GIGABYTE 7IXE4 - what the ****
Kev
i have a Duron 850 on a GIGABYTE 7IXE4 motherboard. I can only change the FSB to get extra Mhz. Theres no option for changing the clock multiplier........does anyone know a way of poking around with anything, reliably, to give the option of changing the multiplier on making it not autodetect .....also a similar case for changing the voltage.
Cheers.
i used to own this board the only way i could overclock it was to increase the FSB i had my 700 to 770 ,110 FSB but make sure u have pc-133 ram alos wheni was at 110FSB my ethernet card acted funny. So i went al;l out and bought the Asus AV7133
Mmmmmmmmm the 7IXE4 is a pretty lame m/b...
Uses the old AMD "Irongate" 750 chipset from the early Slot A days... Max you'll probably get is 110-115MHz FSB...
Not any real easy way to adjust the multipler...
