It was the best overall board I tried no doubt about it. Unfortunately, it still has Asus' world famous voltage reg problems. Vcore was literally all over the place and for $198, there was no way I was putting up with that
The Albatron in my sig is holding me over for Granite Bay. I actually like it a lot. Better than any 845E/645DX boards I've tried (and that's quite a list now). It doesn't work the memory any better than any of them (or any worse), but it does OC 5 FSB higher than any other I tried, including the PE. The P4PE wins in the fact that even at 159FSB, I could run 2-2-2-5 mem settings and on *any* 845E/645DX board I tried, anything over 150FSB and 2.5-3-3-7 was about all they were happy with.
Even though the other 845Es, 645DXs, and PE all limited the OC to 158-159FSB, the difference with the mem timings on the PE is fairly drastic in terms of benches. Even at 164FSB on the Albatron, I can't bench the mem higher than the PE was @ 159FSB 2-2-2-5.
So, the FSB limit on the PE was definitely made up for by how well the memory was handled and I would definitely recommend it with the caveat on the Vcore regulation. You just need to be cautious with it and know that it will somewhat limit how high of an OC you will get (because the damn idle Vc goes so high and it drops so much on load). It was as high as .11V over the setting at idle and *still* dropped to .06V under the setting on load. That is a HUGE swing between idle/load. The Albatron only moves .04V max between idle and load.
Now if a $110 mobo from a "newcomer" can do it, I don't see why Asus can't on what was a $200 mobo (now $165). That has pretty much turned me away from an Asus as a choice for a GB mobo and I've actually started thinking about an Albatron GB, but I think the Abit GB7 Ultra will be my first choice. Of course, I reserve the right to change my mind depending who has a board out first
If I do somehow wind up with an Asus mobo and it has the same VR issue, it will definitely have been their last chance with me.
