Gigabit Ethernet PCI Cards Over Onboard
AngelfireUk83
Can someone tell my mate here next to me he wouldn't see any difference upgradeing over onboard ethernet to a PCI Gigabite Ethernet card. I tell him it's all about your ISP if you want to increase download and upload speeds which our ISP puts a limit on.
He has a ASROCK nForce2 motherboard so if I see it as pointless he would too.
Gig ethernet is great for transferring files on your side of the router if the other equipment also supports gig ethernet.
As for making a difference in internet performance, consider this:
I have 10 Meg download speed. Which is faster than a business class T1, but it is not gigabit speed...... our internet is actually quite slow compared to our ability to transmit data on the lan side.
He will see a bit of a speed increase, most likly, but not due to it being gigabit. It would be due to the fact that its not onboard. Onboard nics use the CPU, where as a seperate nic (a good one anyway) will have its own processor on it to handle that stuff.
So if you get a really good 10 mbit nic, you will see the same jump in performance.
A Pentium 90 can fully saturate a 100MBit link. So how could I measure if a PCI NIC helps on CPU usage, especially when doing stuff in the WAN side with a few MBit/s max speeds?
Also, what kind of CPU processing would a NIC need? There are TCP offloading engines yes, but unless you invest $100 or usually more, you won't see this in your PCI NIC. If you can find it in PCI NICs at all (mostly its server class hardware, PCI-X and lately PCI-E)
Well currently the max connection we have is 3mbps and my download speed if from a good server is usally 365kbps. Our upload speed is limited to 0.50kpbs cause the ISP has put a limiter on it. They are introducing 8mbps but it'll expand into our area from December the 4th and it's £10 cheaper than what where paying now for 3mpbs.
I am looking into a Ethernet card myself well I was but at the moment I want a new set of RAM 2GB. And a new graphics card a 7600-7800 APG and a raptor 36GB for my main XP.
Can anyone also recommend a PCI card with it's wn CPU or whatever just to shut him up!!!
You don't need a PCI NIC. The Ethernet ports on your motherboard will be fine. I believe Klingens just said that a Pentium 90 can fully saturate a 100 MBit link. Therefore, any CPU at a Pentium 90 speed or above can do the same. Since your Internet connection is less than 1/20 of that 100MBit speed, you will not see a difference between onboard and pci NIC's.
Whenever i am transfering something with my onboard nics, I get close to 13% cpu usage. If I start using my pc for something like games or something, it slows down. Infact anything using the cpu will slow down the nic.
With a dedicated nic, I show no CPU usage, and it never slows down.
With my 3mbps connection which is my onboard ethernet port to my Link AG241 router I am happy with my 365kbps download speed to be honest. It's better than 4kbps when I was on dial-up oh the god the torture just my mate has been going on forever about it.
I might see a difference when we upgrade to 8mbps after 4th December but I ain't getting my hopes up it will be massive.
Do you mean transferring files between computers on your network/side of the router? Or over the Internet?
Well 365 KB/s equals 2920 kbps or 2.920 mbps. That is pretty good if you have a 3mbps limit.
There was an article in Maximum PC magazine about this. yes, onboard uses the cpu, but for gaming and stuff, you wouldn't see any difference. That is, unless you get a 8800gtx and play with all the video settings on low so the cpu is the bottleneck.
