Getting one-click dually to work
WillS
Lawton, OK
One click didn't work for me on my dually Athlon MP rig (see sig) with Windows Server. After every reboot the client.cfg files in the various folders get reset. Both files indicate MachineID 1 and no username. I change them and they go right back after the reboot. :bang head I'll try to remove FAH then reinstall but has anybody got any idea why it's doing this?
stan03
you are editing in notepad right? can you try a fresh download? maybe yours was corrupted or something.
Andyman902042
indianapolis
That's probably the problem right there. If FAH detects a corrupt config file, it'll generate a new one. Use notepad to edit it and keep everything the same execpt for the username. Don't add any spaces before or after your username, but keep those little box symbols
W
WillS
Lawton, OK
Thanks guys. I'll clean it off again and try once more.
Leave it to me to make the easy install look hard :rolleyes:
@md0Cer
Senior Member
Denver, CO
Also if it keeps changing what you had in notepad, you could also edit it and set it to read only :)
For quick and easy setup I do recomend the uberbuzzard installer over one-click despite the awsomeness of one-click.
http://www.netbetty.com/uberBuzzardFAHinstall.zip
There is a link to it. Just install one as machine ID1 and the other as ID2 for a duallie ;)
W
WillS
Lawton, OK
Thanks to all, especially @md0Cer. All my machines are now happily folding away. :D
I'm addicted already. Took a look around the office today and spied some empty space that's just begging to be filled up with some extra folding rigs...
