Hi,
I recently used articlean 1 & 2 to clean my GPU and unfortunately some spilled over the sides of the main chip which caused the black material that frames the GPU (thermal tape/pad?) to buckle and start to disintegrate.
My question is, do I need this material? I am working with a Dell XPS Gen 2 laptop with a 7800 GTX Go vid card.
Would it be safe to remove it and apply Artic Cooling MX-4 to the main chip only?
Thank you for any help you can provide!
