01:0x22:Platform 1: CPU
02:03:57:WU01:FS01:0x22:Platform 2: OpenCL
02:03:57:WU01:FS01:0x22: opencl-device 0 specified
02:03:57:WU01:FS01:0x22:Platform 3: CUDA
02:03:57:WU01:FS01:0x22: cuda-device 0 specified
02:03:59:WU00:FS01:Upload complete
02:03:59:WU00:FS01:Server responded WORK_ACK (400)
02:03:59:WU00:FS01:Final credit estimate, 292453.00 points
02:03:59:WU00:FS01:Cleaning up
02:03:59:WU01:FS01:0x22:Attempting to create CUDA context:
02:03:59:WU01:FS01:0x22: Configuring platform CUDA
02:05:27:WU01:FS01:0x22: Using CUDA and gpu 0
02:05:28:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
02:05:28:WU01:FS01:0x22:Checkpoint completed at step 0
02:06:10:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
02:06:53:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
02:06:53:WU01:FS01:0x22:Checkpoint completed at step 100000
02:07:35:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
02:08:18:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
02:08:18:WU01:FS01:0x22:Checkpoint completed at step 200000
02:09:01:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
02:09:43:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
02:09:43:WU01:FS01:0x22:Checkpoint completed at step 300000
02:10:26:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
02:11:09:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
02:11:09:WU01:FS01:0x22:Checkpoint completed at step 400000
02:11:52:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
02:12:34:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
02:12:34:WU01:FS01:0x22:Checkpoint completed at step 500000
02:13:17:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
02:14:00:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
02:14:00:WU01:FS01:0x22:Checkpoint completed at step 600000
02:14:43:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
02:15:25:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
02:15:26:WU01:FS01:0x22:Checkpoint completed at step 700000
02:16:08:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
02:16:51:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
02:16:51:WU01:FS01:0x22:Checkpoint completed at step 800000
02:17:34:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
02:18:17:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
02:18:17:WU01:FS01:0x22:Checkpoint completed at step 900000
02:19:00:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
02:19:42:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
02:19:42:WU01:FS01:0x22:Checkpoint completed at step 1000000
02:20:25:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
02:21:08:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
02:21:08:WU01:FS01:0x22:Checkpoint completed at step 1100000
02:21:51:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
02:22:33:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
02:22:33:WU01:FS01:0x22:Checkpoint completed at step 1200000
02:23:16:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
02:23:59:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
02:23:59:WU01:FS01:0x22:Checkpoint completed at step 1300000
02:24:42:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
02:25:24:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
02:25:24:WU01:FS01:0x22:Checkpoint completed at step 1400000
02:26:07:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
02:26:49:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
02:26:50:WU01:FS01:0x22:Checkpoint completed at step 1500000
02:27:32:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
02:28:15:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
02:28:15:WU01:FS01:0x22:Checkpoint completed at step 1600000
02:28:58:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
02:29:40:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
02:29:40:WU01:FS01:0x22:Checkpoint completed at step 1700000
02:30:23:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
02:31:06:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
02:31:06:WU01:FS01:0x22:Checkpoint completed at step 1800000
02:31:49:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
02:32:31:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
02:32:31:WU01:FS01:0x22:Checkpoint completed at step 1900000
02:33:14:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
02:33:57:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
02:33:57:WU01:FS01:0x22:Checkpoint completed at step 2000000
02:34:39:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
02:35:22:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
02:35:22:WU01:FS01:0x22:Checkpoint completed at step 2100000
02:36:05:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
02:36:47:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
02:36:47:WU01:FS01:0x22:Checkpoint completed at step 2200000
02:37:30:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
02:38:12:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
02:38:12:WU01:FS01:0x22:Checkpoint completed at step 2300000
02:38:55:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
02:39:37:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
02:39:38:WU01:FS01:0x22:Checkpoint completed at step 2400000
02:40:20:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
02:41:03:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
02:41:03:WU01:FS01:0x22:Checkpoint completed at step 2500000
02:41:46:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
02:42:28:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
02:42:28:WU01:FS01:0x22:Checkpoint completed at step 2600000
02:43:11:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
02:43:54:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
02:43:54:WU01:FS01:0x22:Checkpoint completed at step 2700000
02:44:37:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
02:45:19:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
02:45:20:WU01:FS01:0x22:Checkpoint completed at step 2800000
02:46:02:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
02:46:45:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
02:46:45:WU01:FS01:0x22:Checkpoint completed at step 2900000
02:47:28:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
02:48:10:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
02:48:10:WU01:FS01:0x22:Checkpoint completed at step 3000000
02:48:53:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
02:49:36:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
02:49:36:WU01:FS01:0x22:Checkpoint completed at step 3100000
02:50:18:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
02:51:01:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
02:51:01:WU01:FS01:0x22:Checkpoint completed at step 3200000
02:51:44:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
02:52:26:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
02:52:26:WU01:FS01:0x22:Checkpoint completed at step 3300000
02:53:09:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
02:53:52:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
02:53:52:WU01:FS01:0x22:Checkpoint completed at step 3400000
02:54:34:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
02:55:17:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
02:55:17:WU01:FS01:0x22:Checkpoint completed at step 3500000
02:55:59:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
02:56:42:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
02:56:42:WU01:FS01:0x22:Checkpoint completed at step 3600000
02:57:25:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
02:58:07:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
02:58:07:WU01:FS01:0x22:Checkpoint completed at step 3700000
02:58:50:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
02:59:33:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
02:59:33:WU01:FS01:0x22:Checkpoint completed at step 3800000
03:00:15:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
03:00:57:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
03:00:58:WU01:FS01:0x22:Checkpoint completed at step 3900000
03:01:40:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
03:02:22:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
03:02:23:WU01:FS01:0x22:Checkpoint completed at step 4000000
03:03:05:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
03:03:47:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
03:03:47:WU01:FS01:0x22:Checkpoint completed at step 4100000
03:04:30:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
03:05:12:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
03:05:12:WU01:FS01:0x22:Checkpoint completed at step 4200000
03:05:54:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
03:06:37:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
03:06:37:WU01:FS01:0x22:Checkpoint completed at step 4300000
03:07:20:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
03:08:02:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
03:08:02:WU01:FS01:0x22:Checkpoint completed at step 4400000
03:08:45:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
03:09:28:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
03:09:28:WU01:FS01:0x22:Checkpoint completed at step 4500000
03:10:10:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
03:10:53:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
03:10:53:WU01:FS01:0x22:Checkpoint completed at step 4600000
03:11:36:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
03:12:18:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
03:12:18:WU01:FS01:0x22:Checkpoint completed at step 4700000
03:13:01:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
03:13:43:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
03:13:44:WU01:FS01:0x22:Checkpoint completed at step 4800000
03:14:26:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
03:15:09:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
03:15:09:WU01:FS01:0x22:Checkpoint completed at step 4900000
03:15:51:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
03:16:34:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
03:16:34:WU01:FS01:0x22:Average performance: 508.235 ns/day
03:16:34:WU01:FS01:0x22:Checkpoint completed at step 5000000
03:16:34:WU00:FS01:Connecting to assign1.foldingathome.org:80
03:16:34:WU00:FS01:Assigned to work server 128.252.203.11
03:16:34:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 128.252.203.11
03:16:34:WU00:FS01:Connecting to 128.252.203.11:8080
03:16:35:WU01:FS01:0x22:Saving result file ../logfile_01.txt
03:16:35:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
03:16:35:WU01:FS01:0x22:Saving result file checkpointState.xml
03:16:35:WU01:FS01:0x22:Saving result file positions.xtc
03:16:35:WU01:FS01:0x22:Saving result file science.log
03:16:35:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
03:16:35:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:16:35:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:4 clone:133 gen:94 core:0x22 unit:0x000000850000005e000047ff00000004
03:16:35:WU01:FS01:Uploading 14.33MiB to 129.32.209.202
03:16:35:WU01:FS01:Connecting to 129.32.209.202:8080
03:16:38:WU01:FS01:Upload complete
03:16:38:WU01:FS01:Server responded WORK_ACK (400)
03:16:38:WU01:FS01:Final credit estimate, 292286.00 points
03:16:38:WU01:FS01:Cleaning up
03:16:44:WU00:FS01:Downloading 26.57MiB
03:16:49:WU00:FS01:Download complete
03:16:49:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18201 run:36299 clone:0 gen:14 core:0x22 unit:0x000000000000000e0000471900008dcb
03:16:49:WU00:FS01:Starting
03:16:49:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
03:16:49:WU00:FS01:Started FahCore on PID 3824
03:16:49:WU00:FS01:Core PID:3828
03:16:49:WU00:FS01:FahCore 0x22 started
03:16:50:WU00:FS01:0x22:*********************** Log Started 2021-11-11T03:16:49Z ***********************
03:16:50:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
03:16:50:WU00:FS01:0x22: Core: Core22
03:16:50:WU00:FS01:0x22: Type: 0x22
03:16:50:WU00:FS01:0x22: Version: 0.0.13
03:16:50:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
03:16:50:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
03:16:50:WU00:FS01:0x22: Homepage: https://foldingathome.org/
03:16:50:WU00:FS01:0x22: Date: Sep 19 2020
03:16:50:WU00:FS01:0x22: Time: 01:10:35
03:16:50:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
03:16:50:WU00:FS01:0x22: Branch: core22-0.0.13
03:16:50:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
03:16:50:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
03:16:50:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
03:16:50:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
03:16:50:WU00:FS01:0x22: Bits: 64
03:16:50:WU00:FS01:0x22: Mode: Release
03:16:50:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
03:16:50:WU00:FS01:0x22: <[email protected]>
03:16:50:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 3824 -checkpoint 15
03:16:50:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
03:16:50:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
03:16:50:WU00:FS01:0x22:************************************ libFAH ************************************
03:16:50:WU00:FS01:0x22: Date: Sep 15 2020
03:16:50:WU00:FS01:0x22: Time: 05:14:43
03:16:50:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
03:16:50:WU00:FS01:0x22: Branch: HEAD
03:16:50:WU00:FS01:0x22:************************************ CBang *************************************
03:16:50:WU00:FS01:0x22: Time: 05:11:04
03:16:50:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
03:16:50:WU00:FS01:0x22: -funroll-loops -fPIC
03:16:50:WU00:FS01:0x22:************************************ System ************************************
03:16:50:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
03:16:50:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
03:16:50:WU00:FS01:0x22: CPUs: 8
03:16:50:WU00:FS01:0x22: Memory: 15.58GiB
03:16:50:WU00:FS01:0x22:Free Memory: 12.88GiB
03:16:50:WU00:FS01:0x22: Threads: POSIX_THREADS
03:16:50:WU00:FS01:0x22: OS Version: 5.11
03:16:50:WU00:FS01:0x22:Has Battery: false
03:16:50:WU00:FS01:0x22: On Battery: false
03:16:50:WU00:FS01:0x22: UTC Offset: -5
03:16:50:WU00:FS01:0x22: PID: 3828
03:16:50:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
03:16:50:WU00:FS01:0x22:************************************ OpenMM ************************************
03:16:50:WU00:FS01:0x22: Revision: 189320d0
03:16:50:WU00:FS01:0x22:********************************************************************************
03:16:50:WU00:FS01:0x22:Project: 18201 (Run 36299, Clone 0, Gen 14)
03:16:50:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
03:16:50:WU00:FS01:0x22:Reading tar file core.xml
03:16:50:WU00:FS01:0x22:Reading tar file integrator.xml
03:16:50:WU00:FS01:0x22:Reading tar file state.xml
03:16:50:WU00:FS01:0x22:Reading tar file system.xml
03:16:51:WU00:FS01:0x22:Digital signatures verified
03:16:51:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
03:16:51:WU00:FS01:0x22:Version 0.0.13
03:16:51:WU00:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
03:16:51:WU00:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
03:16:51:WU00:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
03:16:51:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
03:16:51:WU00:FS01:0x22:There are 4 platforms available.
03:16:51:WU00:FS01:0x22:Platform 0: Reference
03:16:51:WU00:FS01:0x22:Platform 1: CPU
03:16:51:WU00:FS01:0x22:Platform 2: OpenCL
03:16:51:WU00:FS01:0x22: opencl-device 0 specified
03:16:51:WU00:FS01:0x22:Platform 3: CUDA
03:16:51:WU00:FS01:0x22: cuda-device 0 specified
03:17:00:WU00:FS01:0x22:Attempting to create CUDA context:
03:17:00:WU00:FS01:0x22: Configuring platform CUDA
03:18:32:WU00:FS01:0x22: Using CUDA and gpu 0
03:18:32:WU00:FS01:0x22:Completed 0 out of 1250000 steps (0%)
03:18:33:WU00:FS01:0x22:Checkpoint completed at step 0
03:19:33:WU00:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
03:20:34:WU00:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
03:20:34:WU00:FS01:0x22:Checkpoint completed at step 25000
03:21:36:WU00:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
03:22:36:WU00:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
03:22:37:WU00:FS01:0x22:Checkpoint completed at step 50000
03:23:38:WU00:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
03:24:38:WU00:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
03:24:39:WU00:FS01:0x22:Checkpoint completed at step 75000
03:25:39:WU00:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
03:26:40:WU00:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
03:26:41:WU00:FS01:0x22:Checkpoint completed at step 100000
03:27:41:WU00:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
03:28:42:WU00:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
03:28:42:WU00:FS01:0x22:Checkpoint completed at step 125000
03:29:43:WU00:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
03:30:43:WU00:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
03:30:44:WU00:FS01:0x22:Checkpoint completed at step 150000
03:31:45:WU00:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
03:32:45:WU00:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
03:32:46:WU00:FS01:0x22:Checkpoint completed at step 175000
03:33:47:WU00:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
03:34:48:WU00:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
03:34:48:WU00:FS01:0x22:Checkpoint completed at step 200000
03:35:49:WU00:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
03:36:49:WU00:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
03:36:50:WU00:FS01:0x22:Checkpoint completed at step 225000
03:37:51:WU00:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
03:38:51:WU00:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
03:38:52:WU00:FS01:0x22:Checkpoint completed at step 250000
03:39:53:WU00:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
03:40:53:WU00:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
03:40:54:WU00:FS01:0x22:Checkpoint completed at step 275000
03:41:55:WU00:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
03:42:55:WU00:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
03:42:56:WU00:FS01:0x22:Checkpoint completed at step 300000
03:43:57:WU00:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
03:44:57:WU00:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
03:44:58:WU00:FS01:0x22:Checkpoint completed at step 325000
03:45:59:WU00:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
03:46:59:WU00:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
03:47:00:WU00:FS01:0x22:Checkpoint completed at step 350000
03:48:01:WU00:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
03:49:02:WU00:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
03:49:02:WU00:FS01:0x22:Checkpoint completed at step 375000
03:50:03:WU00:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
03:51:03:WU00:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
03:51:04:WU00:FS01:0x22:Checkpoint completed at step 400000
03:52:05:WU00:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
03:53:06:WU00:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
03:53:07:WU00:FS01:0x22:Checkpoint completed at step 425000
03:54:07:WU00:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
03:55:08:WU00:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
03:55:09:WU00:FS01:0x22:Checkpoint completed at step 450000
03:56:09:WU00:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
03:57:10:WU00:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
03:57:11:WU00:FS01:0x22:Checkpoint completed at step 475000
03:58:11:WU00:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
03:59:12:WU00:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
03:59:13:WU00:FS01:0x22:Checkpoint completed at step 500000
04:00:13:WU00:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
04:01:14:WU00:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
04:01:15:WU00:FS01:0x22:Checkpoint completed at step 525000
04:02:16:WU00:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
04:03:16:WU00:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
04:03:17:WU00:FS01:0x22:Checkpoint completed at step 550000
04:04:18:WU00:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
04:05:18:WU00:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
04:05:19:WU00:FS01:0x22:Checkpoint completed at step 575000
04:06:20:WU00:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
04:07:20:WU00:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
04:07:21:WU00:FS01:0x22:Checkpoint completed at step 600000
04:08:21:WU00:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
04:09:22:WU00:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
04:09:23:WU00:FS01:0x22:Checkpoint completed at step 625000
04:10:23:WU00:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
04:11:24:WU00:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
04:11:25:WU00:FS01:0x22:Checkpoint completed at step 650000
04:12:26:WU00:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
04:13:26:WU00:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
04:13:27:WU00:FS01:0x22:Checkpoint completed at step 675000
04:14:27:WU00:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
04:15:28:WU00:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
04:15:29:WU00:FS01:0x22:Checkpoint completed at step 700000
04:16:30:WU00:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
04:17:30:WU00:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
04:17:31:WU00:FS01:0x22:Checkpoint completed at step 725000
04:18:31:WU00:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
04:19:32:WU00:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
04:19:33:WU00:FS01:0x22:Checkpoint completed at step 750000
04:20:33:WU00:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
04:21:33:WU00:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
04:21:34:WU00:FS01:0x22:Checkpoint completed at step 775000
04:22:35:WU00:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
04:23:35:WU00:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
04:23:36:WU00:FS01:0x22:Checkpoint completed at step 800000
04:24:37:WU00:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
04:25:37:WU00:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
04:25:38:WU00:FS01:0x22:Checkpoint completed at step 825000
04:26:39:WU00:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
04:27:39:WU00:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
04:27:40:WU00:FS01:0x22:Checkpoint completed at step 850000
04:28:41:WU00:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
04:29:41:WU00:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
04:29:42:WU00:FS01:0x22:Checkpoint completed at step 875000
04:30:43:WU00:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
04:31:43:WU00:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
04:31:44:WU00:FS01:0x22:Checkpoint completed at step 900000
04:32:45:WU00:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
04:33:45:WU00:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
04:33:46:WU00:FS01:0x22:Checkpoint completed at step 925000
04:34:47:WU00:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
04:35:47:WU00:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
04:35:48:WU00:FS01:0x22:Checkpoint completed at step 950000
04:36:49:WU00:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
04:37:49:WU00:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
04:37:50:WU00:FS01:0x22:Checkpoint completed at step 975000
04:38:51:WU00:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
04:39:51:WU00:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
04:39:52:WU00:FS01:0x22:Checkpoint completed at step 1000000
04:40:53:WU00:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
04:41:53:WU00:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
04:41:54:WU00:FS01:0x22:Checkpoint completed at step 1025000
04:42:55:WU00:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
04:43:55:WU00:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
04:43:56:WU00:FS01:0x22:Checkpoint completed at step 1050000
04:44:57:WU00:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
04:45:57:WU00:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
04:45:58:WU00:FS01:0x22:Checkpoint completed at step 1075000
04:46:59:WU00:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
04:47:59:WU00:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
04:48:00:WU00:FS01:0x22:Checkpoint completed at step 1100000
04:49:01:WU00:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
04:50:01:WU00:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
04:50:02:WU00:FS01:0x22:Checkpoint completed at step 1125000
04:51:02:WU00:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
04:52:03:WU00:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
04:52:04:WU00:FS01:0x22:Checkpoint completed at step 1150000
04:53:04:WU00:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
04:54:05:WU00:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
04:54:06:WU00:FS01:0x22:Checkpoint completed at step 1175000
04:55:06:WU00:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
04:56:06:WU00:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
04:56:08:WU00:FS01:0x22:Checkpoint completed at step 1200000
04:57:08:WU00:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
04:58:09:WU00:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
04:58:10:WU00:FS01:0x22:Checkpoint completed at step 1225000
04:59:10:WU00:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
05:00:10:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
05:00:10:WU00:FS01:0x22:Average performance: 28.562 ns/day
05:00:11:WU01:FS01:Connecting to assign1.foldingathome.org:80
05:00:11:WU01:FS01:Assigned to work server 207.53.233.146
05:00:11:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 207.53.233.146
05:00:11:WU01:FS01:Connecting to 207.53.233.146:8080
05:00:11:WU01:FS01:Downloading 6.15MiB
05:00:11:WU00:FS01:0x22:Checkpoint completed at step 1250000
05:00:12:WU01:FS01:Download complete
05:00:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17804 run:75 clone:91 gen:440 core:0x22 unit:0x0000005b000001b80000458c0000004b
05:00:16:WU00:FS01:0x22:Saving result file ../logfile_01.txt
05:00:16:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
05:00:16:WU00:FS01:0x22:Saving result file checkpointState.xml
05:00:20:WU00:FS01:0x22:Saving result file positions.xtc
05:00:20:WU00:FS01:0x22:Saving result file science.log
05:00:20:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
05:00:20:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:00:20:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18201 run:36299 clone:0 gen:14 core:0x22 unit:0x000000000000000e0000471900008dcb
05:00:20:WU00:FS01:Uploading 27.49MiB to 128.252.203.11
05:00:20:WU00:FS01:Connecting to 128.252.203.11:8080
05:00:20:WU01:FS01:Starting
05:00:20:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
05:00:20:WU01:FS01:Started FahCore on PID 4037
05:00:20:WU01:FS01:Core PID:4041
05:00:20:WU01:FS01:FahCore 0x22 started
05:00:21:WU01:FS01:0x22:*********************** Log Started 2021-11-11T05:00:20Z ***********************
05:00:21:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
05:00:21:WU01:FS01:0x22: Core: Core22
05:00:21:WU01:FS01:0x22: Type: 0x22
05:00:21:WU01:FS01:0x22: Version: 0.0.13
05:00:21:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
05:00:21:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
05:00:21:WU01:FS01:0x22: Homepage: https://foldingathome.org/
05:00:21:WU01:FS01:0x22: Date: Sep 19 2020
05:00:21:WU01:FS01:0x22: Time: 01:10:35
05:00:21:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
05:00:21:WU01:FS01:0x22: Branch: core22-0.0.13
05:00:21:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
05:00:21:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
05:00:21:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
05:00:21:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
05:00:21:WU01:FS01:0x22: Bits: 64
05:00:21:WU01:FS01:0x22: Mode: Release
05:00:21:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
05:00:21:WU01:FS01:0x22: <[email protected]>
05:00:21:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 4037 -checkpoint 15
05:00:21:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
05:00:21:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
05:00:21:WU01:FS01:0x22:************************************ libFAH ************************************
05:00:21:WU01:FS01:0x22: Date: Sep 15 2020
05:00:21:WU01:FS01:0x22: Time: 05:14:43
05:00:21:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
05:00:21:WU01:FS01:0x22: Branch: HEAD
05:00:21:WU01:FS01:0x22:************************************ CBang *************************************
05:00:21:WU01:FS01:0x22: Time: 05:11:04
05:00:21:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
05:00:21:WU01:FS01:0x22: -funroll-loops -fPIC
05:00:21:WU01:FS01:0x22:************************************ System ************************************
05:00:21:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
05:00:21:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
05:00:21:WU01:FS01:0x22: CPUs: 8
05:00:21:WU01:FS01:0x22: Memory: 15.58GiB
05:00:21:WU01:FS01:0x22:Free Memory: 12.77GiB
05:00:21:WU01:FS01:0x22: Threads: POSIX_THREADS
05:00:21:WU01:FS01:0x22: OS Version: 5.11
05:00:21:WU01:FS01:0x22:Has Battery: false
05:00:21:WU01:FS01:0x22: On Battery: false
05:00:21:WU01:FS01:0x22: UTC Offset: -5
05:00:21:WU01:FS01:0x22: PID: 4041
05:00:21:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
05:00:21:WU01:FS01:0x22:************************************ OpenMM ************************************
05:00:21:WU01:FS01:0x22: Revision: 189320d0
05:00:21:WU01:FS01:0x22:********************************************************************************
05:00:21:WU01:FS01:0x22:Project: 17804 (Run 75, Clone 91, Gen 440)
05:00:21:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
05:00:21:WU01:FS01:0x22:Reading tar file core.xml
05:00:21:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
05:00:21:WU01:FS01:0x22:Reading tar file state.xml.bz2
05:00:21:WU01:FS01:0x22:Reading tar file system.xml.bz2
05:00:21:WU01:FS01:0x22:Digital signatures verified
05:00:21:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
05:00:21:WU01:FS01:0x22:Version 0.0.13
05:00:21:WU01:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
05:00:21:WU01:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
05:00:21:WU01:FS01:0x22: XTC frame write interval: 25000 steps (1%) [100 total]
05:00:21:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
05:00:21:WU01:FS01:0x22:There are 4 platforms available.
05:00:21:WU01:FS01:0x22:Platform 0: Reference
05:00:21:WU01:FS01:0x22:Platform 1: CPU
05:00:21:WU01:FS01:0x22:Platform 2: OpenCL
05:00:21:WU01:FS01:0x22: opencl-device 0 specified
05:00:21:WU01:FS01:0x22:Platform 3: CUDA
05:00:21:WU01:FS01:0x22: cuda-device 0 specified
05:00:24:WU01:FS01:0x22:Attempting to create CUDA context:
05:00:24:WU01:FS01:0x22: Configuring platform CUDA
05:00:26:WU00:FS01:Upload 35.24%
05:00:32:WU00:FS01:Upload 74.57%
05:00:38:WU00:FS01:Upload complete
05:00:38:WU00:FS01:Server responded WORK_ACK (400)
05:00:38:WU00:FS01:Final credit estimate, 488217.00 points
05:00:38:WU00:FS01:Cleaning up
05:01:54:WU01:FS01:0x22: Using CUDA and gpu 0
05:01:54:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
05:01:54:WU01:FS01:0x22:Checkpoint completed at step 0
05:02:32:WU01:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
05:03:10:WU01:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
05:03:48:WU01:FS01:0x22:Completed 75000 out of 2500000 steps (3%)
05:04:27:WU01:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
05:05:05:WU01:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
05:05:05:WU01:FS01:0x22:Checkpoint completed at step 125000
05:05:43:WU01:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
05:06:21:WU01:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
05:06:59:WU01:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
05:07:37:WU01:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
05:08:15:WU01:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
05:08:16:WU01:FS01:0x22:Checkpoint completed at step 250000
05:08:54:WU01:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
05:09:32:WU01:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
05:10:10:WU01:FS01:0x22:Completed 325000 out of 2500000 steps (13%)
05:10:48:WU01:FS01:0x22:Completed 350000 out of 2500000 steps (14%)
05:11:26:WU01:FS01:0x22:Completed 375000 out of 2500000 steps (15%)
05:11:26:WU01:FS01:0x22:Checkpoint completed at step 375000
05:12:04:WU01:FS01:0x22:Completed 400000 out of 2500000 steps (16%)
05:12:42:WU01:FS01:0x22:Completed 425000 out of 2500000 steps (17%)
05:13:20:WU01:FS01:0x22:Completed 450000 out of 2500000 steps (18%)
05:13:58:WU01:FS01:0x22:Completed 475000 out of 2500000 steps (19%)
05:14:36:WU01:FS01:0x22:Completed 500000 out of 2500000 steps (20%)
05:14:37:WU01:FS01:0x22:Checkpoint completed at step 500000
05:15:15:WU01:FS01:0x22:Completed 525000 out of 2500000 steps (21%)
05:15:53:WU01:FS01:0x22:Completed 550000 out of 2500000 steps (22%)
05:16:31:WU01:FS01:0x22:Completed 575000 out of 2500000 steps (23%)
05:17:09:WU01:FS01:0x22:Completed 600000 out of 2500000 steps (24%)
05:17:47:WU01:FS01:0x22:Completed 625000 out of 2500000 steps (25%)
05:17:47:WU01:FS01:0x22:Checkpoint completed at step 625000
05:18:26:WU01:FS01:0x22:Completed 650000 out of 2500000 steps (26%)
05:19:04:WU01:FS01:0x22:Completed 675000 out of 2500000 steps (27%)
05:19:42:WU01:FS01:0x22:Completed 700000 out of 2500000 steps (28%)
05:20:20:WU01:FS01:0x22:Completed 725000 out of 2500000 steps (29%)
05:20:58:WU01:FS01:0x22:Completed 750000 out of 2500000 steps (30%)
05:20:58:WU01:FS01:0x22:Checkpoint completed at step 750000
05:21:36:WU01:FS01:0x22:Completed 775000 out of 2500000 steps (31%)
05:22:14:WU01:FS01:0x22:Completed 800000 out of 2500000 steps (32%)
05:22:52:WU01:FS01:0x22:Completed 825000 out of 2500000 steps (33%)
05:23:30:WU01:FS01:0x22:Completed 850000 out of 2500000 steps (34%)
05:24:08:WU01:FS01:0x22:Completed 875000 out of 2500000 steps (35%)
05:24:08:WU01:FS01:0x22:Checkpoint completed at step 875000
05:24:47:WU01:FS01:0x22:Completed 900000 out of 2500000 steps (36%)
05:25:25:WU01:FS01:0x22:Completed 925000 out of 2500000 steps (37%)
05:26:03:WU01:FS01:0x22:Completed 950000 out of 2500000 steps (38%)
05:26:41:WU01:FS01:0x22:Completed 975000 out of 2500000 steps (39%)
05:27:19:WU01:FS01:0x22:Completed 1000000 out of 2500000 steps (40%)
05:27:19:WU01:FS01:0x22:Checkpoint completed at step 1000000
05:27:57:WU01:FS01:0x22:Completed 1025000 out of 2500000 steps (41%)
05:28:35:WU01:FS01:0x22:Completed 1050000 out of 2500000 steps (42%)
05:29:13:WU01:FS01:0x22:Completed 1075000 out of 2500000 steps (43%)
05:29:51:WU01:FS01:0x22:Completed 1100000 out of 2500000 steps (44%)
05:30:29:WU01:FS01:0x22:Completed 1125000 out of 2500000 steps (45%)
05:30:30:WU01:FS01:0x22:Checkpoint completed at step 1125000
05:31:08:WU01:FS01:0x22:Completed 1150000 out of 2500000 steps (46%)
05:31:46:WU01:FS01:0x22:Completed 1175000 out of 2500000 steps (47%)
05:32:24:WU01:FS01:0x22:Completed 1200000 out of 2500000 steps (48%)
05:33:02:WU01:FS01:0x22:Completed 1225000 out of 2500000 steps (49%)
05:33:40:WU01:FS01:0x22:Completed 1250000 out of 2500000 steps (50%)
05:33:40:WU01:FS01:0x22:Checkpoint completed at step 1250000
05:34:18:WU01:FS01:0x22:Completed 1275000 out of 2500000 steps (51%)
05:34:56:WU01:FS01:0x22:Completed 1300000 out of 2500000 steps (52%)
05:35:34:WU01:FS01:0x22:Completed 1325000 out of 2500000 steps (53%)
05:36:13:WU01:FS01:0x22:Completed 1350000 out of 2500000 steps (54%)
05:36:51:WU01:FS01:0x22:Completed 1375000 out of 2500000 steps (55%)
05:36:51:WU01:FS01:0x22:Checkpoint completed at step 1375000
05:37:29:WU01:FS01:0x22:Completed 1400000 out of 2500000 steps (56%)
05:38:07:WU01:FS01:0x22:Completed 1425000 out of 2500000 steps (57%)
05:38:45:WU01:FS01:0x22:Completed 1450000 out of 2500000 steps (58%)
05:39:23:WU01:FS01:0x22:Completed 1475000 out of 2500000 steps (59%)
05:40:01:WU01:FS01:0x22:Completed 1500000 out of 2500000 steps (60%)
05:40:01:WU01:FS01:0x22:Checkpoint completed at step 1500000
05:40:40:WU01:FS01:0x22:Completed 1525000 out of 2500000 steps (61%)
05:41:18:WU01:FS01:0x22:Completed 1550000 out of 2500000 steps (62%)
05:41:56:WU01:FS01:0x22:Completed 1575000 out of 2500000 steps (63%)
05:42:34:WU01:FS01:0x22:Completed 1600000 out of 2500000 steps (64%)
05:43:12:WU01:FS01:0x22:Completed 1625000 out of 2500000 steps (65%)
05:43:12:WU01:FS01:0x22:Checkpoint completed at step 1625000
05:43:50:WU01:FS01:0x22:Completed 1650000 out of 2500000 steps (66%)
05:44:28:WU01:FS01:0x22:Completed 1675000 out of 2500000 steps (67%)
05:45:06:WU01:FS01:0x22:Completed 1700000 out of 2500000 steps (68%)
05:45:44:WU01:FS01:0x22:Completed 1725000 out of 2500000 steps (69%)
05:46:23:WU01:FS01:0x22:Completed 1750000 out of 2500000 steps (70%)
05:46:23:WU01:FS01:0x22:Checkpoint completed at step 1750000
05:47:01:WU01:FS01:0x22:Completed 1775000 out of 2500000 steps (71%)
05:47:39:WU01:FS01:0x22:Completed 1800000 out of 2500000 steps (72%)
05:48:17:WU01:FS01:0x22:Completed 1825000 out of 2500000 steps (73%)
05:48:55:WU01:FS01:0x22:Completed 1850000 out of 2500000 steps (74%)
05:49:33:WU01:FS01:0x22:Completed 1875000 out of 2500000 steps (75%)
05:49:33:WU01:FS01:0x22:Checkpoint completed at step 1875000
05:50:12:WU01:FS01:0x22:Completed 1900000 out of 2500000 steps (76%)
05:50:50:WU01:FS01:0x22:Completed 1925000 out of 2500000 steps (77%)
05:51:28:WU01:FS01:0x22:Completed 1950000 out of 2500000 steps (78%)
05:52:06:WU01:FS01:0x22:Completed 1975000 out of 2500000 steps (79%)
05:52:44:WU01:FS01:0x22:Completed 2000000 out of 2500000 steps (80%)
05:52:44:WU01:FS01:0x22:Checkpoint completed at step 2000000
05:53:22:WU01:FS01:0x22:Completed 2025000 out of 2500000 steps (81%)
05:54:00:WU01:FS01:0x22:Completed 2050000 out of 2500000 steps (82%)
05:54:38:WU01:FS01:0x22:Completed 2075000 out of 2500000 steps (83%)
05:55:16:WU01:FS01:0x22:Completed 2100000 out of 2500000 steps (84%)
05:55:54:WU01:FS01:0x22:Completed 2125000 out of 2500000 steps (85%)
05:55:55:WU01:FS01:0x22:Checkpoint completed at step 2125000
05:56:33:WU01:FS01:0x22:Completed 2150000 out of 2500000 steps (86%)
05:57:11:WU01:FS01:0x22:Completed 2175000 out of 2500000 steps (87%)
05:57:49:WU01:FS01:0x22:Completed 2200000 out of 2500000 steps (88%)
05:58:27:WU01:FS01:0x22:Completed 2225000 out of 2500000 steps (89%)
05:59:05:WU01:FS01:0x22:Completed 2250000 out of 2500000 steps (90%)
05:59:05:WU01:FS01:0x22:Checkpoint completed at step 2250000
05:59:44:WU01:FS01:0x22:Completed 2275000 out of 2500000 steps (91%)
06:00:22:WU01:FS01:0x22:Completed 2300000 out of 2500000 steps (92%)
06:01:00:WU01:FS01:0x22:Completed 2325000 out of 2500000 steps (93%)
06:01:38:WU01:FS01:0x22:Completed 2350000 out of 2500000 steps (94%)
06:02:16:WU01:FS01:0x22:Completed 2375000 out of 2500000 steps (95%)
06:02:16:WU01:FS01:0x22:Checkpoint completed at step 2375000
06:02:54:WU01:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
06:03:32:WU01:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
06:04:10:WU01:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
06:04:48:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
06:05:26:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
06:05:26:WU01:FS01:0x22:Average performance: 45.4737 ns/day
06:05:27:WU01:FS01:0x22:Checkpoint completed at step 2500000
06:05:27:WU00:FS01:Connecting to assign1.foldingathome.org:80
06:05:27:WU00:FS01:Assigned to work server 207.53.233.146
06:05:27:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 207.53.233.146
06:05:27:WU00:FS01:Connecting to 207.53.233.146:8080
06:05:27:WU00:FS01:Downloading 6.14MiB
06:05:28:WU00:FS01:Download complete
06:05:28:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17804 run:33 clone:10 gen:600 core:0x22 unit:0x0000000a000002580000458c00000021
06:05:33:WU01:FS01:0x22:Saving result file ../logfile_01.txt
06:05:33:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
06:05:33:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
06:05:33:WU01:FS01:0x22:Saving result file positions.xtc
06:05:33:WU01:FS01:0x22:Saving result file science.log
06:05:33:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
06:05:33:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:05:33:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:75 clone:91 gen:440 core:0x22 unit:0x0000005b000001b80000458c0000004b
06:05:33:WU01:FS01:Uploading 8.60MiB to 207.53.233.146
06:05:33:WU01:FS01:Connecting to 207.53.233.146:8080
06:05:33:WU00:FS01:Starting
06:05:33:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
06:05:33:WU00:FS01:Started FahCore on PID 4165
06:05:33:WU00:FS01:Core PID:4169
06:05:33:WU00:FS01:FahCore 0x22 started
06:05:34:WU00:FS01:0x22:*********************** Log Started 2021-11-11T06:05:33Z ***********************
06:05:34:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
06:05:34:WU00:FS01:0x22: Core: Core22
06:05:34:WU00:FS01:0x22: Type: 0x22
06:05:34:WU00:FS01:0x22: Version: 0.0.13
06:05:34:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
06:05:34:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
06:05:34:WU00:FS01:0x22: Homepage: https://foldingathome.org/
06:05:34:WU00:FS01:0x22: Date: Sep 19 2020
06:05:34:WU00:FS01:0x22: Time: 01:10:35
06:05:34:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
06:05:34:WU00:FS01:0x22: Branch: core22-0.0.13
06:05:34:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
06:05:34:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
06:05:34:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
06:05:34:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
06:05:34:WU00:FS01:0x22: Bits: 64
06:05:34:WU00:FS01:0x22: Mode: Release
06:05:34:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
06:05:34:WU00:FS01:0x22: <[email protected]>
06:05:34:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4165 -checkpoint 15
06:05:34:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
06:05:34:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
06:05:34:WU00:FS01:0x22:************************************ libFAH ************************************
06:05:34:WU00:FS01:0x22: Date: Sep 15 2020
06:05:34:WU00:FS01:0x22: Time: 05:14:43
06:05:34:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
06:05:34:WU00:FS01:0x22: Branch: HEAD
06:05:34:WU00:FS01:0x22:************************************ CBang *************************************
06:05:34:WU00:FS01:0x22: Time: 05:11:04
06:05:34:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
06:05:34:WU00:FS01:0x22: -funroll-loops -fPIC
06:05:34:WU00:FS01:0x22:************************************ System ************************************
06:05:34:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
06:05:34:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
06:05:34:WU00:FS01:0x22: CPUs: 8
06:05:34:WU00:FS01:0x22: Memory: 15.58GiB
06:05:34:WU00:FS01:0x22:Free Memory: 12.79GiB
06:05:34:WU00:FS01:0x22: Threads: POSIX_THREADS
06:05:34:WU00:FS01:0x22: OS Version: 5.11
06:05:34:WU00:FS01:0x22:Has Battery: false
06:05:34:WU00:FS01:0x22: On Battery: false
06:05:34:WU00:FS01:0x22: UTC Offset: -5
06:05:34:WU00:FS01:0x22: PID: 4169
06:05:34:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
06:05:34:WU00:FS01:0x22:************************************ OpenMM ************************************
06:05:34:WU00:FS01:0x22: Revision: 189320d0
06:05:34:WU00:FS01:0x22:********************************************************************************
06:05:34:WU00:FS01:0x22:Project: 17804 (Run 33, Clone 10, Gen 600)
06:05:34:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
06:05:34:WU00:FS01:0x22:Reading tar file core.xml
06:05:34:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
06:05:34:WU00:FS01:0x22:Reading tar file state.xml.bz2
06:05:34:WU00:FS01:0x22:Reading tar file system.xml.bz2
06:05:34:WU00:FS01:0x22:Digital signatures verified
06:05:34:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
06:05:34:WU00:FS01:0x22:Version 0.0.13
06:05:34:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
06:05:34:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
06:05:34:WU00:FS01:0x22: XTC frame write interval: 25000 steps (1%) [100 total]
06:05:34:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
06:05:34:WU00:FS01:0x22:There are 4 platforms available.
