I want to run it at 4100Mhz until I get some bugs worked out...then maybe OC a littleWhat you are seeing is normal behavior. It boosts, by default/out of the box to 4.8 GHz. During power saving modes, it drops down to 800 MHz. Is there a reason you want to tie it down to its base frequency of 4.1 GHz?? If anything, lock it at 4.8 GHz....
Thanks, few times while idling it would reboot on its own...There are no record of it in dump fileYou'd want to set the multiplier to 41x to all cores. In Windows, set power plan to high performance... that should do it.
What 'bugs' are you having? I'm struggling to figure out what lowering to base clocks fixes...what's up?!
Looks that way...I dunno my D: which is used for backups/storage did not have the 16mb file but sometimes it would get checked by Win 10 or 11.Sooooooooooooooooo, it was't the motherboard/RAM but the 16MB partition that caused your issues?
