- Jan 12, 2001
- Kansas, USA
Well, since I already had a GlobalWin FOP38 in service (see my signature), I decided to see how it handle a battle for air cooler heavy weight championship crown of my household.
The FOP38 already kicked my ol' Golden Orbs buttocks by cooling the CPU 4-5 degrees under load conditions. The newcomer is an Alpha PAL6035 and I had high expections of this cooler (plus I was getting tired of the noise of that Delta fan).
For total stability when running these test, I throttled my P-III back from the usual 700/1050 clock speed to 1015 MHz @ 1.9v. Ambient temp was 20 degrees C. Temps taken after 15 minutes of Unreal demo loop.
Since the Alpha got beat up, I tried the test again using the 38 cfm Delta fan from the FOP. Guess What? GlobalWin FOP38 is still reigning king!
Alpha w/stock fan -- MB=36 CPU=41
Alpha w/Delta fan -- MB=35 CPU=40.5
GlobalWin FOP38 -- MB=33 CPU=39
Can't wait to try the 80mm Sunon high output fan that I have ordered. It's rated 42.5 cfm which is better than the Delta fan and 10 db quieter than the Delta fan.