06:05:34:WU00:FS01:0x22:Platform 0: Reference
06:05:34:WU00:FS01:0x22:Platform 1: CPU
06:05:34:WU00:FS01:0x22:Platform 2: OpenCL
06:05:34:WU00:FS01:0x22: opencl-device 0 specified
06:05:34:WU00:FS01:0x22:Platform 3: CUDA
06:05:34:WU00:FS01:0x22: cuda-device 0 specified
06:05:36:WU01:FS01:Upload complete
06:05:36:WU01:FS01:Server responded WORK_ACK (400)
06:05:36:WU01:FS01:Final credit estimate, 228154.00 points
06:05:36:WU01:FS01:Cleaning up
06:05:37:WU00:FS01:0x22:Attempting to create CUDA context:
06:05:37:WU00:FS01:0x22: Configuring platform CUDA
06:07:07:WU00:FS01:0x22: Using CUDA and gpu 0
06:07:07:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
06:07:07:WU00:FS01:0x22:Checkpoint completed at step 0
******************************* Date: 2021-11-11 *******************************
06:07:45:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
06:08:23:WU00:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
06:09:01:WU00:FS01:0x22:Completed 75000 out of 2500000 steps (3%)
06:09:39:WU00:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
06:10:17:WU00:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
06:10:18:WU00:FS01:0x22:Checkpoint completed at step 125000
06:10:56:WU00:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
06:11:33:WU00:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
06:12:11:WU00:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
06:12:49:WU00:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
06:13:27:WU00:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
06:13:27:WU00:FS01:0x22:Checkpoint completed at step 250000
06:14:05:WU00:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
06:14:43:WU00:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
06:15:21:WU00:FS01:0x22:Completed 325000 out of 2500000 steps (13%)
06:15:59:WU00:FS01:0x22:Completed 350000 out of 2500000 steps (14%)
06:16:37:WU00:FS01:0x22:Completed 375000 out of 2500000 steps (15%)
06:16:37:WU00:FS01:0x22:Checkpoint completed at step 375000
06:17:15:WU00:FS01:0x22:Completed 400000 out of 2500000 steps (16%)
06:17:53:WU00:FS01:0x22:Completed 425000 out of 2500000 steps (17%)
06:18:31:WU00:FS01:0x22:Completed 450000 out of 2500000 steps (18%)
06:19:09:WU00:FS01:0x22:Completed 475000 out of 2500000 steps (19%)
06:19:47:WU00:FS01:0x22:Completed 500000 out of 2500000 steps (20%)
06:19:47:WU00:FS01:0x22:Checkpoint completed at step 500000
06:20:25:WU00:FS01:0x22:Completed 525000 out of 2500000 steps (21%)
06:21:03:WU00:FS01:0x22:Completed 550000 out of 2500000 steps (22%)
06:21:41:WU00:FS01:0x22:Completed 575000 out of 2500000 steps (23%)
06:22:19:WU00:FS01:0x22:Completed 600000 out of 2500000 steps (24%)
06:22:57:WU00:FS01:0x22:Completed 625000 out of 2500000 steps (25%)
06:22:57:WU00:FS01:0x22:Checkpoint completed at step 625000
06:23:35:WU00:FS01:0x22:Completed 650000 out of 2500000 steps (26%)
06:24:13:WU00:FS01:0x22:Completed 675000 out of 2500000 steps (27%)
06:24:51:WU00:FS01:0x22:Completed 700000 out of 2500000 steps (28%)
06:25:29:WU00:FS01:0x22:Completed 725000 out of 2500000 steps (29%)
06:26:07:WU00:FS01:0x22:Completed 750000 out of 2500000 steps (30%)
06:26:07:WU00:FS01:0x22:Checkpoint completed at step 750000
06:26:45:WU00:FS01:0x22:Completed 775000 out of 2500000 steps (31%)
06:27:23:WU00:FS01:0x22:Completed 800000 out of 2500000 steps (32%)
06:28:01:WU00:FS01:0x22:Completed 825000 out of 2500000 steps (33%)
06:28:39:WU00:FS01:0x22:Completed 850000 out of 2500000 steps (34%)
06:29:17:WU00:FS01:0x22:Completed 875000 out of 2500000 steps (35%)
06:29:17:WU00:FS01:0x22:Checkpoint completed at step 875000
06:29:55:WU00:FS01:0x22:Completed 900000 out of 2500000 steps (36%)
06:30:33:WU00:FS01:0x22:Completed 925000 out of 2500000 steps (37%)
06:31:11:WU00:FS01:0x22:Completed 950000 out of 2500000 steps (38%)
06:31:49:WU00:FS01:0x22:Completed 975000 out of 2500000 steps (39%)
06:32:27:WU00:FS01:0x22:Completed 1000000 out of 2500000 steps (40%)
06:32:27:WU00:FS01:0x22:Checkpoint completed at step 1000000
06:33:05:WU00:FS01:0x22:Completed 1025000 out of 2500000 steps (41%)
06:33:43:WU00:FS01:0x22:Completed 1050000 out of 2500000 steps (42%)
06:34:21:WU00:FS01:0x22:Completed 1075000 out of 2500000 steps (43%)
06:34:59:WU00:FS01:0x22:Completed 1100000 out of 2500000 steps (44%)
06:35:37:WU00:FS01:0x22:Completed 1125000 out of 2500000 steps (45%)
06:35:37:WU00:FS01:0x22:Checkpoint completed at step 1125000
06:36:15:WU00:FS01:0x22:Completed 1150000 out of 2500000 steps (46%)
06:36:53:WU00:FS01:0x22:Completed 1175000 out of 2500000 steps (47%)
06:37:31:WU00:FS01:0x22:Completed 1200000 out of 2500000 steps (48%)
06:38:09:WU00:FS01:0x22:Completed 1225000 out of 2500000 steps (49%)
06:38:47:WU00:FS01:0x22:Completed 1250000 out of 2500000 steps (50%)
06:38:47:WU00:FS01:0x22:Checkpoint completed at step 1250000
06:39:25:WU00:FS01:0x22:Completed 1275000 out of 2500000 steps (51%)
06:40:03:WU00:FS01:0x22:Completed 1300000 out of 2500000 steps (52%)
06:40:41:WU00:FS01:0x22:Completed 1325000 out of 2500000 steps (53%)
06:41:19:WU00:FS01:0x22:Completed 1350000 out of 2500000 steps (54%)
06:41:57:WU00:FS01:0x22:Completed 1375000 out of 2500000 steps (55%)
06:41:57:WU00:FS01:0x22:Checkpoint completed at step 1375000
06:42:35:WU00:FS01:0x22:Completed 1400000 out of 2500000 steps (56%)
06:43:13:WU00:FS01:0x22:Completed 1425000 out of 2500000 steps (57%)
06:43:51:WU00:FS01:0x22:Completed 1450000 out of 2500000 steps (58%)
06:44:29:WU00:FS01:0x22:Completed 1475000 out of 2500000 steps (59%)
06:45:07:WU00:FS01:0x22:Completed 1500000 out of 2500000 steps (60%)
06:45:07:WU00:FS01:0x22:Checkpoint completed at step 1500000
06:45:45:WU00:FS01:0x22:Completed 1525000 out of 2500000 steps (61%)
06:46:23:WU00:FS01:0x22:Completed 1550000 out of 2500000 steps (62%)
06:47:01:WU00:FS01:0x22:Completed 1575000 out of 2500000 steps (63%)
06:47:39:WU00:FS01:0x22:Completed 1600000 out of 2500000 steps (64%)
06:48:17:WU00:FS01:0x22:Completed 1625000 out of 2500000 steps (65%)
06:48:17:WU00:FS01:0x22:Checkpoint completed at step 1625000
06:48:56:WU00:FS01:0x22:Completed 1650000 out of 2500000 steps (66%)
06:49:33:WU00:FS01:0x22:Completed 1675000 out of 2500000 steps (67%)
06:50:11:WU00:FS01:0x22:Completed 1700000 out of 2500000 steps (68%)
06:50:49:WU00:FS01:0x22:Completed 1725000 out of 2500000 steps (69%)
06:51:27:WU00:FS01:0x22:Completed 1750000 out of 2500000 steps (70%)
06:51:27:WU00:FS01:0x22:Checkpoint completed at step 1750000
06:52:05:WU00:FS01:0x22:Completed 1775000 out of 2500000 steps (71%)
06:52:43:WU00:FS01:0x22:Completed 1800000 out of 2500000 steps (72%)
06:53:21:WU00:FS01:0x22:Completed 1825000 out of 2500000 steps (73%)
06:53:59:WU00:FS01:0x22:Completed 1850000 out of 2500000 steps (74%)
06:54:37:WU00:FS01:0x22:Completed 1875000 out of 2500000 steps (75%)
06:54:37:WU00:FS01:0x22:Checkpoint completed at step 1875000
06:55:15:WU00:FS01:0x22:Completed 1900000 out of 2500000 steps (76%)
06:55:53:WU00:FS01:0x22:Completed 1925000 out of 2500000 steps (77%)
06:56:31:WU00:FS01:0x22:Completed 1950000 out of 2500000 steps (78%)
06:57:09:WU00:FS01:0x22:Completed 1975000 out of 2500000 steps (79%)
06:57:47:WU00:FS01:0x22:Completed 2000000 out of 2500000 steps (80%)
06:57:47:WU00:FS01:0x22:Checkpoint completed at step 2000000
06:58:25:WU00:FS01:0x22:Completed 2025000 out of 2500000 steps (81%)
06:59:03:WU00:FS01:0x22:Completed 2050000 out of 2500000 steps (82%)
06:59:41:WU00:FS01:0x22:Completed 2075000 out of 2500000 steps (83%)
07:00:19:WU00:FS01:0x22:Completed 2100000 out of 2500000 steps (84%)
07:00:57:WU00:FS01:0x22:Completed 2125000 out of 2500000 steps (85%)
07:00:57:WU00:FS01:0x22:Checkpoint completed at step 2125000
07:01:35:WU00:FS01:0x22:Completed 2150000 out of 2500000 steps (86%)
07:02:13:WU00:FS01:0x22:Completed 2175000 out of 2500000 steps (87%)
07:02:51:WU00:FS01:0x22:Completed 2200000 out of 2500000 steps (88%)
07:03:29:WU00:FS01:0x22:Completed 2225000 out of 2500000 steps (89%)
07:04:07:WU00:FS01:0x22:Completed 2250000 out of 2500000 steps (90%)
07:04:07:WU00:FS01:0x22:Checkpoint completed at step 2250000
07:04:45:WU00:FS01:0x22:Completed 2275000 out of 2500000 steps (91%)
07:05:23:WU00:FS01:0x22:Completed 2300000 out of 2500000 steps (92%)
07:06:01:WU00:FS01:0x22:Completed 2325000 out of 2500000 steps (93%)
07:06:39:WU00:FS01:0x22:Completed 2350000 out of 2500000 steps (94%)
07:07:17:WU00:FS01:0x22:Completed 2375000 out of 2500000 steps (95%)
07:07:17:WU00:FS01:0x22:Checkpoint completed at step 2375000
07:07:55:WU00:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
07:08:33:WU00:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
07:09:11:WU00:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
07:09:49:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
07:10:27:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
07:10:27:WU00:FS01:0x22:Average performance: 45.4737 ns/day
07:10:27:WU00:FS01:0x22:Checkpoint completed at step 2500000
07:10:28:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:10:28:WU01:FS01:Assigned to work server 129.32.209.202
07:10:28:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
07:10:28:WU01:FS01:Connecting to 129.32.209.202:8080
07:10:28:WU01:FS01:Downloading 27.78MiB
07:10:31:WU01:FS01:Download complete
07:10:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:2 clone:423 gen:81 core:0x22 unit:0x000001a700000051000047ff00000002
07:10:33:WU00:FS01:0x22:Saving result file ../logfile_01.txt
07:10:33:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
07:10:33:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
07:10:33:WU00:FS01:0x22:Saving result file positions.xtc
07:10:33:WU00:FS01:0x22:Saving result file science.log
07:10:33:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
07:10:34:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:10:34:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17804 run:33 clone:10 gen:600 core:0x22 unit:0x0000000a000002580000458c00000021
07:10:34:WU00:FS01:Uploading 8.57MiB to 207.53.233.146
07:10:34:WU00:FS01:Connecting to 207.53.233.146:8080
07:10:34:WU01:FS01:Starting
07:10:34:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
07:10:34:WU01:FS01:Started FahCore on PID 4320
07:10:34:WU01:FS01:Core PID:4324
07:10:34:WU01:FS01:FahCore 0x22 started
07:10:34:WU01:FS01:0x22:*********************** Log Started 2021-11-11T07:10:34Z ***********************
07:10:34:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
07:10:34:WU01:FS01:0x22: Core: Core22
07:10:34:WU01:FS01:0x22: Type: 0x22
07:10:34:WU01:FS01:0x22: Version: 0.0.13
07:10:34:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
07:10:34:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
07:10:34:WU01:FS01:0x22: Homepage: https://foldingathome.org/
07:10:34:WU01:FS01:0x22: Date: Sep 19 2020
07:10:34:WU01:FS01:0x22: Time: 01:10:35
07:10:34:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
07:10:34:WU01:FS01:0x22: Branch: core22-0.0.13
07:10:34:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
07:10:34:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
07:10:34:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
07:10:34:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
07:10:34:WU01:FS01:0x22: Bits: 64
07:10:34:WU01:FS01:0x22: Mode: Release
07:10:34:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
07:10:34:WU01:FS01:0x22: <[email protected]>
07:10:34:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 4320 -checkpoint 15
07:10:34:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
07:10:34:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
07:10:34:WU01:FS01:0x22:************************************ libFAH ************************************
07:10:34:WU01:FS01:0x22: Date: Sep 15 2020
07:10:34:WU01:FS01:0x22: Time: 05:14:43
07:10:34:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
07:10:34:WU01:FS01:0x22: Branch: HEAD
07:10:34:WU01:FS01:0x22:************************************ CBang *************************************
07:10:34:WU01:FS01:0x22: Time: 05:11:04
07:10:34:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
07:10:34:WU01:FS01:0x22: -funroll-loops -fPIC
07:10:34:WU01:FS01:0x22:************************************ System ************************************
07:10:34:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
07:10:34:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
07:10:34:WU01:FS01:0x22: CPUs: 8
07:10:34:WU01:FS01:0x22: Memory: 15.58GiB
07:10:34:WU01:FS01:0x22:Free Memory: 12.75GiB
07:10:34:WU01:FS01:0x22: Threads: POSIX_THREADS
07:10:34:WU01:FS01:0x22: OS Version: 5.11
07:10:34:WU01:FS01:0x22:Has Battery: false
07:10:34:WU01:FS01:0x22: On Battery: false
07:10:34:WU01:FS01:0x22: UTC Offset: -5
07:10:34:WU01:FS01:0x22: PID: 4324
07:10:34:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
07:10:34:WU01:FS01:0x22:************************************ OpenMM ************************************
07:10:34:WU01:FS01:0x22: Revision: 189320d0
07:10:34:WU01:FS01:0x22:********************************************************************************
07:10:34:WU01:FS01:0x22:Project: 18431 (Run 2, Clone 423, Gen 81)
07:10:34:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
07:10:34:WU01:FS01:0x22:Reading tar file core.xml
07:10:34:WU01:FS01:0x22:Reading tar file integrator.xml
07:10:34:WU01:FS01:0x22:Reading tar file state.xml
07:10:34:WU01:FS01:0x22:Reading tar file system.xml
07:10:34:WU01:FS01:0x22:Digital signatures verified
07:10:34:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
07:10:34:WU01:FS01:0x22:Version 0.0.13
07:10:34:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
07:10:34:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
07:10:34:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
07:10:34:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
07:10:34:WU01:FS01:0x22:There are 4 platforms available.
07:10:34:WU01:FS01:0x22:Platform 0: Reference
07:10:34:WU01:FS01:0x22:Platform 1: CPU
07:10:34:WU01:FS01:0x22:Platform 2: OpenCL
07:10:34:WU01:FS01:0x22: opencl-device 0 specified
07:10:34:WU01:FS01:0x22:Platform 3: CUDA
07:10:34:WU01:FS01:0x22: cuda-device 0 specified
07:10:35:WU00:FS01:Upload complete
07:10:35:WU00:FS01:Server responded WORK_ACK (400)
07:10:35:WU00:FS01:Final credit estimate, 228620.00 points
07:10:35:WU00:FS01:Cleaning up
07:10:36:WU01:FS01:0x22:Attempting to create CUDA context:
07:10:36:WU01:FS01:0x22: Configuring platform CUDA
07:12:04:WU01:FS01:0x22: Using CUDA and gpu 0
07:12:04:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
07:12:04:WU01:FS01:0x22:Checkpoint completed at step 0
07:12:47:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
07:13:29:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
07:13:29:WU01:FS01:0x22:Checkpoint completed at step 100000
07:14:11:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
07:14:53:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
07:14:54:WU01:FS01:0x22:Checkpoint completed at step 200000
07:15:36:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
07:16:18:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
07:16:18:WU01:FS01:0x22:Checkpoint completed at step 300000
07:17:00:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
07:17:42:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
07:17:43:WU01:FS01:0x22:Checkpoint completed at step 400000
07:18:25:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
07:19:07:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
07:19:07:WU01:FS01:0x22:Checkpoint completed at step 500000
07:19:49:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
07:20:31:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
07:20:31:WU01:FS01:0x22:Checkpoint completed at step 600000
07:21:13:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
07:21:55:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
07:21:56:WU01:FS01:0x22:Checkpoint completed at step 700000
07:22:38:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
07:23:20:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
07:23:20:WU01:FS01:0x22:Checkpoint completed at step 800000
07:24:02:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
07:24:44:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
07:24:44:WU01:FS01:0x22:Checkpoint completed at step 900000
07:25:26:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
07:26:08:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
07:26:09:WU01:FS01:0x22:Checkpoint completed at step 1000000
07:26:51:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
07:27:33:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
07:27:33:WU01:FS01:0x22:Checkpoint completed at step 1100000
07:28:15:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
07:28:57:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
07:28:58:WU01:FS01:0x22:Checkpoint completed at step 1200000
07:29:40:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
07:30:22:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
07:30:22:WU01:FS01:0x22:Checkpoint completed at step 1300000
07:31:04:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
07:31:46:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
07:31:46:WU01:FS01:0x22:Checkpoint completed at step 1400000
07:32:28:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
07:33:10:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
07:33:10:WU01:FS01:0x22:Checkpoint completed at step 1500000
07:33:52:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
07:34:34:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
07:34:34:WU01:FS01:0x22:Checkpoint completed at step 1600000
07:35:17:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
07:35:59:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
07:35:59:WU01:FS01:0x22:Checkpoint completed at step 1700000
07:36:41:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
07:37:23:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
07:37:23:WU01:FS01:0x22:Checkpoint completed at step 1800000
07:38:05:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
07:38:47:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
07:38:47:WU01:FS01:0x22:Checkpoint completed at step 1900000
07:39:29:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
07:40:12:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
07:40:12:WU01:FS01:0x22:Checkpoint completed at step 2000000
07:40:54:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
07:41:36:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
07:41:36:WU01:FS01:0x22:Checkpoint completed at step 2100000
07:42:18:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
07:43:00:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
07:43:01:WU01:FS01:0x22:Checkpoint completed at step 2200000
07:43:43:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
07:44:25:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
07:44:25:WU01:FS01:0x22:Checkpoint completed at step 2300000
07:45:07:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
07:45:49:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
07:45:49:WU01:FS01:0x22:Checkpoint completed at step 2400000
07:46:31:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
07:47:13:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
07:47:13:WU01:FS01:0x22:Checkpoint completed at step 2500000
07:47:56:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
07:48:38:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
07:48:38:WU01:FS01:0x22:Checkpoint completed at step 2600000
07:49:20:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
07:50:02:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
07:50:02:WU01:FS01:0x22:Checkpoint completed at step 2700000
07:50:44:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
07:51:26:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
07:51:26:WU01:FS01:0x22:Checkpoint completed at step 2800000
07:52:08:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
07:52:50:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
07:52:50:WU01:FS01:0x22:Checkpoint completed at step 2900000
07:53:32:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
07:54:14:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
07:54:14:WU01:FS01:0x22:Checkpoint completed at step 3000000
07:54:56:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
07:55:38:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
07:55:39:WU01:FS01:0x22:Checkpoint completed at step 3100000
07:56:21:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
07:57:03:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
07:57:03:WU01:FS01:0x22:Checkpoint completed at step 3200000
07:57:45:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
07:58:27:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
07:58:27:WU01:FS01:0x22:Checkpoint completed at step 3300000
07:59:09:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
07:59:51:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
07:59:51:WU01:FS01:0x22:Checkpoint completed at step 3400000
08:00:33:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
08:01:15:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
08:01:15:WU01:FS01:0x22:Checkpoint completed at step 3500000
08:01:58:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
08:02:40:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
08:02:40:WU01:FS01:0x22:Checkpoint completed at step 3600000
08:03:22:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
08:04:04:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
08:04:04:WU01:FS01:0x22:Checkpoint completed at step 3700000
08:04:47:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
08:05:29:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
08:05:29:WU01:FS01:0x22:Checkpoint completed at step 3800000
08:06:11:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
08:06:53:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
08:06:53:WU01:FS01:0x22:Checkpoint completed at step 3900000
08:07:35:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
08:08:17:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
08:08:17:WU01:FS01:0x22:Checkpoint completed at step 4000000
08:08:59:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
08:09:41:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
08:09:41:WU01:FS01:0x22:Checkpoint completed at step 4100000
08:10:24:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
08:11:06:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
08:11:06:WU01:FS01:0x22:Checkpoint completed at step 4200000
08:11:48:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
08:12:30:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
08:12:30:WU01:FS01:0x22:Checkpoint completed at step 4300000
08:13:13:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
08:13:55:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
08:13:55:WU01:FS01:0x22:Checkpoint completed at step 4400000
08:14:37:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
08:15:19:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
08:15:19:WU01:FS01:0x22:Checkpoint completed at step 4500000
08:16:02:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
08:16:44:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
08:16:44:WU01:FS01:0x22:Checkpoint completed at step 4600000
08:17:26:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
08:18:08:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
08:18:08:WU01:FS01:0x22:Checkpoint completed at step 4700000
08:18:50:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
08:19:32:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
08:19:32:WU01:FS01:0x22:Checkpoint completed at step 4800000
08:20:14:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
08:20:56:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
08:20:56:WU01:FS01:0x22:Checkpoint completed at step 4900000
08:21:39:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
08:22:20:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
08:22:20:WU01:FS01:0x22:Average performance: 514.286 ns/day
08:22:21:WU01:FS01:0x22:Checkpoint completed at step 5000000
08:22:21:WU00:FS01:Connecting to assign1.foldingathome.org:80
08:22:21:WU00:FS01:Assigned to work server 34.72.228.44
08:22:21:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 34.72.228.44
08:22:21:WU00:FS01:Connecting to 34.72.228.44:8080
08:22:21:WU00:FS01:Downloading 2.09MiB
08:22:22:WU00:FS01:Download complete
08:22:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18117 run:0 clone:61 gen:38 core:0x22 unit:0x0000003d00000026000046c500000000
08:22:22:WU01:FS01:0x22:Saving result file ../logfile_01.txt
08:22:22:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
08:22:22:WU01:FS01:0x22:Saving result file checkpointState.xml
08:22:22:WU01:FS01:0x22:Saving result file positions.xtc
08:22:22:WU01:FS01:0x22:Saving result file science.log
08:22:22:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
08:22:22:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:22:22:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:2 clone:423 gen:81 core:0x22 unit:0x000001a700000051000047ff00000002
08:22:22:WU01:FS01:Uploading 14.33MiB to 129.32.209.202
08:22:22:WU01:FS01:Connecting to 129.32.209.202:8080
08:22:22:WU00:FS01:Starting
08:22:22:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
08:22:22:WU00:FS01:Started FahCore on PID 5405
08:22:22:WU00:FS01:Core PID:5409
08:22:22:WU00:FS01:FahCore 0x22 started
08:22:23:WU00:FS01:0x22:*********************** Log Started 2021-11-11T08:22:22Z ***********************
08:22:23:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
08:22:23:WU00:FS01:0x22: Core: Core22
08:22:23:WU00:FS01:0x22: Type: 0x22
08:22:23:WU00:FS01:0x22: Version: 0.0.13
08:22:23:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
08:22:23:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
08:22:23:WU00:FS01:0x22: Homepage: https://foldingathome.org/
08:22:23:WU00:FS01:0x22: Date: Sep 19 2020
08:22:23:WU00:FS01:0x22: Time: 01:10:35
08:22:23:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:22:23:WU00:FS01:0x22: Branch: core22-0.0.13
08:22:23:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:22:23:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
08:22:23:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
08:22:23:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
08:22:23:WU00:FS01:0x22: Bits: 64
08:22:23:WU00:FS01:0x22: Mode: Release
08:22:23:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
08:22:23:WU00:FS01:0x22: <[email protected]>
08:22:23:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 5405 -checkpoint 15
08:22:23:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
08:22:23:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
08:22:23:WU00:FS01:0x22:************************************ libFAH ************************************
08:22:23:WU00:FS01:0x22: Date: Sep 15 2020
08:22:23:WU00:FS01:0x22: Time: 05:14:43
08:22:23:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:22:23:WU00:FS01:0x22: Branch: HEAD
08:22:23:WU00:FS01:0x22:************************************ CBang *************************************
08:22:23:WU00:FS01:0x22: Time: 05:11:04
08:22:23:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:22:23:WU00:FS01:0x22: -funroll-loops -fPIC
08:22:23:WU00:FS01:0x22:************************************ System ************************************
08:22:23:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
08:22:23:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
08:22:23:WU00:FS01:0x22: CPUs: 8
08:22:23:WU00:FS01:0x22: Memory: 15.58GiB
08:22:23:WU00:FS01:0x22:Free Memory: 12.55GiB
08:22:23:WU00:FS01:0x22: Threads: POSIX_THREADS
08:22:23:WU00:FS01:0x22: OS Version: 5.11
08:22:23:WU00:FS01:0x22:Has Battery: false
08:22:23:WU00:FS01:0x22: On Battery: false
08:22:23:WU00:FS01:0x22: UTC Offset: -5
08:22:23:WU00:FS01:0x22: PID: 5409
08:22:23:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
08:22:23:WU00:FS01:0x22:************************************ OpenMM ************************************
08:22:23:WU00:FS01:0x22: Revision: 189320d0
08:22:23:WU00:FS01:0x22:********************************************************************************
08:22:23:WU00:FS01:0x22:Project: 18117 (Run 0, Clone 61, Gen 38)
08:22:23:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
08:22:23:WU00:FS01:0x22:Reading tar file core.xml
08:22:23:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
08:22:23:WU00:FS01:0x22:Reading tar file state.xml.bz2
08:22:23:WU00:FS01:0x22:Reading tar file system.xml.bz2
08:22:23:WU00:FS01:0x22:Digital signatures verified
08:22:23:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
08:22:23:WU00:FS01:0x22:Version 0.0.13
08:22:23:WU00:FS01:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
08:22:23:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
08:22:23:WU00:FS01:0x22: XTC frame write interval: 50000 steps (1%) [100 total]
08:22:23:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
08:22:23:WU00:FS01:0x22:There are 4 platforms available.
08:22:23:WU00:FS01:0x22:Platform 0: Reference
08:22:23:WU00:FS01:0x22:Platform 1: CPU
08:22:23:WU00:FS01:0x22:Platform 2: OpenCL
08:22:23:WU00:FS01:0x22: opencl-device 0 specified
08:22:23:WU00:FS01:0x22:Platform 3: CUDA
08:22:23:WU00:FS01:0x22: cuda-device 0 specified
08:22:24:WU00:FS01:0x22:Attempting to create CUDA context:
08:22:24:WU00:FS01:0x22: Configuring platform CUDA
08:22:25:WU01:FS01:Upload complete
08:22:25:WU01:FS01:Server responded WORK_ACK (400)
08:22:25:WU01:FS01:Final credit estimate, 293873.00 points
08:22:25:WU01:FS01:Cleaning up
08:23:53:WU00:FS01:0x22: Using CUDA and gpu 0
08:23:53:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
08:23:53:WU00:FS01:0x22:Checkpoint completed at step 0
08:24:26:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
08:24:58:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
08:25:31:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
08:26:04:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
08:26:36:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
08:26:36:WU00:FS01:0x22:Checkpoint completed at step 250000
08:27:09:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
08:27:41:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
08:28:14:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
08:28:46:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
08:29:19:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
08:29:19:WU00:FS01:0x22:Checkpoint completed at step 500000
08:29:52:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
08:30:24:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
08:30:57:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
08:31:29:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
08:32:02:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
08:32:02:WU00:FS01:0x22:Checkpoint completed at step 750000
08:32:35:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
08:33:07:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
08:33:39:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
08:34:12:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
08:34:44:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
08:34:45:WU00:FS01:0x22:Checkpoint completed at step 1000000
08:35:17:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
08:35:50:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
08:36:22:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
08:36:55:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
08:37:27:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
08:37:27:WU00:FS01:0x22:Checkpoint completed at step 1250000
08:38:00:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
08:38:32:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
08:39:05:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
08:39:37:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
08:40:10:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
08:40:10:WU00:FS01:0x22:Checkpoint completed at step 1500000
08:40:42:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
08:41:15:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
08:41:47:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
08:42:20:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
08:42:52:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
08:42:53:WU00:FS01:0x22:Checkpoint completed at step 1750000
08:43:25:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
08:43:58:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
08:44:30:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
08:45:03:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
08:45:35:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
08:45:35:WU00:FS01:0x22:Checkpoint completed at step 2000000
08:46:08:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
08:46:40:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
08:47:13:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
08:47:45:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
08:48:18:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
08:48:18:WU00:FS01:0x22:Checkpoint completed at step 2250000
08:48:50:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
08:49:23:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
08:49:55:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
08:50:28:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
08:51:00:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
08:51:01:WU00:FS01:0x22:Checkpoint completed at step 2500000
08:51:33:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
08:52:06:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
08:52:38:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
08:53:10:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
08:53:43:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
08:53:43:WU00:FS01:0x22:Checkpoint completed at step 2750000
08:54:16:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
08:54:48:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
08:55:21:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
08:55:53:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
08:56:26:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
08:56:26:WU00:FS01:0x22:Checkpoint completed at step 3000000
08:56:58:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
08:57:31:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
08:58:03:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
08:58:36:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
08:59:08:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
08:59:08:WU00:FS01:0x22:Checkpoint completed at step 3250000
08:59:41:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
09:00:13:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
09:00:46:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
09:01:18:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
09:01:51:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
09:01:51:WU00:FS01:0x22:Checkpoint completed at step 3500000
09:02:24:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
09:02:56:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
09:03:29:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
09:04:01:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
09:04:34:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
09:04:34:WU00:FS01:0x22:Checkpoint completed at step 3750000
09:05:06:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
09:05:39:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
09:06:11:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
09:06:44:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
09:07:16:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
09:07:16:WU00:FS01:0x22:Checkpoint completed at step 4000000
09:07:49:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
09:08:21:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
09:08:54:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
09:09:26:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
09:09:58:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
09:09:59:WU00:FS01:0x22:Checkpoint completed at step 4250000
09:10:31:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
09:11:04:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
09:11:36:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
09:12:08:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
09:12:41:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
09:12:41:WU00:FS01:0x22:Checkpoint completed at step 4500000
09:13:14:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
09:13:46:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
09:14:18:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
09:14:51:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
09:15:23:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
09:15:24:WU00:FS01:0x22:Checkpoint completed at step 4750000
09:15:56:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
09:16:29:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
09:17:01:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
09:17:34:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
09:18:06:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
09:18:06:WU00:FS01:0x22:Average performance: 106.667 ns/day
09:18:06:WU00:FS01:0x22:Checkpoint completed at step 5000000
09:18:07:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:18:07:WU01:FS01:Assigned to work server 128.252.203.11
09:18:07:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 128.252.203.11
09:18:07:WU01:FS01:Connecting to 128.252.203.11:8080
09:18:08:WU00:FS01:0x22:Saving result file ../logfile_01.txt
09:18:08:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
09:18:08:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
09:18:08:WU00:FS01:0x22:Saving result file positions.xtc
09:18:08:WU00:FS01:0x22:Saving result file science.log
09:18:08:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
09:18:09:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:18:09:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18117 run:0 clone:61 gen:38 core:0x22 unit:0x0000003d00000026000046c500000000
09:18:09:WU00:FS01:Uploading 11.01MiB to 34.72.228.44
09:18:09:WU00:FS01:Connecting to 34.72.228.44:8080
09:18:18:WU00:FS01:Upload complete
09:18:18:WU00:FS01:Server responded WORK_ACK (400)
09:18:18:WU00:FS01:Final credit estimate, 133522.00 points
09:18:18:WU00:FS01:Cleaning up
09:18:20:WU01:FS01:Downloading 26.57MiB
09:18:23:WU01:FS01:Download complete
09:18:24:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18201 run:42245 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000a505
09:18:24:WU01:FS01:Starting
09:18:24:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
09:18:24:WU01:FS01:Started FahCore on PID 5530
09:18:24:WU01:FS01:Core PID:5534
09:18:24:WU01:FS01:FahCore 0x22 started
09:18:24:WU01:FS01:0x22:*********************** Log Started 2021-11-11T09:18:24Z ***********************
09:18:24:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
09:18:24:WU01:FS01:0x22: Core: Core22
09:18:24:WU01:FS01:0x22: Type: 0x22
09:18:24:WU01:FS01:0x22: Version: 0.0.13
09:18:24:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
09:18:24:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
09:18:24:WU01:FS01:0x22: Homepage: https://foldingathome.org/
09:18:24:WU01:FS01:0x22: Date: Sep 19 2020
09:18:24:WU01:FS01:0x22: Time: 01:10:35
09:18:24:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
09:18:24:WU01:FS01:0x22: Branch: core22-0.0.13
09:18:24:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
09:18:24:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
09:18:24:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
09:18:24:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
09:18:24:WU01:FS01:0x22: Bits: 64
09:18:24:WU01:FS01:0x22: Mode: Release
09:18:24:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
09:18:24:WU01:FS01:0x22: <[email protected]>
09:18:24:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 5530 -checkpoint 15
09:18:24:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
09:18:24:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
09:18:24:WU01:FS01:0x22:************************************ libFAH ************************************
09:18:24:WU01:FS01:0x22: Date: Sep 15 2020
09:18:24:WU01:FS01:0x22: Time: 05:14:43
09:18:24:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
09:18:24:WU01:FS01:0x22: Branch: HEAD
09:18:24:WU01:FS01:0x22:************************************ CBang *************************************
09:18:24:WU01:FS01:0x22: Time: 05:11:04
09:18:24:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
09:18:24:WU01:FS01:0x22: -funroll-loops -fPIC
09:18:24:WU01:FS01:0x22:************************************ System ************************************
09:18:24:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
09:18:24:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
09:18:24:WU01:FS01:0x22: CPUs: 8
09:18:24:WU01:FS01:0x22: Memory: 15.58GiB
09:18:24:WU01:FS01:0x22:Free Memory: 12.57GiB
09:18:24:WU01:FS01:0x22: Threads: POSIX_THREADS
09:18:24:WU01:FS01:0x22: OS Version: 5.11
09:18:24:WU01:FS01:0x22:Has Battery: false
09:18:24:WU01:FS01:0x22: On Battery: false
09:18:24:WU01:FS01:0x22: UTC Offset: -5
09:18:24:WU01:FS01:0x22: PID: 5534
09:18:24:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
09:18:24:WU01:FS01:0x22:************************************ OpenMM ************************************
09:18:24:WU01:FS01:0x22: Revision: 189320d0
09:18:24:WU01:FS01:0x22:********************************************************************************
09:18:24:WU01:FS01:0x22:Project: 18201 (Run 42245, Clone 0, Gen 14)
09:18:24:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
09:18:24:WU01:FS01:0x22:Reading tar file core.xml
09:18:24:WU01:FS01:0x22:Reading tar file integrator.xml
09:18:24:WU01:FS01:0x22:Reading tar file state.xml
09:18:25:WU01:FS01:0x22:Reading tar file system.xml
09:18:25:WU01:FS01:0x22:Digital signatures verified
09:18:25:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
09:18:25:WU01:FS01:0x22:Version 0.0.13
09:18:25:WU01:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
09:18:25:WU01:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
09:18:25:WU01:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
09:18:25:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
09:18:25:WU01:FS01:0x22:There are 4 platforms available.
