Hey all!
I am getting close to hitting the big bad 'buy' button... a final check and comments please!
The case I have is this:
http://www.acoustiproducts.com/en/acousticase.asp
the 6607 in black. I propose to fit the following items with 1/2" tubing...
MCP655 pump:
http://www.swiftnets.com/products/mcp655.asp
The MCRES-525 reservoir:
http://www.swiftnets.com/products/MCRES-525.asp
Good old STORM CPU block:
http://www.swiftnets.com/products/STORM.asp
For the GPU maybe this:
http://www.zalman.co.kr/eng/product...dx=158&code=021
but it states tube size up to 10mm ID, whereas I really need up to 1/2" - Think this would work? Can you find me a good 1/2" GPU cooler block in the UK? The DD Maze4GPU blocks look nice and are 1/2" but I couldn't find a retailer
A single MCR120 rad fitted inside the rear exhaust with a YS-TECH FD1238 120mm Fan drawing air out:
http://www.swiftnets.com/products/mcr120-qp.asp
http://www.overclockers.co.uk/acata...YS_Tech_60.html
I still need to decide what tubing to use - do OCUK stock 1/2" or will I need to get that elsewhere?
So... have I missed something important? Am I getting it all wrong? Would I be better (ie quieter) putting the fan INSIDE the exhaust and the rad outside? Have any of you real life experience with any of this stuff and can offer particular hints or tips on how to get the best out of it?
All help and comments much appreciated!!!
MCP655 pump:
