podja (May 13, 2001 05:02 a.m.):
On what freqency can this processor work and wich program is the best for overclocking.
For tweaking I use NVMax from
http://tweakfiles.com as not only does this give you full control over your graphics card, but it also downloads the latest drivers along with giving you a choice of using normal or beta drivers, as for speed my card can overclock a great deal however once a GPU core speed of 170 mhz has been exceeded.. I no longer get any noticeable gains confirmed by benchmarks. The most noticeable improvements I have personally seen came from moving the fan so that it did not take its power from the graphics card which reduced temperatures and increased stability and modifying my card so that it displays as a Quadro which allows me to play Q3 with more detail without any loss of frame rate. However this is not a gain that shows any noticeably large improvement in benchmarks, so perhaps its me
Duron 800 @ 1050 with Global Win FOP-32 (140 x 7.5)
Abit KT7A-Raid Mobo
512 mb (133 mhz Crucial Stuff CAS 2)
Hard Drive Cooler
Elsa Eraser X2 Gforce with Blue Orb (modified to display as a Quadro and overclocked
http://www.tweakhardware.com/guide/quadro/ )
Sound Blaster Live Value
Full Tower with 5 (120 mm) case fans with seperate PSU