09:18:25:WU01:FS01:0x22:Platform 0: Reference
09:18:25:WU01:FS01:0x22:Platform 1: CPU
09:18:25:WU01:FS01:0x22:Platform 2: OpenCL
09:18:25:WU01:FS01:0x22: opencl-device 0 specified
09:18:25:WU01:FS01:0x22:Platform 3: CUDA
09:18:25:WU01:FS01:0x22: cuda-device 0 specified
09:18:34:WU01:FS01:0x22:Attempting to create CUDA context:
09:18:34:WU01:FS01:0x22: Configuring platform CUDA
09:20:05:WU01:FS01:0x22: Using CUDA and gpu 0
09:20:05:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
09:20:06:WU01:FS01:0x22:Checkpoint completed at step 0
09:21:06:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
09:22:06:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
09:22:07:WU01:FS01:0x22:Checkpoint completed at step 25000
09:23:07:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
09:24:07:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
09:24:08:WU01:FS01:0x22:Checkpoint completed at step 50000
09:25:09:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
09:26:09:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
09:26:09:WU01:FS01:0x22:Checkpoint completed at step 75000
09:27:10:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
09:28:10:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
09:28:11:WU01:FS01:0x22:Checkpoint completed at step 100000
09:29:11:WU01:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
09:30:11:WU01:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
09:30:12:WU01:FS01:0x22:Checkpoint completed at step 125000
09:31:12:WU01:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
09:32:12:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
09:32:13:WU01:FS01:0x22:Checkpoint completed at step 150000
09:33:14:WU01:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
09:34:14:WU01:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
09:34:14:WU01:FS01:0x22:Checkpoint completed at step 175000
09:35:15:WU01:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
09:36:15:WU01:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
09:36:16:WU01:FS01:0x22:Checkpoint completed at step 200000
09:37:16:WU01:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
09:38:16:WU01:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
09:38:17:WU01:FS01:0x22:Checkpoint completed at step 225000
09:39:17:WU01:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
09:40:17:WU01:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
09:40:18:WU01:FS01:0x22:Checkpoint completed at step 250000
09:41:19:WU01:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
09:42:19:WU01:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
09:42:20:WU01:FS01:0x22:Checkpoint completed at step 275000
09:43:20:WU01:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
09:44:20:WU01:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
09:44:21:WU01:FS01:0x22:Checkpoint completed at step 300000
09:45:22:WU01:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
09:46:22:WU01:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
09:46:22:WU01:FS01:0x22:Checkpoint completed at step 325000
09:47:23:WU01:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
09:48:23:WU01:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
09:48:24:WU01:FS01:0x22:Checkpoint completed at step 350000
09:49:24:WU01:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
09:50:24:WU01:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
09:50:25:WU01:FS01:0x22:Checkpoint completed at step 375000
09:51:25:WU01:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
09:52:25:WU01:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
09:52:26:WU01:FS01:0x22:Checkpoint completed at step 400000
09:53:27:WU01:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
09:54:27:WU01:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
09:54:28:WU01:FS01:0x22:Checkpoint completed at step 425000
09:55:28:WU01:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
09:56:28:WU01:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
09:56:29:WU01:FS01:0x22:Checkpoint completed at step 450000
09:57:29:WU01:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
09:58:29:WU01:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
09:58:30:WU01:FS01:0x22:Checkpoint completed at step 475000
09:59:31:WU01:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
10:00:31:WU01:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
10:00:32:WU01:FS01:0x22:Checkpoint completed at step 500000
10:01:32:WU01:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
10:02:32:WU01:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
10:02:33:WU01:FS01:0x22:Checkpoint completed at step 525000
10:03:33:WU01:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
10:04:33:WU01:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
10:04:34:WU01:FS01:0x22:Checkpoint completed at step 550000
10:05:35:WU01:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
10:06:35:WU01:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
10:06:35:WU01:FS01:0x22:Checkpoint completed at step 575000
10:07:36:WU01:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
10:08:36:WU01:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
10:08:37:WU01:FS01:0x22:Checkpoint completed at step 600000
10:09:37:WU01:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
10:10:37:WU01:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
10:10:38:WU01:FS01:0x22:Checkpoint completed at step 625000
10:11:39:WU01:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
10:12:39:WU01:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
10:12:39:WU01:FS01:0x22:Checkpoint completed at step 650000
10:13:40:WU01:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
10:14:40:WU01:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
10:14:41:WU01:FS01:0x22:Checkpoint completed at step 675000
10:15:41:WU01:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
10:16:41:WU01:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
10:16:42:WU01:FS01:0x22:Checkpoint completed at step 700000
10:17:42:WU01:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
10:18:42:WU01:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
10:18:43:WU01:FS01:0x22:Checkpoint completed at step 725000
10:19:44:WU01:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
10:20:44:WU01:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
10:20:45:WU01:FS01:0x22:Checkpoint completed at step 750000
10:21:45:WU01:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
10:22:45:WU01:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
10:22:46:WU01:FS01:0x22:Checkpoint completed at step 775000
10:23:47:WU01:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
10:24:47:WU01:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
10:24:48:WU01:FS01:0x22:Checkpoint completed at step 800000
10:25:48:WU01:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
10:26:48:WU01:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
10:26:49:WU01:FS01:0x22:Checkpoint completed at step 825000
10:27:49:WU01:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
10:28:49:WU01:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
10:28:50:WU01:FS01:0x22:Checkpoint completed at step 850000
10:29:50:WU01:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
10:30:50:WU01:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
10:30:51:WU01:FS01:0x22:Checkpoint completed at step 875000
10:31:51:WU01:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
10:32:51:WU01:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
10:32:52:WU01:FS01:0x22:Checkpoint completed at step 900000
10:33:53:WU01:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
10:34:53:WU01:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
10:34:54:WU01:FS01:0x22:Checkpoint completed at step 925000
10:35:54:WU01:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
10:36:54:WU01:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
10:36:55:WU01:FS01:0x22:Checkpoint completed at step 950000
10:37:55:WU01:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
10:38:55:WU01:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
10:38:56:WU01:FS01:0x22:Checkpoint completed at step 975000
10:39:57:WU01:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
10:40:57:WU01:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
10:40:57:WU01:FS01:0x22:Checkpoint completed at step 1000000
10:41:58:WU01:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
10:42:58:WU01:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
10:42:59:WU01:FS01:0x22:Checkpoint completed at step 1025000
10:43:59:WU01:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
10:44:59:WU01:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
10:45:00:WU01:FS01:0x22:Checkpoint completed at step 1050000
10:46:00:WU01:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
10:47:00:WU01:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
10:47:01:WU01:FS01:0x22:Checkpoint completed at step 1075000
10:48:02:WU01:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
10:49:01:WU01:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
10:49:02:WU01:FS01:0x22:Checkpoint completed at step 1100000
10:50:03:WU01:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
10:51:03:WU01:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
10:51:04:WU01:FS01:0x22:Checkpoint completed at step 1125000
10:52:04:WU01:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
10:53:04:WU01:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
10:53:05:WU01:FS01:0x22:Checkpoint completed at step 1150000
10:54:06:WU01:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
10:55:05:WU01:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
10:55:06:WU01:FS01:0x22:Checkpoint completed at step 1175000
10:56:07:WU01:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
10:57:07:WU01:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
10:57:08:WU01:FS01:0x22:Checkpoint completed at step 1200000
10:58:08:WU01:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
10:59:08:WU01:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
10:59:09:WU01:FS01:0x22:Checkpoint completed at step 1225000
11:00:09:WU01:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
11:01:09:WU01:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
11:01:09:WU01:FS01:0x22:Average performance: 28.8 ns/day
11:01:10:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:01:10:WU00:FS01:Assigned to work server 128.252.203.11
11:01:10:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 128.252.203.11
11:01:10:WU00:FS01:Connecting to 128.252.203.11:8080
11:01:10:WU01:FS01:0x22:Checkpoint completed at step 1250000
11:01:15:WU01:FS01:0x22:Saving result file ../logfile_01.txt
11:01:15:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
11:01:15:WU01:FS01:0x22:Saving result file checkpointState.xml
11:01:18:WU01:FS01:0x22:Saving result file positions.xtc
11:01:19:WU01:FS01:0x22:Saving result file science.log
11:01:19:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
11:01:19:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:01:19:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18201 run:42245 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000a505
11:01:19:WU01:FS01:Uploading 27.50MiB to 128.252.203.11
11:01:19:WU01:FS01:Connecting to 128.252.203.11:8080
11:01:21:WU00:FS01:Downloading 26.56MiB
11:01:24:WU00:FS01:Download complete
11:01:24:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18201 run:43793 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000ab11
11:01:24:WU00:FS01:Starting
11:01:24:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
11:01:24:WU00:FS01:Started FahCore on PID 5710
11:01:24:WU00:FS01:Core PID:5714
11:01:24:WU00:FS01:FahCore 0x22 started
11:01:24:WU00:FS01:0x22:*********************** Log Started 2021-11-11T11:01:24Z ***********************
11:01:24:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
11:01:24:WU00:FS01:0x22: Core: Core22
11:01:24:WU00:FS01:0x22: Type: 0x22
11:01:24:WU00:FS01:0x22: Version: 0.0.13
11:01:24:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
11:01:24:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
11:01:24:WU00:FS01:0x22: Homepage: https://foldingathome.org/
11:01:24:WU00:FS01:0x22: Date: Sep 19 2020
11:01:24:WU00:FS01:0x22: Time: 01:10:35
11:01:24:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
11:01:24:WU00:FS01:0x22: Branch: core22-0.0.13
11:01:24:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
11:01:24:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
11:01:24:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
11:01:24:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
11:01:24:WU00:FS01:0x22: Bits: 64
11:01:24:WU00:FS01:0x22: Mode: Release
11:01:24:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
11:01:24:WU00:FS01:0x22: <[email protected]>
11:01:24:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 5710 -checkpoint 15
11:01:24:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
11:01:24:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
11:01:24:WU00:FS01:0x22:************************************ libFAH ************************************
11:01:24:WU00:FS01:0x22: Date: Sep 15 2020
11:01:24:WU00:FS01:0x22: Time: 05:14:43
11:01:24:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
11:01:24:WU00:FS01:0x22: Branch: HEAD
11:01:24:WU00:FS01:0x22:************************************ CBang *************************************
11:01:24:WU00:FS01:0x22: Time: 05:11:04
11:01:24:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
11:01:24:WU00:FS01:0x22: -funroll-loops -fPIC
11:01:24:WU00:FS01:0x22:************************************ System ************************************
11:01:24:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
11:01:24:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
11:01:24:WU00:FS01:0x22: CPUs: 8
11:01:24:WU00:FS01:0x22: Memory: 15.58GiB
11:01:24:WU00:FS01:0x22:Free Memory: 12.46GiB
11:01:24:WU00:FS01:0x22: Threads: POSIX_THREADS
11:01:24:WU00:FS01:0x22: OS Version: 5.11
11:01:24:WU00:FS01:0x22:Has Battery: false
11:01:24:WU00:FS01:0x22: On Battery: false
11:01:24:WU00:FS01:0x22: UTC Offset: -5
11:01:24:WU00:FS01:0x22: PID: 5714
11:01:24:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
11:01:24:WU00:FS01:0x22:************************************ OpenMM ************************************
11:01:24:WU00:FS01:0x22: Revision: 189320d0
11:01:24:WU00:FS01:0x22:********************************************************************************
11:01:24:WU00:FS01:0x22:Project: 18201 (Run 43793, Clone 0, Gen 14)
11:01:24:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
11:01:24:WU00:FS01:0x22:Reading tar file core.xml
11:01:24:WU00:FS01:0x22:Reading tar file integrator.xml
11:01:24:WU00:FS01:0x22:Reading tar file state.xml
11:01:25:WU01:FS01:Upload 34.55%
11:01:25:WU00:FS01:0x22:Reading tar file system.xml
11:01:25:WU00:FS01:0x22:Digital signatures verified
11:01:25:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
11:01:25:WU00:FS01:0x22:Version 0.0.13
11:01:25:WU00:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
11:01:25:WU00:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
11:01:25:WU00:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
11:01:25:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
11:01:25:WU00:FS01:0x22:There are 4 platforms available.
11:01:25:WU00:FS01:0x22:Platform 0: Reference
11:01:25:WU00:FS01:0x22:Platform 1: CPU
11:01:25:WU00:FS01:0x22:Platform 2: OpenCL
11:01:25:WU00:FS01:0x22: opencl-device 0 specified
11:01:25:WU00:FS01:0x22:Platform 3: CUDA
11:01:25:WU00:FS01:0x22: cuda-device 0 specified
11:01:31:WU01:FS01:Upload 75.46%
11:01:34:WU00:FS01:0x22:Attempting to create CUDA context:
11:01:34:WU00:FS01:0x22: Configuring platform CUDA
11:01:36:WU01:FS01:Upload complete
11:01:36:WU01:FS01:Server responded WORK_ACK (400)
11:01:36:WU01:FS01:Final credit estimate, 489552.00 points
11:01:36:WU01:FS01:Cleaning up
11:03:06:WU00:FS01:0x22: Using CUDA and gpu 0
11:03:06:WU00:FS01:0x22:Completed 0 out of 1250000 steps (0%)
11:03:06:WU00:FS01:0x22:Checkpoint completed at step 0
11:04:06:WU00:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
11:05:06:WU00:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
11:05:07:WU00:FS01:0x22:Checkpoint completed at step 25000
11:06:08:WU00:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
11:07:08:WU00:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
11:07:08:WU00:FS01:0x22:Checkpoint completed at step 50000
11:08:09:WU00:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
11:09:09:WU00:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
11:09:10:WU00:FS01:0x22:Checkpoint completed at step 75000
11:10:10:WU00:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
11:11:10:WU00:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
11:11:11:WU00:FS01:0x22:Checkpoint completed at step 100000
11:12:11:WU00:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
11:13:11:WU00:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
11:13:12:WU00:FS01:0x22:Checkpoint completed at step 125000
11:14:13:WU00:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
11:15:13:WU00:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
11:15:14:WU00:FS01:0x22:Checkpoint completed at step 150000
11:16:14:WU00:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
11:17:14:WU00:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
11:17:15:WU00:FS01:0x22:Checkpoint completed at step 175000
11:18:16:WU00:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
11:19:16:WU00:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
11:19:16:WU00:FS01:0x22:Checkpoint completed at step 200000
11:20:17:WU00:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
11:21:17:WU00:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
11:21:18:WU00:FS01:0x22:Checkpoint completed at step 225000
11:22:18:WU00:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
11:23:18:WU00:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
11:23:19:WU00:FS01:0x22:Checkpoint completed at step 250000
11:24:19:WU00:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
11:25:19:WU00:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
11:25:20:WU00:FS01:0x22:Checkpoint completed at step 275000
11:26:20:WU00:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
11:27:21:WU00:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
11:27:21:WU00:FS01:0x22:Checkpoint completed at step 300000
11:28:22:WU00:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
11:29:22:WU00:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
11:29:23:WU00:FS01:0x22:Checkpoint completed at step 325000
11:30:23:WU00:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
11:31:23:WU00:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
11:31:24:WU00:FS01:0x22:Checkpoint completed at step 350000
11:32:24:WU00:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
11:33:24:WU00:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
11:33:25:WU00:FS01:0x22:Checkpoint completed at step 375000
11:34:26:WU00:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
11:35:26:WU00:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
11:35:27:WU00:FS01:0x22:Checkpoint completed at step 400000
11:36:27:WU00:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
11:37:27:WU00:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
11:37:28:WU00:FS01:0x22:Checkpoint completed at step 425000
11:38:28:WU00:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
11:39:28:WU00:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
11:39:29:WU00:FS01:0x22:Checkpoint completed at step 450000
11:40:30:WU00:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
11:41:30:WU00:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
11:41:31:WU00:FS01:0x22:Checkpoint completed at step 475000
11:42:31:WU00:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
11:43:31:WU00:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
11:43:32:WU00:FS01:0x22:Checkpoint completed at step 500000
11:44:32:WU00:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
11:45:32:WU00:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
11:45:33:WU00:FS01:0x22:Checkpoint completed at step 525000
11:46:34:WU00:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
11:47:34:WU00:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
11:47:34:WU00:FS01:0x22:Checkpoint completed at step 550000
11:48:35:WU00:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
11:49:35:WU00:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
11:49:36:WU00:FS01:0x22:Checkpoint completed at step 575000
11:50:36:WU00:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
11:51:36:WU00:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
11:51:37:WU00:FS01:0x22:Checkpoint completed at step 600000
11:52:37:WU00:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
11:53:37:WU00:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
11:53:38:WU00:FS01:0x22:Checkpoint completed at step 625000
11:54:39:WU00:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
11:55:39:WU00:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
11:55:39:WU00:FS01:0x22:Checkpoint completed at step 650000
11:56:40:WU00:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
11:57:40:WU00:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
11:57:41:WU00:FS01:0x22:Checkpoint completed at step 675000
11:58:41:WU00:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
11:59:41:WU00:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
11:59:42:WU00:FS01:0x22:Checkpoint completed at step 700000
12:00:42:WU00:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
12:01:42:WU00:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
12:01:43:WU00:FS01:0x22:Checkpoint completed at step 725000
12:02:43:WU00:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
12:03:43:WU00:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
12:03:44:WU00:FS01:0x22:Checkpoint completed at step 750000
12:04:45:WU00:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
12:05:45:WU00:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
12:05:46:WU00:FS01:0x22:Checkpoint completed at step 775000
12:06:46:WU00:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
******************************* Date: 2021-11-11 *******************************
12:07:46:WU00:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
12:07:47:WU00:FS01:0x22:Checkpoint completed at step 800000
12:08:47:WU00:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
12:09:47:WU00:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
12:09:48:WU00:FS01:0x22:Checkpoint completed at step 825000
12:10:49:WU00:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
12:11:49:WU00:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
12:11:49:WU00:FS01:0x22:Checkpoint completed at step 850000
12:12:50:WU00:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
12:13:50:WU00:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
12:13:51:WU00:FS01:0x22:Checkpoint completed at step 875000
12:14:51:WU00:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
12:15:51:WU00:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
12:15:52:WU00:FS01:0x22:Checkpoint completed at step 900000
12:16:52:WU00:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
12:17:52:WU00:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
12:17:53:WU00:FS01:0x22:Checkpoint completed at step 925000
12:18:53:WU00:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
12:19:53:WU00:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
12:19:54:WU00:FS01:0x22:Checkpoint completed at step 950000
12:20:54:WU00:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
12:21:54:WU00:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
12:21:55:WU00:FS01:0x22:Checkpoint completed at step 975000
12:22:56:WU00:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
12:23:56:WU00:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
12:23:57:WU00:FS01:0x22:Checkpoint completed at step 1000000
12:24:57:WU00:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
12:25:57:WU00:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
12:25:58:WU00:FS01:0x22:Checkpoint completed at step 1025000
12:26:58:WU00:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
12:27:58:WU00:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
12:27:59:WU00:FS01:0x22:Checkpoint completed at step 1050000
12:28:59:WU00:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
12:29:59:WU00:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
12:30:00:WU00:FS01:0x22:Checkpoint completed at step 1075000
12:31:00:WU00:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
12:32:00:WU00:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
12:32:01:WU00:FS01:0x22:Checkpoint completed at step 1100000
12:33:02:WU00:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
12:34:02:WU00:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
12:34:02:WU00:FS01:0x22:Checkpoint completed at step 1125000
12:35:03:WU00:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
12:36:03:WU00:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
12:36:04:WU00:FS01:0x22:Checkpoint completed at step 1150000
12:37:04:WU00:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
12:38:04:WU00:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
12:38:05:WU00:FS01:0x22:Checkpoint completed at step 1175000
12:39:05:WU00:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
12:40:05:WU00:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
12:40:06:WU00:FS01:0x22:Checkpoint completed at step 1200000
12:41:07:WU00:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
12:42:06:WU00:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
12:42:07:WU00:FS01:0x22:Checkpoint completed at step 1225000
12:43:08:WU00:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
12:44:08:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
12:44:08:WU00:FS01:0x22:Average performance: 28.562 ns/day
12:44:09:WU00:FS01:0x22:Checkpoint completed at step 1250000
12:44:09:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:44:09:WU01:FS01:Assigned to work server 129.32.209.202
12:44:09:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
12:44:09:WU01:FS01:Connecting to 129.32.209.202:8080
12:44:09:WU01:FS01:Downloading 27.76MiB
12:44:12:WU01:FS01:Download complete
12:44:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:5 clone:318 gen:72 core:0x22 unit:0x0000013e00000048000047ff00000005
12:44:14:WU00:FS01:0x22:Saving result file ../logfile_01.txt
12:44:14:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
12:44:14:WU00:FS01:0x22:Saving result file checkpointState.xml
12:44:17:WU00:FS01:0x22:Saving result file positions.xtc
12:44:17:WU00:FS01:0x22:Saving result file science.log
12:44:17:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
12:44:18:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:44:18:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18201 run:43793 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000ab11
12:44:18:WU00:FS01:Uploading 27.50MiB to 128.252.203.11
12:44:18:WU00:FS01:Connecting to 128.252.203.11:8080
12:44:18:WU01:FS01:Starting
12:44:18:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:44:18:WU01:FS01:Started FahCore on PID 6551
12:44:18:WU01:FS01:Core PID:6555
12:44:18:WU01:FS01:FahCore 0x22 started
12:44:18:WU01:FS01:0x22:*********************** Log Started 2021-11-11T12:44:18Z ***********************
12:44:18:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
12:44:18:WU01:FS01:0x22: Core: Core22
12:44:18:WU01:FS01:0x22: Type: 0x22
12:44:18:WU01:FS01:0x22: Version: 0.0.13
12:44:18:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
12:44:18:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
12:44:18:WU01:FS01:0x22: Homepage: https://foldingathome.org/
12:44:18:WU01:FS01:0x22: Date: Sep 19 2020
12:44:18:WU01:FS01:0x22: Time: 01:10:35
12:44:18:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:44:18:WU01:FS01:0x22: Branch: core22-0.0.13
12:44:18:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
12:44:18:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
12:44:18:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
12:44:18:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
12:44:18:WU01:FS01:0x22: Bits: 64
12:44:18:WU01:FS01:0x22: Mode: Release
12:44:18:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
12:44:18:WU01:FS01:0x22: <[email protected]>
12:44:18:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 6551 -checkpoint 15
12:44:18:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
12:44:18:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
12:44:18:WU01:FS01:0x22:************************************ libFAH ************************************
12:44:18:WU01:FS01:0x22: Date: Sep 15 2020
12:44:18:WU01:FS01:0x22: Time: 05:14:43
12:44:18:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:44:18:WU01:FS01:0x22: Branch: HEAD
12:44:18:WU01:FS01:0x22:************************************ CBang *************************************
12:44:18:WU01:FS01:0x22: Time: 05:11:04
12:44:18:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:44:18:WU01:FS01:0x22: -funroll-loops -fPIC
12:44:18:WU01:FS01:0x22:************************************ System ************************************
12:44:18:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
12:44:18:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:44:18:WU01:FS01:0x22: CPUs: 8
12:44:18:WU01:FS01:0x22: Memory: 15.58GiB
12:44:18:WU01:FS01:0x22:Free Memory: 12.34GiB
12:44:18:WU01:FS01:0x22: Threads: POSIX_THREADS
12:44:18:WU01:FS01:0x22: OS Version: 5.11
12:44:18:WU01:FS01:0x22:Has Battery: false
12:44:18:WU01:FS01:0x22: On Battery: false
12:44:18:WU01:FS01:0x22: UTC Offset: -5
12:44:18:WU01:FS01:0x22: PID: 6555
12:44:18:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
12:44:18:WU01:FS01:0x22:************************************ OpenMM ************************************
12:44:18:WU01:FS01:0x22: Revision: 189320d0
12:44:18:WU01:FS01:0x22:********************************************************************************
12:44:18:WU01:FS01:0x22:Project: 18431 (Run 5, Clone 318, Gen 72)
12:44:18:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
12:44:18:WU01:FS01:0x22:Reading tar file core.xml
12:44:18:WU01:FS01:0x22:Reading tar file integrator.xml
12:44:18:WU01:FS01:0x22:Reading tar file state.xml
12:44:18:WU01:FS01:0x22:Reading tar file system.xml
12:44:18:WU01:FS01:0x22:Digital signatures verified
12:44:18:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
12:44:18:WU01:FS01:0x22:Version 0.0.13
12:44:18:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
12:44:18:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
12:44:18:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
12:44:18:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
12:44:18:WU01:FS01:0x22:There are 4 platforms available.
12:44:18:WU01:FS01:0x22:Platform 0: Reference
12:44:18:WU01:FS01:0x22:Platform 1: CPU
12:44:18:WU01:FS01:0x22:Platform 2: OpenCL
12:44:18:WU01:FS01:0x22: opencl-device 0 specified
12:44:18:WU01:FS01:0x22:Platform 3: CUDA
12:44:18:WU01:FS01:0x22: cuda-device 0 specified
12:44:20:WU01:FS01:0x22:Attempting to create CUDA context:
12:44:20:WU01:FS01:0x22: Configuring platform CUDA
12:44:24:WU00:FS01:Upload 40.91%
12:44:30:WU00:FS01:Upload 81.83%
12:44:35:WU00:FS01:Upload complete
12:44:35:WU00:FS01:Server responded WORK_ACK (400)
12:44:35:WU00:FS01:Final credit estimate, 489749.00 points
12:44:35:WU00:FS01:Cleaning up
12:45:49:WU01:FS01:0x22: Using CUDA and gpu 0
12:45:49:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
12:45:49:WU01:FS01:0x22:Checkpoint completed at step 0
12:46:31:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
12:47:13:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
12:47:13:WU01:FS01:0x22:Checkpoint completed at step 100000
12:47:55:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
12:48:37:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
12:48:38:WU01:FS01:0x22:Checkpoint completed at step 200000
12:49:20:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
12:50:02:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
12:50:02:WU01:FS01:0x22:Checkpoint completed at step 300000
12:50:44:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
12:51:26:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
12:51:27:WU01:FS01:0x22:Checkpoint completed at step 400000
12:52:09:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
12:52:51:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
12:52:51:WU01:FS01:0x22:Checkpoint completed at step 500000
12:53:33:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
12:54:16:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
12:54:16:WU01:FS01:0x22:Checkpoint completed at step 600000
12:54:58:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
12:55:40:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
12:55:40:WU01:FS01:0x22:Checkpoint completed at step 700000
12:56:23:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
12:57:05:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
12:57:05:WU01:FS01:0x22:Checkpoint completed at step 800000
12:57:47:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
12:58:29:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
12:58:29:WU01:FS01:0x22:Checkpoint completed at step 900000
12:59:12:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
12:59:54:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
12:59:54:WU01:FS01:0x22:Checkpoint completed at step 1000000
13:00:36:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
13:01:18:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
13:01:19:WU01:FS01:0x22:Checkpoint completed at step 1100000
13:02:01:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
13:02:43:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
13:02:43:WU01:FS01:0x22:Checkpoint completed at step 1200000
13:03:25:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
13:04:08:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
13:04:08:WU01:FS01:0x22:Checkpoint completed at step 1300000
13:04:50:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
13:05:32:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
13:05:32:WU01:FS01:0x22:Checkpoint completed at step 1400000
13:06:15:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
13:06:57:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
13:06:57:WU01:FS01:0x22:Checkpoint completed at step 1500000
13:07:39:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
13:08:22:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
13:08:22:WU01:FS01:0x22:Checkpoint completed at step 1600000
13:09:04:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
13:09:46:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
13:09:47:WU01:FS01:0x22:Checkpoint completed at step 1700000
13:10:29:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
13:11:11:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
13:11:11:WU01:FS01:0x22:Checkpoint completed at step 1800000
13:11:54:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
13:12:36:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
13:12:36:WU01:FS01:0x22:Checkpoint completed at step 1900000
13:13:18:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
13:14:01:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
13:14:01:WU01:FS01:0x22:Checkpoint completed at step 2000000
13:14:43:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
13:15:26:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
13:15:26:WU01:FS01:0x22:Checkpoint completed at step 2100000
13:16:08:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
13:16:50:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
13:16:50:WU01:FS01:0x22:Checkpoint completed at step 2200000
13:17:33:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
13:18:15:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
13:18:15:WU01:FS01:0x22:Checkpoint completed at step 2300000
13:18:57:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
13:19:40:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
13:19:40:WU01:FS01:0x22:Checkpoint completed at step 2400000
13:20:22:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
13:21:04:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
13:21:05:WU01:FS01:0x22:Checkpoint completed at step 2500000
13:21:47:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
13:22:29:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
13:22:29:WU01:FS01:0x22:Checkpoint completed at step 2600000
13:23:12:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
13:23:54:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
13:23:54:WU01:FS01:0x22:Checkpoint completed at step 2700000
13:24:36:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
13:25:18:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
13:25:19:WU01:FS01:0x22:Checkpoint completed at step 2800000
13:26:01:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
13:26:43:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
13:26:43:WU01:FS01:0x22:Checkpoint completed at step 2900000
13:27:26:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
13:28:08:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
13:28:08:WU01:FS01:0x22:Checkpoint completed at step 3000000
13:28:50:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
13:29:33:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
13:29:33:WU01:FS01:0x22:Checkpoint completed at step 3100000
13:30:15:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
13:30:57:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
13:30:58:WU01:FS01:0x22:Checkpoint completed at step 3200000
13:31:40:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
13:32:22:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
13:32:22:WU01:FS01:0x22:Checkpoint completed at step 3300000
13:33:04:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
13:33:47:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
13:33:47:WU01:FS01:0x22:Checkpoint completed at step 3400000
13:34:29:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
13:35:11:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
13:35:11:WU01:FS01:0x22:Checkpoint completed at step 3500000
13:35:54:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
13:36:36:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
13:36:36:WU01:FS01:0x22:Checkpoint completed at step 3600000
13:37:18:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
13:38:00:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
13:38:01:WU01:FS01:0x22:Checkpoint completed at step 3700000
13:38:43:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
13:39:25:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
13:39:25:WU01:FS01:0x22:Checkpoint completed at step 3800000
13:40:07:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
13:40:50:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
13:40:50:WU01:FS01:0x22:Checkpoint completed at step 3900000
13:41:32:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
13:42:14:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
13:42:14:WU01:FS01:0x22:Checkpoint completed at step 4000000
13:42:57:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
13:43:39:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
13:43:39:WU01:FS01:0x22:Checkpoint completed at step 4100000
13:44:21:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
13:45:04:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
13:45:04:WU01:FS01:0x22:Checkpoint completed at step 4200000
13:45:46:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
13:46:29:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
13:46:29:WU01:FS01:0x22:Checkpoint completed at step 4300000
13:47:11:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
13:47:53:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
13:47:54:WU01:FS01:0x22:Checkpoint completed at step 4400000
13:48:36:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
13:49:18:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
13:49:18:WU01:FS01:0x22:Checkpoint completed at step 4500000
13:50:01:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
13:50:43:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
13:50:43:WU01:FS01:0x22:Checkpoint completed at step 4600000
13:51:26:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
13:52:08:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
13:52:08:WU01:FS01:0x22:Checkpoint completed at step 4700000
13:52:51:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
13:53:33:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
13:53:33:WU01:FS01:0x22:Checkpoint completed at step 4800000
13:54:15:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
13:54:58:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
13:54:58:WU01:FS01:0x22:Checkpoint completed at step 4900000
13:55:40:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
13:56:22:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
13:56:22:WU01:FS01:0x22:Average performance: 514.286 ns/day
13:56:23:WU01:FS01:0x22:Checkpoint completed at step 5000000
13:56:23:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:56:23:WU00:FS01:Assigned to work server 34.72.228.44
13:56:23:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 34.72.228.44
13:56:23:WU00:FS01:Connecting to 34.72.228.44:8080
13:56:23:WU00:FS01:Downloading 1.95MiB
13:56:24:WU01:FS01:0x22:Saving result file ../logfile_01.txt
13:56:24:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
13:56:24:WU01:FS01:0x22:Saving result file checkpointState.xml
13:56:24:WU01:FS01:0x22:Saving result file positions.xtc
13:56:24:WU01:FS01:0x22:Saving result file science.log
13:56:24:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
13:56:24:WU00:FS01:Download complete
13:56:24:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18117 run:3 clone:96 gen:37 core:0x22 unit:0x0000006000000025000046c500000003
13:56:24:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:56:24:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:5 clone:318 gen:72 core:0x22 unit:0x0000013e00000048000047ff00000005
13:56:24:WU01:FS01:Uploading 14.32MiB to 129.32.209.202
13:56:24:WU01:FS01:Connecting to 129.32.209.202:8080
13:56:24:WU00:FS01:Starting
13:56:24:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
13:56:24:WU00:FS01:Started FahCore on PID 6693
13:56:24:WU00:FS01:Core PID:6697
13:56:24:WU00:FS01:FahCore 0x22 started
13:56:24:WU00:FS01:0x22:*********************** Log Started 2021-11-11T13:56:24Z ***********************
13:56:24:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
13:56:24:WU00:FS01:0x22: Core: Core22
13:56:24:WU00:FS01:0x22: Type: 0x22
13:56:24:WU00:FS01:0x22: Version: 0.0.13
13:56:24:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
13:56:24:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
13:56:24:WU00:FS01:0x22: Homepage: https://foldingathome.org/
13:56:24:WU00:FS01:0x22: Date: Sep 19 2020
13:56:24:WU00:FS01:0x22: Time: 01:10:35
13:56:24:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
13:56:24:WU00:FS01:0x22: Branch: core22-0.0.13
13:56:24:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
13:56:24:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
13:56:24:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
13:56:24:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
13:56:24:WU00:FS01:0x22: Bits: 64
13:56:24:WU00:FS01:0x22: Mode: Release
13:56:24:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
13:56:24:WU00:FS01:0x22: <[email protected]>
13:56:24:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 6693 -checkpoint 15
13:56:24:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
13:56:24:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
13:56:24:WU00:FS01:0x22:************************************ libFAH ************************************
13:56:24:WU00:FS01:0x22: Date: Sep 15 2020
13:56:24:WU00:FS01:0x22: Time: 05:14:43
13:56:24:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
13:56:24:WU00:FS01:0x22: Branch: HEAD
13:56:24:WU00:FS01:0x22:************************************ CBang *************************************
13:56:24:WU00:FS01:0x22: Time: 05:11:04
13:56:24:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
13:56:24:WU00:FS01:0x22: -funroll-loops -fPIC
13:56:24:WU00:FS01:0x22:************************************ System ************************************
13:56:24:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
13:56:24:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:56:24:WU00:FS01:0x22: CPUs: 8
13:56:24:WU00:FS01:0x22: Memory: 15.58GiB
13:56:24:WU00:FS01:0x22:Free Memory: 12.41GiB
13:56:24:WU00:FS01:0x22: Threads: POSIX_THREADS
13:56:24:WU00:FS01:0x22: OS Version: 5.11
13:56:24:WU00:FS01:0x22:Has Battery: false
13:56:24:WU00:FS01:0x22: On Battery: false
13:56:24:WU00:FS01:0x22: UTC Offset: -5
13:56:24:WU00:FS01:0x22: PID: 6697
13:56:24:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
13:56:24:WU00:FS01:0x22:************************************ OpenMM ************************************
13:56:24:WU00:FS01:0x22: Revision: 189320d0
13:56:24:WU00:FS01:0x22:********************************************************************************
13:56:24:WU00:FS01:0x22:Project: 18117 (Run 3, Clone 96, Gen 37)
13:56:24:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
13:56:24:WU00:FS01:0x22:Reading tar file core.xml
13:56:24:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
13:56:24:WU00:FS01:0x22:Reading tar file state.xml.bz2
13:56:24:WU00:FS01:0x22:Reading tar file system.xml.bz2
13:56:24:WU00:FS01:0x22:Digital signatures verified
13:56:24:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
13:56:24:WU00:FS01:0x22:Version 0.0.13
13:56:24:WU00:FS01:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
13:56:24:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
13:56:24:WU00:FS01:0x22: XTC frame write interval: 50000 steps (1%) [100 total]
13:56:24:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
13:56:24:WU00:FS01:0x22:There are 4 platforms available.
13:56:24:WU00:FS01:0x22:Platform 0: Reference
13:56:24:WU00:FS01:0x22:Platform 1: CPU
13:56:24:WU00:FS01:0x22:Platform 2: OpenCL
13:56:24:WU00:FS01:0x22: opencl-device 0 specified
13:56:24:WU00:FS01:0x22:Platform 3: CUDA
13:56:24:WU00:FS01:0x22: cuda-device 0 specified
13:56:25:WU00:FS01:0x22:Attempting to create CUDA context:
13:56:25:WU00:FS01:0x22: Configuring platform CUDA
13:56:27:WU01:FS01:Upload complete
13:56:27:WU01:FS01:Server responded WORK_ACK (400)
13:56:27:WU01:FS01:Final credit estimate, 293160.00 points
13:56:27:WU01:FS01:Cleaning up
13:57:55:WU00:FS01:0x22: Using CUDA and gpu 0
13:57:55:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
13:57:55:WU00:FS01:0x22:Checkpoint completed at step 0
13:58:27:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
13:58:58:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
13:59:30:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
14:00:02:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
14:00:33:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
14:00:34:WU00:FS01:0x22:Checkpoint completed at step 250000
14:01:05:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
14:01:37:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
14:02:08:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
14:02:40:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
14:03:11:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
14:03:12:WU00:FS01:0x22:Checkpoint completed at step 500000
14:03:43:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
14:04:15:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
14:04:46:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
14:05:18:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
14:05:50:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
14:05:50:WU00:FS01:0x22:Checkpoint completed at step 750000
14:06:21:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
14:06:53:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
14:07:24:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
14:07:56:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
14:08:28:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
14:08:28:WU00:FS01:0x22:Checkpoint completed at step 1000000
14:08:59:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
14:09:31:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
14:10:02:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
14:10:34:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
14:11:06:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
14:11:06:WU00:FS01:0x22:Checkpoint completed at step 1250000
14:11:37:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
14:12:09:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
14:12:40:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
14:13:12:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
14:13:44:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
14:13:44:WU00:FS01:0x22:Checkpoint completed at step 1500000
14:14:16:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
14:14:47:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
14:15:19:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
14:15:50:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
14:16:22:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
14:16:22:WU00:FS01:0x22:Checkpoint completed at step 1750000
14:16:54:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
14:17:25:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
14:17:57:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
14:18:29:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
14:19:00:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
14:19:00:WU00:FS01:0x22:Checkpoint completed at step 2000000
14:19:32:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
14:20:04:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
14:20:35:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
14:21:07:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
14:21:38:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
14:21:38:WU00:FS01:0x22:Checkpoint completed at step 2250000
14:22:10:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
14:22:42:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
14:23:13:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
14:23:45:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
14:24:17:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
14:24:17:WU00:FS01:0x22:Checkpoint completed at step 2500000
14:24:48:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
14:25:20:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
14:25:51:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
14:26:23:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
14:26:54:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
14:26:55:WU00:FS01:0x22:Checkpoint completed at step 2750000
14:27:26:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
14:27:58:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
14:28:30:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
14:29:01:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
14:29:33:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
14:29:33:WU00:FS01:0x22:Checkpoint completed at step 3000000
14:30:04:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
14:30:36:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
14:31:07:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
14:31:39:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
14:32:11:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
14:32:11:WU00:FS01:0x22:Checkpoint completed at step 3250000
14:32:42:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
14:33:14:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
14:33:45:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
14:34:17:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
14:34:48:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
14:34:49:WU00:FS01:0x22:Checkpoint completed at step 3500000
14:35:20:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
14:35:52:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
14:36:23:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
14:36:55:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
14:37:26:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
14:37:26:WU00:FS01:0x22:Checkpoint completed at step 3750000
14:37:58:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
14:38:30:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
14:39:01:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
14:39:33:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
14:40:04:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
14:40:04:WU00:FS01:0x22:Checkpoint completed at step 4000000
14:40:36:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
14:41:07:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
14:41:39:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
14:42:11:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
14:42:42:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
14:42:42:WU00:FS01:0x22:Checkpoint completed at step 4250000
14:43:14:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
14:43:46:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
14:44:17:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
14:44:49:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
14:45:20:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
14:45:20:WU00:FS01:0x22:Checkpoint completed at step 4500000
14:45:52:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
14:46:23:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
14:46:55:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
14:47:27:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
14:47:58:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
14:47:58:WU00:FS01:0x22:Checkpoint completed at step 4750000
14:48:30:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
14:49:01:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
14:49:33:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
14:50:04:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
14:50:36:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
14:50:36:WU00:FS01:0x22:Average performance: 109.367 ns/day
14:50:36:WU00:FS01:0x22:Checkpoint completed at step 5000000
14:50:37:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:50:37:WU01:FS01:Assigned to work server 34.72.228.44
14:50:37:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 34.72.228.44
14:50:37:WU01:FS01:Connecting to 34.72.228.44:8080
14:50:37:WU01:FS01:Downloading 1.85MiB
14:50:38:WU01:FS01:Download complete
14:50:38:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18117 run:2 clone:192 gen:40 core:0x22 unit:0x000000c000000028000046c500000002
14:50:38:WU00:FS01:0x22:Saving result file ../logfile_01.txt
14:50:38:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
14:50:38:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
14:50:38:WU00:FS01:0x22:Saving result file positions.xtc
14:50:38:WU00:FS01:0x22:Saving result file science.log
14:50:38:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
14:50:38:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:50:38:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18117 run:3 clone:96 gen:37 core:0x22 unit:0x0000006000000025000046c500000003
14:50:38:WU00:FS01:Uploading 10.19MiB to 34.72.228.44
14:50:38:WU00:FS01:Connecting to 34.72.228.44:8080
14:50:38:WU01:FS01:Starting
14:50:38:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:50:38:WU01:FS01:Started FahCore on PID 6808
14:50:38:WU01:FS01:Core PID:6812
14:50:38:WU01:FS01:FahCore 0x22 started
14:50:39:WU01:FS01:0x22:*********************** Log Started 2021-11-11T14:50:38Z ***********************
14:50:39:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
14:50:39:WU01:FS01:0x22: Core: Core22
14:50:39:WU01:FS01:0x22: Type: 0x22
14:50:39:WU01:FS01:0x22: Version: 0.0.13
14:50:39:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
14:50:39:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
14:50:39:WU01:FS01:0x22: Homepage: https://foldingathome.org/
14:50:39:WU01:FS01:0x22: Date: Sep 19 2020
14:50:39:WU01:FS01:0x22: Time: 01:10:35
14:50:39:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:50:39:WU01:FS01:0x22: Branch: core22-0.0.13
14:50:39:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
14:50:39:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
14:50:39:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
14:50:39:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
14:50:39:WU01:FS01:0x22: Bits: 64
14:50:39:WU01:FS01:0x22: Mode: Release
14:50:39:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
14:50:39:WU01:FS01:0x22: <[email protected]>
14:50:39:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 6808 -checkpoint 15
14:50:39:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
14:50:39:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
14:50:39:WU01:FS01:0x22:************************************ libFAH ************************************
14:50:39:WU01:FS01:0x22: Date: Sep 15 2020
14:50:39:WU01:FS01:0x22: Time: 05:14:43
14:50:39:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:50:39:WU01:FS01:0x22: Branch: HEAD
14:50:39:WU01:FS01:0x22:************************************ CBang *************************************
14:50:39:WU01:FS01:0x22: Time: 05:11:04
14:50:39:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:50:39:WU01:FS01:0x22: -funroll-loops -fPIC
14:50:39:WU01:FS01:0x22:************************************ System ************************************
14:50:39:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
14:50:39:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:50:39:WU01:FS01:0x22: CPUs: 8
14:50:39:WU01:FS01:0x22: Memory: 15.58GiB
14:50:39:WU01:FS01:0x22:Free Memory: 12.43GiB
14:50:39:WU01:FS01:0x22: Threads: POSIX_THREADS
14:50:39:WU01:FS01:0x22: OS Version: 5.11
14:50:39:WU01:FS01:0x22:Has Battery: false
14:50:39:WU01:FS01:0x22: On Battery: false
14:50:39:WU01:FS01:0x22: UTC Offset: -5
14:50:39:WU01:FS01:0x22: PID: 6812
14:50:39:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
14:50:39:WU01:FS01:0x22:************************************ OpenMM ************************************
14:50:39:WU01:FS01:0x22: Revision: 189320d0
14:50:39:WU01:FS01:0x22:********************************************************************************
14:50:39:WU01:FS01:0x22:Project: 18117 (Run 2, Clone 192, Gen 40)
14:50:39:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
14:50:39:WU01:FS01:0x22:Reading tar file core.xml
14:50:39:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
14:50:39:WU01:FS01:0x22:Reading tar file state.xml.bz2
14:50:39:WU01:FS01:0x22:Reading tar file system.xml.bz2
14:50:39:WU01:FS01:0x22:Digital signatures verified
14:50:39:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
14:50:39:WU01:FS01:0x22:Version 0.0.13
14:50:39:WU01:FS01:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
14:50:39:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
14:50:39:WU01:FS01:0x22: XTC frame write interval: 50000 steps (1%) [100 total]
14:50:39:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
14:50:39:WU01:FS01:0x22:There are 4 platforms available.
