- Jun 1, 2005
Hi all,
If I run CPUz on my GA-P35C-DS3R / E8400 system it is reporting the the chip is actually running at 2ghz (not 3) at x6.
Now, I dont think this is a CPU issue... could it be to do with all the Gigabyte automatic overclocking options?
I have Easy Tune 5 on - that seems to report the right speed. BUT... If I set the BIOS to run the CPU at, for example 3.4ghz (by raising the BUS) - when I load windows, CPUz reports it running at 2ghz x6 again and when I load Easy Tune 5 that reports as 3.15ghz (which is stock speed on a 9.5 multi).
Also, my memory (Corsair DDR2 800 2x 2gb) was bought as 4-4-4-12 timings, but in the BIOS it shows up as 5-5-5-18?
If anyone has seen and of the above before, or has any similar OCing issues with this board, I would love to know.
Many thanks
Slack
Many thanks
Slack
