General Advise needed. P4 [email protected] on a DFI INFINITY
Newman_SCO
Scotland
Hello!,
Wonder if you can give me some advice.
My system is very happy of going from 2.80 to 3.30. With only changing the FSB. (from PC2700/333 to 394)
What do u reckon my max overclocking capablility is? taking in to account my temperature readings below. And I have attached a screenshot from speedfan of the temp changes when playing UT2003 for 60 seconds. The red crosses indicate starting then stopping. It's to give u an idea.
If I pump it up to high and the system shutsdown. Would that damage the processor? I'm sorry.. But I'am the paranoid type
My setup:
P4 2.8 with 533FSB
2X256mb Dual Channel (budget Pc World 333's)
DFI Infinity Rev B Motherboard
Hauppauge tv card/5.1 soundblaster/1 extra firewire card..
Radeon 9000 Pro OC'ked
3X80mm fans. 1 intake/2 output
Bog standard Intel Heatsink and fan
CPU temp idle @ 2.8 = 39.5/40 degrees
CPU Full load @ 2.8 = 50-53 degrees
Internal temp according to coolermaster musketer = 30 degrees
Note the screenshot attached is from running at 3.30
Many Thanks for any responses
Newman_SCO
Newman_SCO
Scotland
Ahhh
Tony Hawks 4 for 5 minutes. Time for a new heatsink/fan?
see attached
David
Forums Super Moderator
I am sure ~60C is far too high for a Pentium 4. I would suggest looking into a new CPU cooler and working on the airflow in your case.]
I wouldn't push it further until you can bring load temps down by 5-10C.
Btw, welcome to the forums :)
archilochus
THE Senior FANMAN
Houston,TX-USA
These would be better choices for a HS, IMO..:) The fan selection at that site..well there is no selection..:(
"We would rather explain the price of quality than to have to apoligize for something less".
You'll need a neo back plate to go with the SP-94 HS...At least thats my recommendation..I know it's higher than your budget..Just trying to save you money and grief in the long run..You'll still need a fan for the SP-94..This place doesn't have anything in that catagory..:burn::)
CLICK HERE