14:50:39:WU01:FS01:0x22:Platform 0: Reference
14:50:39:WU01:FS01:0x22:Platform 1: CPU
14:50:39:WU01:FS01:0x22:Platform 2: OpenCL
14:50:39:WU01:FS01:0x22: opencl-device 0 specified
14:50:39:WU01:FS01:0x22:Platform 3: CUDA
14:50:39:WU01:FS01:0x22: cuda-device 0 specified
14:50:40:WU01:FS01:0x22:Attempting to create CUDA context:
14:50:40:WU01:FS01:0x22: Configuring platform CUDA
14:50:47:WU00:FS01:Upload complete
14:50:47:WU00:FS01:Server responded WORK_ACK (400)
14:50:47:WU00:FS01:Final credit estimate, 135413.00 points
14:50:47:WU00:FS01:Cleaning up
14:52:09:WU01:FS01:0x22: Using CUDA and gpu 0
14:52:09:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
14:52:09:WU01:FS01:0x22:Checkpoint completed at step 0
14:52:41:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
14:53:12:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
14:53:43:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
14:54:14:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
14:54:46:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
14:54:46:WU01:FS01:0x22:Checkpoint completed at step 250000
14:55:17:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
14:55:48:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
14:56:20:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
14:56:51:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
14:57:22:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
14:57:22:WU01:FS01:0x22:Checkpoint completed at step 500000
14:57:54:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
14:58:25:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
14:58:56:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
14:59:28:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
14:59:59:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
14:59:59:WU01:FS01:0x22:Checkpoint completed at step 750000
15:00:30:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
15:01:02:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
15:01:33:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
15:02:04:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
15:02:36:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
15:02:36:WU01:FS01:0x22:Checkpoint completed at step 1000000
15:03:07:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
15:03:38:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
15:04:10:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
15:04:41:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
15:05:12:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
15:05:13:WU01:FS01:0x22:Checkpoint completed at step 1250000
15:05:44:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
15:06:15:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
15:06:47:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
15:07:18:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
15:07:49:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
15:07:50:WU01:FS01:0x22:Checkpoint completed at step 1500000
15:08:21:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
15:08:52:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
15:09:23:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
15:09:55:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
15:10:26:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
15:10:26:WU01:FS01:0x22:Checkpoint completed at step 1750000
15:10:58:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
15:11:29:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
15:12:00:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
15:12:31:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
15:13:03:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
15:13:03:WU01:FS01:0x22:Checkpoint completed at step 2000000
15:13:34:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
15:14:05:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
15:14:37:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
15:15:08:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
15:15:39:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
15:15:39:WU01:FS01:0x22:Checkpoint completed at step 2250000
15:16:11:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
15:16:42:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
15:17:13:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
15:17:45:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
15:18:16:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
15:18:16:WU01:FS01:0x22:Checkpoint completed at step 2500000
15:18:47:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
15:19:19:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
15:19:50:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
15:20:21:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
15:20:53:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
15:20:53:WU01:FS01:0x22:Checkpoint completed at step 2750000
15:21:24:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
15:21:55:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
15:22:27:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
15:22:58:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
15:23:29:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
15:23:29:WU01:FS01:0x22:Checkpoint completed at step 3000000
15:24:01:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
15:24:32:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
15:25:03:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
15:25:34:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
15:26:06:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
15:26:06:WU01:FS01:0x22:Checkpoint completed at step 3250000
15:26:37:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
15:27:08:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
15:27:39:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
15:28:11:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
15:28:42:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
15:28:42:WU01:FS01:0x22:Checkpoint completed at step 3500000
15:29:13:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
15:29:45:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
15:30:16:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
15:30:47:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
15:31:19:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
15:31:19:WU01:FS01:0x22:Checkpoint completed at step 3750000
15:31:50:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
15:32:21:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
15:32:52:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
15:33:24:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
15:33:55:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
15:33:55:WU01:FS01:0x22:Checkpoint completed at step 4000000
15:34:27:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
15:34:58:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
15:35:29:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
15:36:01:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
15:36:32:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
15:36:32:WU01:FS01:0x22:Checkpoint completed at step 4250000
15:37:03:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
15:37:34:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
15:38:06:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
15:38:37:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
15:39:08:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
15:39:08:WU01:FS01:0x22:Checkpoint completed at step 4500000
15:39:40:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
15:40:11:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
15:40:42:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
15:41:14:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
15:41:45:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
15:41:45:WU01:FS01:0x22:Checkpoint completed at step 4750000
15:42:16:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
15:42:48:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
15:43:19:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
15:43:50:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
15:44:21:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
15:44:21:WU01:FS01:0x22:Average performance: 110.769 ns/day
15:44:22:WU01:FS01:0x22:Checkpoint completed at step 5000000
15:44:22:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:44:22:WU00:FS01:Assigned to work server 128.252.203.11
15:44:22:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 128.252.203.11
15:44:22:WU00:FS01:Connecting to 128.252.203.11:8080
15:44:24:WU01:FS01:0x22:Saving result file ../logfile_01.txt
15:44:24:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
15:44:24:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
15:44:24:WU01:FS01:0x22:Saving result file positions.xtc
15:44:24:WU01:FS01:0x22:Saving result file science.log
15:44:24:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
15:44:24:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:44:24:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18117 run:2 clone:192 gen:40 core:0x22 unit:0x000000c000000028000046c500000002
15:44:24:WU01:FS01:Uploading 10.75MiB to 34.72.228.44
15:44:24:WU01:FS01:Connecting to 34.72.228.44:8080
15:44:30:WU01:FS01:Upload 96.56%
15:44:32:WU00:FS01:Downloading 26.57MiB
15:44:33:WU01:FS01:Upload complete
15:44:33:WU01:FS01:Server responded WORK_ACK (400)
15:44:33:WU01:FS01:Final credit estimate, 135998.00 points
15:44:33:WU01:FS01:Cleaning up
15:44:37:WU00:FS01:Download complete
15:44:37:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18201 run:26493 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000677d
15:44:37:WU00:FS01:Starting
15:44:37:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
15:44:37:WU00:FS01:Started FahCore on PID 6911
15:44:37:WU00:FS01:Core PID:6915
15:44:37:WU00:FS01:FahCore 0x22 started
15:44:38:WU00:FS01:0x22:*********************** Log Started 2021-11-11T15:44:37Z ***********************
15:44:38:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
15:44:38:WU00:FS01:0x22: Core: Core22
15:44:38:WU00:FS01:0x22: Type: 0x22
15:44:38:WU00:FS01:0x22: Version: 0.0.13
15:44:38:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
15:44:38:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
15:44:38:WU00:FS01:0x22: Homepage: https://foldingathome.org/
15:44:38:WU00:FS01:0x22: Date: Sep 19 2020
15:44:38:WU00:FS01:0x22: Time: 01:10:35
15:44:38:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:44:38:WU00:FS01:0x22: Branch: core22-0.0.13
15:44:38:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:44:38:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
15:44:38:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
15:44:38:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
15:44:38:WU00:FS01:0x22: Bits: 64
15:44:38:WU00:FS01:0x22: Mode: Release
15:44:38:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
15:44:38:WU00:FS01:0x22: <[email protected]>
15:44:38:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 6911 -checkpoint 15
15:44:38:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:44:38:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
15:44:38:WU00:FS01:0x22:************************************ libFAH ************************************
15:44:38:WU00:FS01:0x22: Date: Sep 15 2020
15:44:38:WU00:FS01:0x22: Time: 05:14:43
15:44:38:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:44:38:WU00:FS01:0x22: Branch: HEAD
15:44:38:WU00:FS01:0x22:************************************ CBang *************************************
15:44:38:WU00:FS01:0x22: Time: 05:11:04
15:44:38:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:44:38:WU00:FS01:0x22: -funroll-loops -fPIC
15:44:38:WU00:FS01:0x22:************************************ System ************************************
15:44:38:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
15:44:38:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:44:38:WU00:FS01:0x22: CPUs: 8
15:44:38:WU00:FS01:0x22: Memory: 15.58GiB
15:44:38:WU00:FS01:0x22:Free Memory: 12.41GiB
15:44:38:WU00:FS01:0x22: Threads: POSIX_THREADS
15:44:38:WU00:FS01:0x22: OS Version: 5.11
15:44:38:WU00:FS01:0x22:Has Battery: false
15:44:38:WU00:FS01:0x22: On Battery: false
15:44:38:WU00:FS01:0x22: UTC Offset: -5
15:44:38:WU00:FS01:0x22: PID: 6915
15:44:38:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
15:44:38:WU00:FS01:0x22:************************************ OpenMM ************************************
15:44:38:WU00:FS01:0x22: Revision: 189320d0
15:44:38:WU00:FS01:0x22:********************************************************************************
15:44:38:WU00:FS01:0x22:Project: 18201 (Run 26493, Clone 0, Gen 14)
15:44:38:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
15:44:38:WU00:FS01:0x22:Reading tar file core.xml
15:44:38:WU00:FS01:0x22:Reading tar file integrator.xml
15:44:38:WU00:FS01:0x22:Reading tar file state.xml
15:44:38:WU00:FS01:0x22:Reading tar file system.xml
15:44:38:WU00:FS01:0x22:Digital signatures verified
15:44:38:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
15:44:38:WU00:FS01:0x22:Version 0.0.13
15:44:38:WU00:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
15:44:38:WU00:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
15:44:38:WU00:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
15:44:38:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
15:44:38:WU00:FS01:0x22:There are 4 platforms available.
15:44:38:WU00:FS01:0x22:Platform 0: Reference
15:44:38:WU00:FS01:0x22:Platform 1: CPU
15:44:38:WU00:FS01:0x22:Platform 2: OpenCL
15:44:38:WU00:FS01:0x22: opencl-device 0 specified
15:44:38:WU00:FS01:0x22:Platform 3: CUDA
15:44:38:WU00:FS01:0x22: cuda-device 0 specified
15:44:47:WU00:FS01:0x22:Attempting to create CUDA context:
15:44:47:WU00:FS01:0x22: Configuring platform CUDA
15:46:18:WU00:FS01:0x22: Using CUDA and gpu 0
15:46:18:WU00:FS01:0x22:Completed 0 out of 1250000 steps (0%)
15:46:18:WU00:FS01:0x22:Checkpoint completed at step 0
15:47:18:WU00:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
15:48:18:WU00:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
15:48:19:WU00:FS01:0x22:Checkpoint completed at step 25000
15:49:19:WU00:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
15:50:18:WU00:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
15:50:19:WU00:FS01:0x22:Checkpoint completed at step 50000
15:51:19:WU00:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
15:52:19:WU00:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
15:52:19:WU00:FS01:0x22:Checkpoint completed at step 75000
15:53:19:WU00:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
15:54:19:WU00:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
15:54:20:WU00:FS01:0x22:Checkpoint completed at step 100000
15:55:20:WU00:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
15:56:19:WU00:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
15:56:20:WU00:FS01:0x22:Checkpoint completed at step 125000
15:57:20:WU00:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
15:58:20:WU00:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
15:58:21:WU00:FS01:0x22:Checkpoint completed at step 150000
15:59:21:WU00:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
16:00:20:WU00:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
16:00:21:WU00:FS01:0x22:Checkpoint completed at step 175000
16:01:22:WU00:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
16:02:21:WU00:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
16:02:22:WU00:FS01:0x22:Checkpoint completed at step 200000
16:03:22:WU00:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
16:04:22:WU00:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
16:04:23:WU00:FS01:0x22:Checkpoint completed at step 225000
16:05:23:WU00:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
16:06:22:WU00:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
16:06:23:WU00:FS01:0x22:Checkpoint completed at step 250000
16:07:23:WU00:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
16:08:23:WU00:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
16:08:24:WU00:FS01:0x22:Checkpoint completed at step 275000
16:09:24:WU00:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
16:10:24:WU00:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
16:10:24:WU00:FS01:0x22:Checkpoint completed at step 300000
16:11:24:WU00:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
16:12:24:WU00:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
16:12:25:WU00:FS01:0x22:Checkpoint completed at step 325000
16:13:25:WU00:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
16:14:25:WU00:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
16:14:26:WU00:FS01:0x22:Checkpoint completed at step 350000
16:15:26:WU00:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
16:16:25:WU00:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
16:16:26:WU00:FS01:0x22:Checkpoint completed at step 375000
16:17:26:WU00:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
16:18:26:WU00:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
16:18:27:WU00:FS01:0x22:Checkpoint completed at step 400000
16:19:27:WU00:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
16:20:27:WU00:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
16:20:28:WU00:FS01:0x22:Checkpoint completed at step 425000
16:21:28:WU00:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
16:22:27:WU00:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
16:22:28:WU00:FS01:0x22:Checkpoint completed at step 450000
16:23:28:WU00:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
16:24:28:WU00:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
16:24:29:WU00:FS01:0x22:Checkpoint completed at step 475000
16:25:29:WU00:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
16:26:29:WU00:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
16:26:30:WU00:FS01:0x22:Checkpoint completed at step 500000
16:27:30:WU00:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
16:28:30:WU00:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
16:28:31:WU00:FS01:0x22:Checkpoint completed at step 525000
16:29:31:WU00:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
16:30:30:WU00:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
16:30:31:WU00:FS01:0x22:Checkpoint completed at step 550000
16:31:31:WU00:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
16:32:31:WU00:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
16:32:32:WU00:FS01:0x22:Checkpoint completed at step 575000
16:33:32:WU00:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
16:34:32:WU00:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
16:34:33:WU00:FS01:0x22:Checkpoint completed at step 600000
16:35:33:WU00:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
16:36:32:WU00:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
16:36:33:WU00:FS01:0x22:Checkpoint completed at step 625000
16:37:33:WU00:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
16:38:33:WU00:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
16:38:34:WU00:FS01:0x22:Checkpoint completed at step 650000
16:39:34:WU00:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
16:40:33:WU00:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
16:40:34:WU00:FS01:0x22:Checkpoint completed at step 675000
16:41:34:WU00:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
16:42:34:WU00:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
16:42:35:WU00:FS01:0x22:Checkpoint completed at step 700000
16:43:35:WU00:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
16:44:35:WU00:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
16:44:36:WU00:FS01:0x22:Checkpoint completed at step 725000
16:45:36:WU00:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
16:46:35:WU00:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
16:46:36:WU00:FS01:0x22:Checkpoint completed at step 750000
16:47:36:WU00:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
16:48:36:WU00:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
16:48:37:WU00:FS01:0x22:Checkpoint completed at step 775000
16:49:37:WU00:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
16:50:36:WU00:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
16:50:37:WU00:FS01:0x22:Checkpoint completed at step 800000
16:51:37:WU00:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
16:52:37:WU00:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
16:52:38:WU00:FS01:0x22:Checkpoint completed at step 825000
16:53:38:WU00:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
16:54:38:WU00:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
16:54:39:WU00:FS01:0x22:Checkpoint completed at step 850000
16:55:39:WU00:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
16:56:38:WU00:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
16:56:39:WU00:FS01:0x22:Checkpoint completed at step 875000
16:57:39:WU00:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
16:58:39:WU00:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
16:58:39:WU00:FS01:0x22:Checkpoint completed at step 900000
16:59:39:WU00:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
17:00:39:WU00:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
17:00:40:WU00:FS01:0x22:Checkpoint completed at step 925000
17:01:40:WU00:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
17:02:40:WU00:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
17:02:41:WU00:FS01:0x22:Checkpoint completed at step 950000
17:03:41:WU00:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
17:04:40:WU00:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
17:04:41:WU00:FS01:0x22:Checkpoint completed at step 975000
17:05:41:WU00:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
17:06:41:WU00:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
17:06:42:WU00:FS01:0x22:Checkpoint completed at step 1000000
17:07:42:WU00:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
17:08:42:WU00:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
17:08:43:WU00:FS01:0x22:Checkpoint completed at step 1025000
17:09:43:WU00:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
17:10:42:WU00:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
17:10:43:WU00:FS01:0x22:Checkpoint completed at step 1050000
17:11:43:WU00:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
17:12:43:WU00:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
17:12:44:WU00:FS01:0x22:Checkpoint completed at step 1075000
17:13:44:WU00:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
17:14:43:WU00:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
17:14:44:WU00:FS01:0x22:Checkpoint completed at step 1100000
17:15:44:WU00:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
17:16:44:WU00:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
17:16:45:WU00:FS01:0x22:Checkpoint completed at step 1125000
17:17:45:WU00:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
17:18:45:WU00:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
17:18:46:WU00:FS01:0x22:Checkpoint completed at step 1150000
17:19:46:WU00:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
17:20:45:WU00:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
17:20:46:WU00:FS01:0x22:Checkpoint completed at step 1175000
17:21:47:WU00:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
17:22:46:WU00:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
17:22:47:WU00:FS01:0x22:Checkpoint completed at step 1200000
17:23:47:WU00:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
17:24:47:WU00:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
17:24:48:WU00:FS01:0x22:Checkpoint completed at step 1225000
17:25:48:WU00:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
17:26:48:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
17:26:48:WU00:FS01:0x22:Average performance: 28.8 ns/day
17:26:48:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:26:48:WU01:FS01:Assigned to work server 129.32.209.202
17:26:48:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
17:26:48:WU01:FS01:Connecting to 129.32.209.202:8080
17:26:48:WU01:FS01:Downloading 27.78MiB
17:26:49:WU00:FS01:0x22:Checkpoint completed at step 1250000
17:26:51:WU01:FS01:Download complete
17:26:51:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:4 clone:16 gen:102 core:0x22 unit:0x0000001000000066000047ff00000004
17:26:54:WU00:FS01:0x22:Saving result file ../logfile_01.txt
17:26:54:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
17:26:54:WU00:FS01:0x22:Saving result file checkpointState.xml
17:26:57:WU00:FS01:0x22:Saving result file positions.xtc
17:26:57:WU00:FS01:0x22:Saving result file science.log
17:26:57:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
17:26:58:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:26:58:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18201 run:26493 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000677d
17:26:58:WU00:FS01:Uploading 27.50MiB to 128.252.203.11
17:26:58:WU00:FS01:Connecting to 128.252.203.11:8080
17:26:58:WU01:FS01:Starting
17:26:58:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
17:26:58:WU01:FS01:Started FahCore on PID 7077
17:26:58:WU01:FS01:Core PID:7081
17:26:58:WU01:FS01:FahCore 0x22 started
17:26:58:WU01:FS01:0x22:*********************** Log Started 2021-11-11T17:26:58Z ***********************
17:26:58:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
17:26:58:WU01:FS01:0x22: Core: Core22
17:26:58:WU01:FS01:0x22: Type: 0x22
17:26:58:WU01:FS01:0x22: Version: 0.0.13
17:26:58:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
17:26:58:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
17:26:58:WU01:FS01:0x22: Homepage: https://foldingathome.org/
17:26:58:WU01:FS01:0x22: Date: Sep 19 2020
17:26:58:WU01:FS01:0x22: Time: 01:10:35
17:26:58:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
17:26:58:WU01:FS01:0x22: Branch: core22-0.0.13
17:26:58:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
17:26:58:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
17:26:58:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
17:26:58:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
17:26:58:WU01:FS01:0x22: Bits: 64
17:26:58:WU01:FS01:0x22: Mode: Release
17:26:58:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
17:26:58:WU01:FS01:0x22: <[email protected]>
17:26:58:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 7077 -checkpoint 15
17:26:58:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
17:26:58:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
17:26:58:WU01:FS01:0x22:************************************ libFAH ************************************
17:26:58:WU01:FS01:0x22: Date: Sep 15 2020
17:26:58:WU01:FS01:0x22: Time: 05:14:43
17:26:58:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
17:26:58:WU01:FS01:0x22: Branch: HEAD
17:26:58:WU01:FS01:0x22:************************************ CBang *************************************
17:26:58:WU01:FS01:0x22: Time: 05:11:04
17:26:58:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
17:26:58:WU01:FS01:0x22: -funroll-loops -fPIC
17:26:58:WU01:FS01:0x22:************************************ System ************************************
17:26:58:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
17:26:58:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:26:58:WU01:FS01:0x22: CPUs: 8
17:26:58:WU01:FS01:0x22: Memory: 15.58GiB
17:26:58:WU01:FS01:0x22:Free Memory: 12.29GiB
17:26:58:WU01:FS01:0x22: Threads: POSIX_THREADS
17:26:58:WU01:FS01:0x22: OS Version: 5.11
17:26:58:WU01:FS01:0x22:Has Battery: false
17:26:58:WU01:FS01:0x22: On Battery: false
17:26:58:WU01:FS01:0x22: UTC Offset: -5
17:26:58:WU01:FS01:0x22: PID: 7081
17:26:58:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
17:26:58:WU01:FS01:0x22:************************************ OpenMM ************************************
17:26:58:WU01:FS01:0x22: Revision: 189320d0
17:26:58:WU01:FS01:0x22:********************************************************************************
17:26:58:WU01:FS01:0x22:Project: 18431 (Run 4, Clone 16, Gen 102)
17:26:58:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
17:26:58:WU01:FS01:0x22:Reading tar file core.xml
17:26:58:WU01:FS01:0x22:Reading tar file integrator.xml
17:26:58:WU01:FS01:0x22:Reading tar file state.xml
17:26:58:WU01:FS01:0x22:Reading tar file system.xml
17:26:58:WU01:FS01:0x22:Digital signatures verified
17:26:58:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
17:26:58:WU01:FS01:0x22:Version 0.0.13
17:26:58:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
17:26:58:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
17:26:58:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
17:26:58:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
17:26:58:WU01:FS01:0x22:There are 4 platforms available.
17:26:58:WU01:FS01:0x22:Platform 0: Reference
17:26:58:WU01:FS01:0x22:Platform 1: CPU
17:26:58:WU01:FS01:0x22:Platform 2: OpenCL
17:26:58:WU01:FS01:0x22: opencl-device 0 specified
17:26:58:WU01:FS01:0x22:Platform 3: CUDA
17:26:58:WU01:FS01:0x22: cuda-device 0 specified
17:27:00:WU01:FS01:0x22:Attempting to create CUDA context:
17:27:00:WU01:FS01:0x22: Configuring platform CUDA
17:27:04:WU00:FS01:Upload 39.09%
17:27:10:WU00:FS01:Upload 78.87%
17:27:14:WU00:FS01:Upload complete
17:27:14:WU00:FS01:Server responded WORK_ACK (400)
17:27:14:WU00:FS01:Final credit estimate, 491017.00 points
17:27:14:WU00:FS01:Cleaning up
17:28:27:WU01:FS01:0x22: Using CUDA and gpu 0
17:28:27:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
17:28:27:WU01:FS01:0x22:Checkpoint completed at step 0
17:29:10:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
17:29:53:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
17:29:53:WU01:FS01:0x22:Checkpoint completed at step 100000
17:30:35:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
17:31:18:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
17:31:18:WU01:FS01:0x22:Checkpoint completed at step 200000
17:32:01:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
17:32:44:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
17:32:44:WU01:FS01:0x22:Checkpoint completed at step 300000
17:33:27:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
17:34:09:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
17:34:10:WU01:FS01:0x22:Checkpoint completed at step 400000
17:34:52:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
17:35:35:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
17:35:35:WU01:FS01:0x22:Checkpoint completed at step 500000
17:36:18:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
17:37:01:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
17:37:01:WU01:FS01:0x22:Checkpoint completed at step 600000
17:37:44:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
17:38:26:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
17:38:26:WU01:FS01:0x22:Checkpoint completed at step 700000
17:39:09:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
17:39:52:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
17:39:52:WU01:FS01:0x22:Checkpoint completed at step 800000
17:40:35:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
17:41:18:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
17:41:18:WU01:FS01:0x22:Checkpoint completed at step 900000
17:42:01:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
17:42:44:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
17:42:44:WU01:FS01:0x22:Checkpoint completed at step 1000000
17:43:26:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
17:44:09:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
17:44:09:WU01:FS01:0x22:Checkpoint completed at step 1100000
17:44:52:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
17:45:35:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
17:45:35:WU01:FS01:0x22:Checkpoint completed at step 1200000
17:46:18:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
17:47:01:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
17:47:01:WU01:FS01:0x22:Checkpoint completed at step 1300000
17:47:44:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
17:48:26:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
17:48:26:WU01:FS01:0x22:Checkpoint completed at step 1400000
17:49:09:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
17:49:52:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
17:49:52:WU01:FS01:0x22:Checkpoint completed at step 1500000
17:50:35:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
17:51:18:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
17:51:18:WU01:FS01:0x22:Checkpoint completed at step 1600000
17:52:01:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
17:52:44:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
17:52:44:WU01:FS01:0x22:Checkpoint completed at step 1700000
17:53:27:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
17:54:09:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
17:54:10:WU01:FS01:0x22:Checkpoint completed at step 1800000
17:54:52:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
17:55:35:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
17:55:36:WU01:FS01:0x22:Checkpoint completed at step 1900000
17:56:18:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
17:57:01:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
17:57:01:WU01:FS01:0x22:Checkpoint completed at step 2000000
17:57:44:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
17:58:27:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
17:58:27:WU01:FS01:0x22:Checkpoint completed at step 2100000
17:59:10:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
17:59:53:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
17:59:53:WU01:FS01:0x22:Checkpoint completed at step 2200000
18:00:36:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
18:01:18:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
18:01:19:WU01:FS01:0x22:Checkpoint completed at step 2300000
18:02:01:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
18:02:44:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
18:02:44:WU01:FS01:0x22:Checkpoint completed at step 2400000
18:03:27:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
18:04:10:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
18:04:10:WU01:FS01:0x22:Checkpoint completed at step 2500000
18:04:53:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
18:05:36:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
18:05:36:WU01:FS01:0x22:Checkpoint completed at step 2600000
18:06:18:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
18:07:01:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
18:07:01:WU01:FS01:0x22:Checkpoint completed at step 2700000
18:07:44:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
******************************* Date: 2021-11-11 *******************************
18:08:27:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
18:08:27:WU01:FS01:0x22:Checkpoint completed at step 2800000
18:09:10:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
18:09:53:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
18:09:53:WU01:FS01:0x22:Checkpoint completed at step 2900000
18:10:36:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
18:11:18:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
18:11:18:WU01:FS01:0x22:Checkpoint completed at step 3000000
18:12:01:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
18:12:44:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
18:12:44:WU01:FS01:0x22:Checkpoint completed at step 3100000
18:13:27:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
18:14:09:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
18:14:10:WU01:FS01:0x22:Checkpoint completed at step 3200000
18:14:52:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
18:15:35:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
18:15:35:WU01:FS01:0x22:Checkpoint completed at step 3300000
18:16:18:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
18:17:00:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
18:17:01:WU01:FS01:0x22:Checkpoint completed at step 3400000
18:17:43:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
18:18:26:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
18:18:26:WU01:FS01:0x22:Checkpoint completed at step 3500000
18:19:09:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
18:19:52:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
18:19:52:WU01:FS01:0x22:Checkpoint completed at step 3600000
18:20:34:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
18:21:17:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
18:21:17:WU01:FS01:0x22:Checkpoint completed at step 3700000
18:22:00:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
18:22:43:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
18:22:43:WU01:FS01:0x22:Checkpoint completed at step 3800000
18:23:26:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
18:24:09:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
18:24:09:WU01:FS01:0x22:Checkpoint completed at step 3900000
18:24:52:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
18:25:34:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
18:25:34:WU01:FS01:0x22:Checkpoint completed at step 4000000
18:26:17:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
18:27:00:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
18:27:00:WU01:FS01:0x22:Checkpoint completed at step 4100000
18:27:43:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
18:28:25:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
18:28:26:WU01:FS01:0x22:Checkpoint completed at step 4200000
18:29:08:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
18:29:51:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
18:29:51:WU01:FS01:0x22:Checkpoint completed at step 4300000
18:30:34:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
18:31:17:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
18:31:17:WU01:FS01:0x22:Checkpoint completed at step 4400000
18:32:00:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
18:32:43:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
18:32:43:WU01:FS01:0x22:Checkpoint completed at step 4500000
18:33:26:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
18:34:08:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
18:34:09:WU01:FS01:0x22:Checkpoint completed at step 4600000
18:34:51:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
18:35:34:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
18:35:34:WU01:FS01:0x22:Checkpoint completed at step 4700000
18:36:17:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
18:37:00:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
18:37:00:WU01:FS01:0x22:Checkpoint completed at step 4800000
18:37:43:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
18:38:26:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
18:38:26:WU01:FS01:0x22:Checkpoint completed at step 4900000
18:39:09:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
18:39:51:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
18:39:51:WU01:FS01:0x22:Average performance: 508.235 ns/day
18:39:51:WU01:FS01:0x22:Checkpoint completed at step 5000000
18:39:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:39:52:WU00:FS01:Assigned to work server 129.32.209.202
18:39:52:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
18:39:52:WU00:FS01:Connecting to 129.32.209.202:8080
18:39:52:WU00:FS01:Downloading 27.71MiB
18:39:52:WU01:FS01:0x22:Saving result file ../logfile_01.txt
18:39:52:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
18:39:52:WU01:FS01:0x22:Saving result file checkpointState.xml
18:39:52:WU01:FS01:0x22:Saving result file positions.xtc
18:39:52:WU01:FS01:0x22:Saving result file science.log
18:39:52:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
18:39:53:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:39:53:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:4 clone:16 gen:102 core:0x22 unit:0x0000001000000066000047ff00000004
18:39:53:WU01:FS01:Uploading 14.33MiB to 129.32.209.202
18:39:53:WU01:FS01:Connecting to 129.32.209.202:8080
18:39:55:WU00:FS01:Download complete
18:39:55:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18431 run:3 clone:465 gen:48 core:0x22 unit:0x000001d100000030000047ff00000003
18:39:55:WU00:FS01:Starting
18:39:55:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:39:55:WU00:FS01:Started FahCore on PID 7237
18:39:55:WU00:FS01:Core PID:7241
18:39:55:WU00:FS01:FahCore 0x22 started
18:39:55:WU00:FS01:0x22:*********************** Log Started 2021-11-11T18:39:55Z ***********************
18:39:55:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
18:39:55:WU00:FS01:0x22: Core: Core22
18:39:55:WU00:FS01:0x22: Type: 0x22
18:39:55:WU00:FS01:0x22: Version: 0.0.13
18:39:55:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
18:39:55:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
18:39:55:WU00:FS01:0x22: Homepage: https://foldingathome.org/
18:39:55:WU00:FS01:0x22: Date: Sep 19 2020
18:39:55:WU00:FS01:0x22: Time: 01:10:35
18:39:55:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
18:39:55:WU00:FS01:0x22: Branch: core22-0.0.13
18:39:55:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
18:39:55:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
18:39:55:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
18:39:55:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
18:39:55:WU00:FS01:0x22: Bits: 64
18:39:55:WU00:FS01:0x22: Mode: Release
18:39:55:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
18:39:55:WU00:FS01:0x22: <[email protected]>
18:39:55:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 7237 -checkpoint 15
18:39:55:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:39:55:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
18:39:55:WU00:FS01:0x22:************************************ libFAH ************************************
18:39:55:WU00:FS01:0x22: Date: Sep 15 2020
18:39:55:WU00:FS01:0x22: Time: 05:14:43
18:39:55:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:39:55:WU00:FS01:0x22: Branch: HEAD
18:39:55:WU00:FS01:0x22:************************************ CBang *************************************
18:39:55:WU00:FS01:0x22: Time: 05:11:04
18:39:55:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:39:55:WU00:FS01:0x22: -funroll-loops -fPIC
18:39:55:WU00:FS01:0x22:************************************ System ************************************
18:39:55:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
18:39:55:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
18:39:55:WU00:FS01:0x22: CPUs: 8
18:39:55:WU00:FS01:0x22: Memory: 15.58GiB
18:39:55:WU00:FS01:0x22:Free Memory: 12.26GiB
18:39:55:WU00:FS01:0x22: Threads: POSIX_THREADS
18:39:55:WU00:FS01:0x22: OS Version: 5.11
18:39:55:WU00:FS01:0x22:Has Battery: false
18:39:55:WU00:FS01:0x22: On Battery: false
18:39:55:WU00:FS01:0x22: UTC Offset: -5
18:39:55:WU00:FS01:0x22: PID: 7241
18:39:55:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
18:39:55:WU00:FS01:0x22:************************************ OpenMM ************************************
18:39:55:WU00:FS01:0x22: Revision: 189320d0
18:39:55:WU00:FS01:0x22:********************************************************************************
18:39:55:WU00:FS01:0x22:Project: 18431 (Run 3, Clone 465, Gen 48)
18:39:55:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:39:55:WU00:FS01:0x22:Reading tar file core.xml
18:39:55:WU00:FS01:0x22:Reading tar file integrator.xml
18:39:55:WU00:FS01:0x22:Reading tar file state.xml
18:39:55:WU00:FS01:0x22:Reading tar file system.xml
18:39:55:WU00:FS01:0x22:Digital signatures verified
18:39:55:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
18:39:55:WU00:FS01:0x22:Version 0.0.13
18:39:55:WU00:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
18:39:55:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
18:39:55:WU00:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
18:39:55:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
18:39:55:WU00:FS01:0x22:There are 4 platforms available.
18:39:55:WU00:FS01:0x22:Platform 0: Reference
18:39:55:WU00:FS01:0x22:Platform 1: CPU
18:39:55:WU00:FS01:0x22:Platform 2: OpenCL
18:39:55:WU00:FS01:0x22: opencl-device 0 specified
18:39:55:WU00:FS01:0x22:Platform 3: CUDA
18:39:55:WU00:FS01:0x22: cuda-device 0 specified
18:39:57:WU01:FS01:Upload complete
18:39:57:WU01:FS01:Server responded WORK_ACK (400)
18:39:57:WU01:FS01:Final credit estimate, 291452.00 points
18:39:57:WU01:FS01:Cleaning up
18:39:57:WU00:FS01:0x22:Attempting to create CUDA context:
18:39:57:WU00:FS01:0x22: Configuring platform CUDA
18:41:25:WU00:FS01:0x22: Using CUDA and gpu 0
18:41:25:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
18:41:26:WU00:FS01:0x22:Checkpoint completed at step 0
18:42:08:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
18:42:51:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
18:42:51:WU00:FS01:0x22:Checkpoint completed at step 100000
18:43:34:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
18:44:16:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
18:44:16:WU00:FS01:0x22:Checkpoint completed at step 200000
18:44:59:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
18:45:41:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
18:45:42:WU00:FS01:0x22:Checkpoint completed at step 300000
18:46:24:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
18:47:07:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
18:47:07:WU00:FS01:0x22:Checkpoint completed at step 400000
18:47:49:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
18:48:32:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
18:48:32:WU00:FS01:0x22:Checkpoint completed at step 500000
18:49:15:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
18:49:58:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
18:49:58:WU00:FS01:0x22:Checkpoint completed at step 600000
18:50:40:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
18:51:23:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
18:51:23:WU00:FS01:0x22:Checkpoint completed at step 700000
18:52:06:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
18:52:48:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
18:52:48:WU00:FS01:0x22:Checkpoint completed at step 800000
18:53:31:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
18:54:14:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
18:54:14:WU00:FS01:0x22:Checkpoint completed at step 900000
18:54:56:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
18:55:39:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
18:55:39:WU00:FS01:0x22:Checkpoint completed at step 1000000
18:56:22:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
18:57:05:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
18:57:05:WU00:FS01:0x22:Checkpoint completed at step 1100000
18:57:47:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
18:58:30:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
18:58:30:WU00:FS01:0x22:Checkpoint completed at step 1200000
18:59:13:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
18:59:55:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
18:59:56:WU00:FS01:0x22:Checkpoint completed at step 1300000
19:00:38:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
19:01:21:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
19:01:21:WU00:FS01:0x22:Checkpoint completed at step 1400000
19:02:04:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
19:02:47:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
19:02:47:WU00:FS01:0x22:Checkpoint completed at step 1500000
19:03:30:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
19:04:12:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
19:04:13:WU00:FS01:0x22:Checkpoint completed at step 1600000
19:04:55:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
19:05:38:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
19:05:38:WU00:FS01:0x22:Checkpoint completed at step 1700000
19:06:21:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
19:07:04:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
19:07:04:WU00:FS01:0x22:Checkpoint completed at step 1800000
19:07:47:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
19:08:29:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
19:08:29:WU00:FS01:0x22:Checkpoint completed at step 1900000
19:09:12:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
19:09:55:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
19:09:55:WU00:FS01:0x22:Checkpoint completed at step 2000000
19:10:38:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
19:11:20:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
19:11:21:WU00:FS01:0x22:Checkpoint completed at step 2100000
19:12:03:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
19:12:46:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
19:12:46:WU00:FS01:0x22:Checkpoint completed at step 2200000
19:13:29:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
19:14:11:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
19:14:12:WU00:FS01:0x22:Checkpoint completed at step 2300000
19:14:54:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
19:15:37:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
19:15:37:WU00:FS01:0x22:Checkpoint completed at step 2400000
19:16:20:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
19:17:03:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
19:17:03:WU00:FS01:0x22:Checkpoint completed at step 2500000
19:17:45:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
19:18:28:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
19:18:28:WU00:FS01:0x22:Checkpoint completed at step 2600000
19:19:11:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
19:19:53:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
19:19:53:WU00:FS01:0x22:Checkpoint completed at step 2700000
19:20:36:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
19:21:18:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
19:21:18:WU00:FS01:0x22:Checkpoint completed at step 2800000
19:22:01:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
19:22:43:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
19:22:43:WU00:FS01:0x22:Checkpoint completed at step 2900000
19:23:26:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
19:24:08:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
19:24:08:WU00:FS01:0x22:Checkpoint completed at step 3000000
19:24:51:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
19:25:33:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
19:25:33:WU00:FS01:0x22:Checkpoint completed at step 3100000
19:26:16:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
19:26:58:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
19:26:58:WU00:FS01:0x22:Checkpoint completed at step 3200000
19:27:41:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
19:28:23:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
19:28:23:WU00:FS01:0x22:Checkpoint completed at step 3300000
19:29:06:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
19:29:49:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
19:29:49:WU00:FS01:0x22:Checkpoint completed at step 3400000
19:30:32:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
19:31:14:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
19:31:14:WU00:FS01:0x22:Checkpoint completed at step 3500000
19:31:57:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
19:32:40:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
19:32:40:WU00:FS01:0x22:Checkpoint completed at step 3600000
19:33:22:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
19:34:05:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
19:34:05:WU00:FS01:0x22:Checkpoint completed at step 3700000
19:34:48:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
19:35:30:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
19:35:31:WU00:FS01:0x22:Checkpoint completed at step 3800000
19:36:13:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
19:36:56:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
19:36:56:WU00:FS01:0x22:Checkpoint completed at step 3900000
19:37:39:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
19:38:21:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
19:38:21:WU00:FS01:0x22:Checkpoint completed at step 4000000
19:39:04:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
19:39:46:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
19:39:47:WU00:FS01:0x22:Checkpoint completed at step 4100000
19:40:29:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
19:41:12:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
19:41:12:WU00:FS01:0x22:Checkpoint completed at step 4200000
19:41:55:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
19:42:37:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
19:42:38:WU00:FS01:0x22:Checkpoint completed at step 4300000
19:43:20:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
19:44:03:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
19:44:03:WU00:FS01:0x22:Checkpoint completed at step 4400000
19:44:46:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
19:45:29:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
19:45:29:WU00:FS01:0x22:Checkpoint completed at step 4500000
19:46:12:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
19:46:55:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
19:46:55:WU00:FS01:0x22:Checkpoint completed at step 4600000
19:47:37:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
19:48:20:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
19:48:20:WU00:FS01:0x22:Checkpoint completed at step 4700000
19:49:03:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
19:49:45:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
19:49:46:WU00:FS01:0x22:Checkpoint completed at step 4800000
19:50:28:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
19:51:11:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
19:51:11:WU00:FS01:0x22:Checkpoint completed at step 4900000
19:51:54:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
19:52:36:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
19:52:36:WU00:FS01:0x22:Average performance: 508.235 ns/day
19:52:37:WU00:FS01:0x22:Checkpoint completed at step 5000000
19:52:37:WU01:FS01:Connecting to assign1.foldingathome.org:80
19:52:37:WU01:FS01:Assigned to work server 128.252.203.11
19:52:37:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 128.252.203.11
19:52:37:WU01:FS01:Connecting to 128.252.203.11:8080
19:52:38:WU00:FS01:0x22:Saving result file ../logfile_01.txt
19:52:38:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
19:52:38:WU00:FS01:0x22:Saving result file checkpointState.xml
19:52:38:WU00:FS01:0x22:Saving result file positions.xtc
19:52:38:WU00:FS01:0x22:Saving result file science.log
19:52:38:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
19:52:38:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:52:38:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18431 run:3 clone:465 gen:48 core:0x22 unit:0x000001d100000030000047ff00000003
19:52:38:WU00:FS01:Uploading 14.32MiB to 129.32.209.202
19:52:38:WU00:FS01:Connecting to 129.32.209.202:8080
19:52:40:WU00:FS01:Upload complete
19:52:40:WU00:FS01:Server responded WORK_ACK (400)
19:52:40:WU00:FS01:Final credit estimate, 292152.00 points
19:52:40:WU00:FS01:Cleaning up
19:52:47:WU01:FS01:Downloading 26.58MiB
19:52:50:WU01:FS01:Download complete
19:52:50:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18201 run:37548 clone:0 gen:13 core:0x22 unit:0x000000000000000d00004719000092ac
19:52:50:WU01:FS01:Starting
19:52:50:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:52:50:WU01:FS01:Started FahCore on PID 7429
19:52:50:WU01:FS01:Core PID:7433
19:52:50:WU01:FS01:FahCore 0x22 started
19:52:51:WU01:FS01:0x22:*********************** Log Started 2021-11-11T19:52:50Z ***********************
19:52:51:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
19:52:51:WU01:FS01:0x22: Core: Core22
19:52:51:WU01:FS01:0x22: Type: 0x22
19:52:51:WU01:FS01:0x22: Version: 0.0.13
19:52:51:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
19:52:51:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
19:52:51:WU01:FS01:0x22: Homepage: https://foldingathome.org/
19:52:51:WU01:FS01:0x22: Date: Sep 19 2020
19:52:51:WU01:FS01:0x22: Time: 01:10:35
19:52:51:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:52:51:WU01:FS01:0x22: Branch: core22-0.0.13
19:52:51:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
19:52:51:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
19:52:51:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
19:52:51:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
19:52:51:WU01:FS01:0x22: Bits: 64
19:52:51:WU01:FS01:0x22: Mode: Release
19:52:51:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
19:52:51:WU01:FS01:0x22: <[email protected]>
19:52:51:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 7429 -checkpoint 15
19:52:51:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:52:51:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
19:52:51:WU01:FS01:0x22:************************************ libFAH ************************************
19:52:51:WU01:FS01:0x22: Date: Sep 15 2020
19:52:51:WU01:FS01:0x22: Time: 05:14:43
19:52:51:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:52:51:WU01:FS01:0x22: Branch: HEAD
19:52:51:WU01:FS01:0x22:************************************ CBang *************************************
19:52:51:WU01:FS01:0x22: Time: 05:11:04
19:52:51:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:52:51:WU01:FS01:0x22: -funroll-loops -fPIC
19:52:51:WU01:FS01:0x22:************************************ System ************************************
19:52:51:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
19:52:51:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
19:52:51:WU01:FS01:0x22: CPUs: 8
19:52:51:WU01:FS01:0x22: Memory: 15.58GiB
19:52:51:WU01:FS01:0x22:Free Memory: 12.28GiB
19:52:51:WU01:FS01:0x22: Threads: POSIX_THREADS
19:52:51:WU01:FS01:0x22: OS Version: 5.11
19:52:51:WU01:FS01:0x22:Has Battery: false
19:52:51:WU01:FS01:0x22: On Battery: false
19:52:51:WU01:FS01:0x22: UTC Offset: -5
19:52:51:WU01:FS01:0x22: PID: 7433
19:52:51:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
19:52:51:WU01:FS01:0x22:************************************ OpenMM ************************************
19:52:51:WU01:FS01:0x22: Revision: 189320d0
19:52:51:WU01:FS01:0x22:********************************************************************************
19:52:51:WU01:FS01:0x22:Project: 18201 (Run 37548, Clone 0, Gen 13)
19:52:51:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
19:52:51:WU01:FS01:0x22:Reading tar file core.xml
19:52:51:WU01:FS01:0x22:Reading tar file integrator.xml
19:52:51:WU01:FS01:0x22:Reading tar file state.xml
19:52:51:WU01:FS01:0x22:Reading tar file system.xml
19:52:52:WU01:FS01:0x22:Digital signatures verified
19:52:52:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
19:52:52:WU01:FS01:0x22:Version 0.0.13
19:52:52:WU01:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
19:52:52:WU01:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:52:52:WU01:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
19:52:52:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
19:52:52:WU01:FS01:0x22:There are 4 platforms available.
19:52:52:WU01:FS01:0x22:Platform 0: Reference
19:52:52:WU01:FS01:0x22:Platform 1: CPU
19:52:52:WU01:FS01:0x22:Platform 2: OpenCL
19:52:52:WU01:FS01:0x22: opencl-device 0 specified
19:52:52:WU01:FS01:0x22:Platform 3: CUDA
19:52:52:WU01:FS01:0x22: cuda-device 0 specified
19:53:01:WU01:FS01:0x22:Attempting to create CUDA context:
19:53:01:WU01:FS01:0x22: Configuring platform CUDA
19:54:32:WU01:FS01:0x22: Using CUDA and gpu 0
19:54:32:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
19:54:33:WU01:FS01:0x22:Checkpoint completed at step 0
19:55:33:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
19:56:32:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
19:56:33:WU01:FS01:0x22:Checkpoint completed at step 25000
19:57:33:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
19:58:33:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
19:58:33:WU01:FS01:0x22:Checkpoint completed at step 50000
19:59:33:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
20:00:33:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
20:00:34:WU01:FS01:0x22:Checkpoint completed at step 75000
20:01:34:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
20:02:33:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
20:02:34:WU01:FS01:0x22:Checkpoint completed at step 100000
20:03:34:WU01:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
20:04:34:WU01:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
20:04:35:WU01:FS01:0x22:Checkpoint completed at step 125000
20:05:35:WU01:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
20:06:34:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
20:06:35:WU01:FS01:0x22:Checkpoint completed at step 150000
20:07:35:WU01:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
20:08:35:WU01:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
20:08:36:WU01:FS01:0x22:Checkpoint completed at step 175000
20:09:36:WU01:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
20:10:36:WU01:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
20:10:37:WU01:FS01:0x22:Checkpoint completed at step 200000
20:11:37:WU01:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
20:12:36:WU01:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
20:12:37:WU01:FS01:0x22:Checkpoint completed at step 225000
20:13:37:WU01:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
20:14:37:WU01:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
20:14:38:WU01:FS01:0x22:Checkpoint completed at step 250000
20:15:38:WU01:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
20:16:37:WU01:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
20:16:38:WU01:FS01:0x22:Checkpoint completed at step 275000
20:17:38:WU01:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
20:18:38:WU01:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
20:18:39:WU01:FS01:0x22:Checkpoint completed at step 300000
20:19:39:WU01:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
20:20:38:WU01:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
20:20:39:WU01:FS01:0x22:Checkpoint completed at step 325000
20:21:39:WU01:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
20:22:39:WU01:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
20:22:40:WU01:FS01:0x22:Checkpoint completed at step 350000
20:23:40:WU01:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
20:24:39:WU01:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
20:24:40:WU01:FS01:0x22:Checkpoint completed at step 375000
20:25:40:WU01:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
20:26:40:WU01:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
20:26:41:WU01:FS01:0x22:Checkpoint completed at step 400000
20:27:41:WU01:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
20:28:40:WU01:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
20:28:41:WU01:FS01:0x22:Checkpoint completed at step 425000
20:29:41:WU01:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
20:30:41:WU01:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
20:30:42:WU01:FS01:0x22:Checkpoint completed at step 450000
20:31:42:WU01:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
20:32:41:WU01:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
20:32:42:WU01:FS01:0x22:Checkpoint completed at step 475000
20:33:42:WU01:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
20:34:42:WU01:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
20:34:43:WU01:FS01:0x22:Checkpoint completed at step 500000
20:35:43:WU01:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
20:36:42:WU01:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
20:36:43:WU01:FS01:0x22:Checkpoint completed at step 525000
20:37:43:WU01:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
20:38:43:WU01:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
20:38:44:WU01:FS01:0x22:Checkpoint completed at step 550000
20:39:44:WU01:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
20:40:43:WU01:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
20:40:44:WU01:FS01:0x22:Checkpoint completed at step 575000
20:41:44:WU01:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
20:42:44:WU01:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
20:42:45:WU01:FS01:0x22:Checkpoint completed at step 600000
20:43:45:WU01:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
20:44:44:WU01:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
20:44:45:WU01:FS01:0x22:Checkpoint completed at step 625000
20:45:45:WU01:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
20:46:44:WU01:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
20:46:45:WU01:FS01:0x22:Checkpoint completed at step 650000
20:47:45:WU01:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
20:48:45:WU01:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
20:48:46:WU01:FS01:0x22:Checkpoint completed at step 675000
20:49:46:WU01:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
20:50:46:WU01:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
20:50:47:WU01:FS01:0x22:Checkpoint completed at step 700000
20:51:47:WU01:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
20:52:46:WU01:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
20:52:47:WU01:FS01:0x22:Checkpoint completed at step 725000
20:53:47:WU01:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
20:54:47:WU01:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
20:54:48:WU01:FS01:0x22:Checkpoint completed at step 750000
20:55:48:WU01:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
20:56:47:WU01:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
20:56:48:WU01:FS01:0x22:Checkpoint completed at step 775000
20:57:48:WU01:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
20:58:48:WU01:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
20:58:49:WU01:FS01:0x22:Checkpoint completed at step 800000
20:59:48:WU01:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
21:00:48:WU01:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
21:00:49:WU01:FS01:0x22:Checkpoint completed at step 825000
21:01:49:WU01:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
21:02:49:WU01:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
21:02:50:WU01:FS01:0x22:Checkpoint completed at step 850000
21:03:50:WU01:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
21:04:49:WU01:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
21:04:50:WU01:FS01:0x22:Checkpoint completed at step 875000
21:05:50:WU01:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
21:06:50:WU01:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
21:06:51:WU01:FS01:0x22:Checkpoint completed at step 900000
21:07:51:WU01:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
21:08:50:WU01:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
21:08:51:WU01:FS01:0x22:Checkpoint completed at step 925000
21:09:51:WU01:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
21:10:51:WU01:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
21:10:52:WU01:FS01:0x22:Checkpoint completed at step 950000
21:11:52:WU01:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
21:12:51:WU01:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
21:12:52:WU01:FS01:0x22:Checkpoint completed at step 975000
21:13:52:WU01:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
21:14:52:WU01:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
21:14:53:WU01:FS01:0x22:Checkpoint completed at step 1000000
21:15:53:WU01:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
21:16:52:WU01:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
21:16:53:WU01:FS01:0x22:Checkpoint completed at step 1025000
21:17:53:WU01:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
21:18:53:WU01:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
21:18:54:WU01:FS01:0x22:Checkpoint completed at step 1050000
21:19:54:WU01:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
21:20:53:WU01:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
21:20:54:WU01:FS01:0x22:Checkpoint completed at step 1075000
21:21:54:WU01:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
21:22:54:WU01:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
21:22:54:WU01:FS01:0x22:Checkpoint completed at step 1100000
21:23:54:WU01:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
21:24:54:WU01:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
21:24:55:WU01:FS01:0x22:Checkpoint completed at step 1125000
21:25:55:WU01:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
21:26:54:WU01:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
21:26:55:WU01:FS01:0x22:Checkpoint completed at step 1150000
21:27:55:WU01:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
21:28:55:WU01:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
21:28:56:WU01:FS01:0x22:Checkpoint completed at step 1175000
21:29:56:WU01:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
21:30:55:WU01:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
21:30:56:WU01:FS01:0x22:Checkpoint completed at step 1200000
21:31:56:WU01:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
21:32:56:WU01:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
21:32:57:WU01:FS01:0x22:Checkpoint completed at step 1225000
21:33:57:WU01:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
21:34:56:WU01:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
21:34:56:WU01:FS01:0x22:Average performance: 29.042 ns/day
21:34:57:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:34:57:WU00:FS01:Assigned to work server 128.252.203.11
21:34:57:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 128.252.203.11
21:34:57:WU00:FS01:Connecting to 128.252.203.11:8080
21:34:57:WU01:FS01:0x22:Checkpoint completed at step 1250000
21:35:02:WU01:FS01:0x22:Saving result file ../logfile_01.txt
21:35:02:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
21:35:02:WU01:FS01:0x22:Saving result file checkpointState.xml
21:35:06:WU01:FS01:0x22:Saving result file positions.xtc
21:35:06:WU01:FS01:0x22:Saving result file science.log
21:35:06:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
21:35:06:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:35:06:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18201 run:37548 clone:0 gen:13 core:0x22 unit:0x000000000000000d00004719000092ac
21:35:06:WU01:FS01:Uploading 27.49MiB to 128.252.203.11
21:35:06:WU01:FS01:Connecting to 128.252.203.11:8080
21:35:08:WU00:FS01:Downloading 26.57MiB
21:35:11:WU00:FS01:Download complete
21:35:11:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18201 run:52134 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000cba6
21:35:11:WU00:FS01:Starting
21:35:11:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:35:11:WU00:FS01:Started FahCore on PID 7635
21:35:11:WU00:FS01:Core PID:7639
21:35:11:WU00:FS01:FahCore 0x22 started
21:35:12:WU01:FS01:Upload 31.83%
21:35:12:WU00:FS01:0x22:*********************** Log Started 2021-11-11T21:35:11Z ***********************
21:35:12:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
21:35:12:WU00:FS01:0x22: Core: Core22
21:35:12:WU00:FS01:0x22: Type: 0x22
21:35:12:WU00:FS01:0x22: Version: 0.0.13
21:35:12:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
21:35:12:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
21:35:12:WU00:FS01:0x22: Homepage: https://foldingathome.org/
21:35:12:WU00:FS01:0x22: Date: Sep 19 2020
21:35:12:WU00:FS01:0x22: Time: 01:10:35
21:35:12:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
21:35:12:WU00:FS01:0x22: Branch: core22-0.0.13
21:35:12:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
21:35:12:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
21:35:12:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
21:35:12:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
21:35:12:WU00:FS01:0x22: Bits: 64
21:35:12:WU00:FS01:0x22: Mode: Release
21:35:12:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
21:35:12:WU00:FS01:0x22: <[email protected]>
21:35:12:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 7635 -checkpoint 15
21:35:12:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:35:12:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
21:35:12:WU00:FS01:0x22:************************************ libFAH ************************************
21:35:12:WU00:FS01:0x22: Date: Sep 15 2020
21:35:12:WU00:FS01:0x22: Time: 05:14:43
21:35:12:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
21:35:12:WU00:FS01:0x22: Branch: HEAD
21:35:12:WU00:FS01:0x22:************************************ CBang *************************************
21:35:12:WU00:FS01:0x22: Time: 05:11:04
21:35:12:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
21:35:12:WU00:FS01:0x22: -funroll-loops -fPIC
21:35:12:WU00:FS01:0x22:************************************ System ************************************
21:35:12:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
21:35:12:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:35:12:WU00:FS01:0x22: CPUs: 8
21:35:12:WU00:FS01:0x22: Memory: 15.58GiB
21:35:12:WU00:FS01:0x22:Free Memory: 12.15GiB
21:35:12:WU00:FS01:0x22: Threads: POSIX_THREADS
21:35:12:WU00:FS01:0x22: OS Version: 5.11
21:35:12:WU00:FS01:0x22:Has Battery: false
21:35:12:WU00:FS01:0x22: On Battery: false
21:35:12:WU00:FS01:0x22: UTC Offset: -5
21:35:12:WU00:FS01:0x22: PID: 7639
21:35:12:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
21:35:12:WU00:FS01:0x22:************************************ OpenMM ************************************
21:35:12:WU00:FS01:0x22: Revision: 189320d0
21:35:12:WU00:FS01:0x22:********************************************************************************
21:35:12:WU00:FS01:0x22:Project: 18201 (Run 52134, Clone 0, Gen 14)
21:35:12:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
21:35:12:WU00:FS01:0x22:Reading tar file core.xml
21:35:12:WU00:FS01:0x22:Reading tar file integrator.xml
21:35:12:WU00:FS01:0x22:Reading tar file state.xml
21:35:12:WU00:FS01:0x22:Reading tar file system.xml
21:35:13:WU00:FS01:0x22:Digital signatures verified
21:35:13:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
21:35:13:WU00:FS01:0x22:Version 0.0.13
21:35:13:WU00:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
21:35:13:WU00:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
21:35:13:WU00:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
21:35:13:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
21:35:13:WU00:FS01:0x22:There are 4 platforms available.
21:35:13:WU00:FS01:0x22:Platform 0: Reference
21:35:13:WU00:FS01:0x22:Platform 1: CPU
21:35:13:WU00:FS01:0x22:Platform 2: OpenCL
21:35:13:WU00:FS01:0x22: opencl-device 0 specified
21:35:13:WU00:FS01:0x22:Platform 3: CUDA
21:35:13:WU00:FS01:0x22: cuda-device 0 specified
21:35:18:WU01:FS01:Upload 71.15%
21:35:22:WU00:FS01:0x22:Attempting to create CUDA context:
21:35:22:WU00:FS01:0x22: Configuring platform CUDA
21:35:25:WU01:FS01:Upload complete
21:35:25:WU01:FS01:Server responded WORK_ACK (400)
21:35:25:WU01:FS01:Final credit estimate, 491216.00 points
21:35:25:WU01:FS01:Cleaning up
21:36:54:WU00:FS01:0x22: Using CUDA and gpu 0
21:36:54:WU00:FS01:0x22:Completed 0 out of 1250000 steps (0%)
21:36:54:WU00:FS01:0x22:Checkpoint completed at step 0
21:37:54:WU00:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
21:38:54:WU00:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
21:38:55:WU00:FS01:0x22:Checkpoint completed at step 25000
21:39:55:WU00:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
21:40:55:WU00:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
21:40:56:WU00:FS01:0x22:Checkpoint completed at step 50000
21:41:56:WU00:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
21:42:55:WU00:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
21:42:56:WU00:FS01:0x22:Checkpoint completed at step 75000
21:43:56:WU00:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
21:44:56:WU00:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
21:44:57:WU00:FS01:0x22:Checkpoint completed at step 100000
21:45:57:WU00:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
21:46:56:WU00:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
21:46:57:WU00:FS01:0x22:Checkpoint completed at step 125000
21:47:57:WU00:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
21:48:57:WU00:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
21:48:58:WU00:FS01:0x22:Checkpoint completed at step 150000
21:49:58:WU00:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
21:50:57:WU00:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
21:50:58:WU00:FS01:0x22:Checkpoint completed at step 175000
21:51:58:WU00:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
21:52:58:WU00:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
21:52:59:WU00:FS01:0x22:Checkpoint completed at step 200000
21:53:59:WU00:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
21:54:59:WU00:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
21:55:00:WU00:FS01:0x22:Checkpoint completed at step 225000
21:56:00:WU00:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
21:56:59:WU00:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
21:57:00:WU00:FS01:0x22:Checkpoint completed at step 250000
21:58:00:WU00:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
21:59:00:WU00:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
21:59:01:WU00:FS01:0x22:Checkpoint completed at step 275000
22:00:01:WU00:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
22:01:00:WU00:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
22:01:01:WU00:FS01:0x22:Checkpoint completed at step 300000
22:02:01:WU00:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
22:03:01:WU00:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
22:03:02:WU00:FS01:0x22:Checkpoint completed at step 325000
22:04:02:WU00:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
22:05:01:WU00:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
22:05:02:WU00:FS01:0x22:Checkpoint completed at step 350000
22:06:02:WU00:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
22:07:02:WU00:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
22:07:03:WU00:FS01:0x22:Checkpoint completed at step 375000
22:08:03:WU00:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
22:09:02:WU00:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
22:09:03:WU00:FS01:0x22:Checkpoint completed at step 400000
22:10:03:WU00:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
22:11:03:WU00:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
22:11:04:WU00:FS01:0x22:Checkpoint completed at step 425000
22:12:04:WU00:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
22:13:03:WU00:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
22:13:04:WU00:FS01:0x22:Checkpoint completed at step 450000
22:14:04:WU00:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
22:15:04:WU00:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
22:15:05:WU00:FS01:0x22:Checkpoint completed at step 475000
22:16:05:WU00:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
22:17:04:WU00:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
22:17:05:WU00:FS01:0x22:Checkpoint completed at step 500000
22:18:05:WU00:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
22:19:05:WU00:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
22:19:06:WU00:FS01:0x22:Checkpoint completed at step 525000
22:20:06:WU00:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
22:21:05:WU00:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
22:21:06:WU00:FS01:0x22:Checkpoint completed at step 550000
22:22:06:WU00:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
22:23:06:WU00:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
22:23:07:WU00:FS01:0x22:Checkpoint completed at step 575000
22:24:07:WU00:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
22:25:06:WU00:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
22:25:07:WU00:FS01:0x22:Checkpoint completed at step 600000
22:26:07:WU00:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
22:27:07:WU00:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
22:27:08:WU00:FS01:0x22:Checkpoint completed at step 625000
22:28:08:WU00:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
22:29:07:WU00:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
22:29:08:WU00:FS01:0x22:Checkpoint completed at step 650000
22:30:08:WU00:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
22:31:08:WU00:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
22:31:09:WU00:FS01:0x22:Checkpoint completed at step 675000
22:32:09:WU00:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
22:33:08:WU00:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
22:33:09:WU00:FS01:0x22:Checkpoint completed at step 700000
22:34:09:WU00:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
22:35:09:WU00:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
22:35:10:WU00:FS01:0x22:Checkpoint completed at step 725000
22:36:10:WU00:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
22:37:09:WU00:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
22:37:10:WU00:FS01:0x22:Checkpoint completed at step 750000
22:38:10:WU00:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
22:39:10:WU00:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
22:39:11:WU00:FS01:0x22:Checkpoint completed at step 775000
22:40:11:WU00:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
22:41:10:WU00:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
22:41:11:WU00:FS01:0x22:Checkpoint completed at step 800000
22:42:11:WU00:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
22:43:11:WU00:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
22:43:12:WU00:FS01:0x22:Checkpoint completed at step 825000
22:44:12:WU00:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
22:45:12:WU00:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
22:45:12:WU00:FS01:0x22:Checkpoint completed at step 850000
22:46:13:WU00:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
22:47:12:WU00:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
22:47:13:WU00:FS01:0x22:Checkpoint completed at step 875000
22:48:13:WU00:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
22:49:13:WU00:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
22:49:14:WU00:FS01:0x22:Checkpoint completed at step 900000
22:50:14:WU00:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
22:51:13:WU00:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
22:51:14:WU00:FS01:0x22:Checkpoint completed at step 925000
22:52:14:WU00:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
22:53:14:WU00:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
22:53:14:WU00:FS01:0x22:Checkpoint completed at step 950000
22:54:14:WU00:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
22:55:14:WU00:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
22:55:15:WU00:FS01:0x22:Checkpoint completed at step 975000
22:56:15:WU00:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
22:57:14:WU00:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
22:57:15:WU00:FS01:0x22:Checkpoint completed at step 1000000
22:58:15:WU00:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
22:59:15:WU00:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
22:59:16:WU00:FS01:0x22:Checkpoint completed at step 1025000
23:00:16:WU00:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
23:01:16:WU00:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
23:01:16:WU00:FS01:0x22:Checkpoint completed at step 1050000
23:02:17:WU00:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
23:03:16:WU00:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
23:03:17:WU00:FS01:0x22:Checkpoint completed at step 1075000
23:04:17:WU00:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
23:05:17:WU00:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
23:05:17:WU00:FS01:0x22:Checkpoint completed at step 1100000
23:06:17:WU00:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
23:07:17:WU00:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
23:07:18:WU00:FS01:0x22:Checkpoint completed at step 1125000
23:08:18:WU00:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
23:09:17:WU00:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
23:09:18:WU00:FS01:0x22:Checkpoint completed at step 1150000
23:10:18:WU00:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
23:11:18:WU00:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
23:11:19:WU00:FS01:0x22:Checkpoint completed at step 1175000
23:12:19:WU00:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
23:13:19:WU00:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
23:13:20:WU00:FS01:0x22:Checkpoint completed at step 1200000
23:14:20:WU00:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
23:15:19:WU00:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
23:15:20:WU00:FS01:0x22:Checkpoint completed at step 1225000
23:16:20:WU00:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
23:17:20:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
23:17:20:WU00:FS01:0x22:Average performance: 28.8 ns/day
23:17:20:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:17:20:WU01:FS01:Assigned to work server 128.252.203.11
23:17:20:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 128.252.203.11
23:17:20:WU01:FS01:Connecting to 128.252.203.11:8080
23:17:21:WU00:FS01:0x22:Checkpoint completed at step 1250000
23:17:25:WU00:FS01:0x22:Saving result file ../logfile_01.txt
23:17:25:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
23:17:25:WU00:FS01:0x22:Saving result file checkpointState.xml
23:17:29:WU00:FS01:0x22:Saving result file positions.xtc
23:17:29:WU00:FS01:0x22:Saving result file science.log
23:17:29:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
23:17:30:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:17:30:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18201 run:52134 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000cba6
23:17:30:WU00:FS01:Uploading 27.49MiB to 128.252.203.11
23:17:30:WU00:FS01:Connecting to 128.252.203.11:8080
23:17:30:WU01:FS01:Downloading 26.57MiB
23:17:35:WU01:FS01:Download complete
23:17:35:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18201 run:53475 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000d0e3
23:17:35:WU01:FS01:Starting
23:17:35:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
23:17:35:WU01:FS01:Started FahCore on PID 7795
23:17:35:WU01:FS01:Core PID:7799
23:17:35:WU01:FS01:FahCore 0x22 started
23:17:36:WU00:FS01:Upload 35.01%
23:17:36:WU01:FS01:0x22:*********************** Log Started 2021-11-11T23:17:35Z ***********************
23:17:36:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
23:17:36:WU01:FS01:0x22: Core: Core22
23:17:36:WU01:FS01:0x22: Type: 0x22
23:17:36:WU01:FS01:0x22: Version: 0.0.13
23:17:36:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
23:17:36:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
23:17:36:WU01:FS01:0x22: Homepage: https://foldingathome.org/
23:17:36:WU01:FS01:0x22: Date: Sep 19 2020
23:17:36:WU01:FS01:0x22: Time: 01:10:35
23:17:36:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
23:17:36:WU01:FS01:0x22: Branch: core22-0.0.13
23:17:36:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
23:17:36:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
23:17:36:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
23:17:36:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
23:17:36:WU01:FS01:0x22: Bits: 64
23:17:36:WU01:FS01:0x22: Mode: Release
23:17:36:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
23:17:36:WU01:FS01:0x22: <[email protected]>
23:17:36:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 7795 -checkpoint 15
23:17:36:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
23:17:36:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
23:17:36:WU01:FS01:0x22:************************************ libFAH ************************************
23:17:36:WU01:FS01:0x22: Date: Sep 15 2020
23:17:36:WU01:FS01:0x22: Time: 05:14:43
23:17:36:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
23:17:36:WU01:FS01:0x22: Branch: HEAD
23:17:36:WU01:FS01:0x22:************************************ CBang *************************************
23:17:36:WU01:FS01:0x22: Time: 05:11:04
23:17:36:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
23:17:36:WU01:FS01:0x22: -funroll-loops -fPIC
23:17:36:WU01:FS01:0x22:************************************ System ************************************
23:17:36:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
23:17:36:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
23:17:36:WU01:FS01:0x22: CPUs: 8
23:17:36:WU01:FS01:0x22: Memory: 15.58GiB
23:17:36:WU01:FS01:0x22:Free Memory: 12.09GiB
23:17:36:WU01:FS01:0x22: Threads: POSIX_THREADS
23:17:36:WU01:FS01:0x22: OS Version: 5.11
23:17:36:WU01:FS01:0x22:Has Battery: false
23:17:36:WU01:FS01:0x22: On Battery: false
23:17:36:WU01:FS01:0x22: UTC Offset: -5
23:17:36:WU01:FS01:0x22: PID: 7799
23:17:36:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
23:17:36:WU01:FS01:0x22:************************************ OpenMM ************************************
23:17:36:WU01:FS01:0x22: Revision: 189320d0
23:17:36:WU01:FS01:0x22:********************************************************************************
23:17:36:WU01:FS01:0x22:Project: 18201 (Run 53475, Clone 0, Gen 14)
23:17:36:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
23:17:36:WU01:FS01:0x22:Reading tar file core.xml
23:17:36:WU01:FS01:0x22:Reading tar file integrator.xml
23:17:36:WU01:FS01:0x22:Reading tar file state.xml
23:17:36:WU01:FS01:0x22:Reading tar file system.xml
23:17:37:WU01:FS01:0x22:Digital signatures verified
23:17:37:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
23:17:37:WU01:FS01:0x22:Version 0.0.13
23:17:37:WU01:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
23:17:37:WU01:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
23:17:37:WU01:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
23:17:37:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
23:17:37:WU01:FS01:0x22:There are 4 platforms available.
23:17:37:WU01:FS01:0x22:Platform 0: Reference
23:17:37:WU01:FS01:0x22:Platform 1: CPU
23:17:37:WU01:FS01:0x22:Platform 2: OpenCL
23:17:37:WU01:FS01:0x22: opencl-device 0 specified
23:17:37:WU01:FS01:0x22:Platform 3: CUDA
23:17:37:WU01:FS01:0x22: cuda-device 0 specified
23:17:42:WU00:FS01:Upload 73.21%
23:17:46:WU01:FS01:0x22:Attempting to create CUDA context:
23:17:46:WU01:FS01:0x22: Configuring platform CUDA
23:17:49:WU00:FS01:Upload complete
23:17:49:WU00:FS01:Server responded WORK_ACK (400)
23:17:49:WU00:FS01:Final credit estimate, 491097.00 points
23:17:49:WU00:FS01:Cleaning up
23:19:17:WU01:FS01:0x22: Using CUDA and gpu 0
23:19:17:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
23:19:18:WU01:FS01:0x22:Checkpoint completed at step 0
23:20:17:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
23:21:17:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
23:21:18:WU01:FS01:0x22:Checkpoint completed at step 25000
23:22:18:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
23:23:18:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
23:23:19:WU01:FS01:0x22:Checkpoint completed at step 50000
23:24:19:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
23:25:18:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
23:25:19:WU01:FS01:0x22:Checkpoint completed at step 75000
23:26:19:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
23:27:19:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
23:27:20:WU01:FS01:0x22:Checkpoint completed at step 100000
23:28:20:WU01:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
23:29:20:WU01:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
23:29:20:WU01:FS01:0x22:Checkpoint completed at step 125000
23:30:20:WU01:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
23:31:20:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
23:31:21:WU01:FS01:0x22:Checkpoint completed at step 150000
23:32:21:WU01:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
23:33:21:WU01:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
23:33:21:WU01:FS01:0x22:Checkpoint completed at step 175000
23:34:21:WU01:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
23:35:21:WU01:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
23:35:22:WU01:FS01:0x22:Checkpoint completed at step 200000
23:36:22:WU01:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
23:37:22:WU01:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
23:37:23:WU01:FS01:0x22:Checkpoint completed at step 225000
23:38:23:WU01:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
23:39:22:WU01:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
23:39:23:WU01:FS01:0x22:Checkpoint completed at step 250000
23:40:23:WU01:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
23:41:23:WU01:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
23:41:24:WU01:FS01:0x22:Checkpoint completed at step 275000
23:42:24:WU01:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
23:43:23:WU01:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
23:43:24:WU01:FS01:0x22:Checkpoint completed at step 300000
23:44:24:WU01:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
23:45:24:WU01:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
23:45:25:WU01:FS01:0x22:Checkpoint completed at step 325000
23:46:25:WU01:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
23:47:25:WU01:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
23:47:25:WU01:FS01:0x22:Checkpoint completed at step 350000
23:48:25:WU01:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
23:49:25:WU01:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
23:49:26:WU01:FS01:0x22:Checkpoint completed at step 375000
23:50:26:WU01:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
23:51:26:WU01:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
23:51:27:WU01:FS01:0x22:Checkpoint completed at step 400000
23:52:27:WU01:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
23:53:26:WU01:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
23:53:27:WU01:FS01:0x22:Checkpoint completed at step 425000
23:54:27:WU01:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
23:55:27:WU01:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
23:55:28:WU01:FS01:0x22:Checkpoint completed at step 450000
23:56:28:WU01:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
23:57:27:WU01:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
23:57:28:WU01:FS01:0x22:Checkpoint completed at step 475000
23:58:28:WU01:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
23:59:28:WU01:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
23:59:29:WU01:FS01:0x22:Checkpoint completed at step 500000
00:00:29:WU01:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
00:01:28:WU01:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
00:01:29:WU01:FS01:0x22:Checkpoint completed at step 525000
00:02:29:WU01:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
00:03:29:WU01:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
00:03:30:WU01:FS01:0x22:Checkpoint completed at step 550000
00:04:30:WU01:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
00:05:30:WU01:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
00:05:31:WU01:FS01:0x22:Checkpoint completed at step 575000
00:06:31:WU01:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
00:07:30:WU01:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
00:07:31:WU01:FS01:0x22:Checkpoint completed at step 600000
******************************* Date: 2021-11-12 *******************************
00:08:31:WU01:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
00:09:31:WU01:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
00:09:32:WU01:FS01:0x22:Checkpoint completed at step 625000
00:10:32:WU01:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
00:11:31:WU01:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
00:11:32:WU01:FS01:0x22:Checkpoint completed at step 650000
00:12:32:WU01:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
00:13:32:WU01:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
00:13:33:WU01:FS01:0x22:Checkpoint completed at step 675000
00:14:33:WU01:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
00:15:32:WU01:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
00:15:33:WU01:FS01:0x22:Checkpoint completed at step 700000
00:16:34:WU01:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
00:17:33:WU01:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
00:17:34:WU01:FS01:0x22:Checkpoint completed at step 725000
00:18:34:WU01:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
00:19:34:WU01:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
00:19:35:WU01:FS01:0x22:Checkpoint completed at step 750000
00:20:35:WU01:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
00:21:34:WU01:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
00:21:35:WU01:FS01:0x22:Checkpoint completed at step 775000
00:22:35:WU01:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
00:23:35:WU01:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
00:23:36:WU01:FS01:0x22:Checkpoint completed at step 800000
00:24:36:WU01:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
00:25:35:WU01:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
00:25:36:WU01:FS01:0x22:Checkpoint completed at step 825000
00:26:36:WU01:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
00:27:36:WU01:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
00:27:37:WU01:FS01:0x22:Checkpoint completed at step 850000
00:28:37:WU01:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
00:29:37:WU01:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
00:29:38:WU01:FS01:0x22:Checkpoint completed at step 875000
00:30:38:WU01:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
00:31:38:WU01:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
00:31:38:WU01:FS01:0x22:Checkpoint completed at step 900000
00:32:39:WU01:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
00:33:38:WU01:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
00:33:39:WU01:FS01:0x22:Checkpoint completed at step 925000
00:34:39:WU01:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
00:35:39:WU01:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
00:35:40:WU01:FS01:0x22:Checkpoint completed at step 950000
00:36:40:WU01:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
00:37:39:WU01:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
00:37:40:WU01:FS01:0x22:Checkpoint completed at step 975000
00:38:40:WU01:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
00:39:40:WU01:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
00:39:41:WU01:FS01:0x22:Checkpoint completed at step 1000000
00:40:41:WU01:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
00:41:40:WU01:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
00:41:41:WU01:FS01:0x22:Checkpoint completed at step 1025000
00:42:41:WU01:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
00:43:41:WU01:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
00:43:42:WU01:FS01:0x22:Checkpoint completed at step 1050000
00:44:42:WU01:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
00:45:42:WU01:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
00:45:43:WU01:FS01:0x22:Checkpoint completed at step 1075000
00:46:43:WU01:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
00:47:42:WU01:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
00:47:43:WU01:FS01:0x22:Checkpoint completed at step 1100000
00:48:43:WU01:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
00:49:43:WU01:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
00:49:44:WU01:FS01:0x22:Checkpoint completed at step 1125000
00:50:44:WU01:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
00:51:43:WU01:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
00:51:44:WU01:FS01:0x22:Checkpoint completed at step 1150000
00:52:44:WU01:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
00:53:44:WU01:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
00:53:45:WU01:FS01:0x22:Checkpoint completed at step 1175000
00:54:45:WU01:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
00:55:44:WU01:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
00:55:45:WU01:FS01:0x22:Checkpoint completed at step 1200000
00:56:46:WU01:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
00:57:45:WU01:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
00:57:46:WU01:FS01:0x22:Checkpoint completed at step 1225000
00:58:46:WU01:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
00:59:46:WU01:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
00:59:46:WU01:FS01:0x22:Average performance: 28.8 ns/day
00:59:46:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:59:46:WU00:FS01:Assigned to work server 129.32.209.202
00:59:46:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
00:59:46:WU00:FS01:Connecting to 129.32.209.202:8080
00:59:46:WU00:FS01:Downloading 27.78MiB
00:59:47:WU01:FS01:0x22:Checkpoint completed at step 1250000
00:59:49:WU00:FS01:Download complete
00:59:49:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18431 run:2 clone:366 gen:77 core:0x22 unit:0x0000016e0000004d000047ff00000002
00:59:52:WU01:FS01:0x22:Saving result file ../logfile_01.txt
00:59:52:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
00:59:52:WU01:FS01:0x22:Saving result file checkpointState.xml
00:59:55:WU01:FS01:0x22:Saving result file positions.xtc
00:59:55:WU01:FS01:0x22:Saving result file science.log
00:59:55:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
00:59:56:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:59:56:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18201 run:53475 clone:0 gen:14 core:0x22 unit:0x000000000000000e000047190000d0e3
00:59:56:WU01:FS01:Uploading 27.49MiB to 128.252.203.11
00:59:56:WU01:FS01:Connecting to 128.252.203.11:8080
00:59:56:WU00:FS01:Starting
00:59:56:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:59:56:WU00:FS01:Started FahCore on PID 7982
00:59:56:WU00:FS01:Core PID:7986
00:59:56:WU00:FS01:FahCore 0x22 started
00:59:56:WU00:FS01:0x22:*********************** Log Started 2021-11-12T00:59:56Z ***********************
00:59:56:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
00:59:56:WU00:FS01:0x22: Core: Core22
00:59:56:WU00:FS01:0x22: Type: 0x22
00:59:56:WU00:FS01:0x22: Version: 0.0.13
00:59:56:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]drondevelopment.com>
00:59:56:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
00:59:56:WU00:FS01:0x22: Homepage: https://foldingathome.org/
00:59:56:WU00:FS01:0x22: Date: Sep 19 2020
00:59:56:WU00:FS01:0x22: Time: 01:10:35
00:59:56:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:59:56:WU00:FS01:0x22: Branch: core22-0.0.13
00:59:56:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
00:59:56:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
00:59:56:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
00:59:56:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
00:59:56:WU00:FS01:0x22: Bits: 64
00:59:56:WU00:FS01:0x22: Mode: Release
00:59:56:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
00:59:56:WU00:FS01:0x22: <[email protected]>
00:59:56:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 7982 -checkpoint 15
00:59:56:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:59:56:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
00:59:56:WU00:FS01:0x22:************************************ libFAH ************************************
00:59:56:WU00:FS01:0x22: Date: Sep 15 2020
00:59:56:WU00:FS01:0x22: Time: 05:14:43
00:59:56:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:59:56:WU00:FS01:0x22: Branch: HEAD
00:59:56:WU00:FS01:0x22:************************************ CBang *************************************
00:59:56:WU00:FS01:0x22: Time: 05:11:04
00:59:56:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:59:56:WU00:FS01:0x22: -funroll-loops -fPIC
00:59:56:WU00:FS01:0x22:************************************ System ************************************
00:59:56:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
00:59:56:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
00:59:56:WU00:FS01:0x22: CPUs: 8
00:59:56:WU00:FS01:0x22: Memory: 15.58GiB
00:59:56:WU00:FS01:0x22:Free Memory: 12.03GiB
00:59:56:WU00:FS01:0x22: Threads: POSIX_THREADS
00:59:56:WU00:FS01:0x22: OS Version: 5.11
00:59:56:WU00:FS01:0x22:Has Battery: false
00:59:56:WU00:FS01:0x22: On Battery: false
00:59:56:WU00:FS01:0x22: UTC Offset: -5
00:59:56:WU00:FS01:0x22: PID: 7986
00:59:56:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
00:59:56:WU00:FS01:0x22:************************************ OpenMM ************************************
00:59:56:WU00:FS01:0x22: Revision: 189320d0
00:59:56:WU00:FS01:0x22:********************************************************************************
00:59:56:WU00:FS01:0x22:Project: 18431 (Run 2, Clone 366, Gen 77)
00:59:56:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
00:59:56:WU00:FS01:0x22:Reading tar file core.xml
00:59:56:WU00:FS01:0x22:Reading tar file integrator.xml
00:59:56:WU00:FS01:0x22:Reading tar file state.xml
00:59:56:WU00:FS01:0x22:Reading tar file system.xml
00:59:56:WU00:FS01:0x22:Digital signatures verified
00:59:56:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
00:59:56:WU00:FS01:0x22:Version 0.0.13
00:59:56:WU00:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
00:59:56:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
00:59:56:WU00:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
00:59:56:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
00:59:56:WU00:FS01:0x22:There are 4 platforms available.
