Getting my 2700k past 4.5ghz
Gerardz
i can't seem to get my 2700k past 4.5ghz. Up to this point I have only changed V core to get to 4.5ghz and it is at 1.30.
Tried going to 4.6 and tried up to 1.34 Vcore and it freezes using very high test on IntelBurnTest.
can anyone shed some light on what other settings I may need to change in Bios to get past 4.5 ?
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Try 1.4v for giggles and see if that helps.
Otherwise, have you enabled PLL Override voltage? Its an enabled and disabled thing, not a voltage value.
EarthDog
Buckeyes!
Sorry, they are sideways and I can't read them...... after contorting my head to read them :)p), I don't see the PLL Override option in there is the first place. Also, I cannot read the yellow voltage levels because its a screencap. ;)
You do know that BIOS can take screenshots and save them to a USB stick, right? We don't have to do screencaps. :)
EDIT: I see it now (PLL Ovrd is enabled), sorry!!
