Getting an Os/2 warp startup screen?
xb1az3x
Chicago, IL
I am currently running windows xp and for some reason last time i restarted i got an Os/2 warp startup screen. I did do a scan with adaware and had about 250 objects before this. could it be some type of spyware/adware? this computer is brand new and has never had os/2 on it
what exactly do you mean by startup screen? The load screen(little scrolling boxes screen)? welcome screen?
I ask, because these can be changed, if its one of these, its possible something got in there and changed it.
Have you tried a virus scan?
i mean the screen that usually has the scrolling boxes. and no i havent done a virus scan which one do you recommend
i got the problem fixed my brother was messing around with a program called bootskin and he changed it on accident thanks for your help though