00:59:56:WU00:FS01:0x22:Platform 0: Reference
00:59:56:WU00:FS01:0x22:Platform 1: CPU
00:59:56:WU00:FS01:0x22:Platform 2: OpenCL
00:59:56:WU00:FS01:0x22: opencl-device 0 specified
00:59:56:WU00:FS01:0x22:Platform 3: CUDA
00:59:56:WU00:FS01:0x22: cuda-device 0 specified
00:59:58:WU00:FS01:0x22:Attempting to create CUDA context:
00:59:58:WU00:FS01:0x22: Configuring platform CUDA
01:00:02:WU01:FS01:Upload 39.78%
01:00:08:WU01:FS01:Upload 79.56%
01:00:12:WU01:FS01:Upload complete
01:00:12:WU01:FS01:Server responded WORK_ACK (400)
01:00:12:WU01:FS01:Final credit estimate, 491017.00 points
01:00:12:WU01:FS01:Cleaning up
01:01:25:WU00:FS01:0x22: Using CUDA and gpu 0
01:01:25:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
01:01:25:WU00:FS01:0x22:Checkpoint completed at step 0
01:02:07:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
01:02:48:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
01:02:49:WU00:FS01:0x22:Checkpoint completed at step 100000
01:03:31:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
01:04:13:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
01:04:13:WU00:FS01:0x22:Checkpoint completed at step 200000
01:04:56:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
01:05:38:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
01:05:38:WU00:FS01:0x22:Checkpoint completed at step 300000
01:06:20:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
01:07:02:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
01:07:03:WU00:FS01:0x22:Checkpoint completed at step 400000
01:07:45:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
01:08:27:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
01:08:27:WU00:FS01:0x22:Checkpoint completed at step 500000
01:09:09:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
01:09:51:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
01:09:52:WU00:FS01:0x22:Checkpoint completed at step 600000
01:10:34:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
01:11:16:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
01:11:16:WU00:FS01:0x22:Checkpoint completed at step 700000
01:11:58:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
01:12:40:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
01:12:40:WU00:FS01:0x22:Checkpoint completed at step 800000
01:13:23:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
01:14:05:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
01:14:05:WU00:FS01:0x22:Checkpoint completed at step 900000
01:14:47:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
01:15:29:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
01:15:30:WU00:FS01:0x22:Checkpoint completed at step 1000000
01:16:12:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
01:16:54:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
01:16:54:WU00:FS01:0x22:Checkpoint completed at step 1100000
01:17:37:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
01:18:19:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
01:18:19:WU00:FS01:0x22:Checkpoint completed at step 1200000
01:19:02:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
01:19:44:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
01:19:44:WU00:FS01:0x22:Checkpoint completed at step 1300000
01:20:27:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
01:21:09:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
01:21:09:WU00:FS01:0x22:Checkpoint completed at step 1400000
01:21:52:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
01:22:34:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
01:22:34:WU00:FS01:0x22:Checkpoint completed at step 1500000
01:23:17:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
01:23:59:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
01:23:59:WU00:FS01:0x22:Checkpoint completed at step 1600000
01:24:41:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
01:25:24:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
01:25:24:WU00:FS01:0x22:Checkpoint completed at step 1700000
01:26:06:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
01:26:49:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
01:26:49:WU00:FS01:0x22:Checkpoint completed at step 1800000
01:27:31:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
01:28:13:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
01:28:13:WU00:FS01:0x22:Checkpoint completed at step 1900000
01:28:56:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
01:29:38:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
01:29:38:WU00:FS01:0x22:Checkpoint completed at step 2000000
01:30:21:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
01:31:03:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
01:31:03:WU00:FS01:0x22:Checkpoint completed at step 2100000
01:31:46:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
01:32:28:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
01:32:28:WU00:FS01:0x22:Checkpoint completed at step 2200000
01:33:11:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
01:33:53:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
01:33:53:WU00:FS01:0x22:Checkpoint completed at step 2300000
01:34:36:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
01:35:18:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
01:35:18:WU00:FS01:0x22:Checkpoint completed at step 2400000
01:36:01:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
01:36:43:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
01:36:43:WU00:FS01:0x22:Checkpoint completed at step 2500000
01:37:26:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
01:38:08:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
01:38:08:WU00:FS01:0x22:Checkpoint completed at step 2600000
01:38:50:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
01:39:33:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
01:39:33:WU00:FS01:0x22:Checkpoint completed at step 2700000
01:40:15:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
01:40:58:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
01:40:58:WU00:FS01:0x22:Checkpoint completed at step 2800000
01:41:40:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
01:42:23:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
01:42:23:WU00:FS01:0x22:Checkpoint completed at step 2900000
01:43:05:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
01:43:47:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
01:43:48:WU00:FS01:0x22:Checkpoint completed at step 3000000
01:44:30:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
01:45:13:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
01:45:13:WU00:FS01:0x22:Checkpoint completed at step 3100000
01:45:55:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
01:46:38:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
01:46:38:WU00:FS01:0x22:Checkpoint completed at step 3200000
01:47:20:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
01:48:02:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
01:48:03:WU00:FS01:0x22:Checkpoint completed at step 3300000
01:48:45:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
01:49:27:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
01:49:27:WU00:FS01:0x22:Checkpoint completed at step 3400000
01:50:10:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
01:50:52:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
01:50:52:WU00:FS01:0x22:Checkpoint completed at step 3500000
01:51:35:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
01:52:17:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
01:52:17:WU00:FS01:0x22:Checkpoint completed at step 3600000
01:53:00:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
01:53:42:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
01:53:42:WU00:FS01:0x22:Checkpoint completed at step 3700000
01:54:24:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
01:55:07:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
01:55:07:WU00:FS01:0x22:Checkpoint completed at step 3800000
01:55:49:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
01:56:31:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
01:56:32:WU00:FS01:0x22:Checkpoint completed at step 3900000
01:57:14:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
01:57:56:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
01:57:57:WU00:FS01:0x22:Checkpoint completed at step 4000000
01:58:39:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
01:59:22:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
01:59:22:WU00:FS01:0x22:Checkpoint completed at step 4100000
02:00:04:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
02:00:47:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
02:00:47:WU00:FS01:0x22:Checkpoint completed at step 4200000
02:01:29:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
02:02:12:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
02:02:12:WU00:FS01:0x22:Checkpoint completed at step 4300000
02:02:54:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
02:03:37:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
02:03:37:WU00:FS01:0x22:Checkpoint completed at step 4400000
02:04:19:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
02:05:02:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
02:05:02:WU00:FS01:0x22:Checkpoint completed at step 4500000
02:05:44:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
02:06:27:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
02:06:27:WU00:FS01:0x22:Checkpoint completed at step 4600000
02:07:09:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
02:07:51:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
02:07:52:WU00:FS01:0x22:Checkpoint completed at step 4700000
02:08:34:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
02:09:17:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
02:09:17:WU00:FS01:0x22:Checkpoint completed at step 4800000
02:09:59:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
02:10:41:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
02:10:42:WU00:FS01:0x22:Checkpoint completed at step 4900000
02:11:24:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
02:12:06:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
02:12:06:WU00:FS01:0x22:Average performance: 514.286 ns/day
02:12:06:WU00:FS01:0x22:Checkpoint completed at step 5000000
02:12:07:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:12:07:WU01:FS01:Assigned to work server 129.32.209.202
02:12:07:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
02:12:07:WU01:FS01:Connecting to 129.32.209.202:8080
02:12:07:WU01:FS01:Downloading 27.81MiB
02:12:07:WU00:FS01:0x22:Saving result file ../logfile_01.txt
02:12:07:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
02:12:07:WU00:FS01:0x22:Saving result file checkpointState.xml
02:12:08:WU00:FS01:0x22:Saving result file positions.xtc
02:12:08:WU00:FS01:0x22:Saving result file science.log
02:12:08:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
02:12:08:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:12:08:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18431 run:2 clone:366 gen:77 core:0x22 unit:0x0000016e0000004d000047ff00000002
02:12:08:WU00:FS01:Uploading 14.33MiB to 129.32.209.202
02:12:08:WU00:FS01:Connecting to 129.32.209.202:8080
02:12:10:WU01:FS01:Download complete
02:12:10:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:7 clone:99 gen:41 core:0x22 unit:0x0000006300000029000047ff00000007
02:12:10:WU01:FS01:Starting
02:12:10:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
02:12:10:WU01:FS01:Started FahCore on PID 8144
02:12:10:WU01:FS01:Core PID:8148
02:12:10:WU01:FS01:FahCore 0x22 started
02:12:10:WU01:FS01:0x22:*********************** Log Started 2021-11-12T02:12:10Z ***********************
02:12:10:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
02:12:10:WU01:FS01:0x22: Core: Core22
02:12:10:WU01:FS01:0x22: Type: 0x22
02:12:10:WU01:FS01:0x22: Version: 0.0.13
02:12:10:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
02:12:10:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
02:12:10:WU01:FS01:0x22: Homepage: https://foldingathome.org/
02:12:10:WU01:FS01:0x22: Date: Sep 19 2020
02:12:10:WU01:FS01:0x22: Time: 01:10:35
02:12:10:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
02:12:10:WU01:FS01:0x22: Branch: core22-0.0.13
02:12:10:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
02:12:10:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
02:12:10:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
02:12:10:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
02:12:10:WU01:FS01:0x22: Bits: 64
02:12:10:WU01:FS01:0x22: Mode: Release
02:12:10:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
02:12:10:WU01:FS01:0x22: <[email protected]>
02:12:10:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 8144 -checkpoint 15
02:12:10:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
02:12:10:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
02:12:10:WU01:FS01:0x22:************************************ libFAH ************************************
02:12:10:WU01:FS01:0x22: Date: Sep 15 2020
02:12:10:WU01:FS01:0x22: Time: 05:14:43
02:12:10:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
02:12:10:WU01:FS01:0x22: Branch: HEAD
02:12:10:WU01:FS01:0x22:************************************ CBang *************************************
02:12:10:WU01:FS01:0x22: Time: 05:11:04
02:12:10:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
02:12:10:WU01:FS01:0x22: -funroll-loops -fPIC
02:12:10:WU01:FS01:0x22:************************************ System ************************************
02:12:10:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
02:12:10:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
02:12:10:WU01:FS01:0x22: CPUs: 8
02:12:10:WU01:FS01:0x22: Memory: 15.58GiB
02:12:10:WU01:FS01:0x22:Free Memory: 12.00GiB
02:12:10:WU01:FS01:0x22: Threads: POSIX_THREADS
02:12:10:WU01:FS01:0x22: OS Version: 5.11
02:12:10:WU01:FS01:0x22:Has Battery: false
02:12:10:WU01:FS01:0x22: On Battery: false
02:12:10:WU01:FS01:0x22: UTC Offset: -5
02:12:10:WU01:FS01:0x22: PID: 8148
02:12:10:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
02:12:10:WU01:FS01:0x22:************************************ OpenMM ************************************
02:12:10:WU01:FS01:0x22: Revision: 189320d0
02:12:10:WU01:FS01:0x22:********************************************************************************
02:12:10:WU01:FS01:0x22:Project: 18431 (Run 7, Clone 99, Gen 41)
02:12:10:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
02:12:10:WU01:FS01:0x22:Reading tar file core.xml
02:12:10:WU01:FS01:0x22:Reading tar file integrator.xml
02:12:10:WU01:FS01:0x22:Reading tar file state.xml
02:12:10:WU01:FS01:0x22:Reading tar file system.xml
02:12:10:WU01:FS01:0x22:Digital signatures verified
02:12:10:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
02:12:10:WU01:FS01:0x22:Version 0.0.13
02:12:10:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
02:12:10:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
02:12:10:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
02:12:10:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
02:12:10:WU01:FS01:0x22:There are 4 platforms available.
02:12:10:WU01:FS01:0x22:Platform 0: Reference
02:12:10:WU01:FS01:0x22:Platform 1: CPU
02:12:10:WU01:FS01:0x22:Platform 2: OpenCL
02:12:10:WU01:FS01:0x22: opencl-device 0 specified
02:12:10:WU01:FS01:0x22:Platform 3: CUDA
02:12:10:WU01:FS01:0x22: cuda-device 0 specified
02:12:12:WU00:FS01:Upload complete
02:12:12:WU00:FS01:Server responded WORK_ACK (400)
02:12:12:WU00:FS01:Final credit estimate, 292890.00 points
02:12:12:WU00:FS01:Cleaning up
02:12:12:WU01:FS01:0x22:Attempting to create CUDA context:
02:12:12:WU01:FS01:0x22: Configuring platform CUDA
02:13:40:WU01:FS01:0x22: Using CUDA and gpu 0
02:13:40:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
02:13:40:WU01:FS01:0x22:Checkpoint completed at step 0
02:14:23:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
02:15:05:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
02:15:05:WU01:FS01:0x22:Checkpoint completed at step 100000
02:15:47:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
02:16:29:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
02:16:29:WU01:FS01:0x22:Checkpoint completed at step 200000
02:17:12:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
02:17:54:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
02:17:54:WU01:FS01:0x22:Checkpoint completed at step 300000
02:18:36:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
02:19:18:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
02:19:18:WU01:FS01:0x22:Checkpoint completed at step 400000
02:20:00:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
02:20:42:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
02:20:42:WU01:FS01:0x22:Checkpoint completed at step 500000
02:21:24:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
02:22:06:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
02:22:06:WU01:FS01:0x22:Checkpoint completed at step 600000
02:22:48:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
02:23:30:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
02:23:31:WU01:FS01:0x22:Checkpoint completed at step 700000
02:24:13:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
02:24:55:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
02:24:55:WU01:FS01:0x22:Checkpoint completed at step 800000
02:25:37:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
02:26:19:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
02:26:20:WU01:FS01:0x22:Checkpoint completed at step 900000
02:27:02:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
02:27:44:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
02:27:44:WU01:FS01:0x22:Checkpoint completed at step 1000000
02:28:26:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
02:29:08:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
02:29:08:WU01:FS01:0x22:Checkpoint completed at step 1100000
02:29:50:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
02:30:32:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
02:30:32:WU01:FS01:0x22:Checkpoint completed at step 1200000
02:31:14:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
02:31:56:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
02:31:56:WU01:FS01:0x22:Checkpoint completed at step 1300000
02:32:38:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
02:33:20:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
02:33:20:WU01:FS01:0x22:Checkpoint completed at step 1400000
02:34:02:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
02:34:44:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
02:34:44:WU01:FS01:0x22:Checkpoint completed at step 1500000
02:35:26:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
02:36:08:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
02:36:08:WU01:FS01:0x22:Checkpoint completed at step 1600000
02:36:50:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
02:37:32:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
02:37:32:WU01:FS01:0x22:Checkpoint completed at step 1700000
02:38:14:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
02:38:56:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
02:38:56:WU01:FS01:0x22:Checkpoint completed at step 1800000
02:39:39:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
02:40:21:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
02:40:21:WU01:FS01:0x22:Checkpoint completed at step 1900000
02:41:03:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
02:41:44:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
02:41:45:WU01:FS01:0x22:Checkpoint completed at step 2000000
02:42:27:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
02:43:09:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
02:43:09:WU01:FS01:0x22:Checkpoint completed at step 2100000
02:43:51:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
02:44:33:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
02:44:33:WU01:FS01:0x22:Checkpoint completed at step 2200000
02:45:15:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
02:45:57:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
02:45:57:WU01:FS01:0x22:Checkpoint completed at step 2300000
02:46:39:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
02:47:21:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
02:47:21:WU01:FS01:0x22:Checkpoint completed at step 2400000
02:48:03:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
02:48:45:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
02:48:45:WU01:FS01:0x22:Checkpoint completed at step 2500000
02:49:27:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
02:50:09:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
02:50:09:WU01:FS01:0x22:Checkpoint completed at step 2600000
02:50:51:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
02:51:33:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
02:51:33:WU01:FS01:0x22:Checkpoint completed at step 2700000
02:52:15:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
02:52:57:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
02:52:57:WU01:FS01:0x22:Checkpoint completed at step 2800000
02:53:39:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
02:54:21:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
02:54:21:WU01:FS01:0x22:Checkpoint completed at step 2900000
02:55:03:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
02:55:45:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
02:55:45:WU01:FS01:0x22:Checkpoint completed at step 3000000
02:56:27:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
02:57:09:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
02:57:09:WU01:FS01:0x22:Checkpoint completed at step 3100000
02:57:51:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
02:58:33:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
02:58:33:WU01:FS01:0x22:Checkpoint completed at step 3200000
02:59:16:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
02:59:58:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
02:59:58:WU01:FS01:0x22:Checkpoint completed at step 3300000
03:00:40:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
03:01:22:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
03:01:22:WU01:FS01:0x22:Checkpoint completed at step 3400000
03:02:04:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
03:02:46:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
03:02:47:WU01:FS01:0x22:Checkpoint completed at step 3500000
03:03:29:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
03:04:11:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
03:04:11:WU01:FS01:0x22:Checkpoint completed at step 3600000
03:04:53:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
03:05:35:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
03:05:35:WU01:FS01:0x22:Checkpoint completed at step 3700000
03:06:17:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
03:06:59:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
03:06:59:WU01:FS01:0x22:Checkpoint completed at step 3800000
03:07:41:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
03:08:23:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
03:08:23:WU01:FS01:0x22:Checkpoint completed at step 3900000
03:09:05:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
03:09:47:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
03:09:48:WU01:FS01:0x22:Checkpoint completed at step 4000000
03:10:30:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
03:11:12:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
03:11:12:WU01:FS01:0x22:Checkpoint completed at step 4100000
03:11:54:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
03:12:36:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
03:12:36:WU01:FS01:0x22:Checkpoint completed at step 4200000
03:13:18:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
03:14:00:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
03:14:00:WU01:FS01:0x22:Checkpoint completed at step 4300000
03:14:43:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
03:15:25:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
03:15:25:WU01:FS01:0x22:Checkpoint completed at step 4400000
03:16:07:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
03:16:49:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
03:16:49:WU01:FS01:0x22:Checkpoint completed at step 4500000
03:17:31:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
03:18:13:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
03:18:14:WU01:FS01:0x22:Checkpoint completed at step 4600000
03:18:56:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
03:19:38:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
03:19:38:WU01:FS01:0x22:Checkpoint completed at step 4700000
03:20:20:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
03:21:03:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
03:21:03:WU01:FS01:0x22:Checkpoint completed at step 4800000
03:21:45:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
03:22:27:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
03:22:27:WU01:FS01:0x22:Checkpoint completed at step 4900000
03:23:09:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
03:23:51:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
03:23:51:WU01:FS01:0x22:Average performance: 514.286 ns/day
03:23:51:WU01:FS01:0x22:Checkpoint completed at step 5000000
03:23:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
03:23:52:WU00:FS01:Assigned to work server 129.32.209.202
03:23:52:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
03:23:52:WU00:FS01:Connecting to 129.32.209.202:8080
03:23:52:WU01:FS01:0x22:Saving result file ../logfile_01.txt
03:23:52:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
03:23:52:WU01:FS01:0x22:Saving result file checkpointState.xml
03:23:52:WU01:FS01:0x22:Saving result file positions.xtc
03:23:52:WU01:FS01:0x22:Saving result file science.log
03:23:52:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
03:23:52:WU00:FS01:Downloading 27.78MiB
03:23:53:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:23:53:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:7 clone:99 gen:41 core:0x22 unit:0x0000006300000029000047ff00000007
03:23:53:WU01:FS01:Uploading 14.35MiB to 129.32.209.202
03:23:53:WU01:FS01:Connecting to 129.32.209.202:8080
03:23:55:WU00:FS01:Download complete
03:23:55:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18431 run:10 clone:140 gen:16 core:0x22 unit:0x0000008c00000010000047ff0000000a
03:23:55:WU00:FS01:Starting
03:23:55:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
03:23:55:WU00:FS01:Started FahCore on PID 8287
03:23:55:WU00:FS01:Core PID:8291
03:23:55:WU00:FS01:FahCore 0x22 started
03:23:56:WU00:FS01:0x22:*********************** Log Started 2021-11-12T03:23:55Z ***********************
03:23:56:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
03:23:56:WU00:FS01:0x22: Core: Core22
03:23:56:WU00:FS01:0x22: Type: 0x22
03:23:56:WU00:FS01:0x22: Version: 0.0.13
03:23:56:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
03:23:56:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
03:23:56:WU00:FS01:0x22: Homepage: https://foldingathome.org/
03:23:56:WU00:FS01:0x22: Date: Sep 19 2020
03:23:56:WU00:FS01:0x22: Time: 01:10:35
03:23:56:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
03:23:56:WU00:FS01:0x22: Branch: core22-0.0.13
03:23:56:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
03:23:56:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
03:23:56:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
03:23:56:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
03:23:56:WU00:FS01:0x22: Bits: 64
03:23:56:WU00:FS01:0x22: Mode: Release
03:23:56:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
03:23:56:WU00:FS01:0x22: <[email protected]>
03:23:56:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 8287 -checkpoint 15
03:23:56:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
03:23:56:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
03:23:56:WU00:FS01:0x22:************************************ libFAH ************************************
03:23:56:WU00:FS01:0x22: Date: Sep 15 2020
03:23:56:WU00:FS01:0x22: Time: 05:14:43
03:23:56:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
03:23:56:WU00:FS01:0x22: Branch: HEAD
03:23:56:WU00:FS01:0x22:************************************ CBang *************************************
03:23:56:WU00:FS01:0x22: Time: 05:11:04
03:23:56:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
03:23:56:WU00:FS01:0x22: -funroll-loops -fPIC
03:23:56:WU00:FS01:0x22:************************************ System ************************************
03:23:56:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
03:23:56:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
03:23:56:WU00:FS01:0x22: CPUs: 8
03:23:56:WU00:FS01:0x22: Memory: 15.58GiB
03:23:56:WU00:FS01:0x22:Free Memory: 11.96GiB
03:23:56:WU00:FS01:0x22: Threads: POSIX_THREADS
03:23:56:WU00:FS01:0x22: OS Version: 5.11
03:23:56:WU00:FS01:0x22:Has Battery: false
03:23:56:WU00:FS01:0x22: On Battery: false
03:23:56:WU00:FS01:0x22: UTC Offset: -5
03:23:56:WU00:FS01:0x22: PID: 8291
03:23:56:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
03:23:56:WU00:FS01:0x22:************************************ OpenMM ************************************
03:23:56:WU00:FS01:0x22: Revision: 189320d0
03:23:56:WU00:FS01:0x22:********************************************************************************
03:23:56:WU00:FS01:0x22:Project: 18431 (Run 10, Clone 140, Gen 16)
03:23:56:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
03:23:56:WU00:FS01:0x22:Reading tar file core.xml
03:23:56:WU00:FS01:0x22:Reading tar file integrator.xml
03:23:56:WU00:FS01:0x22:Reading tar file state.xml
03:23:56:WU00:FS01:0x22:Reading tar file system.xml
03:23:56:WU00:FS01:0x22:Digital signatures verified
03:23:56:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
03:23:56:WU00:FS01:0x22:Version 0.0.13
03:23:56:WU00:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
03:23:56:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
03:23:56:WU00:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
03:23:56:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
03:23:56:WU00:FS01:0x22:There are 4 platforms available.
03:23:56:WU00:FS01:0x22:Platform 0: Reference
03:23:56:WU00:FS01:0x22:Platform 1: CPU
03:23:56:WU00:FS01:0x22:Platform 2: OpenCL
03:23:56:WU00:FS01:0x22: opencl-device 0 specified
03:23:56:WU00:FS01:0x22:Platform 3: CUDA
03:23:56:WU00:FS01:0x22: cuda-device 0 specified
03:23:57:WU01:FS01:Upload complete
03:23:57:WU01:FS01:Server responded WORK_ACK (400)
03:23:57:WU01:FS01:Final credit estimate, 294111.00 points
03:23:57:WU01:FS01:Cleaning up
03:23:58:WU00:FS01:0x22:Attempting to create CUDA context:
03:23:58:WU00:FS01:0x22: Configuring platform CUDA
03:25:25:WU00:FS01:0x22: Using CUDA and gpu 0
03:25:25:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
03:25:26:WU00:FS01:0x22:Checkpoint completed at step 0
03:26:08:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
03:26:50:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
03:26:50:WU00:FS01:0x22:Checkpoint completed at step 100000
03:27:33:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
03:28:15:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
03:28:15:WU00:FS01:0x22:Checkpoint completed at step 200000
03:28:58:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
03:29:40:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
03:29:40:WU00:FS01:0x22:Checkpoint completed at step 300000
03:30:22:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
03:31:05:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
03:31:05:WU00:FS01:0x22:Checkpoint completed at step 400000
03:31:48:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
03:32:30:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
03:32:30:WU00:FS01:0x22:Checkpoint completed at step 500000
03:33:12:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
03:33:55:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
03:33:55:WU00:FS01:0x22:Checkpoint completed at step 600000
03:34:37:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
03:35:20:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
03:35:20:WU00:FS01:0x22:Checkpoint completed at step 700000
03:36:02:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
03:36:44:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
03:36:45:WU00:FS01:0x22:Checkpoint completed at step 800000
03:37:27:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
03:38:09:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
03:38:09:WU00:FS01:0x22:Checkpoint completed at step 900000
03:38:52:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
03:39:34:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
03:39:34:WU00:FS01:0x22:Checkpoint completed at step 1000000
03:40:17:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
03:40:59:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
03:40:59:WU00:FS01:0x22:Checkpoint completed at step 1100000
03:41:41:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
03:42:24:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
03:42:24:WU00:FS01:0x22:Checkpoint completed at step 1200000
03:43:06:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
03:43:49:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
03:43:49:WU00:FS01:0x22:Checkpoint completed at step 1300000
03:44:31:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
03:45:14:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
03:45:14:WU00:FS01:0x22:Checkpoint completed at step 1400000
03:45:57:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
03:46:39:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
03:46:39:WU00:FS01:0x22:Checkpoint completed at step 1500000
03:47:22:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
03:48:04:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
03:48:04:WU00:FS01:0x22:Checkpoint completed at step 1600000
03:48:46:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
03:49:29:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
03:49:29:WU00:FS01:0x22:Checkpoint completed at step 1700000
03:50:11:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
03:50:54:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
03:50:54:WU00:FS01:0x22:Checkpoint completed at step 1800000
03:51:36:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
03:52:18:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
03:52:19:WU00:FS01:0x22:Checkpoint completed at step 1900000
03:53:01:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
03:53:43:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
03:53:43:WU00:FS01:0x22:Checkpoint completed at step 2000000
03:54:26:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
03:55:08:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
03:55:08:WU00:FS01:0x22:Checkpoint completed at step 2100000
03:55:50:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
03:56:33:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
03:56:33:WU00:FS01:0x22:Checkpoint completed at step 2200000
03:57:15:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
03:57:57:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
03:57:58:WU00:FS01:0x22:Checkpoint completed at step 2300000
03:58:40:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
03:59:22:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
03:59:23:WU00:FS01:0x22:Checkpoint completed at step 2400000
04:00:05:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
04:00:47:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
04:00:47:WU00:FS01:0x22:Checkpoint completed at step 2500000
04:01:29:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
04:02:12:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
04:02:12:WU00:FS01:0x22:Checkpoint completed at step 2600000
04:02:54:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
04:03:36:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
04:03:37:WU00:FS01:0x22:Checkpoint completed at step 2700000
04:04:19:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
04:05:01:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
04:05:01:WU00:FS01:0x22:Checkpoint completed at step 2800000
04:05:43:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
04:06:26:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
04:06:26:WU00:FS01:0x22:Checkpoint completed at step 2900000
04:07:08:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
04:07:50:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
04:07:50:WU00:FS01:0x22:Checkpoint completed at step 3000000
04:08:33:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
04:09:15:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
04:09:15:WU00:FS01:0x22:Checkpoint completed at step 3100000
04:09:57:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
04:10:40:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
04:10:40:WU00:FS01:0x22:Checkpoint completed at step 3200000
04:11:22:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
04:12:04:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
04:12:04:WU00:FS01:0x22:Checkpoint completed at step 3300000
04:12:47:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
04:13:29:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
04:13:30:WU00:FS01:0x22:Checkpoint completed at step 3400000
04:14:12:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
04:14:54:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
04:14:54:WU00:FS01:0x22:Checkpoint completed at step 3500000
04:15:37:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
04:16:19:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
04:16:19:WU00:FS01:0x22:Checkpoint completed at step 3600000
04:17:02:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
04:17:44:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
04:17:44:WU00:FS01:0x22:Checkpoint completed at step 3700000
04:18:26:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
04:19:09:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
04:19:09:WU00:FS01:0x22:Checkpoint completed at step 3800000
04:19:51:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
04:20:33:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
04:20:33:WU00:FS01:0x22:Checkpoint completed at step 3900000
04:21:15:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
04:21:58:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
04:21:58:WU00:FS01:0x22:Checkpoint completed at step 4000000
04:22:40:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
04:23:22:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
04:23:22:WU00:FS01:0x22:Checkpoint completed at step 4100000
04:24:04:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
04:24:47:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
04:24:47:WU00:FS01:0x22:Checkpoint completed at step 4200000
04:25:29:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
04:26:11:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
04:26:12:WU00:FS01:0x22:Checkpoint completed at step 4300000
04:26:54:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
04:27:36:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
04:27:36:WU00:FS01:0x22:Checkpoint completed at step 4400000
04:28:19:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
04:29:01:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
04:29:01:WU00:FS01:0x22:Checkpoint completed at step 4500000
04:29:44:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
04:30:26:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
04:30:26:WU00:FS01:0x22:Checkpoint completed at step 4600000
04:31:08:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
04:31:50:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
04:31:51:WU00:FS01:0x22:Checkpoint completed at step 4700000
04:32:33:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
04:33:15:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
04:33:15:WU00:FS01:0x22:Checkpoint completed at step 4800000
04:33:58:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
04:34:40:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
04:34:40:WU00:FS01:0x22:Checkpoint completed at step 4900000
04:35:22:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
04:36:04:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
04:36:04:WU00:FS01:0x22:Average performance: 514.286 ns/day
04:36:05:WU00:FS01:0x22:Checkpoint completed at step 5000000
04:36:05:WU01:FS01:Connecting to assign1.foldingathome.org:80
04:36:05:WU01:FS01:Assigned to work server 129.32.209.202
04:36:05:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
04:36:05:WU01:FS01:Connecting to 129.32.209.202:8080
04:36:05:WU01:FS01:Downloading 27.78MiB
04:36:06:WU00:FS01:0x22:Saving result file ../logfile_01.txt
04:36:06:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
04:36:06:WU00:FS01:0x22:Saving result file checkpointState.xml
04:36:06:WU00:FS01:0x22:Saving result file positions.xtc
04:36:06:WU00:FS01:0x22:Saving result file science.log
04:36:06:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
04:36:06:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:36:06:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18431 run:10 clone:140 gen:16 core:0x22 unit:0x0000008c00000010000047ff0000000a
04:36:06:WU00:FS01:Uploading 14.33MiB to 129.32.209.202
04:36:06:WU00:FS01:Connecting to 129.32.209.202:8080
04:36:08:WU01:FS01:Download complete
04:36:08:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:4 clone:120 gen:91 core:0x22 unit:0x000000780000005b000047ff00000004
04:36:08:WU01:FS01:Starting
04:36:08:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
04:36:08:WU01:FS01:Started FahCore on PID 8471
04:36:08:WU01:FS01:Core PID:8475
04:36:08:WU01:FS01:FahCore 0x22 started
04:36:08:WU01:FS01:0x22:*********************** Log Started 2021-11-12T04:36:08Z ***********************
04:36:08:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
04:36:08:WU01:FS01:0x22: Core: Core22
04:36:08:WU01:FS01:0x22: Type: 0x22
04:36:08:WU01:FS01:0x22: Version: 0.0.13
04:36:08:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
04:36:08:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
04:36:08:WU01:FS01:0x22: Homepage: https://foldingathome.org/
04:36:08:WU01:FS01:0x22: Date: Sep 19 2020
04:36:08:WU01:FS01:0x22: Time: 01:10:35
04:36:08:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
04:36:08:WU01:FS01:0x22: Branch: core22-0.0.13
04:36:08:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:36:08:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
04:36:08:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
04:36:08:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
04:36:08:WU01:FS01:0x22: Bits: 64
04:36:08:WU01:FS01:0x22: Mode: Release
04:36:08:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
04:36:08:WU01:FS01:0x22: <[email protected]>
04:36:08:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 8471 -checkpoint 15
04:36:08:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
04:36:08:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
04:36:08:WU01:FS01:0x22:************************************ libFAH ************************************
04:36:08:WU01:FS01:0x22: Date: Sep 15 2020
04:36:08:WU01:FS01:0x22: Time: 05:14:43
04:36:08:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
04:36:08:WU01:FS01:0x22: Branch: HEAD
04:36:08:WU01:FS01:0x22:************************************ CBang *************************************
04:36:08:WU01:FS01:0x22: Time: 05:11:04
04:36:08:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
04:36:08:WU01:FS01:0x22: -funroll-loops -fPIC
04:36:08:WU01:FS01:0x22:************************************ System ************************************
04:36:08:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
04:36:08:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:36:08:WU01:FS01:0x22: CPUs: 8
04:36:08:WU01:FS01:0x22: Memory: 15.58GiB
04:36:08:WU01:FS01:0x22:Free Memory: 11.92GiB
04:36:08:WU01:FS01:0x22: Threads: POSIX_THREADS
04:36:08:WU01:FS01:0x22: OS Version: 5.11
04:36:08:WU01:FS01:0x22:Has Battery: false
04:36:08:WU01:FS01:0x22: On Battery: false
04:36:08:WU01:FS01:0x22: UTC Offset: -5
04:36:08:WU01:FS01:0x22: PID: 8475
04:36:08:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
04:36:08:WU01:FS01:0x22:************************************ OpenMM ************************************
04:36:08:WU01:FS01:0x22: Revision: 189320d0
04:36:08:WU01:FS01:0x22:********************************************************************************
04:36:08:WU01:FS01:0x22:Project: 18431 (Run 4, Clone 120, Gen 91)
04:36:08:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
04:36:08:WU01:FS01:0x22:Reading tar file core.xml
04:36:08:WU01:FS01:0x22:Reading tar file integrator.xml
04:36:08:WU01:FS01:0x22:Reading tar file state.xml
04:36:08:WU01:FS01:0x22:Reading tar file system.xml
04:36:08:WU01:FS01:0x22:Digital signatures verified
04:36:08:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
04:36:08:WU01:FS01:0x22:Version 0.0.13
04:36:08:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
04:36:08:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
04:36:08:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
04:36:08:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
04:36:08:WU01:FS01:0x22:There are 4 platforms available.
