- Aug 23, 2001
nihili said:
ol' man,
I didn't mean to imply that you were confused, only that what you had written got things a bit jumbled up.
For example, you said "It gets so cold in the shadow that A few seconds in it and you are done I guess. " That implies that the problem is that it's cold in the shadow. But the coldness of space is actually no problem at all because space has no thermal mass. That was the point of my dry ice example. Space has a temperature near absolute zero. Normally we think that if something is cold, we will get cold by being in it. But this doesn't work in space. Discounting issues of pressure, if you could stop the radiation from your body, you could stay warm nearly indefinitely in space, even in the shadow of the moon. This is because space has no thermal mass.
Btw, the definition of heat that you quote is also a bit off. Heat is not the *transfer* of kinetic energy. Again this may seem like a minor error, but in the context of a discussion of thermodynamics in a vacuum, it's an important one.
nihili
Well nihili that was not my definition but this place.
http://whatis.techtarget.com/defini...i771825,00.html
I guess they are wrong too. That is okay it is the story of my life
