- Dec 5, 2015
i will try keep this as short as possible.
iv'e had nothing but problems with this board
first off i had overvolting/overheating problems, fans dont work as they should, temps don't show properly or freeze on a set temperature. as well as a few other little glitches with their crappy software.
i'm pretty sure i fried my original 6700k i had in it too. that is going back for RMA when i get the time.
i had to send the mobo back for RMA.
when i was getting the board ready to pack up and send back for RMA i actually damaged the socket "bent pins" as i found out when they received the board back.
so was quoted $55au to have the socket fixed. which i thought was reasonable and as the board cost me $765au it was a no brainer.
received the board back after 6-7 weeks.
drained all my system and pulled it apart "had to replace mobo and CPU while my other was in RMA" so took all that out of the case and put the Gigabyte Z170x mobo back in, which took a few hrs...
in the time my Gigabyte was getting fixed i had an Asus hero and new 6700k CPU running "it ran sweet"
fired up the gigabyte Z170x and installed windows and their drivers etc etc.
nothing but problems with the fans again. the SIV software is an absolute piece of crap. this software is all over the place. calibrate the fans all good. then i set them to the params i want. ok.
then for no reason at all the fans start going haywire. play a game or run a program. the fans go full bore, stop the game or program "IE Photo Shop" and the fan have set to full bore.
try reset the fans and they reset to some stupid setting. so try re-calibrate again and they won't re-calibrate to the right levels.
so i uninstall all gigabyte software re-install again and back to square one.
every time i reboot my system i also loose all the settings i have set the fans too.
as for the temps in the same software, sometimes the CPU/PCH temps freeze say on 32c, i know for a fact this temp is wrong.
then sometimes the CPU/PCH temps won't show at all.
so uninstall all the gigabyte software/ re-install and it shows temps again...
now because from what iv'e read, that gigabyte wont release the source code for their software. no other software that i know of will monitor or control this mobo "properly"
tried using their e-support, but they are just telling me to try things i have tried multiple times.
yes i also realize that i can use a fan controller to fix the fan problems, but should i have to on such an expensive board "imo no i shouldn't have to"
also the temps monitoring of this mobo/software just doesn't work as it should.
"fans are 3 x 120mm PWM Noctura 1 x 140mm PWM noctura and 2 x 300m NZXT LED"
i had a popup friday night telling me to update app center so thought beauty, they might have fixed this thing. installed it and it didn't change anything for me.
then noticed there was an new inf update via live update and thought again beauty maybe that with fix things, so started to install that.
BSOD "service exception error" try again BSOD "irql not less or equal" "lol what a joke"
contacted the store i got it from and they are saying they will have to return it to gigabyte for them to look at, so i said i will have to wait another 6-8 weeks and was told yes maybe.
this will mean they will have had the mobo longer than i actually have. "what a joke this is turning out to be"
i now just want either my money back or i want it replaced with another high end board that actually works how it should.
firstly i have posted this info for others considering buying this mobo.
secondly to get some advise on what my rights are about getting rid of this piece of crap mobo "i hate it"
P.S. i advertised this mobo on a local site for sale at a loss just to try move it on, stating reason for sale is i don't like it.
had one call from a bloke saying he didn't want to buy it but tell me about all the problems he has with the same board lol...