04:36:08:WU01:FS01:0x22:Platform 0: Reference
04:36:08:WU01:FS01:0x22:Platform 1: CPU
04:36:08:WU01:FS01:0x22:Platform 2: OpenCL
04:36:08:WU01:FS01:0x22: opencl-device 0 specified
04:36:08:WU01:FS01:0x22:Platform 3: CUDA
04:36:08:WU01:FS01:0x22: cuda-device 0 specified
04:36:10:WU00:FS01:Upload complete
04:36:10:WU00:FS01:Server responded WORK_ACK (400)
04:36:10:WU00:FS01:Final credit estimate, 293160.00 points
04:36:10:WU00:FS01:Cleaning up
04:36:10:WU01:FS01:0x22:Attempting to create CUDA context:
04:36:10:WU01:FS01:0x22: Configuring platform CUDA
04:37:37:WU01:FS01:0x22: Using CUDA and gpu 0
04:37:37:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
04:37:37:WU01:FS01:0x22:Checkpoint completed at step 0
04:38:18:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
04:39:00:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
04:39:01:WU01:FS01:0x22:Checkpoint completed at step 100000
04:39:42:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
04:40:24:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
04:40:24:WU01:FS01:0x22:Checkpoint completed at step 200000
04:41:06:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
04:41:48:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
04:41:48:WU01:FS01:0x22:Checkpoint completed at step 300000
04:42:30:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
04:43:12:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
04:43:12:WU01:FS01:0x22:Checkpoint completed at step 400000
04:43:54:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
04:44:36:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
04:44:36:WU01:FS01:0x22:Checkpoint completed at step 500000
04:45:18:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
04:45:59:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
04:45:59:WU01:FS01:0x22:Checkpoint completed at step 600000
04:46:41:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
04:47:23:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
04:47:23:WU01:FS01:0x22:Checkpoint completed at step 700000
04:48:05:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
04:48:47:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
04:48:47:WU01:FS01:0x22:Checkpoint completed at step 800000
04:49:29:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
04:50:11:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
04:50:11:WU01:FS01:0x22:Checkpoint completed at step 900000
04:50:53:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
04:51:35:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
04:51:35:WU01:FS01:0x22:Checkpoint completed at step 1000000
04:52:17:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
04:52:59:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
04:52:59:WU01:FS01:0x22:Checkpoint completed at step 1100000
04:53:41:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
04:54:23:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
04:54:24:WU01:FS01:0x22:Checkpoint completed at step 1200000
04:55:06:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
04:55:48:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
04:55:48:WU01:FS01:0x22:Checkpoint completed at step 1300000
04:56:30:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
04:57:12:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
04:57:12:WU01:FS01:0x22:Checkpoint completed at step 1400000
04:57:54:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
04:58:36:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
04:58:36:WU01:FS01:0x22:Checkpoint completed at step 1500000
04:59:18:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
05:00:00:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
05:00:00:WU01:FS01:0x22:Checkpoint completed at step 1600000
05:00:42:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
05:01:24:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
05:01:24:WU01:FS01:0x22:Checkpoint completed at step 1700000
05:02:06:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
05:02:48:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
05:02:48:WU01:FS01:0x22:Checkpoint completed at step 1800000
05:03:30:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
05:04:12:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
05:04:12:WU01:FS01:0x22:Checkpoint completed at step 1900000
05:04:54:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
05:05:36:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
05:05:36:WU01:FS01:0x22:Checkpoint completed at step 2000000
05:06:18:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
05:07:00:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
05:07:00:WU01:FS01:0x22:Checkpoint completed at step 2100000
05:07:42:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
05:08:24:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
05:08:24:WU01:FS01:0x22:Checkpoint completed at step 2200000
05:09:06:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
05:09:47:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
05:09:48:WU01:FS01:0x22:Checkpoint completed at step 2300000
05:10:29:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
05:11:11:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
05:11:12:WU01:FS01:0x22:Checkpoint completed at step 2400000
05:11:54:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
05:12:36:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
05:12:36:WU01:FS01:0x22:Checkpoint completed at step 2500000
05:13:18:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
05:13:59:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
05:14:00:WU01:FS01:0x22:Checkpoint completed at step 2600000
05:14:42:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
05:15:23:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
05:15:24:WU01:FS01:0x22:Checkpoint completed at step 2700000
05:16:06:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
05:16:48:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
05:16:48:WU01:FS01:0x22:Checkpoint completed at step 2800000
05:17:30:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
05:18:12:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
05:18:12:WU01:FS01:0x22:Checkpoint completed at step 2900000
05:18:54:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
05:19:36:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
05:19:36:WU01:FS01:0x22:Checkpoint completed at step 3000000
05:20:18:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
05:21:00:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
05:21:00:WU01:FS01:0x22:Checkpoint completed at step 3100000
05:21:42:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
05:22:24:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
05:22:24:WU01:FS01:0x22:Checkpoint completed at step 3200000
05:23:06:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
05:23:48:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
05:23:48:WU01:FS01:0x22:Checkpoint completed at step 3300000
05:24:30:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
05:25:12:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
05:25:12:WU01:FS01:0x22:Checkpoint completed at step 3400000
05:25:54:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
05:26:35:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
05:26:36:WU01:FS01:0x22:Checkpoint completed at step 3500000
05:27:18:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
05:27:59:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
05:27:59:WU01:FS01:0x22:Checkpoint completed at step 3600000
05:28:41:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
05:29:23:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
05:29:23:WU01:FS01:0x22:Checkpoint completed at step 3700000
05:30:05:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
05:30:47:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
05:30:47:WU01:FS01:0x22:Checkpoint completed at step 3800000
05:31:29:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
05:32:11:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
05:32:11:WU01:FS01:0x22:Checkpoint completed at step 3900000
05:32:53:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
05:33:35:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
05:33:35:WU01:FS01:0x22:Checkpoint completed at step 4000000
05:34:17:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
05:34:59:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
05:34:59:WU01:FS01:0x22:Checkpoint completed at step 4100000
05:35:41:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
05:36:22:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
05:36:23:WU01:FS01:0x22:Checkpoint completed at step 4200000
05:37:04:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
05:37:46:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
05:37:46:WU01:FS01:0x22:Checkpoint completed at step 4300000
05:38:28:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
05:39:10:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
05:39:10:WU01:FS01:0x22:Checkpoint completed at step 4400000
05:39:52:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
05:40:34:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
05:40:34:WU01:FS01:0x22:Checkpoint completed at step 4500000
05:41:16:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
05:41:58:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
05:41:58:WU01:FS01:0x22:Checkpoint completed at step 4600000
05:42:40:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
05:43:22:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
05:43:22:WU01:FS01:0x22:Checkpoint completed at step 4700000
05:44:04:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
05:44:46:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
05:44:46:WU01:FS01:0x22:Checkpoint completed at step 4800000
05:45:28:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
05:46:10:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
05:46:10:WU01:FS01:0x22:Checkpoint completed at step 4900000
05:46:52:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
05:47:34:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
05:47:34:WU01:FS01:0x22:Average performance: 514.286 ns/day
05:47:34:WU01:FS01:0x22:Checkpoint completed at step 5000000
05:47:35:WU00:FS01:Connecting to assign1.foldingathome.org:80
05:47:35:WU00:FS01:Assigned to work server 34.72.228.44
05:47:35:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 34.72.228.44
05:47:35:WU00:FS01:Connecting to 34.72.228.44:8080
05:47:35:WU01:FS01:0x22:Saving result file ../logfile_01.txt
05:47:35:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
05:47:35:WU01:FS01:0x22:Saving result file checkpointState.xml
05:47:35:WU01:FS01:0x22:Saving result file positions.xtc
05:47:35:WU01:FS01:0x22:Saving result file science.log
05:47:35:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
05:47:35:WU00:FS01:Downloading 3.12MiB
05:47:36:WU00:FS01:Download complete
05:47:36:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:47:36:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:4 clone:120 gen:91 core:0x22 unit:0x000000780000005b000047ff00000004
05:47:36:WU01:FS01:Uploading 14.33MiB to 129.32.209.202
05:47:36:WU01:FS01:Connecting to 129.32.209.202:8080
05:47:36:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18115 run:0 clone:495 gen:37 core:0x22 unit:0x000001ef00000025000046c300000000
05:47:36:WU00:FS01:Starting
05:47:36:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
05:47:36:WU00:FS01:Started FahCore on PID 8640
05:47:36:WU00:FS01:Core PID:8644
05:47:36:WU00:FS01:FahCore 0x22 started
05:47:36:WU00:FS01:0x22:*********************** Log Started 2021-11-12T05:47:36Z ***********************
05:47:36:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
05:47:36:WU00:FS01:0x22: Core: Core22
05:47:36:WU00:FS01:0x22: Type: 0x22
05:47:36:WU00:FS01:0x22: Version: 0.0.13
05:47:36:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
05:47:36:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
05:47:36:WU00:FS01:0x22: Homepage: https://foldingathome.org/
05:47:36:WU00:FS01:0x22: Date: Sep 19 2020
05:47:36:WU00:FS01:0x22: Time: 01:10:35
05:47:36:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
05:47:36:WU00:FS01:0x22: Branch: core22-0.0.13
05:47:36:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
05:47:36:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
05:47:36:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
05:47:36:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
05:47:36:WU00:FS01:0x22: Bits: 64
05:47:36:WU00:FS01:0x22: Mode: Release
05:47:36:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
05:47:36:WU00:FS01:0x22: <[email protected]>
05:47:36:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 8640 -checkpoint 15
05:47:36:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
05:47:36:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
05:47:36:WU00:FS01:0x22:************************************ libFAH ************************************
05:47:36:WU00:FS01:0x22: Date: Sep 15 2020
05:47:36:WU00:FS01:0x22: Time: 05:14:43
05:47:36:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
05:47:36:WU00:FS01:0x22: Branch: HEAD
05:47:36:WU00:FS01:0x22:************************************ CBang *************************************
05:47:36:WU00:FS01:0x22: Time: 05:11:04
05:47:36:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
05:47:36:WU00:FS01:0x22: -funroll-loops -fPIC
05:47:36:WU00:FS01:0x22:************************************ System ************************************
05:47:36:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
05:47:36:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
05:47:36:WU00:FS01:0x22: CPUs: 8
05:47:36:WU00:FS01:0x22: Memory: 15.58GiB
05:47:36:WU00:FS01:0x22:Free Memory: 11.91GiB
05:47:36:WU00:FS01:0x22: Threads: POSIX_THREADS
05:47:36:WU00:FS01:0x22: OS Version: 5.11
05:47:36:WU00:FS01:0x22:Has Battery: false
05:47:36:WU00:FS01:0x22: On Battery: false
05:47:36:WU00:FS01:0x22: UTC Offset: -5
05:47:36:WU00:FS01:0x22: PID: 8644
05:47:36:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
05:47:36:WU00:FS01:0x22:************************************ OpenMM ************************************
05:47:36:WU00:FS01:0x22: Revision: 189320d0
05:47:36:WU00:FS01:0x22:********************************************************************************
05:47:36:WU00:FS01:0x22:Project: 18115 (Run 0, Clone 495, Gen 37)
05:47:36:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
05:47:36:WU00:FS01:0x22:Reading tar file core.xml
05:47:36:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
05:47:36:WU00:FS01:0x22:Reading tar file state.xml.bz2
05:47:36:WU00:FS01:0x22:Reading tar file system.xml.bz2
05:47:36:WU00:FS01:0x22:Digital signatures verified
05:47:36:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
05:47:36:WU00:FS01:0x22:Version 0.0.13
05:47:36:WU00:FS01:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
05:47:36:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
05:47:36:WU00:FS01:0x22: XTC frame write interval: 50000 steps (1%) [100 total]
05:47:36:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
05:47:36:WU00:FS01:0x22:There are 4 platforms available.
05:47:36:WU00:FS01:0x22:Platform 0: Reference
05:47:36:WU00:FS01:0x22:Platform 1: CPU
05:47:36:WU00:FS01:0x22:Platform 2: OpenCL
05:47:36:WU00:FS01:0x22: opencl-device 0 specified
05:47:36:WU00:FS01:0x22:Platform 3: CUDA
05:47:36:WU00:FS01:0x22: cuda-device 0 specified
05:47:38:WU00:FS01:0x22:Attempting to create CUDA context:
05:47:38:WU00:FS01:0x22: Configuring platform CUDA
05:47:39:WU01:FS01:Upload complete
05:47:39:WU01:FS01:Server responded WORK_ACK (400)
05:47:39:WU01:FS01:Final credit estimate, 294659.00 points
05:47:39:WU01:FS01:Cleaning up
05:49:08:WU00:FS01:0x22: Using CUDA and gpu 0
05:49:08:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
05:49:08:WU00:FS01:0x22:Checkpoint completed at step 0
05:49:51:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
05:50:33:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
05:51:15:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
05:51:57:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
05:52:39:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
05:52:39:WU00:FS01:0x22:Checkpoint completed at step 250000
05:53:21:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
05:54:03:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
05:54:45:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
05:55:27:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
05:56:10:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
05:56:10:WU00:FS01:0x22:Checkpoint completed at step 500000
05:56:52:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
05:57:34:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
05:58:17:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
05:58:59:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
05:59:41:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
05:59:41:WU00:FS01:0x22:Checkpoint completed at step 750000
06:00:23:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
06:01:05:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
06:01:48:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
06:02:30:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
06:03:12:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
06:03:12:WU00:FS01:0x22:Checkpoint completed at step 1000000
06:03:55:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
06:04:37:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
06:05:19:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
06:06:01:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
06:06:44:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
06:06:44:WU00:FS01:0x22:Checkpoint completed at step 1250000
06:07:26:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
06:08:09:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
******************************* Date: 2021-11-12 *******************************
06:08:51:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
06:09:34:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
06:10:16:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
06:10:16:WU00:FS01:0x22:Checkpoint completed at step 1500000
06:10:58:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
06:11:41:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
06:12:23:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
06:13:05:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
06:13:47:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
06:13:47:WU00:FS01:0x22:Checkpoint completed at step 1750000
06:14:30:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
06:15:12:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
06:15:54:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
06:16:36:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
06:17:18:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
06:17:18:WU00:FS01:0x22:Checkpoint completed at step 2000000
06:18:00:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
06:18:42:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
06:19:24:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
06:20:07:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
06:20:49:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
06:20:49:WU00:FS01:0x22:Checkpoint completed at step 2250000
06:21:31:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
06:22:13:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
06:22:55:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
06:23:38:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
06:24:20:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
06:24:20:WU00:FS01:0x22:Checkpoint completed at step 2500000
06:25:02:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
06:25:44:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
06:26:26:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
06:27:08:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
06:27:51:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
06:27:51:WU00:FS01:0x22:Checkpoint completed at step 2750000
06:28:33:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
06:29:15:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
06:29:58:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
06:30:40:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
06:31:22:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
06:31:22:WU00:FS01:0x22:Checkpoint completed at step 3000000
06:32:05:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
06:32:47:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
06:33:29:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
06:34:11:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
06:34:54:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
06:34:54:WU00:FS01:0x22:Checkpoint completed at step 3250000
06:35:36:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
06:36:19:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
06:37:01:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
06:37:43:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
06:38:26:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
06:38:26:WU00:FS01:0x22:Checkpoint completed at step 3500000
06:39:08:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
06:39:51:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
06:40:33:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
06:41:15:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
06:41:58:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
06:41:58:WU00:FS01:0x22:Checkpoint completed at step 3750000
06:42:41:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
06:43:23:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
06:44:06:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
06:44:48:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
06:45:30:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
06:45:31:WU00:FS01:0x22:Checkpoint completed at step 4000000
06:46:13:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
06:46:55:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
06:47:37:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
06:48:20:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
06:49:02:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
06:49:02:WU00:FS01:0x22:Checkpoint completed at step 4250000
06:49:44:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
06:50:27:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
06:51:09:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
06:51:51:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
06:52:33:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
06:52:34:WU00:FS01:0x22:Checkpoint completed at step 4500000
06:53:16:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
06:53:58:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
06:54:40:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
06:55:23:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
06:56:05:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
06:56:05:WU00:FS01:0x22:Checkpoint completed at step 4750000
06:56:47:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
06:57:29:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
06:58:12:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
06:58:54:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
06:59:36:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
06:59:36:WU00:FS01:0x22:Average performance: 81.8957 ns/day
06:59:36:WU00:FS01:0x22:Checkpoint completed at step 5000000
06:59:37:WU01:FS01:Connecting to assign1.foldingathome.org:80
06:59:37:WU01:FS01:Assigned to work server 129.32.209.202
06:59:37:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
06:59:37:WU01:FS01:Connecting to 129.32.209.202:8080
06:59:37:WU01:FS01:Downloading 27.77MiB
06:59:39:WU00:FS01:0x22:Saving result file ../logfile_01.txt
06:59:39:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
06:59:39:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
06:59:39:WU00:FS01:0x22:Saving result file positions.xtc
06:59:39:WU00:FS01:0x22:Saving result file science.log
06:59:39:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
06:59:40:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:59:40:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18115 run:0 clone:495 gen:37 core:0x22 unit:0x000001ef00000025000046c300000000
06:59:40:WU00:FS01:Uploading 16.80MiB to 34.72.228.44
06:59:40:WU00:FS01:Connecting to 34.72.228.44:8080
06:59:40:WU01:FS01:Download complete
06:59:40:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:8 clone:166 gen:57 core:0x22 unit:0x000000a600000039000047ff00000008
06:59:40:WU01:FS01:Starting
06:59:40:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
06:59:40:WU01:FS01:Started FahCore on PID 9339
06:59:40:WU01:FS01:Core PID:9343
06:59:40:WU01:FS01:FahCore 0x22 started
06:59:40:WU01:FS01:0x22:*********************** Log Started 2021-11-12T06:59:40Z ***********************
06:59:40:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
06:59:40:WU01:FS01:0x22: Core: Core22
06:59:40:WU01:FS01:0x22: Type: 0x22
06:59:40:WU01:FS01:0x22: Version: 0.0.13
06:59:40:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
06:59:40:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
06:59:40:WU01:FS01:0x22: Homepage: https://foldingathome.org/
06:59:40:WU01:FS01:0x22: Date: Sep 19 2020
06:59:40:WU01:FS01:0x22: Time: 01:10:35
06:59:40:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
06:59:40:WU01:FS01:0x22: Branch: core22-0.0.13
06:59:40:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
06:59:40:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
06:59:40:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
06:59:40:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
06:59:40:WU01:FS01:0x22: Bits: 64
06:59:40:WU01:FS01:0x22: Mode: Release
06:59:40:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
06:59:40:WU01:FS01:0x22: <[email protected]>
06:59:40:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 9339 -checkpoint 15
06:59:40:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
06:59:40:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
06:59:40:WU01:FS01:0x22:************************************ libFAH ************************************
06:59:40:WU01:FS01:0x22: Date: Sep 15 2020
06:59:40:WU01:FS01:0x22: Time: 05:14:43
06:59:40:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
06:59:40:WU01:FS01:0x22: Branch: HEAD
06:59:40:WU01:FS01:0x22:************************************ CBang *************************************
06:59:40:WU01:FS01:0x22: Time: 05:11:04
06:59:40:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
06:59:40:WU01:FS01:0x22: -funroll-loops -fPIC
06:59:40:WU01:FS01:0x22:************************************ System ************************************
06:59:40:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
06:59:40:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
06:59:40:WU01:FS01:0x22: CPUs: 8
06:59:40:WU01:FS01:0x22: Memory: 15.58GiB
06:59:40:WU01:FS01:0x22:Free Memory: 11.85GiB
06:59:40:WU01:FS01:0x22: Threads: POSIX_THREADS
06:59:40:WU01:FS01:0x22: OS Version: 5.11
06:59:40:WU01:FS01:0x22:Has Battery: false
06:59:40:WU01:FS01:0x22: On Battery: false
06:59:40:WU01:FS01:0x22: UTC Offset: -5
06:59:40:WU01:FS01:0x22: PID: 9343
06:59:40:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
06:59:40:WU01:FS01:0x22:************************************ OpenMM ************************************
06:59:40:WU01:FS01:0x22: Revision: 189320d0
06:59:40:WU01:FS01:0x22:********************************************************************************
06:59:40:WU01:FS01:0x22:Project: 18431 (Run 8, Clone 166, Gen 57)
06:59:40:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
06:59:40:WU01:FS01:0x22:Reading tar file core.xml
06:59:40:WU01:FS01:0x22:Reading tar file integrator.xml
06:59:40:WU01:FS01:0x22:Reading tar file state.xml
06:59:40:WU01:FS01:0x22:Reading tar file system.xml
06:59:40:WU01:FS01:0x22:Digital signatures verified
06:59:40:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
06:59:40:WU01:FS01:0x22:Version 0.0.13
06:59:40:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
06:59:40:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
06:59:40:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
06:59:40:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
06:59:40:WU01:FS01:0x22:There are 4 platforms available.
06:59:40:WU01:FS01:0x22:Platform 0: Reference
06:59:40:WU01:FS01:0x22:Platform 1: CPU
06:59:40:WU01:FS01:0x22:Platform 2: OpenCL
06:59:40:WU01:FS01:0x22: opencl-device 0 specified
06:59:40:WU01:FS01:0x22:Platform 3: CUDA
06:59:40:WU01:FS01:0x22: cuda-device 0 specified
06:59:42:WU01:FS01:0x22:Attempting to create CUDA context:
06:59:42:WU01:FS01:0x22: Configuring platform CUDA
06:59:46:WU00:FS01:Upload 67.73%
06:59:56:WU00:FS01:Upload complete
06:59:56:WU00:FS01:Server responded WORK_ACK (400)
06:59:56:WU00:FS01:Final credit estimate, 246076.00 points
06:59:56:WU00:FS01:Cleaning up
07:01:10:WU01:FS01:0x22: Using CUDA and gpu 0
07:01:10:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
07:01:10:WU01:FS01:0x22:Checkpoint completed at step 0
07:01:53:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
07:02:35:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
07:02:35:WU01:FS01:0x22:Checkpoint completed at step 100000
07:03:17:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
07:03:59:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
07:04:00:WU01:FS01:0x22:Checkpoint completed at step 200000
07:04:42:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
07:05:24:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
07:05:24:WU01:FS01:0x22:Checkpoint completed at step 300000
07:06:06:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
07:06:48:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
07:06:49:WU01:FS01:0x22:Checkpoint completed at step 400000
07:07:31:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
07:08:13:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
07:08:13:WU01:FS01:0x22:Checkpoint completed at step 500000
07:08:55:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
07:09:37:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
07:09:37:WU01:FS01:0x22:Checkpoint completed at step 600000
07:10:20:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
07:11:02:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
07:11:02:WU01:FS01:0x22:Checkpoint completed at step 700000
07:11:44:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
07:12:26:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
07:12:26:WU01:FS01:0x22:Checkpoint completed at step 800000
07:13:08:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
07:13:50:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
07:13:50:WU01:FS01:0x22:Checkpoint completed at step 900000
07:14:33:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
07:15:15:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
07:15:15:WU01:FS01:0x22:Checkpoint completed at step 1000000
07:15:57:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
07:16:39:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
07:16:40:WU01:FS01:0x22:Checkpoint completed at step 1100000
07:17:22:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
07:18:04:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
07:18:04:WU01:FS01:0x22:Checkpoint completed at step 1200000
07:18:46:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
07:19:28:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
07:19:28:WU01:FS01:0x22:Checkpoint completed at step 1300000
07:20:11:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
07:20:53:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
07:20:53:WU01:FS01:0x22:Checkpoint completed at step 1400000
07:21:35:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
07:22:17:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
07:22:17:WU01:FS01:0x22:Checkpoint completed at step 1500000
07:23:00:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
07:23:42:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
07:23:42:WU01:FS01:0x22:Checkpoint completed at step 1600000
07:24:24:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
07:25:06:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
07:25:06:WU01:FS01:0x22:Checkpoint completed at step 1700000
07:25:49:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
07:26:31:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
07:26:31:WU01:FS01:0x22:Checkpoint completed at step 1800000
07:27:13:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
07:27:55:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
07:27:55:WU01:FS01:0x22:Checkpoint completed at step 1900000
07:28:38:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
07:29:20:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
07:29:20:WU01:FS01:0x22:Checkpoint completed at step 2000000
07:30:02:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
07:30:44:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
07:30:45:WU01:FS01:0x22:Checkpoint completed at step 2100000
07:31:27:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
07:32:09:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
07:32:09:WU01:FS01:0x22:Checkpoint completed at step 2200000
07:32:51:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
07:33:33:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
07:33:34:WU01:FS01:0x22:Checkpoint completed at step 2300000
07:34:16:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
07:34:58:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
07:34:58:WU01:FS01:0x22:Checkpoint completed at step 2400000
07:35:40:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
07:36:22:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
07:36:23:WU01:FS01:0x22:Checkpoint completed at step 2500000
07:37:05:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
07:37:47:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
07:37:47:WU01:FS01:0x22:Checkpoint completed at step 2600000
07:38:29:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
07:39:11:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
07:39:11:WU01:FS01:0x22:Checkpoint completed at step 2700000
07:39:54:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
07:40:36:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
07:40:36:WU01:FS01:0x22:Checkpoint completed at step 2800000
07:41:18:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
07:42:00:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
07:42:00:WU01:FS01:0x22:Checkpoint completed at step 2900000
07:42:42:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
07:43:25:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
07:43:25:WU01:FS01:0x22:Checkpoint completed at step 3000000
07:44:07:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
07:44:49:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
07:44:49:WU01:FS01:0x22:Checkpoint completed at step 3100000
07:45:31:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
07:46:13:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
07:46:14:WU01:FS01:0x22:Checkpoint completed at step 3200000
07:46:56:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
07:47:38:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
07:47:38:WU01:FS01:0x22:Checkpoint completed at step 3300000
07:48:20:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
07:49:02:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
07:49:02:WU01:FS01:0x22:Checkpoint completed at step 3400000
07:49:44:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
07:50:26:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
07:50:26:WU01:FS01:0x22:Checkpoint completed at step 3500000
07:51:08:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
07:51:50:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
07:51:51:WU01:FS01:0x22:Checkpoint completed at step 3600000
07:52:33:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
07:53:15:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
07:53:15:WU01:FS01:0x22:Checkpoint completed at step 3700000
07:53:57:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
07:54:39:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
07:54:39:WU01:FS01:0x22:Checkpoint completed at step 3800000
07:55:22:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
07:56:04:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
07:56:04:WU01:FS01:0x22:Checkpoint completed at step 3900000
07:56:46:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
07:57:28:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
07:57:28:WU01:FS01:0x22:Checkpoint completed at step 4000000
07:58:11:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
07:58:53:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
07:58:53:WU01:FS01:0x22:Checkpoint completed at step 4100000
07:59:35:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
08:00:17:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
08:00:17:WU01:FS01:0x22:Checkpoint completed at step 4200000
08:00:59:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
08:01:42:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
08:01:42:WU01:FS01:0x22:Checkpoint completed at step 4300000
08:02:24:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
08:03:06:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
08:03:06:WU01:FS01:0x22:Checkpoint completed at step 4400000
08:03:48:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
08:04:31:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
08:04:31:WU01:FS01:0x22:Checkpoint completed at step 4500000
08:05:13:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
08:05:55:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
08:05:55:WU01:FS01:0x22:Checkpoint completed at step 4600000
08:06:38:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
08:07:20:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
08:07:20:WU01:FS01:0x22:Checkpoint completed at step 4700000
08:08:02:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
08:08:45:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
08:08:45:WU01:FS01:0x22:Checkpoint completed at step 4800000
08:09:27:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
08:10:09:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
08:10:09:WU01:FS01:0x22:Checkpoint completed at step 4900000
08:10:52:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
08:11:34:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
08:11:34:WU01:FS01:0x22:Average performance: 514.286 ns/day
08:11:34:WU01:FS01:0x22:Checkpoint completed at step 5000000
08:11:34:WU00:FS01:Connecting to assign1.foldingathome.org:80
08:11:34:WU00:FS01:Assigned to work server 140.163.4.200
08:11:34:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 140.163.4.200
08:11:34:WU00:FS01:Connecting to 140.163.4.200:8080
08:11:34:WU00:FS01:Downloading 13.12MiB
08:11:35:WU01:FS01:0x22:Saving result file ../logfile_01.txt
08:11:35:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
08:11:35:WU01:FS01:0x22:Saving result file checkpointState.xml
08:11:35:WU01:FS01:0x22:Saving result file positions.xtc
08:11:35:WU01:FS01:0x22:Saving result file science.log
08:11:35:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
08:11:35:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:11:35:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:8 clone:166 gen:57 core:0x22 unit:0x000000a600000039000047ff00000008
08:11:35:WU01:FS01:Uploading 14.33MiB to 129.32.209.202
08:11:35:WU01:FS01:Connecting to 129.32.209.202:8080
08:11:36:WU00:FS01:Download complete
08:11:36:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16485 run:0 clone:174 gen:13 core:0x22 unit:0x000000ae0000000d0000406500000000
08:11:36:WU00:FS01:Starting
08:11:36:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
08:11:36:WU00:FS01:Started FahCore on PID 9527
08:11:36:WU00:FS01:Core PID:9531
08:11:36:WU00:FS01:FahCore 0x22 started
08:11:36:WU00:FS01:0x22:*********************** Log Started 2021-11-12T08:11:36Z ***********************
08:11:36:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
08:11:36:WU00:FS01:0x22: Core: Core22
08:11:36:WU00:FS01:0x22: Type: 0x22
08:11:36:WU00:FS01:0x22: Version: 0.0.13
08:11:36:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
08:11:36:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
08:11:36:WU00:FS01:0x22: Homepage: https://foldingathome.org/
08:11:36:WU00:FS01:0x22: Date: Sep 19 2020
08:11:36:WU00:FS01:0x22: Time: 01:10:35
08:11:36:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:11:36:WU00:FS01:0x22: Branch: core22-0.0.13
08:11:36:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:11:36:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
08:11:36:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
08:11:36:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
08:11:36:WU00:FS01:0x22: Bits: 64
08:11:36:WU00:FS01:0x22: Mode: Release
08:11:36:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
08:11:36:WU00:FS01:0x22: <[email protected]>
08:11:36:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 9527 -checkpoint 15
08:11:36:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
08:11:36:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
08:11:36:WU00:FS01:0x22:************************************ libFAH ************************************
08:11:36:WU00:FS01:0x22: Date: Sep 15 2020
08:11:36:WU00:FS01:0x22: Time: 05:14:43
08:11:36:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:11:36:WU00:FS01:0x22: Branch: HEAD
08:11:36:WU00:FS01:0x22:************************************ CBang *************************************
08:11:36:WU00:FS01:0x22: Time: 05:11:04
08:11:36:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:11:36:WU00:FS01:0x22: -funroll-loops -fPIC
08:11:36:WU00:FS01:0x22:************************************ System ************************************
08:11:36:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
08:11:36:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
08:11:36:WU00:FS01:0x22: CPUs: 8
08:11:36:WU00:FS01:0x22: Memory: 15.58GiB
08:11:36:WU00:FS01:0x22:Free Memory: 11.81GiB
08:11:36:WU00:FS01:0x22: Threads: POSIX_THREADS
08:11:36:WU00:FS01:0x22: OS Version: 5.11
08:11:36:WU00:FS01:0x22:Has Battery: false
08:11:36:WU00:FS01:0x22: On Battery: false
08:11:36:WU00:FS01:0x22: UTC Offset: -5
08:11:36:WU00:FS01:0x22: PID: 9531
08:11:36:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
08:11:36:WU00:FS01:0x22:************************************ OpenMM ************************************
08:11:36:WU00:FS01:0x22: Revision: 189320d0
08:11:36:WU00:FS01:0x22:********************************************************************************
08:11:36:WU00:FS01:0x22:Project: 16485 (Run 0, Clone 174, Gen 13)
08:11:36:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
08:11:36:WU00:FS01:0x22:Reading tar file core.xml
08:11:36:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
08:11:36:WU00:FS01:0x22:Reading tar file state.xml.bz2
08:11:36:WU00:FS01:0x22:Reading tar file system.xml.bz2
08:11:36:WU00:FS01:0x22:Digital signatures verified
08:11:36:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
08:11:36:WU00:FS01:0x22:Version 0.0.13
08:11:36:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
08:11:36:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
08:11:36:WU00:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
08:11:36:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
08:11:36:WU00:FS01:0x22:There are 4 platforms available.
08:11:36:WU00:FS01:0x22:Platform 0: Reference
08:11:36:WU00:FS01:0x22:Platform 1: CPU
08:11:36:WU00:FS01:0x22:Platform 2: OpenCL
08:11:36:WU00:FS01:0x22: opencl-device 0 specified
08:11:36:WU00:FS01:0x22:Platform 3: CUDA
08:11:36:WU00:FS01:0x22: cuda-device 0 specified
08:11:38:WU01:FS01:Upload complete
08:11:38:WU01:FS01:Server responded WORK_ACK (400)
08:11:38:WU01:FS01:Final credit estimate, 293736.00 points
08:11:38:WU01:FS01:Cleaning up
08:11:44:WU00:FS01:0x22:Attempting to create CUDA context:
08:11:44:WU00:FS01:0x22: Configuring platform CUDA
08:13:13:WU00:FS01:0x22: Using CUDA and gpu 0
08:13:13:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
08:13:13:WU00:FS01:0x22:Checkpoint completed at step 0
08:14:19:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
08:15:24:WU00:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
08:16:30:WU00:FS01:0x22:Completed 75000 out of 2500000 steps (3%)
08:17:36:WU00:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
08:18:41:WU00:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
08:18:42:WU00:FS01:0x22:Checkpoint completed at step 125000
08:19:47:WU00:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
08:20:53:WU00:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
08:21:58:WU00:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
08:23:04:WU00:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
08:24:09:WU00:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
08:24:10:WU00:FS01:0x22:Checkpoint completed at step 250000
08:25:16:WU00:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
08:26:21:WU00:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
08:27:27:WU00:FS01:0x22:Completed 325000 out of 2500000 steps (13%)
08:28:32:WU00:FS01:0x22:Completed 350000 out of 2500000 steps (14%)
08:29:38:WU00:FS01:0x22:Completed 375000 out of 2500000 steps (15%)
08:29:38:WU00:FS01:0x22:Checkpoint completed at step 375000
08:30:44:WU00:FS01:0x22:Completed 400000 out of 2500000 steps (16%)
08:31:50:WU00:FS01:0x22:Completed 425000 out of 2500000 steps (17%)
08:32:55:WU00:FS01:0x22:Completed 450000 out of 2500000 steps (18%)
08:34:01:WU00:FS01:0x22:Completed 475000 out of 2500000 steps (19%)
08:35:06:WU00:FS01:0x22:Completed 500000 out of 2500000 steps (20%)
08:35:07:WU00:FS01:0x22:Checkpoint completed at step 500000
08:36:13:WU00:FS01:0x22:Completed 525000 out of 2500000 steps (21%)
08:37:18:WU00:FS01:0x22:Completed 550000 out of 2500000 steps (22%)
08:38:24:WU00:FS01:0x22:Completed 575000 out of 2500000 steps (23%)
08:39:29:WU00:FS01:0x22:Completed 600000 out of 2500000 steps (24%)
08:40:35:WU00:FS01:0x22:Completed 625000 out of 2500000 steps (25%)
08:40:35:WU00:FS01:0x22:Checkpoint completed at step 625000
08:41:41:WU00:FS01:0x22:Completed 650000 out of 2500000 steps (26%)
08:42:47:WU00:FS01:0x22:Completed 675000 out of 2500000 steps (27%)
08:43:52:WU00:FS01:0x22:Completed 700000 out of 2500000 steps (28%)
08:44:58:WU00:FS01:0x22:Completed 725000 out of 2500000 steps (29%)
08:46:03:WU00:FS01:0x22:Completed 750000 out of 2500000 steps (30%)
08:46:04:WU00:FS01:0x22:Checkpoint completed at step 750000
08:47:10:WU00:FS01:0x22:Completed 775000 out of 2500000 steps (31%)
08:48:15:WU00:FS01:0x22:Completed 800000 out of 2500000 steps (32%)
08:49:21:WU00:FS01:0x22:Completed 825000 out of 2500000 steps (33%)
08:50:26:WU00:FS01:0x22:Completed 850000 out of 2500000 steps (34%)
08:51:32:WU00:FS01:0x22:Completed 875000 out of 2500000 steps (35%)
08:51:32:WU00:FS01:0x22:Checkpoint completed at step 875000
08:52:38:WU00:FS01:0x22:Completed 900000 out of 2500000 steps (36%)
08:53:44:WU00:FS01:0x22:Completed 925000 out of 2500000 steps (37%)
08:54:49:WU00:FS01:0x22:Completed 950000 out of 2500000 steps (38%)
08:55:55:WU00:FS01:0x22:Completed 975000 out of 2500000 steps (39%)
08:57:00:WU00:FS01:0x22:Completed 1000000 out of 2500000 steps (40%)
08:57:01:WU00:FS01:0x22:Checkpoint completed at step 1000000
08:58:07:WU00:FS01:0x22:Completed 1025000 out of 2500000 steps (41%)
08:59:12:WU00:FS01:0x22:Completed 1050000 out of 2500000 steps (42%)
09:00:18:WU00:FS01:0x22:Completed 1075000 out of 2500000 steps (43%)
09:01:23:WU00:FS01:0x22:Completed 1100000 out of 2500000 steps (44%)
09:02:29:WU00:FS01:0x22:Completed 1125000 out of 2500000 steps (45%)
09:02:29:WU00:FS01:0x22:Checkpoint completed at step 1125000
09:03:35:WU00:FS01:0x22:Completed 1150000 out of 2500000 steps (46%)
09:04:41:WU00:FS01:0x22:Completed 1175000 out of 2500000 steps (47%)
09:05:46:WU00:FS01:0x22:Completed 1200000 out of 2500000 steps (48%)
09:06:52:WU00:FS01:0x22:Completed 1225000 out of 2500000 steps (49%)
09:07:57:WU00:FS01:0x22:Completed 1250000 out of 2500000 steps (50%)
09:07:58:WU00:FS01:0x22:Checkpoint completed at step 1250000
09:09:04:WU00:FS01:0x22:Completed 1275000 out of 2500000 steps (51%)
09:10:09:WU00:FS01:0x22:Completed 1300000 out of 2500000 steps (52%)
09:11:15:WU00:FS01:0x22:Completed 1325000 out of 2500000 steps (53%)
09:12:20:WU00:FS01:0x22:Completed 1350000 out of 2500000 steps (54%)
09:13:26:WU00:FS01:0x22:Completed 1375000 out of 2500000 steps (55%)
09:13:26:WU00:FS01:0x22:Checkpoint completed at step 1375000
09:14:32:WU00:FS01:0x22:Completed 1400000 out of 2500000 steps (56%)
09:15:38:WU00:FS01:0x22:Completed 1425000 out of 2500000 steps (57%)
09:16:44:WU00:FS01:0x22:Completed 1450000 out of 2500000 steps (58%)
09:17:49:WU00:FS01:0x22:Completed 1475000 out of 2500000 steps (59%)
09:18:55:WU00:FS01:0x22:Completed 1500000 out of 2500000 steps (60%)
09:18:55:WU00:FS01:0x22:Checkpoint completed at step 1500000
09:20:01:WU00:FS01:0x22:Completed 1525000 out of 2500000 steps (61%)
09:21:07:WU00:FS01:0x22:Completed 1550000 out of 2500000 steps (62%)
09:22:12:WU00:FS01:0x22:Completed 1575000 out of 2500000 steps (63%)
09:23:18:WU00:FS01:0x22:Completed 1600000 out of 2500000 steps (64%)
09:24:24:WU00:FS01:0x22:Completed 1625000 out of 2500000 steps (65%)
09:24:24:WU00:FS01:0x22:Checkpoint completed at step 1625000
09:25:30:WU00:FS01:0x22:Completed 1650000 out of 2500000 steps (66%)
09:26:36:WU00:FS01:0x22:Completed 1675000 out of 2500000 steps (67%)
09:27:42:WU00:FS01:0x22:Completed 1700000 out of 2500000 steps (68%)
09:28:47:WU00:FS01:0x22:Completed 1725000 out of 2500000 steps (69%)
09:29:53:WU00:FS01:0x22:Completed 1750000 out of 2500000 steps (70%)
09:29:53:WU00:FS01:0x22:Checkpoint completed at step 1750000
09:30:59:WU00:FS01:0x22:Completed 1775000 out of 2500000 steps (71%)
09:32:04:WU00:FS01:0x22:Completed 1800000 out of 2500000 steps (72%)
09:33:10:WU00:FS01:0x22:Completed 1825000 out of 2500000 steps (73%)
09:34:16:WU00:FS01:0x22:Completed 1850000 out of 2500000 steps (74%)
09:35:21:WU00:FS01:0x22:Completed 1875000 out of 2500000 steps (75%)
09:35:22:WU00:FS01:0x22:Checkpoint completed at step 1875000
09:36:27:WU00:FS01:0x22:Completed 1900000 out of 2500000 steps (76%)
09:37:33:WU00:FS01:0x22:Completed 1925000 out of 2500000 steps (77%)
09:38:38:WU00:FS01:0x22:Completed 1950000 out of 2500000 steps (78%)
09:39:44:WU00:FS01:0x22:Completed 1975000 out of 2500000 steps (79%)
09:40:49:WU00:FS01:0x22:Completed 2000000 out of 2500000 steps (80%)
09:40:50:WU00:FS01:0x22:Checkpoint completed at step 2000000
09:41:56:WU00:FS01:0x22:Completed 2025000 out of 2500000 steps (81%)
09:43:01:WU00:FS01:0x22:Completed 2050000 out of 2500000 steps (82%)
09:44:07:WU00:FS01:0x22:Completed 2075000 out of 2500000 steps (83%)
09:45:12:WU00:FS01:0x22:Completed 2100000 out of 2500000 steps (84%)
09:46:18:WU00:FS01:0x22:Completed 2125000 out of 2500000 steps (85%)
09:46:18:WU00:FS01:0x22:Checkpoint completed at step 2125000
09:47:24:WU00:FS01:0x22:Completed 2150000 out of 2500000 steps (86%)
09:48:30:WU00:FS01:0x22:Completed 2175000 out of 2500000 steps (87%)
09:49:35:WU00:FS01:0x22:Completed 2200000 out of 2500000 steps (88%)
09:50:41:WU00:FS01:0x22:Completed 2225000 out of 2500000 steps (89%)
09:51:46:WU00:FS01:0x22:Completed 2250000 out of 2500000 steps (90%)
09:51:47:WU00:FS01:0x22:Checkpoint completed at step 2250000
09:52:52:WU00:FS01:0x22:Completed 2275000 out of 2500000 steps (91%)
09:53:58:WU00:FS01:0x22:Completed 2300000 out of 2500000 steps (92%)
09:55:04:WU00:FS01:0x22:Completed 2325000 out of 2500000 steps (93%)
09:56:09:WU00:FS01:0x22:Completed 2350000 out of 2500000 steps (94%)
09:57:14:WU00:FS01:0x22:Completed 2375000 out of 2500000 steps (95%)
09:57:15:WU00:FS01:0x22:Checkpoint completed at step 2375000
09:58:21:WU00:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
09:59:26:WU00:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
10:00:32:WU00:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
10:01:37:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
10:02:43:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
10:02:43:WU00:FS01:0x22:Average performance: 263.415 ns/day
10:02:43:WU00:FS01:0x22:Checkpoint completed at step 2500000
10:02:44:WU01:FS01:Connecting to assign1.foldingathome.org:80
10:02:44:WU01:FS01:Assigned to work server 129.32.209.202
10:02:44:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
10:02:44:WU01:FS01:Connecting to 129.32.209.202:8080
10:02:44:WU01:FS01:Downloading 27.77MiB
10:02:47:WU01:FS01:Download complete
10:02:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:3 clone:279 gen:95 core:0x22 unit:0x000001170000005f000047ff00000003
10:02:51:WU00:FS01:0x22:Saving result file ../logfile_01.txt
10:02:51:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
10:02:51:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
10:02:51:WU00:FS01:0x22:Saving result file positions.xtc
10:02:51:WU00:FS01:0x22:Saving result file science.log
10:02:51:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
10:02:51:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:02:51:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16485 run:0 clone:174 gen:13 core:0x22 unit:0x000000ae0000000d0000406500000000
10:02:51:WU00:FS01:Uploading 13.47MiB to 140.163.4.200
10:02:51:WU00:FS01:Connecting to 140.163.4.200:8080
10:02:51:WU01:FS01:Starting
10:02:51:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
10:02:51:WU01:FS01:Started FahCore on PID 9779
10:02:51:WU01:FS01:Core PID:9783
10:02:51:WU01:FS01:FahCore 0x22 started
10:02:52:WU01:FS01:0x22:*********************** Log Started 2021-11-12T10:02:51Z ***********************
10:02:52:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
10:02:52:WU01:FS01:0x22: Core: Core22
10:02:52:WU01:FS01:0x22: Type: 0x22
10:02:52:WU01:FS01:0x22: Version: 0.0.13
10:02:52:WU01:FS01:0x22: Author: Joseph Coffland <jos[email protected]>
10:02:52:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
10:02:52:WU01:FS01:0x22: Homepage: https://foldingathome.org/
10:02:52:WU01:FS01:0x22: Date: Sep 19 2020
10:02:52:WU01:FS01:0x22: Time: 01:10:35
10:02:52:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
10:02:52:WU01:FS01:0x22: Branch: core22-0.0.13
10:02:52:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
10:02:52:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
10:02:52:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
10:02:52:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
10:02:52:WU01:FS01:0x22: Bits: 64
10:02:52:WU01:FS01:0x22: Mode: Release
10:02:52:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
10:02:52:WU01:FS01:0x22: <[email protected]>
10:02:52:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 9779 -checkpoint 15
10:02:52:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
10:02:52:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
10:02:52:WU01:FS01:0x22:************************************ libFAH ************************************
10:02:52:WU01:FS01:0x22: Date: Sep 15 2020
10:02:52:WU01:FS01:0x22: Time: 05:14:43
10:02:52:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
10:02:52:WU01:FS01:0x22: Branch: HEAD
10:02:52:WU01:FS01:0x22:************************************ CBang *************************************
10:02:52:WU01:FS01:0x22: Time: 05:11:04
10:02:52:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
10:02:52:WU01:FS01:0x22: -funroll-loops -fPIC
10:02:52:WU01:FS01:0x22:************************************ System ************************************
10:02:52:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
10:02:52:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:02:52:WU01:FS01:0x22: CPUs: 8
10:02:52:WU01:FS01:0x22: Memory: 15.58GiB
10:02:52:WU01:FS01:0x22:Free Memory: 11.73GiB
10:02:52:WU01:FS01:0x22: Threads: POSIX_THREADS
10:02:52:WU01:FS01:0x22: OS Version: 5.11
10:02:52:WU01:FS01:0x22:Has Battery: false
10:02:52:WU01:FS01:0x22: On Battery: false
10:02:52:WU01:FS01:0x22: UTC Offset: -5
10:02:52:WU01:FS01:0x22: PID: 9783
10:02:52:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
10:02:52:WU01:FS01:0x22:************************************ OpenMM ************************************
10:02:52:WU01:FS01:0x22: Revision: 189320d0
10:02:52:WU01:FS01:0x22:********************************************************************************
10:02:52:WU01:FS01:0x22:Project: 18431 (Run 3, Clone 279, Gen 95)
10:02:52:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
10:02:52:WU01:FS01:0x22:Reading tar file core.xml
10:02:52:WU01:FS01:0x22:Reading tar file integrator.xml
10:02:52:WU01:FS01:0x22:Reading tar file state.xml
10:02:52:WU01:FS01:0x22:Reading tar file system.xml
10:02:52:WU01:FS01:0x22:Digital signatures verified
10:02:52:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
10:02:52:WU01:FS01:0x22:Version 0.0.13
10:02:52:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
10:02:52:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
10:02:52:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
10:02:52:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
10:02:52:WU01:FS01:0x22:There are 4 platforms available.
