- Aug 17, 2002
Ok I'm a linux newbie but I ahve heard nice things about Gentoo and thought I would give it a try. I have pretty much got it all installed I jsut have a few problems however.
1. When I start my computer it goes to the GRUB Promt. At first i didn't know what to do so I hit the TAB and looked at the options. When I type in configurefile or whatever it is it then loads into the splash screen and works.
2. I'm at the splash screen and have two OSs on my comp. Windows XP and Gentoo. So I select gentoo and then it goes through the whole startup procedure looking just fine. Then where it says login it's wierd. I'm not on a network and am just using it for personal use. On the step where you had to configure hostname is just made my hostname mymachine.mydomain.com. I go into /etc/hosts and i put in 192.168.1.1, I'm behind a router and my IP to the router is that..... So when I select Gentoo and it runs through the startup sequence it says
192.168.1.1 mymachine.mydomain.com mymachine login:
just to try it i put in #root and the pass for #root and it won't work. So i need to edit that somewhere. I would like to get rid of all the 192...... junk and just have a login.
if you have any ideas please inform me. I would greatly appreciate it. Thanks =UFO=
