- Jan 10, 2002
- Dublin, Ireland
I am getting some copper and aluminium bars in the post, and will be making some blocks for Skt370, SktA and Skt478 processors.
All I have at the moment is a dremel, and it is crap on copper blocks, and just about adequate (but slow) on aluminium blocks.
I need a bigger and stronger drill, but am unsure of what to get.
I could get a hand drill ,a drill press or a milling machine (if I can find a small and cheapish one).
I will not be making very complex blocks, but will be using it a lot to make different types and hopefully evaporator blocks in the future. I have a budget of €150 = $150 approx.
I am new to big power tools so do not know the good brands for drill-presses or milling machines or even hand drills. Can anyone tell me which type of tool would be best for my needs ( I think it may be the drill-press, but then I may be mistaken).
Any info is helpful,
thanks.
s.
thanks.
s.
