Hi I am running a [email protected] and have a peltier with PEP66T and two Delta's on it , the PEP66T is very hot to the touch so i guess it isn't capable of cooling the pelt. In the sidepanel i have a 120mm fan blowing on the mobo , on the front i have a 90mm 24 volts fan blowing in and at the back i have another 90mm blowing in . In the backtop side i have 2 powersupply's exhausting air out and two 90mm also exhausting. The delta's on the PEP66T are running at 7 volts because the noise is unbearable at 12 volts
Does anybody see's any improvements that i can make to get the PEP cooler? My sys temp is idle 8 celsius idle and 27 c under full load , i now it's not high but it can run cooler , the temp at the socket is so high it is blistering my fingers ! This can't be good for the cpu and or mobo , right ??
please help if possible , Thanks !
