AMD Vs NVIDA TRANSPLANT SURGUREY
thanx for all you recent info,the tweeks so far ::
amd duron up from 950 to 1050mhz X10,fsb up from 100 to 104mhz,pci @34.6 mhz,nvida mx400 64 m core up from 200 to 200mhz,mem clock up from 166 to 175:::
all the settings have been achived using Riva tuner,i can set the riva to 240 mhz core clock and 187 mhz mem clock,but system went unstable after an hour.i can not check system on 3dtest yet as my monitor wont deal with 1276x and above 60 hrtz but have used cpuhot and had a 99 % readingidrivers being used on nvida are the 29.42,these seem to run medal of honour with alot more smoothness and weapon fire seems to have improved on weapon recoils ie no more judders or slow fire rate,explosions ect have more affect ie flames ,smoke,even down to breathing vapours from mouths of soldiers.
my amd chip i have used pencil to join L1 GATES AND CUT @ JOINED the other Lgates but this seems to have only unlocked
the chip for multiplyer use only,to a max of 10 x even though board will do 12 x.front side bus clock is set at 100 mhz i can not uce any switch as the board has solder joint where dip should be,
ANY SUGESTIONS appriciated!
the rest of the tweekong stage is how do i turn up the voltage cores HELP.WHAT INFO HAS ANY ONE ELSE WANT TO ADD.
JOHN240SX.........AMDs CHIP CHOPPER!
