- Dec 5, 2015
been having a lot of problems with the above motherboard, first issues was it was overvolting my CPU, but that was fixed with bios updates.
the other issues i was having though was it would not control my PWM fans properly, these things were all over the place and would not hold a curve setting after re-boots etc.
also can't set the fans to a fixed RPM.
now after a lot of too and frowing with Gigabyte E-support and having to pull my system down multiple times to send it back for testing, it's with them again now.
i finally find out the answer why this morning from e-support.
out of all the fan headers on the high end motherboard only the CPU header is a PWM header, so the other 7-8 fan headers on this board are only voltage controlled.
they have told me to try and replace all my other fans with non PWM fans to see if it fixes the problem "what a joke"
i paid $35au a piece for Noctura PWM fans only to be told i can't use them. i'm running 3 x 120mm on the rad and 1 x 140mm rear.
this is this mornings reply from e-support.
what an absolute joke i think this is.
just a heads up to anyone considering buying Gigabyte motherboards if you want to run PWM fans...
Kindly note except CPU_FAN header is PWM mode, all rest of SYS_FAN headers(SYS_FAN1/2/3/4/5) and CPU_OPT header are Voltage mode. The Voltage mode header pin definition is different from PWM mode header pin definition. If possible, please connect Voltage mode fans on SYS_FAN1/2/3/4/5 headers and CPU_OPT header to see if the problem still persists.
