Mark Larson
Disabled
- Feb 26, 2003
- Assembled in Malaysia
Atleast that's what my amateur setup tells me in my personal system.
I've applied a fair bit of thermal grease myself, starting from normal white goop and going onto the rocket-science AS3 stuff. Got good temps, thought everything was fine.
Then i read about TIM and why it was better for long-term applications and suchlike. Well, i thought, why not try it out? I ordered some as a sample from a well-known company and it arrived neatly packaged.
I ripped out my AX-7, cleaned off both the CPU and HSF bottom with acetone, and applied the thermal pad as they instructed.
Got better temps, but didn't think much. This was back in Jan `03.
Then i got a watercooling setup, with a Maze2, Maxijet 1200 and heatercore and a 10gal res. I used AS3 and wasn't happy with the temps. I waited a week, reapplied, still the same.
Then today i decided to try the thermal pad. I thought, "well, if it worked on my AX-7 it should work here".
Took the block off, cleaned everything off with a lot of acetone (don't do this in an ill-ventilated area, kids!) and applied the TIM. Put everything back together, and fired up the system without the pump running. Watched the temps get up to 44...prime crashed. 48....Windows crashed.
Get into BIOS and watch the temps climb to 55°C. Switch on pump and watch temps fall. Restart at 41°C.
All this was about 4 hours ago. I believe i've given enough time for the water temp to stabilize. I'm running at 34°C right now. My earlier temp used to be 40-42°C on average, more in the morning when the windows had been closed all night.
I'm a firm believer of TIM now, and my AS3 will be relegated to the cupboard, only for emergencies when a TIM is not available, not worth the trouble of cleaning up, or just too precious to be used.
I will look at AS3 fanboys online and nod my head sagely and hit backspace. The damage to the thread has been done and i won't bother with it.
Chalk it up to whatever - maybe i'm bad at applying AS3, maybe the Arctic Gods don't like me, maybe its been a fluke all these times. But i believe. I believe in the TIM. I will always use TIM. TIM is my lover and i want to have its children.
SETUP:
1700+ Tbred at 2600+ (166x12.5) 1.750v
EP-8RDA
Maze2
5.5"x7.5" surface area heatercore without fan
Maxijet 1200
10gal res with pump submerged
Everything connected with ½" vinyl tubing.
Take this post in jest or take it seriously. My writing style may invite jeers but my gains are real.
Mirror: http://iupload.net/042003/tempreduction.png (Copy and Paste - clicking won't work)
BTW this is no joke.
SETUP:
EP-8RDA
Maze2
Maxijet 1200
