BF in the core control does it allow you to shut down individual core/modules or just each bank. For example if one wanted to can you shut down all the cores except #1 and #3 or is it set up, if you want to shut down say core #4 you have to shut down 3 as well?
I was thinking of getting UD3 (R5) version of this board as that's the model available from my fav online retailer in OZ, This place I order from also has the Asrock 990FX killer and Asus's 990FX sabertooth all these boards including the Gigabyte are within AUD$200-270 range.
After reading over this mini review.. I'm not sure of the diff between UD3 (R5) and UD5 (R5) as mentioned in this thread. Both have 8+2 vrm's and decent looking heatsinks.. that's all that really matters to me with being a 1 gpu gamer.
Last Giga board I had was on Intel's P55 chipset paired with i7 (Lynnfield) It was a UD6 version.. solid overclocker board but as the years went by it got a bit 'flaky'... if you know what I mean. I'm not complaining, just sayin... Hope that tradition of building solid overclocking boards continues in this AMD series...
IIRC the heatsink is more robust on the UD5. Other than that it is 990x vs 990fx.
The sabertooth is the best option, followed by the UD5, then the UD3. Last would be the asrock. It's just lackluster without LLC controls. If you can afford it, the saber kitty is your best option. If not, buy what you want/can afford, but the rest mean sacrificing overclocking capabilities as far as I am concerned. The UD5 is decent, but here and there are features I find lacking, such as fan control. By nature the UD3 should have exactly the same issues.
Mind you I am still looking at setting up my custom loop for the FX, then I can get a better idea how robust this board truly is. This is why I have issue recommending it over the saberkitty as good board for overclocking.
Bottom line: at 4.5ghz, I have been limited by my cooling, and not the board.
The 990FX Killer is garbage for overclocking, FYI.
The EVO R2.0 in your sig is good enough for a mild OC, 4.5GHz or less should be stable.
3) And removed the Firewire ports. But if you don't use Firewire then it's a mute point.From what I have found out between the UD5 Rev 1 and the UD5 R5:
1) They changed the arrangement of the 5 PCIe slots and the PCI slot. With the Rev 1 you had 4 PCIe slots, PCI slot, and then the last PCIe slot. With the R5 they have put all 5 PCIe slots first and the PCI slot last.
Now my complaints:
1) They upgraded the UD5 R5 with a better audio chip but still left only 4 USB 3.0 connections that where also on the Rev 1 board.
2) When they changed the PCIe layout it also limited the board to 4 video cards total. The Rev 1 board allowed 5 video cards to be used.
Fixed that for ya WH3) And removed the Firewire ports. But if you don't use Firewire then it's amute pointmoot point.
The UD5 rev 3.0 has the same PCIe and PCI layout as the R5 and has Firewire.
I have 1 UD5 Rev 1.0, 2 UD5 Rev 3.0 and 1 UD5 R5 Rev 1.0![]()
