Gif maker/Avatar Maker
palee72
Pittsburgh, PA
Can someone suggest a program that I can download that will let me create + edit Gif's and Avatrs?
Or is this a trade secret among the AV makers of the forum :D
Thanks in advance....
macklin01
Computational Oncologist / Biomathematician / Mode
Bloomington, IN
Well, I use the simple freeware MS GIF animator. To use it, you'll want to make several frames (each a GIF file) and then piece them together with the gif animator. Some features I use:
1) can set transparency color in the animator
2) can set the length of time of each frame (which can help you cut down its size)
3) can set how many times it loops.
Hope this helps! -- Paul
Audioaficionado
Sparkomatic Moderator
I've used the M$ animator but it doesn't optimize the frames like newer software does. I made an avatar using 18 frames to keep it under 100kb. One of our avatar builders gave me 29 frames with the same file limits. It looked smoother and played a second longer. I think he used Ulead gif animator. Try the full version trial good for 15days.
macklin01
Bloomington, IN
Do any of these allow easy creation of gif or mpeg animations from a series of jpeg or the like with an ordered naming scheme?
EG.,
Thanks -- Paul
UnWishedLegacy
NorthEast England
I use "Babarosa"- transparency features, optimisation, and a V.easy user interface- free from www.liatro.com
The avatar you see now is just one thing I made with it.
It's worked for about 3 or 4 weeks- I dont know if there is a time limit to the trial period (which is what I use).
XprincoX
bargain hunter
Irvine, CA
EG.,
Thanks -- Paul
yup gif animator has the option to create gifs from video files and saves each image file in an order sequence. Or you can just select the images you want. :D
macklin01
Bloomington, IN
Yeah, but I was hoping for soemthing more automated, since I might be making it from 100's of frames ... Thanks -- Paul
Scudrunr
Super Moderator , CO
this biohazard one was just made using microsoft gif animator, got it off of cnet.com. :)
[Edit] I just replaced this one with the current one you see now.
Spiked
Dallas, Texas
um.... hey scdrunr..... you know you have grammar errors in your avatar right? I mean you are telling everyone to look at it because it is an example but you are just calling notice that you are very poor in grammar! (you life should be your life)
UnWishedLegacy
NorthEast England
Moog- for every frame you need to "save a copy" and select .GIF format (if it is a long amination it will use may frames- I think mine used 12frames on a constant loop).
Once you save all your pics, you will need a Gif Animator (there a thread around here somewhere-Oh wait> THIS IS THE THREAD).
If you got PaintShopPro then there is a bilt in Gif Animator but for us with PhotoShop- we need to take the long way round.
{{edit}} I forgot what thread I was in :rolleyes:
