Ghost or Clone a raid array? (stripe)
Oni
Oni-ni-Kanab;, Ninja Hippo eater Moderator
St. Catharines, Ontario Canada
Um . . . I'm not sure. You'd pro'lly need the latest version of Norton Ghost Corporate to do it, but you would pro'lly need a running array to ghost to. I don't think you could just back that up.
XprincoX
bargain hunter
Irvine, CA
hmm..well i would think thats what a mirror raid setups for. But i dont think its possible to ghost the array, as both hds would need to read simultaneously. Otherwise u'd probably need like 4 hds and back up each seperately.. :burn:
Tweak
You should be able to ghost it if you have a hard drive to ghost it to. The RAID stuff is done in the bios so it should be seen to any software as one continual drive, and thus be ghostable.
Oni
RAID Mirroring (That's RAID-1 I think . . . But it might be RAID-5) is a form of RAID Redundancy. It takes everything on drive 1, and copies it to drive 2, so if drive 1 dies, you can backup from drive 2.
Sonny
Senior TIFOSI
VARIANTE ASCARI
Ghosting a RAID Array is risky. Some people have done it with Norton Ghost 2001 so the latest one might work.
RAID0 = Stripping, fast read/write performance, no back up, 2 HDDs
RAID1 = Mirroring, fast read, slow write, data is always backed up, 2 HDDs
RAID0+1 = Sripping & Mirroring, Fast read/write, back up, 4 HDDs
RAID5 = Stripping with Back up, Fast read/write, if there is a failure on the Stripped array the third HDD can be used to replace either the 1st or 2nd drive, 3 HDDs
Oni
Um . . . I don't mean to nit-pick, but you're a little wrong on that. RAID5 backs up a bit of each other drive on all 3 drives. So if drive 1 dies, it could be rebuilt w/ drives 2 and 3. I'm pretty sure that's how it works.
