For anyone interested here are some C/W values I arrived at for my Glaciator cooling a Tbird 1200 AVIA running at either 1.85v or 1.95v. I used the 'CPU Stability Test 6.0 (CPU warming only)' program for 10+ mins to make the CPU reach max temp. Temp reading are from MBM5 using the standard built-in mb temp sensors.
There is a possible trend of the Glaciator getting less efficient as the cooling work it has to do increases. But overall it seems to provide excellent cooling.
1000 Mhz @ 1.85v
C/W = (43C load - 33C case) / 60 watts
= 10C / 60 watts
= .17
1333 Mhz (133 X 10) @ 1.95v
C/W = (53C load - 35C case) / 85 watts
= 18C / 85 watts
= .21
1380 Mhz (138 X 10) @ 1.95v (Actual test)
C/W = (54C load - 36C case) / 88 watts
= 18C / 88 watts
= .20
1400 Mhz (140 X 10) @ 1.95v (Actual test)
C/W = (55C load - 36C case) / 89 watts
= 19C / 89 watts
= .21
1000 Mhz @ 1.85v
= 10C / 60 watts
= .17
= 18C / 85 watts
= .21
= 18C / 88 watts
= .20
= 19C / 89 watts
= .21
