I couldnt find many posts on the internet that their cpu has died due to overvoltage, so if there is a chance like 1/10000 why not to risk.
Well i would like to last it around 2 years, skylake is great compared to older gens, also i pretty much won silicon lottery, not many can run it stable at 1.412.
KL is just a "facelift" for SL not worth saving for it, performance is pretty much the same.
Well hopefully i will be able to lower voltage even more after my CLU arive. Temperature does help to lower voltage.
Does anyone know if there any tricks in bios that will help to increase stability at the same or lower voltage?
Here is an exert explaining why the voltage effects longevity.
"It's both. High heat and high voltage speeds up the process of electron migration, the process where connections slowly lose their capacity to conduct electricity. But ultimately, it is the voltage. Resistance to the electrical flow is what creates the heat. You can put a CPU in a 80C oven for 20 years and it would still work. However, run it for 20 years and the probability will have it fail. However, heat is also a very important factor. It exponentially accelerates electromigration."
An then a bit better explanation:
Electromigration, which is dependent on current (which is directly dependent on clock speed), voltage, and temperature. Reduce one and you can increase the others without increasing rate of electromigration.
Regarding temperature, a rough rule of thumb is that every 10C increase halves the lifespan of the part.
Strictly speaking, it's not the silicon that's damaged. It's the metals in the various traces, interconnects, and gates being knocked out of place. This either causes shorts as metals penetrate into insulators, or it increases the resistance where metal has been displaced, leading to more heat and more rapid migration, until the circuit fails entirely.
http://en.wikipedia.org/wiki/Electromigration
http://www.csl.mete.metu.edu.tr/Electromigration/emig.htm
Eventually, electromigration will kill pretty much every chip, if some other physical failure doesn't get it first.
