Getting Everything Together for a New Comp
Jonny 2x4
.stl
Here is the computer I will be dealing with (I don't need any opinion on the computer components, the Intel Motherboard section is taking care of that :D).
I am thinking of a peltier solution. I don't know ANYTHING about water cooling, but I am a fast learner and I am a DIY. I just need to know what to buy, and why.
I was looking at this , I assume this is a great peltier. This would be for the CPU, now what do I need for everything else? Besides the blocks, what other components do I need?
nealric
under the floorboards
Well, for water cooling you will need:
Waterblock (you will have that if you buy that swiftech package)
Radiator/Heatercore- auto parts store. Just find one of the dimenstions you need and mount a fan on it.
Pump- Many people are fond of the via aquas and the ehiem pumps. I just use a bilge pump. Just make sure it gets at least 250Gph
Tube- Tygon is popluar, but normal hardware store plastic stuff works fine.
Valves- Will make things usefull to take it apart.
Power supply (for pelt)- They usually need to be pretty burly. Check out ebay for some good psu deals.