10:02:52:WU01:FS01:0x22:Platform 0: Reference
10:02:52:WU01:FS01:0x22:Platform 1: CPU
10:02:52:WU01:FS01:0x22:Platform 2: OpenCL
10:02:52:WU01:FS01:0x22: opencl-device 0 specified
10:02:52:WU01:FS01:0x22:Platform 3: CUDA
10:02:52:WU01:FS01:0x22: cuda-device 0 specified
10:02:54:WU00:FS01:Upload complete
10:02:54:WU00:FS01:Server responded WORK_ACK (400)
10:02:54:WU00:FS01:Final credit estimate, 485683.00 points
10:02:54:WU00:FS01:Cleaning up
10:02:54:WU01:FS01:0x22:Attempting to create CUDA context:
10:02:54:WU01:FS01:0x22: Configuring platform CUDA
10:04:20:WU01:FS01:0x22: Using CUDA and gpu 0
10:04:20:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
10:04:20:WU01:FS01:0x22:Checkpoint completed at step 0
10:05:03:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
10:05:45:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
10:05:45:WU01:FS01:0x22:Checkpoint completed at step 100000
10:06:27:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
10:07:09:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
10:07:09:WU01:FS01:0x22:Checkpoint completed at step 200000
10:07:51:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
10:08:33:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
10:08:33:WU01:FS01:0x22:Checkpoint completed at step 300000
10:09:15:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
10:09:57:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
10:09:57:WU01:FS01:0x22:Checkpoint completed at step 400000
10:10:40:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
10:11:21:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
10:11:22:WU01:FS01:0x22:Checkpoint completed at step 500000
10:12:04:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
10:12:46:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
10:12:46:WU01:FS01:0x22:Checkpoint completed at step 600000
10:13:28:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
10:14:10:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
10:14:10:WU01:FS01:0x22:Checkpoint completed at step 700000
10:14:52:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
10:15:35:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
10:15:35:WU01:FS01:0x22:Checkpoint completed at step 800000
10:16:17:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
10:16:59:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
10:16:59:WU01:FS01:0x22:Checkpoint completed at step 900000
10:17:41:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
10:18:23:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
10:18:23:WU01:FS01:0x22:Checkpoint completed at step 1000000
10:19:05:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
10:19:47:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
10:19:47:WU01:FS01:0x22:Checkpoint completed at step 1100000
10:20:29:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
10:21:11:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
10:21:11:WU01:FS01:0x22:Checkpoint completed at step 1200000
10:21:53:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
10:22:35:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
10:22:36:WU01:FS01:0x22:Checkpoint completed at step 1300000
10:23:18:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
10:24:00:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
10:24:00:WU01:FS01:0x22:Checkpoint completed at step 1400000
10:24:42:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
10:25:24:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
10:25:24:WU01:FS01:0x22:Checkpoint completed at step 1500000
10:26:06:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
10:26:48:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
10:26:48:WU01:FS01:0x22:Checkpoint completed at step 1600000
10:27:30:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
10:28:12:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
10:28:12:WU01:FS01:0x22:Checkpoint completed at step 1700000
10:28:55:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
10:29:37:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
10:29:37:WU01:FS01:0x22:Checkpoint completed at step 1800000
10:30:19:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
10:31:01:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
10:31:01:WU01:FS01:0x22:Checkpoint completed at step 1900000
10:31:43:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
10:32:25:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
10:32:25:WU01:FS01:0x22:Checkpoint completed at step 2000000
10:33:07:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
10:33:49:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
10:33:49:WU01:FS01:0x22:Checkpoint completed at step 2100000
10:34:31:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
10:35:13:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
10:35:13:WU01:FS01:0x22:Checkpoint completed at step 2200000
10:35:55:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
10:36:37:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
10:36:37:WU01:FS01:0x22:Checkpoint completed at step 2300000
10:37:19:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
10:38:01:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
10:38:02:WU01:FS01:0x22:Checkpoint completed at step 2400000
10:38:44:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
10:39:25:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
10:39:26:WU01:FS01:0x22:Checkpoint completed at step 2500000
10:40:08:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
10:40:50:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
10:40:50:WU01:FS01:0x22:Checkpoint completed at step 2600000
10:41:32:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
10:42:14:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
10:42:14:WU01:FS01:0x22:Checkpoint completed at step 2700000
10:42:56:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
10:43:38:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
10:43:38:WU01:FS01:0x22:Checkpoint completed at step 2800000
10:44:20:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
10:45:02:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
10:45:03:WU01:FS01:0x22:Checkpoint completed at step 2900000
10:45:45:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
10:46:27:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
10:46:27:WU01:FS01:0x22:Checkpoint completed at step 3000000
10:47:09:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
10:47:51:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
10:47:51:WU01:FS01:0x22:Checkpoint completed at step 3100000
10:48:34:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
10:49:16:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
10:49:16:WU01:FS01:0x22:Checkpoint completed at step 3200000
10:49:58:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
10:50:40:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
10:50:40:WU01:FS01:0x22:Checkpoint completed at step 3300000
10:51:22:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
10:52:04:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
10:52:04:WU01:FS01:0x22:Checkpoint completed at step 3400000
10:52:46:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
10:53:28:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
10:53:28:WU01:FS01:0x22:Checkpoint completed at step 3500000
10:54:10:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
10:54:52:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
10:54:53:WU01:FS01:0x22:Checkpoint completed at step 3600000
10:55:35:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
10:56:17:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
10:56:17:WU01:FS01:0x22:Checkpoint completed at step 3700000
10:56:59:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
10:57:41:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
10:57:41:WU01:FS01:0x22:Checkpoint completed at step 3800000
10:58:23:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
10:59:05:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
10:59:05:WU01:FS01:0x22:Checkpoint completed at step 3900000
10:59:47:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
11:00:29:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
11:00:29:WU01:FS01:0x22:Checkpoint completed at step 4000000
11:01:11:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
11:01:53:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
11:01:53:WU01:FS01:0x22:Checkpoint completed at step 4100000
11:02:35:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
11:03:17:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
11:03:17:WU01:FS01:0x22:Checkpoint completed at step 4200000
11:03:59:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
11:04:41:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
11:04:41:WU01:FS01:0x22:Checkpoint completed at step 4300000
11:05:23:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
11:06:05:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
11:06:05:WU01:FS01:0x22:Checkpoint completed at step 4400000
11:06:47:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
11:07:30:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
11:07:30:WU01:FS01:0x22:Checkpoint completed at step 4500000
11:08:12:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
11:08:54:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
11:08:54:WU01:FS01:0x22:Checkpoint completed at step 4600000
11:09:36:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
11:10:18:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
11:10:18:WU01:FS01:0x22:Checkpoint completed at step 4700000
11:11:00:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
11:11:42:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
11:11:42:WU01:FS01:0x22:Checkpoint completed at step 4800000
11:12:24:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
11:13:06:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
11:13:06:WU01:FS01:0x22:Checkpoint completed at step 4900000
11:13:48:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
11:14:30:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
11:14:30:WU01:FS01:0x22:Average performance: 514.286 ns/day
11:14:31:WU01:FS01:0x22:Checkpoint completed at step 5000000
11:14:31:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:14:31:WU00:FS01:Assigned to work server 34.72.228.44
11:14:31:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 34.72.228.44
11:14:31:WU00:FS01:Connecting to 34.72.228.44:8080
11:14:31:WU00:FS01:Downloading 3.12MiB
11:14:32:WU01:FS01:0x22:Saving result file ../logfile_01.txt
11:14:32:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
11:14:32:WU01:FS01:0x22:Saving result file checkpointState.xml
11:14:32:WU01:FS01:0x22:Saving result file positions.xtc
11:14:32:WU01:FS01:0x22:Saving result file science.log
11:14:32:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
11:14:32:WU00:FS01:Download complete
11:14:32:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18115 run:0 clone:138 gen:45 core:0x22 unit:0x0000008a0000002d000046c300000000
11:14:32:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:14:32:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:3 clone:279 gen:95 core:0x22 unit:0x000001170000005f000047ff00000003
11:14:32:WU01:FS01:Uploading 14.32MiB to 129.32.209.202
11:14:32:WU01:FS01:Connecting to 129.32.209.202:8080
11:14:32:WU00:FS01:Starting
11:14:32:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
11:14:32:WU00:FS01:Started FahCore on PID 10410
11:14:32:WU00:FS01:Core PID:10414
11:14:32:WU00:FS01:FahCore 0x22 started
11:14:33:WU00:FS01:0x22:*********************** Log Started 2021-11-12T11:14:32Z ***********************
11:14:33:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
11:14:33:WU00:FS01:0x22: Core: Core22
11:14:33:WU00:FS01:0x22: Type: 0x22
11:14:33:WU00:FS01:0x22: Version: 0.0.13
11:14:33:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
11:14:33:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
11:14:33:WU00:FS01:0x22: Homepage: https://foldingathome.org/
11:14:33:WU00:FS01:0x22: Date: Sep 19 2020
11:14:33:WU00:FS01:0x22: Time: 01:10:35
11:14:33:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
11:14:33:WU00:FS01:0x22: Branch: core22-0.0.13
11:14:33:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
11:14:33:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
11:14:33:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
11:14:33:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
11:14:33:WU00:FS01:0x22: Bits: 64
11:14:33:WU00:FS01:0x22: Mode: Release
11:14:33:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
11:14:33:WU00:FS01:0x22: <[email protected]>
11:14:33:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 10410 -checkpoint 15
11:14:33:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
11:14:33:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
11:14:33:WU00:FS01:0x22:************************************ libFAH ************************************
11:14:33:WU00:FS01:0x22: Date: Sep 15 2020
11:14:33:WU00:FS01:0x22: Time: 05:14:43
11:14:33:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
11:14:33:WU00:FS01:0x22: Branch: HEAD
11:14:33:WU00:FS01:0x22:************************************ CBang *************************************
11:14:33:WU00:FS01:0x22: Time: 05:11:04
11:14:33:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
11:14:33:WU00:FS01:0x22: -funroll-loops -fPIC
11:14:33:WU00:FS01:0x22:************************************ System ************************************
11:14:33:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
11:14:33:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
11:14:33:WU00:FS01:0x22: CPUs: 8
11:14:33:WU00:FS01:0x22: Memory: 15.58GiB
11:14:33:WU00:FS01:0x22:Free Memory: 11.74GiB
11:14:33:WU00:FS01:0x22: Threads: POSIX_THREADS
11:14:33:WU00:FS01:0x22: OS Version: 5.11
11:14:33:WU00:FS01:0x22:Has Battery: false
11:14:33:WU00:FS01:0x22: On Battery: false
11:14:33:WU00:FS01:0x22: UTC Offset: -5
11:14:33:WU00:FS01:0x22: PID: 10414
11:14:33:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
11:14:33:WU00:FS01:0x22:************************************ OpenMM ************************************
11:14:33:WU00:FS01:0x22: Revision: 189320d0
11:14:33:WU00:FS01:0x22:********************************************************************************
11:14:33:WU00:FS01:0x22:Project: 18115 (Run 0, Clone 138, Gen 45)
11:14:33:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
11:14:33:WU00:FS01:0x22:Reading tar file core.xml
11:14:33:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
11:14:33:WU00:FS01:0x22:Reading tar file state.xml.bz2
11:14:33:WU00:FS01:0x22:Reading tar file system.xml.bz2
11:14:33:WU00:FS01:0x22:Digital signatures verified
11:14:33:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
11:14:33:WU00:FS01:0x22:Version 0.0.13
11:14:33:WU00:FS01:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
11:14:33:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
11:14:33:WU00:FS01:0x22: XTC frame write interval: 50000 steps (1%) [100 total]
11:14:33:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
11:14:33:WU00:FS01:0x22:There are 4 platforms available.
11:14:33:WU00:FS01:0x22:Platform 0: Reference
11:14:33:WU00:FS01:0x22:Platform 1: CPU
11:14:33:WU00:FS01:0x22:Platform 2: OpenCL
11:14:33:WU00:FS01:0x22: opencl-device 0 specified
11:14:33:WU00:FS01:0x22:Platform 3: CUDA
11:14:33:WU00:FS01:0x22: cuda-device 0 specified
11:14:34:WU00:FS01:0x22:Attempting to create CUDA context:
11:14:34:WU00:FS01:0x22: Configuring platform CUDA
11:14:35:WU01:FS01:Upload complete
11:14:35:WU01:FS01:Server responded WORK_ACK (400)
11:14:35:WU01:FS01:Final credit estimate, 294077.00 points
11:14:35:WU01:FS01:Cleaning up
11:16:02:WU00:FS01:0x22: Using CUDA and gpu 0
11:16:02:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
11:16:02:WU00:FS01:0x22:Checkpoint completed at step 0
11:16:44:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
11:17:26:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
11:18:08:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
11:18:50:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
11:19:33:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
11:19:33:WU00:FS01:0x22:Checkpoint completed at step 250000
11:20:15:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
11:20:57:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
11:21:39:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
11:22:21:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
11:23:03:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
11:23:03:WU00:FS01:0x22:Checkpoint completed at step 500000
11:23:46:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
11:24:28:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
11:25:10:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
11:25:52:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
11:26:34:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
11:26:34:WU00:FS01:0x22:Checkpoint completed at step 750000
11:27:16:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
11:27:58:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
11:28:40:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
11:29:22:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
11:30:04:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
11:30:04:WU00:FS01:0x22:Checkpoint completed at step 1000000
11:30:47:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
11:31:29:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
11:32:11:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
11:32:53:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
11:33:35:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
11:33:35:WU00:FS01:0x22:Checkpoint completed at step 1250000
11:34:18:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
11:35:00:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
11:35:42:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
11:36:24:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
11:37:06:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
11:37:06:WU00:FS01:0x22:Checkpoint completed at step 1500000
11:37:48:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
11:38:30:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
11:39:12:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
11:39:54:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
11:40:37:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
11:40:37:WU00:FS01:0x22:Checkpoint completed at step 1750000
11:41:19:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
11:42:01:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
11:42:43:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
11:43:25:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
11:44:07:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
11:44:07:WU00:FS01:0x22:Checkpoint completed at step 2000000
11:44:49:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
11:45:31:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
11:46:13:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
11:46:55:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
11:47:38:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
11:47:38:WU00:FS01:0x22:Checkpoint completed at step 2250000
11:48:20:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
11:49:02:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
11:49:44:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
11:50:26:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
11:51:08:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
11:51:08:WU00:FS01:0x22:Checkpoint completed at step 2500000
11:51:50:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
11:52:32:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
11:53:14:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
11:53:57:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
11:54:39:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
11:54:39:WU00:FS01:0x22:Checkpoint completed at step 2750000
11:55:21:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
11:56:03:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
11:56:46:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
11:57:28:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
11:58:10:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
11:58:10:WU00:FS01:0x22:Checkpoint completed at step 3000000
11:58:53:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
11:59:35:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
12:00:17:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
12:00:59:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
12:01:42:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
12:01:42:WU00:FS01:0x22:Checkpoint completed at step 3250000
12:02:24:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
12:03:06:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
12:03:48:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
12:04:30:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
12:05:12:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
12:05:12:WU00:FS01:0x22:Checkpoint completed at step 3500000
12:05:55:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
12:06:37:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
12:07:19:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
12:08:01:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
12:08:43:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
12:08:43:WU00:FS01:0x22:Checkpoint completed at step 3750000
******************************* Date: 2021-11-12 *******************************
12:09:25:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
12:10:07:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
12:10:49:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
12:11:31:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
12:12:14:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
12:12:14:WU00:FS01:0x22:Checkpoint completed at step 4000000
12:12:56:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
12:13:38:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
12:14:20:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
12:15:02:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
12:15:44:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
12:15:44:WU00:FS01:0x22:Checkpoint completed at step 4250000
12:16:26:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
12:17:08:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
12:17:50:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
12:18:32:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
12:19:15:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
12:19:15:WU00:FS01:0x22:Checkpoint completed at step 4500000
12:19:57:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
12:20:39:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
12:21:21:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
12:22:03:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
12:22:45:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
12:22:45:WU00:FS01:0x22:Checkpoint completed at step 4750000
12:23:27:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
12:24:09:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
12:24:51:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
12:25:33:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
12:26:15:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
12:26:15:WU00:FS01:0x22:Average performance: 82.2857 ns/day
12:26:16:WU00:FS01:0x22:Checkpoint completed at step 5000000
12:26:16:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:26:16:WU01:FS01:Assigned to work server 129.32.209.202
12:26:16:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
12:26:16:WU01:FS01:Connecting to 129.32.209.202:8080
12:26:16:WU01:FS01:Downloading 27.77MiB
12:26:19:WU01:FS01:Download complete
12:26:19:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18431 run:8 clone:59 gen:81 core:0x22 unit:0x0000003b00000051000047ff00000008
12:26:19:WU00:FS01:0x22:Saving result file ../logfile_01.txt
12:26:19:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
12:26:19:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
12:26:19:WU00:FS01:0x22:Saving result file positions.xtc
12:26:19:WU00:FS01:0x22:Saving result file science.log
12:26:19:WU00:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
12:26:19:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:26:19:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18115 run:0 clone:138 gen:45 core:0x22 unit:0x0000008a0000002d000046c300000000
12:26:19:WU00:FS01:Uploading 16.82MiB to 34.72.228.44
12:26:19:WU00:FS01:Connecting to 34.72.228.44:8080
12:26:19:WU01:FS01:Starting
12:26:19:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:26:19:WU01:FS01:Started FahCore on PID 12767
12:26:19:WU01:FS01:Core PID:12771
12:26:19:WU01:FS01:FahCore 0x22 started
12:26:20:WU01:FS01:0x22:*********************** Log Started 2021-11-12T12:26:19Z ***********************
12:26:20:WU01:FS01:0x22:*************************** Core22 [email protected] Core ***************************
12:26:20:WU01:FS01:0x22: Core: Core22
12:26:20:WU01:FS01:0x22: Type: 0x22
12:26:20:WU01:FS01:0x22: Version: 0.0.13
12:26:20:WU01:FS01:0x22: Author: Joseph Coffland <[email protected]>
12:26:20:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
12:26:20:WU01:FS01:0x22: Homepage: https://foldingathome.org/
12:26:20:WU01:FS01:0x22: Date: Sep 19 2020
12:26:20:WU01:FS01:0x22: Time: 01:10:35
12:26:20:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:26:20:WU01:FS01:0x22: Branch: core22-0.0.13
12:26:20:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
12:26:20:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
12:26:20:WU01:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
12:26:20:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
12:26:20:WU01:FS01:0x22: Bits: 64
12:26:20:WU01:FS01:0x22: Mode: Release
12:26:20:WU01:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
12:26:20:WU01:FS01:0x22: <[email protected]>
12:26:20:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 12767 -checkpoint 15
12:26:20:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
12:26:20:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
12:26:20:WU01:FS01:0x22:************************************ libFAH ************************************
12:26:20:WU01:FS01:0x22: Date: Sep 15 2020
12:26:20:WU01:FS01:0x22: Time: 05:14:43
12:26:20:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:26:20:WU01:FS01:0x22: Branch: HEAD
12:26:20:WU01:FS01:0x22:************************************ CBang *************************************
12:26:20:WU01:FS01:0x22: Time: 05:11:04
12:26:20:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:26:20:WU01:FS01:0x22: -funroll-loops -fPIC
12:26:20:WU01:FS01:0x22:************************************ System ************************************
12:26:20:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
12:26:20:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:26:20:WU01:FS01:0x22: CPUs: 8
12:26:20:WU01:FS01:0x22: Memory: 15.58GiB
12:26:20:WU01:FS01:0x22:Free Memory: 11.61GiB
12:26:20:WU01:FS01:0x22: Threads: POSIX_THREADS
12:26:20:WU01:FS01:0x22: OS Version: 5.11
12:26:20:WU01:FS01:0x22:Has Battery: false
12:26:20:WU01:FS01:0x22: On Battery: false
12:26:20:WU01:FS01:0x22: UTC Offset: -5
12:26:20:WU01:FS01:0x22: PID: 12771
12:26:20:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
12:26:20:WU01:FS01:0x22:************************************ OpenMM ************************************
12:26:20:WU01:FS01:0x22: Revision: 189320d0
12:26:20:WU01:FS01:0x22:********************************************************************************
12:26:20:WU01:FS01:0x22:Project: 18431 (Run 8, Clone 59, Gen 81)
12:26:20:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
12:26:20:WU01:FS01:0x22:Reading tar file core.xml
12:26:20:WU01:FS01:0x22:Reading tar file integrator.xml
12:26:20:WU01:FS01:0x22:Reading tar file state.xml
12:26:20:WU01:FS01:0x22:Reading tar file system.xml
12:26:20:WU01:FS01:0x22:Digital signatures verified
12:26:20:WU01:FS01:0x22:[email protected] GPU Core22 [email protected] Core
12:26:20:WU01:FS01:0x22:Version 0.0.13
12:26:20:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
12:26:20:WU01:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
12:26:20:WU01:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
12:26:20:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
12:26:20:WU01:FS01:0x22:There are 4 platforms available.
12:26:20:WU01:FS01:0x22:Platform 0: Reference
12:26:20:WU01:FS01:0x22:Platform 1: CPU
12:26:20:WU01:FS01:0x22:Platform 2: OpenCL
12:26:20:WU01:FS01:0x22: opencl-device 0 specified
12:26:20:WU01:FS01:0x22:Platform 3: CUDA
12:26:20:WU01:FS01:0x22: cuda-device 0 specified
12:26:22:WU01:FS01:0x22:Attempting to create CUDA context:
12:26:22:WU01:FS01:0x22: Configuring platform CUDA
12:26:25:WU00:FS01:Upload 58.34%
12:26:33:WU00:FS01:Upload complete
12:26:33:WU00:FS01:Server responded WORK_ACK (400)
12:26:33:WU00:FS01:Final credit estimate, 246532.00 points
12:26:33:WU00:FS01:Cleaning up
12:27:48:WU01:FS01:0x22: Using CUDA and gpu 0
12:27:48:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
12:27:48:WU01:FS01:0x22:Checkpoint completed at step 0
12:28:31:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
12:29:13:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
12:29:13:WU01:FS01:0x22:Checkpoint completed at step 100000
12:29:55:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
12:30:38:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
12:30:38:WU01:FS01:0x22:Checkpoint completed at step 200000
12:31:20:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
12:32:02:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
12:32:02:WU01:FS01:0x22:Checkpoint completed at step 300000
12:32:45:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
12:33:27:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
12:33:27:WU01:FS01:0x22:Checkpoint completed at step 400000
12:34:09:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
12:34:51:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
12:34:51:WU01:FS01:0x22:Checkpoint completed at step 500000
12:35:34:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
12:36:16:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
12:36:16:WU01:FS01:0x22:Checkpoint completed at step 600000
12:36:58:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
12:37:40:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
12:37:41:WU01:FS01:0x22:Checkpoint completed at step 700000
12:38:23:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
12:39:05:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
12:39:05:WU01:FS01:0x22:Checkpoint completed at step 800000
12:39:48:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
12:40:30:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
12:40:30:WU01:FS01:0x22:Checkpoint completed at step 900000
12:41:12:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
12:41:54:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
12:41:55:WU01:FS01:0x22:Checkpoint completed at step 1000000
12:42:37:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
12:43:19:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
12:43:19:WU01:FS01:0x22:Checkpoint completed at step 1100000
12:44:01:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
12:44:44:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
12:44:44:WU01:FS01:0x22:Checkpoint completed at step 1200000
12:45:26:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
12:46:08:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
12:46:08:WU01:FS01:0x22:Checkpoint completed at step 1300000
12:46:51:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
12:47:33:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
12:47:33:WU01:FS01:0x22:Checkpoint completed at step 1400000
12:48:15:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
12:48:57:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
12:48:57:WU01:FS01:0x22:Checkpoint completed at step 1500000
12:49:40:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
12:50:22:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
12:50:22:WU01:FS01:0x22:Checkpoint completed at step 1600000
12:51:04:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
12:51:46:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
12:51:46:WU01:FS01:0x22:Checkpoint completed at step 1700000
12:52:29:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
12:53:11:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
12:53:11:WU01:FS01:0x22:Checkpoint completed at step 1800000
12:53:54:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
12:54:36:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
12:54:36:WU01:FS01:0x22:Checkpoint completed at step 1900000
12:55:18:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
12:56:00:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
12:56:00:WU01:FS01:0x22:Checkpoint completed at step 2000000
12:56:43:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
12:57:25:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
12:57:25:WU01:FS01:0x22:Checkpoint completed at step 2100000
12:58:07:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
12:58:49:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
12:58:49:WU01:FS01:0x22:Checkpoint completed at step 2200000
12:59:32:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
13:00:14:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
13:00:14:WU01:FS01:0x22:Checkpoint completed at step 2300000
13:00:56:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
13:01:38:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
13:01:39:WU01:FS01:0x22:Checkpoint completed at step 2400000
13:02:21:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
13:03:03:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
13:03:03:WU01:FS01:0x22:Checkpoint completed at step 2500000
13:03:45:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
13:04:28:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
13:04:28:WU01:FS01:0x22:Checkpoint completed at step 2600000
13:05:10:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
13:05:52:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
13:05:52:WU01:FS01:0x22:Checkpoint completed at step 2700000
13:06:35:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
13:07:17:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
13:07:17:WU01:FS01:0x22:Checkpoint completed at step 2800000
13:07:59:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
13:08:42:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
13:08:42:WU01:FS01:0x22:Checkpoint completed at step 2900000
13:09:24:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
13:10:06:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
13:10:06:WU01:FS01:0x22:Checkpoint completed at step 3000000
13:10:49:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
13:11:31:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
13:11:31:WU01:FS01:0x22:Checkpoint completed at step 3100000
13:12:13:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
13:12:56:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
13:12:56:WU01:FS01:0x22:Checkpoint completed at step 3200000
13:13:38:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
13:14:20:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
13:14:20:WU01:FS01:0x22:Checkpoint completed at step 3300000
13:15:03:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
13:15:45:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
13:15:45:WU01:FS01:0x22:Checkpoint completed at step 3400000
13:16:27:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
13:17:10:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
13:17:10:WU01:FS01:0x22:Checkpoint completed at step 3500000
13:17:52:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
13:18:34:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
13:18:34:WU01:FS01:0x22:Checkpoint completed at step 3600000
13:19:17:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
13:19:59:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
13:19:59:WU01:FS01:0x22:Checkpoint completed at step 3700000
13:20:41:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
13:21:24:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
13:21:24:WU01:FS01:0x22:Checkpoint completed at step 3800000
13:22:06:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
13:22:48:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
13:22:48:WU01:FS01:0x22:Checkpoint completed at step 3900000
13:23:31:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
13:24:13:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
13:24:13:WU01:FS01:0x22:Checkpoint completed at step 4000000
13:24:55:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
13:25:37:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
13:25:37:WU01:FS01:0x22:Checkpoint completed at step 4100000
13:26:20:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
13:27:02:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
13:27:02:WU01:FS01:0x22:Checkpoint completed at step 4200000
13:27:44:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
13:28:26:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
13:28:26:WU01:FS01:0x22:Checkpoint completed at step 4300000
13:29:08:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
13:29:51:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
13:29:51:WU01:FS01:0x22:Checkpoint completed at step 4400000
13:30:33:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
13:31:15:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
13:31:15:WU01:FS01:0x22:Checkpoint completed at step 4500000
13:31:57:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
13:32:40:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
13:32:40:WU01:FS01:0x22:Checkpoint completed at step 4600000
13:33:22:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
13:34:04:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
13:34:05:WU01:FS01:0x22:Checkpoint completed at step 4700000
13:34:47:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
13:35:29:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
13:35:29:WU01:FS01:0x22:Checkpoint completed at step 4800000
13:36:11:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
13:36:53:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
13:36:54:WU01:FS01:0x22:Checkpoint completed at step 4900000
13:37:36:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
13:38:18:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
13:38:18:WU01:FS01:0x22:Average performance: 508.235 ns/day
13:38:18:WU01:FS01:0x22:Checkpoint completed at step 5000000
13:38:19:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:38:19:WU00:FS01:Assigned to work server 129.32.209.202
13:38:19:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Lite Hash Rate] from 129.32.209.202
13:38:19:WU00:FS01:Connecting to 129.32.209.202:8080
13:38:19:WU01:FS01:0x22:Saving result file ../logfile_01.txt
13:38:19:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
13:38:19:WU01:FS01:0x22:Saving result file checkpointState.xml
13:38:19:WU01:FS01:0x22:Saving result file positions.xtc
13:38:19:WU01:FS01:0x22:Saving result file science.log
13:38:19:WU01:FS01:0x22:[email protected] Core Shutdown: FINISHED_UNIT
13:38:19:WU00:FS01:Downloading 27.79MiB
13:38:20:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:38:20:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18431 run:8 clone:59 gen:81 core:0x22 unit:0x0000003b00000051000047ff00000008
13:38:20:WU01:FS01:Uploading 14.33MiB to 129.32.209.202
13:38:20:WU01:FS01:Connecting to 129.32.209.202:8080
13:38:22:WU00:FS01:Download complete
13:38:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18431 run:0 clone:53 gen:138 core:0x22 unit:0x000000350000008a000047ff00000000
13:38:22:WU00:FS01:Starting
13:38:22:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1184 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
13:38:22:WU00:FS01:Started FahCore on PID 13043
13:38:22:WU00:FS01:Core PID:13047
13:38:22:WU00:FS01:FahCore 0x22 started
13:38:22:WU00:FS01:0x22:*********************** Log Started 2021-11-12T13:38:22Z ***********************
13:38:22:WU00:FS01:0x22:*************************** Core22 [email protected] Core ***************************
13:38:22:WU00:FS01:0x22: Core: Core22
13:38:22:WU00:FS01:0x22: Type: 0x22
13:38:22:WU00:FS01:0x22: Version: 0.0.13
13:38:22:WU00:FS01:0x22: Author: Joseph Coffland <[email protected]>
13:38:22:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
13:38:22:WU00:FS01:0x22: Homepage: https://foldingathome.org/
13:38:22:WU00:FS01:0x22: Date: Sep 19 2020
13:38:22:WU00:FS01:0x22: Time: 01:10:35
13:38:22:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
13:38:22:WU00:FS01:0x22: Branch: core22-0.0.13
13:38:22:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
13:38:22:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
13:38:22:WU00:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
13:38:22:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
13:38:22:WU00:FS01:0x22: Bits: 64
13:38:22:WU00:FS01:0x22: Mode: Release
13:38:22:WU00:FS01:0x22:Maintainers: John Chodera <[email protected]> and Peter Eastman
13:38:22:WU00:FS01:0x22: <[email protected]>
13:38:22:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 13043 -checkpoint 15
13:38:22:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
13:38:22:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
13:38:22:WU00:FS01:0x22:************************************ libFAH ************************************
13:38:22:WU00:FS01:0x22: Date: Sep 15 2020
13:38:22:WU00:FS01:0x22: Time: 05:14:43
13:38:22:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
13:38:22:WU00:FS01:0x22: Branch: HEAD
13:38:22:WU00:FS01:0x22:************************************ CBang *************************************
13:38:22:WU00:FS01:0x22: Time: 05:11:04
13:38:22:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
13:38:22:WU00:FS01:0x22: -funroll-loops -fPIC
13:38:22:WU00:FS01:0x22:************************************ System ************************************
13:38:22:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
13:38:22:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:38:22:WU00:FS01:0x22: CPUs: 8
13:38:22:WU00:FS01:0x22: Memory: 15.58GiB
13:38:22:WU00:FS01:0x22:Free Memory: 11.59GiB
13:38:22:WU00:FS01:0x22: Threads: POSIX_THREADS
13:38:22:WU00:FS01:0x22: OS Version: 5.11
13:38:22:WU00:FS01:0x22:Has Battery: false
13:38:22:WU00:FS01:0x22: On Battery: false
13:38:22:WU00:FS01:0x22: UTC Offset: -5
13:38:22:WU00:FS01:0x22: PID: 13047
13:38:22:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
13:38:22:WU00:FS01:0x22:************************************ OpenMM ************************************
13:38:22:WU00:FS01:0x22: Revision: 189320d0
13:38:22:WU00:FS01:0x22:********************************************************************************
13:38:22:WU00:FS01:0x22:Project: 18431 (Run 0, Clone 53, Gen 138)
13:38:22:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
13:38:22:WU00:FS01:0x22:Reading tar file core.xml
13:38:22:WU00:FS01:0x22:Reading tar file integrator.xml
13:38:22:WU00:FS01:0x22:Reading tar file state.xml
13:38:22:WU00:FS01:0x22:Reading tar file system.xml
13:38:22:WU00:FS01:0x22:Digital signatures verified
13:38:22:WU00:FS01:0x22:[email protected] GPU Core22 [email protected] Core
13:38:22:WU00:FS01:0x22:Version 0.0.13
13:38:22:WU00:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
13:38:22:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
13:38:22:WU00:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
13:38:22:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
13:38:22:WU00:FS01:0x22:There are 4 platforms available.
13:38:22:WU00:FS01:0x22:Platform 0: Reference
13:38:22:WU00:FS01:0x22:Platform 1: CPU
13:38:22:WU00:FS01:0x22:Platform 2: OpenCL
13:38:22:WU00:FS01:0x22: opencl-device 0 specified
13:38:22:WU00:FS01:0x22:Platform 3: CUDA
13:38:22:WU00:FS01:0x22: cuda-device 0 specified
13:38:23:WU01:FS01:Upload complete
13:38:24:WU01:FS01:Server responded WORK_ACK (400)
13:38:24:WU01:FS01:Final credit estimate, 293533.00 points
13:38:24:WU01:FS01:Cleaning up
13:38:24:WU00:FS01:0x22:Attempting to create CUDA context:
13:38:24:WU00:FS01:0x22: Configuring platform CUDA
13:39:52:WU00:FS01:0x22: Using CUDA and gpu 0
13:39:52:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
13:39:52:WU00:FS01:0x22:Checkpoint completed at step 0
13:40:35:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
13:41:18:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
13:41:18:WU00:FS01:0x22:Checkpoint completed at step 100000
13:42:00:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
13:42:43:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
13:42:43:WU00:FS01:0x22:Checkpoint completed at step 200000
13:43:26:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
13:44:08:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
13:44:08:WU00:FS01:0x22:Checkpoint completed at step 300000
13:44:51:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
13:45:33:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
13:45:34:WU00:FS01:0x22:Checkpoint completed at step 400000
13:46:16:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
13:46:59:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
13:46:59:WU00:FS01:0x22:Checkpoint completed at step 500000
13:47:42:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
13:48:24:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
13:48:24:WU00:FS01:0x22:Checkpoint completed at step 600000
13:49:07:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
13:49:49:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
13:49:50:WU00:FS01:0x22:Checkpoint completed at step 700000
13:50:32:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
13:51:15:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
13:51:15:WU00:FS01:0x22:Checkpoint completed at step 800000
13:51:57:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
13:52:40:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
13:52:40:WU00:FS01:0x22:Checkpoint completed at step 900000
13:53:23:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
13:54:05:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
13:54:06:WU00:FS01:0x22:Checkpoint completed at step 1000000
13:54:48:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
13:55:31:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
13:55:31:WU00:FS01:0x22:Checkpoint completed at step 1100000
13:56:13:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
13:56:56:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
13:56:56:WU00:FS01:0x22:Checkpoint completed at step 1200000
13:57:39:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
13:58:21:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
13:58:21:WU00:FS01:0x22:Checkpoint completed at step 1300000
13:59:04:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
13:59:47:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
13:59:47:WU00:FS01:0x22:Checkpoint completed at step 1400000
14:00:29:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
14:01:12:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
14:01:12:WU00:FS01:0x22:Checkpoint completed at step 1500000
14:01:55:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
14:02:37:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
14:02:38:WU00:FS01:0x22:Checkpoint completed at step 1600000
14:03:20:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
14:04:02:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
14:04:02:WU00:FS01:0x22:Checkpoint completed at step 1700000
14:04:45:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
14:05:28:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
14:05:28:WU00:FS01:0x22:Checkpoint completed at step 1800000
14:06:10:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
14:06:53:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
14:06:53:WU00:FS01:0x22:Checkpoint completed at step 1900000
14:07:35:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
14:08:18:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
14:08:18:WU00:FS01:0x22:Checkpoint completed at step 2000000
14:09:01:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
14:09:43:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
14:09:43:WU00:FS01:0x22:Checkpoint completed at step 2100000
14:10:26:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
14:11:08:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
14:11:09:WU00:FS01:0x22:Checkpoint completed at step 2200000
14:11:51:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
14:12:34:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
14:12:34:WU00:FS01:0x22:Checkpoint completed at step 2300000
14:13:16:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
14:13:59:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
14:13:59:WU00:FS01:0x22:Checkpoint completed at step 2400000
14:14:42:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
14:15:24:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
14:15:25:WU00:FS01:0x22:Checkpoint completed at step 2500000
14:16:07:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
14:16:50:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
14:16:50:WU00:FS01:0x22:Checkpoint completed at step 2600000
14:17:32:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
14:18:15:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
14:18:15:WU00:FS01:0x22:Checkpoint completed at step 2700000
14:18:58:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
14:19:40:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
14:19:40:WU00:FS01:0x22:Checkpoint completed at step 2800000
14:20:23:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
14:21:06:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
14:21:06:WU00:FS01:0x22:Checkpoint completed at step 2900000
14:21:48:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
14:22:31:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
14:22:31:WU00:FS01:0x22:Checkpoint completed at step 3000000
14:23:13:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
14:23:56:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
14:23:56:WU00:FS01:0x22:Checkpoint completed at step 3100000
14:24:39:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
14:25:21:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
14:25:21:WU00:FS01:0x22:Checkpoint completed at step 3200000
14:26:04:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
14:26:46:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
14:26:46:WU00:FS01:0x22:Checkpoint completed at step 3300000
14:27:29:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
14:28:11:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
14:28:11:WU00:FS01:0x22:Checkpoint completed at step 3400000
14:28:54:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
14:29:37:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
14:29:37:WU00:FS01:0x22:Checkpoint completed at step 3500000
14:30:19:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
14:31:02:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
14:31:02:WU00:FS01:0x22:Checkpoint completed at step 3600000
14:31:45:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
14:32:27:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
14:32:27:WU00:FS01:0x22:Checkpoint completed at step 3700000
14:33:10:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
14:33:52:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
14:33:52:WU00:FS01:0x22:Checkpoint completed at step 3800000
14:34:35:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
14:35:17:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
14:35:18:WU00:FS01:0x22:Checkpoint completed at step 3900000
14:36:00:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
14:36:43:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
14:36:43:WU00:FS01:0x22:Checkpoint completed at step 4000000
14:37:26:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
